2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: R3.14.8/logClient
To: [email protected]
Date: Tue, 15 Nov 2005 07:47:36 -0600
Benjamin Franksen wrote:
Hello,
I am in the process of porting CaPutLog [1] to R3.14 and noticed that the implementation relies on an almost identical copy of the R3.13 logClient library (part of libCom). I further noticed that the logClient in R3.14 is *almost* fit to be re-used for CaPutLog. I have made some rather superficial changes to logClient.[ch] that would enable such a re-use. The only change in the interface is an additional extended initialization routine
epicsShareFunc logClientId epicsShareAPI logClientInitExt (
   struct in_addr server_addr, unsigned short server_port);
that enables creation of a client that send messages to a different server. Additionally, this init routine does /not/ automatically register with the errlog library, i.e. it does not call errlogAddListener.
Since all existing routines remain unchanged, this change would be completely backward compatible.
Are there any chances to get this into R3.14.8? If yes, to whom should I send the patches?
[1] http://www-kryo.desy.de/documents/EPICS/DESY/EpicsLog/CAPutLog.html
Ben
Perhaps it could go into 3.14.8 or 3.14.9
Send me your version of logClient.h and logClient.c so that I can take a look.
Also
1) what changes are needed for the Application Developers Guide?
2) What should be added to the release notes?
Marty
Re: R3.14.8/logClient Benjamin Franksen
Prev: R3.14.8/logClient Benjamin Franksen
Next: Mantus bug 204 Marty Kraimer
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: R3.14.8/logClient Benjamin Franksen
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
