2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: ICALEPCS and EPICS iocCore V4
To: [email protected]
Date: Mon, 17 Oct 2005 13:35:46 -0500
Steve Lewis wrote:
Marty Kraimer wrote:
2) The interface to the IOC database is narrow in the sense that communication is done via data rather than a large set of objects. This is what allows general purpose tools like display managers and what makes it easy for other systems to talk to IOCs. In EPICS facilities it is common for operators to create displays for MEDM or EDM. I suspect that tools like the the tango gui builder would be used by programmers rather than operators or hardware oriented engineers. Thus we must be carefull about how much device orientation we introduce into IOCs. Perhaps a power supply but not a high level physics abstraction.
Again, this is what the NIF architecture is like. It is (was) extremely frustrating under this architecture to bring some functionality to bear on the hardware and to the operators. What would have taken 10 minutes with VDCT and 1 minute with MEDM in EPICS took from 1 hour to 1 day from each of 1) the FEP programmer; 2) the tier 2 programmer; 3) the IDL/SQL/RDB team; 4) the GUI programmer; 5) the tier 3 team [sequencer-like "scripts"]; 6) the CM team to "regenerate the IDL", do "make clean; make". And then you test. Elapsed calendar time: weeks to months.
We called it "IDL hell" and employed the most devious strategies to avoid items (2)-(6).
</RANT>
There was at one time a middle ground here, and it was called CDEV. I'm not suggesting reviving that particular implementation, but it was a interesting idea, and there was a great deal of thought and design that went into it. There are quite a few similarities between the old CDEV discussions, and what I'm hearing now about the tension between channel-based and object-based access.
CDEV provided a device abstraction (sort of like objects with a dynamic invocation interface) while being readily re-configured. In short, no "make clean; make", or IDL hell. So...
Is there anything wrong with supporting 2 namespaces for control? One would be the channel-based namespace EPICS currently offers, and the other would be a device abstraction ala CDEV. Before everyone recoils in horror, realize that most places wind up de-facto doing this anyways. SNS has EPICS, but yet all their applications are driven via an object model realized in a relational database, that in turn has the association with the underlying EPICS PVs. Here at APS, our OAG group is effectively doing a form of this using SDDS to group PVs into more useful abstractions. All this to make higher level operations and physics applications easier to understand and work with.
So keep the nimble applications like MEDM, which require a channel-based data layer, but explicitly support a device abstraction layer as well. Things like feedback loops would be left to the EPICS record level, not implemented at the device abstraction layer.
I guess this isn't too far from just dropping the upper levels of Tango on top of EPICS, but it is distinct from that approach in that I would suggest making it more configurable than the typical IDL based approach (which Steve correctly notes can be hell in a dynamic environment). These dynamic device abstractions could be presented as CORBA objects in an ORB possibly...
<disclaimer>
Just talking out loud here, and please forgive me if I have misrepresented CDEV, Tango, or EPICS.
</disclaimer>
 - Claude
RE: ICALEPCS and EPICS iocCore V4 Jeff Hill
ICALEPCS and EPICS iocCore V4 Marty Kraimer
Re: ICALEPCS and EPICS iocCore V4 Steve Lewis
Prev: Re: ICALEPCS and EPICS iocCore V4 Kay-Uwe Kasemir
Next: RE: ICALEPCS and EPICS iocCore V4 Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: ICALEPCS and EPICS iocCore V4 Benjamin Franksen
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
