On Tuesday 15 November 2005 20:18, Andrew Johnson wrote:
> It would be nice to get Banjamin's patch to the logClient library
> included, which we're expecting tomorrow.
Small problem, here. Some explanation(s) first: The current module named
'logClient' contains two kinds of routines: generic (logClient*) and
specific (iocLog*, for the standard IOC error logging i.e. via
errlogAddListener). The latter stuff is only a very thin layer that
actually uses only the public interface of the generic routines.
However, teh separatioon is not complete; there are still a few places
where the generic routines do specific things:
(1) logClientSendMessage() checks the value of iocLogDisable and returns
without doing anything if it is set.
(2) logClientInit() uses the EPICS_IOC_LOG_* environment vars to
identify server address and port.
(3) logClientInit() also contains a call to errlogAddListener, so that
for all calls to errlog* a message is sent via the created logClient
instance.
These things do not belong to the generic functionality and instead
should be done by the special instance, namely the standard ioc (error)
logging client and its supporting routines.
OTOH, for strict compatibility, the behavior must remain exactly the
same as before, which means that instead of changing the existing
functions logClientSendMessage() and logClientInit(), I must add new
additional versions of them.
What should I do?
Note: The generic routines are not yet documented anywhere.
Does anyone actually use them, relying on the above behavior?
Ben
- Re: R3.14.8 Status/logClient patch Benjamin Franksen
- R3.14.8 Status Andrew Johnson
RE: R3.14.8 Status Denison, PN (Peter)
Re: R3.14.8 Status Ralph Lange
<2005>
2025
<2005>
2025
