2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: memory management
To: 'Benjamin Franksen' <[email protected]>
Cc: 'Eric Norum' <[email protected]>, 'Ralph Lange' <[email protected]>, 'Matej Sekoranja' <[email protected]>, 'Marty Kraimer' <[email protected]>, 'Andrew Johnson' <[email protected]>, 'Ken Evans' <[email protected]>, 'Bob Dalesio' <[email protected]>, "'Kasemir, Kay'" <[email protected]>
Date: Mon, 28 Feb 2005 18:10:01 -0700
> Jeff, could you please explain why the interface of
> std::string is not
> compatible with such implementations?
One of the OO convential wisdoms is to never implement an
interface that passes off handles to an internal data structure.
See Item 29 in "Effective C++ 2nd edition", Scott Meyers. To my
continued amazement there is in std::basic_string a function
called c_str() which all implementations I have looked at so far
implement by providing a pointer to the raw internal storage for
the string. Here is the latest GNU source code. This
implementation appears to prevent strings stored in
non-contiguous, fixed sized blocks.
const value_type *c_str( ) const;
      // String operations:
       *  @brief  Return const pointer to null-terminated
contents.
       *  This is a handle to internal data.  Do not modify or
dire things may
       *  happen.
      const _CharT*
      c_str() const { return _M_data(); }
> BTW, "free-list" is a strange term for allocation in
> fixed-sized blocks.
> AFAIK, many different memory allocation schemes keep a list
> of free memory
> blocks.
Sorry, this is probably yet another name that has grown to become
universally meaningful to EPICS base persons, but perhaps not in
the wider community.
> > We did experience memory fragmentation issues on vxWorks in
the
> > 90's. I vaguely recall that at the time, after someone had a
> > quick look at the WRS source code, it was stated that the WRS
> > memory allocation algorithms wasn't main stream.
> I've been told things were even worse with the original
> VxWorks semaphore implementation ;-)
Some of my favorites old WRS bugs...
o crashing every vxWorks when any SUN system booted using bootp
o crashing vxWorks if a person typed "logout" instead of using
"<ctrl>]",
and for some reason they could never log in again!
I dont remember the semaphore bug despite using vxWorks even when
it was still based on the VRTX kernel, but perhaps we jumped over
that version.
Jeff
Re: memory management Benjamin Franksen
Prev: Re: memory management Benjamin Franksen
Next: Re: memory management Benjamin Franksen
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
