2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: V4 Data Types: Request for tagged unions
To: [email protected]
Date: Thu, 16 Jun 2005 13:40:57 +0200
On Thursday 16 June 2005 12:55, Benjamin Franksen wrote:
> On Wednesday 15 June 2005 23:12, Andrew Johnson wrote:
> > To step back a little: I don't understand why your states have
> > parameters, and what you could do with them - presumably I can't
> > put a CA monitor on a member of a tagged union (what happens to the
> > monitor when the state changes and the member no longer exists?).
> It must disconnect, indicating that the value in question no longer
> exists. Note that a similar question must be answered for the case of
> adding/removing views. Here, too, the client will need to receive
> notification that a certain value is no longer available. We could
> make this a dedicated event type so that clients can react in a
> generic way to such conditions.
Let me state this more precisely:
The very idea of a tagged union implies that independent read or write
access to properties subordinate to a certain tag hardly makes sense. I
cannot change, nor query, the scanRate of a record, as long as I am not
certain that the tag is 'Periodic'. However, subscribing to merely a
certain subordinate property might reduce system load.
The problem is that changing the tag independently brings the other
subordinate properties to an undefined state and this is something we
can't handle because we don't have a representation for "no value
here". Thus, at least write access must provide all values every time
(i.e. tag + add. properties), while reading and subscribing to either
tag only or other properties can be allowed but must fail in case of
unavailability.
Ben
Re: V4 Data Types: Request for tagged unions Ralph Lange
RE: V4 Data Types: Request for tagged unions Jeff Hill
Re: V4 Data Types: Request for tagged unions Benjamin Franksen
Prev: Re: Fundamental Types document Benjamin Franksen
Next: Re: V4 Data Types: Request for tagged unions Ralph Lange
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: V4 Data Types: Request for tagged unions Benjamin Franksen
