2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: osiWireFormat.h problems
To: "'Ralph Lange'" <[email protected]>
Cc: "'EPICS Core Talk'" <[email protected]>
Date: Tue, 5 Dec 2006 16:25:22 -0700
> Here we go .... I really hope you see more than I do ....
I committed fixes for the warnings, but don't see any obvious clues for the
compiler crash. Maybe a compiler upgrade is possible (sorry if we are
rehashing old discussion)?
Jeff
> -----Original Message-----
> From: Ralph Lange [mailto:[email protected]]
> Sent: Monday, December 04, 2006 6:38 PM
> To: Jeff Hill
> Cc: EPICS Core Talk
> Subject: Re: osiWireFormat.h problems
> Jeff Hill wrote:
> > Ralph,
> > Could you send a copy of all the messages the HP-UX compiler emits
> before it
> > fails (when compiling this particular source file). I have some
> experience
> > with this sort of thing and might be able to create a workaround. Also,
> > please send a version number and release date for this compiler. It's
> > probably getting a bit dated but perhaps we can still support it.
> The compiler is
> aCC: HP ANSI C++ B3910B A.03.52
> Thanks, Ralph
> aCC -c           -DHP_UX   -AA -Aa -mt  +O3  +w      +DAportable +z
> -I. -I.. -I../../../include/os/hpux -I../../../include
> ../tcpiiu.cpp 2>&1 | ../../../configure/tools/filterWarnings.pl
> Warning (suggestion) 818: "../../../include/osiWireFormat.h", line 116 #
> Type
>     'int' is larger than type 'unsigned short', truncation in value may
> result.
>         return ( src << 8u ) | ( src >> 8u );
> Warning (suggestion) 818: "../../../include/osiWireFormat.h", line 124 #
> Type
> result.
>         tmp0 = ( tmp0 << 8u ) | ( tmp0 >> 8u );
> Warning (suggestion) 818: "../../../include/osiWireFormat.h", line 125 #
> Type
> result.
>         tmp1 = ( tmp1 << 8u ) | ( tmp1 >> 8u );
> Warning (suggestion) 819: "../../../include/osiWireFormat.h", line 122 #
>     Initialization of type 'unsigned short' with 'unsigned int' may
> result in
>     truncation of value.
>         epicsUInt16 tmp0 = src >> 16u;
> Warning (suggestion) 818: "../../../include/osiWireFormat.h", line 122 #
> Type
>     'unsigned int' is larger than type 'unsigned short', truncation in
> value may
>     result.
> Warning (suggestion) 819: "../../../include/osiWireFormat.h", line 123 #
>     Initialization of type 'unsigned short' with 'const unsigned int &'
> may
>     result in truncation of value.
>         epicsUInt16 tmp1 = src;
> Warning (suggestion) 818: "../../../include/osiWireFormat.h", line 123 #
> Type
>     'const unsigned int' is larger than type 'unsigned short', truncation
> in
>     value may result.
> Warning (suggestion) 818: "../../../include/osiWireFormat.h", line 170 #
> Type
> result.
>             ( static_cast < epicsUInt16 > ( pWireSrc[0] ) << 8u ) |
> Error (future) 229: "../comQueSend.h", line 123 # "Ambiguous overloaded
> function
>     call; a function match was not found that was strictly best for ALL
>     arguments. Two functions that matched best for some arguments (but
> not all)
>     were "unsigned int comBuf::push(const char *,unsigned int)"
> ["../comBuf.h",
>     line 196] and "unsigned int comBuf::push(const char *,unsigned int)"
>     ["../comBuf.h", line 196]." Choosing "unsigned int
>     *,unsigned int)" ["../comBuf.h", line 196] for resolving ambiguity.
>                 nCopied = pLastBuf->push ( pVal, nElem );
> Error (future) 229: "../comQueSend.h", line 130 # "Ambiguous overloaded
> function
> not all)
> ["../comBuf.h",
>                 nCopied += pComBuf->push
> Warning (suggestion) 818: "../tcpiiu.cpp", line 1381 # Type 'int' is
> larger than
>     type 'unsigned short', truncation in value may result.
>             command, 0u,
> Warning:        2 future errors were detected and ignored. Add a '+p'
> option to
>     detect and fix them before they become fatal errors in a future
> release.
>     Behavior of this ill-formed program is not guaranteed to match that of
> a
>     well-formed program
> Signal 11
Re: osiWireFormat.h problems Ralph Lange
Prev: RE: osiWireFormat.h problems Jeff Hill
Next: Re: osiWireFormat.h problems Ralph Lange
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
