2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fundamental Types / Gateway
To: [email protected]
Date: Fri, 17 Jun 2005 22:09:26 +0200
On Friday 17 June 2005 17:48, Marty Kraimer wrote:
> Ralph Lange wrote:
> > What I really like to have (if I had a free wish...) for the
> > Gateway is a completely opaque black-boxed data store.
> A wish is not an implementation and actually not even an interface
Dear Marty,
the interface /is already there/! It is called Data Access. Yes, Ralph's
wish is not an implementation. Note: Andrew said he wished we would
first arrive at a specification and then start hacking. Of course, if
there are open questions as regards the intended semantics of DA
operations, then these must be clarified.
> This is really important. We must see how to implement the data store
> for a CA gateway.
> If someone can create code to describe, store, and transport all data
> we have discussed so far via just the Data Access definitions then
> please tell us how to do it.
Yes. But before that, let us agree that DA is the interface. Or else let
us state precisely in what regard DA is /not/ capable of handling all
the requirements we have, and then fix DA so that we are all happy with
it.
I agree that it makes (a lot of) sense to explore the /possibility/ to
implement such a data store efficiently before finally committing to an
interface. But it is definitely not necessary to have a working
prototype. It's enough to be reasonably sure that we will find
solutions to any as yet unsolved problems. Furthermore, as Ralph stated
explicitly, as soon as we are convinced that the interface really
covers everything we want it to, we can spend every effort necessary to
optimize the data store. We could even start and read advanced
literature on how to do stuff like that, including things such as
on-line code optimization etc...
> Let me just make a wild proposal that involves allowing only well
> defined types.
> GIVEN
> The types
> primitive
>      bool,
>      octet,
>      int16,
>      float64
> string
> array
> struct   - can contain fields of any type including itself
> And via these types define a way to introspect.
Correct me if I am wrong, but IIRC these types are a /subset/ of those
DA supports. The primitive types are named differently, i.e. using
'native' C++ type names. The structured types are covered, too, maybe
not yet in all necessary detail. These can and must be worked out.
Great effort has been spent to try and make DA the Right Thing. I think
it at least deserves to be treated as the starting point for further
development. I am somewhat suspicious of ad-hoc solutions to try and
re-invent the wheel once again.
Note: Keep in mind that this is /not/ about the low-level representation
of EPICS records on the IOC. As regards the latter, of course we will
need a way to store compound record data in the IOC so that we will
have the most efficient access from the record support. I would argue
that we don't need to hide any data representation behind bars of any
kind, but instead give record support complete unsafe low-level access,
supported by C routines for convenience only.
And, as Ralph already stated, this low-level data representation for
EPICS records /can/ be /used/ by some generic Data Store. To d so would
be economic, at least for the first version, but it is by no means
necessary and any such use will be completely opaque to users of a
generic Data Store.
Ben
RE: Fundamental Types document Jeff Hill
Re: Fundamental Types / Gateway Ralph Lange
Re: Fundamental Types / Gateway Marty Kraimer
Prev: Re: Fundamental Types / Gateway Benjamin Franksen
Next: Re: Fundamental Types document / unsigned integers Benjamin Franksen
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fundamental Types / Gateway Marty Kraimer
Next: RE: Fundamental Types / Gateway Jeff Hill
