2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fundamental Types document / unsigned integers
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Fri, 17 Jun 2005 16:32:14 -0500
On Jun 17, 2005, at 4:21 PM, Benjamin Franksen wrote:
Regarding Jeff's argument as for the advantages of programming with
numbers that are garanteed to be non-negative. I would argue that this
is also mostly valid in C/C++, where arrays are always indexed starting
with zero. Many languages allow upper /and/ lower index bounds to be
arbitrary (signed) integers, or even any other data type, provided the
programmer can specify a one-to-one mapping onto a bounded interval of
integers. Thus, non-negativity seems to be a somewhat arbitrary
guarantee (why not, for instance, strict positivity?). Furthermore,
with regard to the efficiency question (only one range-check for upper
bound instead of two for upper and lower), in  C/C++ you are always
free to apply the zero-cost type cast from signed to unsigned, thereby
mapping negative numbers to large positive ones, and then range-test
only for the upper bound. This will fail for /exactly/ the cases where
the original check failed, as long as you don't rely on the upper half
of the possible range, something you (Jeff) suggested is to be avoided
anyway.
The inefficiency is only in typing a few extra characters on your keyboard. Any modern optimizing compiler is going to optimize
	if ((i < 0) || (i >= j))
(where i and j are signed integer values) into a single test without you needing to help it by performing the cast.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
RE: Fundamental Types document / unsigned integers Jeff Hill
RE: Fundamental Types document Jeff Hill
Re: Fundamental Types document Marty Kraimer
Re: Fundamental Types document Ralph Lange
Re: Fundamental Types document / unsigned integers Benjamin Franksen
Prev: Re: V4 Data Types: Request for tagged unions Benjamin Franksen
Next: Re: Fundamental Types document Benjamin Franksen
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fundamental Types document / unsigned integers Benjamin Franksen
Next: RE: Fundamental Types document / unsigned integers Jeff Hill
