2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AppDevGuide not up-to-date on devLib
To: [email protected]
Cc: [email protected]
Date: Mon, 05 Feb 2007 15:32:20 -0600
Benjamin Franksen wrote:
It seems the current AppDevGuide doesn't document the routines devReadProbe, devNoResponseProbe, and devWriteProbe (chapter 20.18 Device Support Library). Furthermore, the documentation for the devLib routines does not say anything about what the return values of the several routines mean.
Since I'm not responsible for maintaining devLib I didn't want to spend much time on this, but I have added most of the current devLib.h routines to the final R3.14.9 AppDevGuide with some rudimentary text where appropriate.
If the return value is a long and the meaning is not described, most EPICS routines will give back a status value of some kind, where 0 means Ok and anything else is an error. I have no idea where this should be documented, especially since none of the errSymLib.c routines are covered anywhere...
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
AppDevGuide not up-to-date on devLib Benjamin Franksen
Prev: Proposal for an addition to configure/tools/convertRelease.pl Benjamin Franksen
Next: Re: necessary changes in caServer code for redundancy support Jeffrey O. Hill
Index: 2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: AppDevGuide not up-to-date on devLib Benjamin Franksen
Next: Re: 3.14.9 Andrew Johnson
