2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems with database breakpoint routines.
To: "Rees, NP (Nick)" <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Tue, 19 Dec 2006 10:56:49 -0600
Hi Nick,
Rees, NP (Nick) wrote:
The dbBkpt changes. Modified R3.14.9-pre2 files are attached, and the
diffs are given at the end of this message. The bottom line is that I
created a dbBkptInit routine that needs to be called at initialisation,
and then most problems go away (I think).
Thanks; I used that as the basis for what I've committed, which included a little cleanup (I renamed lset_stack_not_empty to lset_stack_count and maintain its value strictly according to the ellAdd/ellDelete calls.
The only question I had was where/how to call the dbBkptInit. Hence the
changes to dbBkptRegister so I can call it from the iocsh. However, I
really want it to always be called from iocInit, and I don't know the
recommended way to do this. I presume I can call initHookRegister in
dbBkptRegister, but then it probably doesn't happen in the VxWorks
environment. How do I do this in base?
I didn't add dbBkptInit() as a command like you did, but call it from iocInit() instead.
The result seems to be less fragile than before, as I didn't manage to cause any crashes in my tests. The output from the breakpoint commands isn't particularly user-friendly, but this is better than it was.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
RE: Problems with database breakpoint routines. Rees, NP (Nick)
Prev: Re: Patches for recognizing external dependencies Andrew Johnson
Next: Re: EPICS on Tru64unix and HP-UX Andrew Johnson
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: yet another bug in mkmf.pl Janet Anderson
Next: RE: Problems with database breakpoint routines. Rees, NP (Nick)
