2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: C++ Exceptions from CAC-UDP on exit
To: "'Jeff Hill'" <[email protected]>, "'Andrew Johnson'" <[email protected]>, "'EPICS core-talk'" <[email protected]>
Date: Thu, 14 Dec 2006 11:02:44 -0700
> As I recall, the crux of this issue is that a shutdown procedure for the
> db
> ca link code would need to destroy all of its channels first, before
> destroying the ca context, and that would require that the individual
> records have shutdown procedures in place also - a big change.
Typically there isn't a problem if the ca context is destroyed and the
channels are not deleted first. However in an IOC context we have in memory
channels and the situation is more complex. In that situation if the
channels are not destroyed before the ca context is destroyed we will
continue to receive monitor callbacks as the scan tasks run, and the monitor
callbacks crash when using a ca context that no-longer exists.
I further recall that this could be fixed if:
O CA were to keep a list of all in-memory channels
O When the context is destroyed we could run this list of in-memory channels
and uninstall all of their subscriptions
This would cause some duplication (wasted storage) however because the
database is already storing pointers to all of the channels that it creates,
and presumably we will never get shutdown fixed properly until the db has
implemented an orderly shutdown.
Jeff
RE: C++ Exceptions from CAC-UDP on exit Jeff Hill
Prev: RE: C++ Exceptions from CAC-UDP on exit Jeff Hill
Next: Re: C++ Exceptions from CAC-UDP on exit Andrew Johnson
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
