2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sat. CVS snap built against vxWorks 6.3
To: "Ernest L. Williams Jr." <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Mon, 11 Dec 2006 13:04:22 -0600
Hi Ernest,
Ernest L. Williams Jr. wrote:
I ran into a build issue with vxWorks 6.3 regarding WIND_HOST_TYPE.
The patch you provided works provided there is no definition
WIND_HOST_TYPE in "CONFIG.<EPICS_HOST_ARCH>.Common"
Specifically, I had to remove the WIND_HOST_TYPE definition in CONFIG.linux-x86.Common and CONFIG.linux-x86_64.Common
By removing the setting from those files you are just using the value of your WIND_HOST_TYPE environment variable. If you unset that, it'll stop working again, which is not a desirable outcome.
The problem is that make doesn't know the value of $(VXWORKS_VERSION) at the point where I'm using it. I can solve one use easily, but I'm going to have to talk to Janet about the other. Luckily I think I can debug it fairly easily without having vxWorks 6 installed, since it appears in the compiler path that is the first thing actually run in a vxWorks 6 build.
Once this issue is resolved, I'll be tagging R3-14-9-pre2 (we're only just over a week late).
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Re: Sat. CVS snap built against vxWorks 6.3 Ernest L. Williams Jr.
Prev: Sat. CVS snap built against vxWorks 6.3 Ernest L. Williams Jr.
Next: Re: Sat. CVS snap built against vxWorks 6.3 Ernest L. Williams Jr.
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
