2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: V4 DB RecordCommon: Suggestion for alarmAckTransient (ACKT replacement)
To: EPICS Core Talk <[email protected]>
Date: Thu, 20 Oct 2005 07:34:43 -0500
Ralph Lange wrote:
Maybe change the name?
alarmAckTransient  ->  alarmNoAckTransientLevel
Would that be more comprehensive? Or do you have a better idea?
No. I will make it alarmNoAckTransientLevel unless someone has a better idea.
Marty
Ralph
Marty Kraimer wrote:
Ralph Lange wrote:
Suggestion:
Change the type of alarmAckTransient from boolean to menu(menuAlarmSevr) and redefine it as "highest level of alarm that does not have to be acknowledged". Doesn't need more space in the DB and allows for nice and subtle configuration options: e.g. warnings that don't have to be ack'ed while errors do.
What do you think?
Sounds fine to me. I will change RecordCommon.wiki to
        field(alarmAckTransient,menu(menuAlarmSevr)) {
        # highest level of alarm that does not have to be acknowledged"
If there are objections it can always be changed back.
Marty
V4 DB RecordCommon: Suggestion for alarmAckTransient (ACKT replacement) Ralph Lange
Re: V4 DB RecordCommon: Suggestion for alarmAckTransient (ACKT replacement) Marty Kraimer
Re: V4 DB RecordCommon: Suggestion for alarmAckTransient (ACKT replacement) Ralph Lange
Prev: Re: Fwd: Control System Data Access API Marty Kraimer
Next: Re: Control System Data Access API Ralph Lange
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: V4 DB RecordCommon: Suggestion for alarmAckTransient (ACKT replacement) Ralph Lange
Next: [Fwd: EPICS V4 requirement ?] Marty Kraimer
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
