-----Original Message-----
Sent: Friday, April 15, 2005 6:06 AM
To: Andrew Johnson
Cc: Jeff Hill; 'Kay-Uwe Kasemir'; 'Eric Norum'
Subject: Re: Possible bug in taskwd
Andrew Johnson wrote:
> If we do implement something like your epicsThreadClose() routine that
> only returns after the indicated task is actually dead, it really
> should be named epicsThreadJoin() as it's analagous to the Posix
> pthread_join() behaviour. I'm not too sure if it can be implemented
> very easily in vxWorks, but some combination of taskDeleteHookAdd()
> and/or taskIdVerify() may work.
> - Andrew
If we do the following then vxWorks and anything else is not a problem.
Instead of epicsThreadCreate doing the equivalent of taskSpawn it should
do the equivalent of taskInit, i.e. create the task but do not call the
function passed to epicsThreadCreate. Then a separate function must be
available to call the function. Note that Jeff's C++ implementation of
epicsThread already has a start method which does something very
similar. Also instead of directly calling the function passed to
epicsThreadCreate provide a "wrapper" function which calls it. The
wrapper function can do stuff before and after calling the function.
Note again the Jeff's C++ already does this. In Jeff's implementation
epicsThreadCreate calls his wrapper function which waits until start is
called berfore calling the run method.
After talking to Jeff I also take back my suggestion about the run
method having an epicsEvent argument that must be checked regularly to
see if the thread should cleanup and terminate by having the run method
return. I now agree that clean up is so application specific that this
is not the way to request the threads terminate.
So what to do?
Maybe we are closer to what we want than we realize.
Perthaps epicsExit is all we need. Applications that must clean up
before the process is terminated must call epicsAtExit. epicsExit must
be called to force a process to exit.
The BIG question to be answered is:
Does it matter if most tasks don't clean up when the process is terminated?
If it does not matter then are channel access and errlog the main problems?
None of this answers the problems with taskwd. :-(
Marty
FW: error log facility Jeff Hill
FW: sysAtReboot Jeff Hill
<2005>
2025
<2005>
2025
