2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fundamental Types document
To: Jeff Hill <[email protected]>
Cc: "'EPICS core-talk'" <[email protected]>
Date: Wed, 15 Jun 2005 11:15:43 -0500
Jeff Hill wrote:
I revised my comments on the wiki as follows.
I think email (via core talk) is probably a far simpler medium to use for discussions, as we can always use the core-talk archive to review past dicussions. The Wiki's talk pages don't work terribly well in practice for live conversations (they're not event driven), as you've obviously realized since you're emailing your comments as well as posting them.
2) You have created interface classes for buffers, arrays, enumerated,
strings etc. All of these interfaces are already in data access. Was there a
good justification to create new ones? In any case, it seems that we should
have the goal of using the same interfaces for each of the fundamental data
types?
Agreed about the goal, but your interfaces don't necessarily take into account all of our requirements, and we think some of your interfaces are stricter than they need to be, which harms performance. I suspect we would have few problems implementing most of your interfaces on top of ours, but adopting ours should be more efficient since you don't have to do everything one character or element at a time - we expose a whole segment at once.
3) These interfaces seem to require contiguous storage of random sized
blocks of characters. Doesn't this preclude use of fixed length buffer based
(free list based) memory allocation, and therefore almost guarantee
fragmentation of memory. Note that fragmentation isnt just a binary
condition (memory of a particular size is or isnt available). Fragmentation
is also an efficency isssue because most random sized block memory
allocators require searching for the best sized free block. Note that one of
my goals for V4 is to no longer require EPICS_CA_MAX_ARRAY_BYTES.
Go back and read the section on the EpicsBuffer interface again; none of our classes require contiguous buffer storage. Any segmented implementation has to provide segments that are (presented as) an exact multiple of the basic element size as given by the parameter to EpicsBufferCreator::create(), but the EpicsBuffer interface and the classes that use it were explicitly designed to allow both contiguous and segmented buffer implementations to be used interchangably without having to know which you are using.
Since we never really write down and agree what all the detailed requirements are, but just present each other with code snippets that implement our view of them, I think we're going to continue to have disagreements like these. It would speed things up immensely if we could first agree in writing on what we are going to accomplish *before* we actually start implementing it (and I plead as guilty as everyone else on that charge).
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
RE: Fundamental Types document Jeff Hill
Prev: V4 Database Access Ralph Lange
Next: Re: V4 Data Types: Request for tagged unions Andrew Johnson
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Fundamental Types document Jeff Hill
Next: RE: Fundamental Types document Jeff Hill
