2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS R3.14.9 experiences
To: "EPICS core-talk" <[email protected]>
Date: Wed, 20 Dec 2006 15:47:29 -0000
Core-talk,
Am I missing something? My first build of a VxWorks IOC using
R3.14.9-pre2 gave the following on boot:
ld < bin/vxWorks-ppc604_long/slitTest.munch
Undefined symbol: push__H1Zi_6comBufPCX01Ui_Ui (binding 1 type 0)
Undefined symbol: pop__H1ZUc_6comBufRX01_Q26comBuf9popStatus (binding 1
type 0)
Undefined symbol: push__H1Zd_6comBufPCX01Ui_Ui (binding 1 type 0)
Undefined symbol: push__H1Zf_6comBufPCX01Ui_Ui (binding 1 type 0)
Undefined symbol: push__H1Zs_6comBufPCX01Ui_Ui (binding 1 type 0)
Undefined symbol: pop__H1ZUs_6comBufRX01_Q26comBuf9popStatus (binding 1
type 0)
Undefined symbol: pop__H1ZUi_6comBufRX01_Q26comBuf9popStatus (binding 1
type 0)
ld error: Module contains undefined symbol(s) and may be unusable.
These symbols are apparently referred to by comQueRecv.cpp and
comQueSend.cpp and have demangled names of:
[npr78@pc0025 vxWorks-ppc604_long]$ nm -o --demangle libca.a | grep
"comQue.*.o: *U.*comBuf::p"
libca.a:comQueRecv.o:         U comBuf::popStatus comBuf::pop<unsigned
char>(unsigned char &)
int>(unsigned int &)
short>(unsigned short &)
libca.a:comQueSend.o:         U unsigned int comBuf::push<double>(double
const *, unsigned int)
libca.a:comQueSend.o:         U unsigned int comBuf::push<float>(float
libca.a:comQueSend.o:         U unsigned int comBuf::push<int>(int const
*, unsigned int)
libca.a:comQueSend.o:         U unsigned int comBuf::push<short>(short
These appear to be defined in comBuf.h, but don't seem to be making it
into libca.c.
The cc version I am using is:
[npr78@pc0025 ca]$ ccppc -v
Reading specs from
/dls_sw/targetOS/vxWorks/Tornado-2.2/host/i386-Linux/bin/../lib/gcc-lib/
powerpc-wrs-vxworks/gcc-2.96/specs
gcc version gcc-2.96 (2.96+) 19990621 AltiVec
Any ideas?
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
Re: EPICS R3.14.9 experiences Andrew Johnson
Prev: Re: yet another bug in mkmf.pl Janet Anderson
Next: Re: C++ Exceptions from CAC-UDP on exit Andrew Johnson
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS on Tru64unix and HP-UX Kazuro FURUKAWA
Next: Re: EPICS R3.14.9 experiences Andrew Johnson
