2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Bug in generated MakefileInclude?
To: EPICS core-talk <[email protected]>
Date: Thu, 14 Dec 2006 15:29:07 +0100
When, in the makeBaseApp-generated example, in exampleApp/src/Makefile I
change
PROD_IOC = example
to
PROD_IOC_vxWorks = example
then the product no longer depends on neither sources nor libraries. I
can do e.g.
aragon: .../work/test > make -s
[...make builds everything...]
aragon: .../work/test > touch exampleApp/src/sncProgram.st
[...silence, nothing is done...]
I suspect that the problem is in the generated MakefileInclude. Here is
a snippet:
ifeq ($(filter example,$(TESTPROD) $(PROD)),example)
ifeq (,$(strip $(example_OBJS) $(PRODUCT_OBJS)))
example_OBJS+=example$(OBJ)
endif
example_RESS+=$(addsuffix $(RES),$(basename $(example_RCS)))
example_OBJSNAME+=$(addsuffix $(OBJ),$(basename $(example_OBJS)))
example_DEPLIBS=$(foreach lib, $(example_LDLIBS),\
 $(firstword $(wildcard $(addsuffix /$(LIB_PREFIX)$(lib).*,\
 $($(lib)_DIR) $(SHRLIB_SEARCH_DIRS)))\
 $(addsuffix /$(LIB_PREFIX)$(lib)$(LIB_SUFFIX),\
 $(firstword $($(lib)_DIR) $(SHRLIB_SEARCH_DIRS))/)))
example$(EXE): $(example_OBJSNAME) $(example_RESS) $(example_DEPLIBS)
endif
So example will depend on its libraries only if mentioned in either PROD
or TESTPROD, but not if mentioned only in e.g. PROD_IOC_vxWorks.
I have no idea what the outer ifeq...endif is good for; maybe it could
be removed?
Would be nice if this could be fixed before 3.14.9 comes out.
Cheers
Ben
To the functional programmer's eye a loop is just a degenerate
form of linear recursion written in an adhoc special syntax.
Re: Bug in generated MakefileInclude? Janet Anderson
Prev: Re: C++ Exceptions from CAC-UDP on exit Andrew Johnson
Next: Re: Bug in generated MakefileInclude? Janet Anderson
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: C++ Exceptions from CAC-UDP on exit Ernest L. Williams Jr.
