2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: C++ compiler issues
To: Jeff Hill <[email protected]>, Janet Anderson <[email protected]>, Andrew Johnson <[email protected]>
Cc: "'EPICS Core Talk'" <[email protected]>, Stephanie Allison <[email protected]>
Date: Tue, 12 Dec 2006 12:47:42 -0800
Hi Jeff,
On 12/12/06 10:47 AM, "Jeff Hill" <[email protected]> wrote:
> Does CEBAF still use HPUX? Apparently JAERI (and probably also KEK) servers
> are HPUX? Do they have modern HPUX versions with modern C++ compilers?
I'm pretty sure JLab (i.e. CEBAF) still uses HP-UX pretty heavily, but I
don't know what resources they have to assist in continuing development.
You might try contacting Matt Bickley.
> PS: I noticed today that maybe Java, as released by Sun, is available now
> only for Windows, Linux, and Solaris? Do I understand that correctly?
> Presumably other commonly used Unix variants (such as BSD Unix) must get the
> source and self support?
Hasn't this always been the case?  HP provides java for HP-UX and OpenVMS.
Apple provides java for Mac OS X.  IBM provides java for AIX machines.
I imagine that since Sun has open-sourced Java, they want to make it clear
that they won't support every architecture to which someone ports the code.
Chris
C++ compiler issues Jeff Hill
Prev: Re: C++ compiler issues Ernest L. Williams Jr.
Next: C++ Exceptions from CAC-UDP on exit Andrew Johnson
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
