2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: vxWorks 6.3 and EPICS R3.14.9-pre1
To: "Ernest L. Williams Jr." <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Tue, 05 Dec 2006 13:26:17 -0600
Ernest L. Williams Jr. wrote:
This is a 6.x thing.  All releases 6.0 thru 6.3 have the following:
$(WIND_BASE)/gnu/<gnu-version>-vxworks-<version>/x86-linux2
Ok, this change in configure/os should fix it. It's a bit ugly, but setting WIND_HOST_TYPE to the correct value in the first place isn't really possible.
Index: CONFIG.Common.vxWorksCommon
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/configure/os/CONFIG.Common.vxWorksCommon,v
retrieving revision 1.35.2.10
diff -u -b -r1.35.2.10 CONFIG.Common.vxWorksCommon
--- CONFIG.Common.vxWorksCommon 2 Dec 2006 00:09:16 -0000       1.35.2.10
+++ CONFIG.Common.vxWorksCommon 5 Dec 2006 19:19:05 -0000
@@ -89,6 +89,14 @@
 VX_GNU_VERSION = $(VX_GNU_VERSION_$(VXWORKS_VERSION))
+# Fix WIND_BASE for vxWorks 6.x on linux
+ifeq ($(VXWORKS_MAJOR_VERSION),6)
+  ifeq ($(WIND_HOST_TYPE),x86-linux)
+    WIND_HOST_TYPE = x86-linux2
+  endif
+endif
 # vxWorks directory definitions
 VX_DIR_5 = $(WIND_BASE)
 VX_DIR_6 = $(WIND_BASE)/vxWorks-$(VXWORKS_VERSION)
I'm about to look at your other changes too.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Re: vxWorks 6.3 and EPICS R3.14.9-pre1 Ernest L. Williams Jr.
Re: vxWorks 6.3 and EPICS R3.14.9-pre1 Andrew Johnson
Prev: Re: vxWorks 6.3 and EPICS R3.14.9-pre1 Ernest L. Williams Jr.
Next: Re: vxWorks 6.3 and EPICS R3.14.9-pre1 Ernest L. Williams Jr.
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
