2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Patch for 3.14.9
To: [email protected]
Date: Wed, 28 Feb 2007 14:22:03 +0100
attached is small bug-fix patch for the macLib (part of libCom). It appears
that a certain warning ("macLib: xyz is recursive") issued by the macLib is
not suppressed even if FLAG_SUPPRESS_WARNINGS is set. The patch fixes that;
it can be applied equally well to to base-3.14.8.2 and base-3.14.9.
The problem with the un-suppressed warning is that when using MSI (which
relies on macLib for the macro substitution) generated files get corrupted
by the error message, since error output goes to stdout.
A more radical solution for problems like these might be to make the output
stream of errlog configurable by the application (currently it is
hard-coded to stdout).
Cheers
Ben
"Programming = Mathematics + Murphy's Law" (Dijkstra in EWD1008)
Index: src/libCom/macLib/macCore.c
RCS file: /opt/repositories/controls/epics/base/3.14/src/libCom/macLib/macCore.c,v
retrieving revision 1.1.1.3
diff -r1.1.1.3 macCore.c
768,771c768,773
<                 entry->error = TRUE;
<                 errlogPrintf( "macLib: %s %s is recursive (expanding %s %s)\n",
<                               entry->type, entry->name,
<                               entry2->type, entry2->name );
>                 if ( (handle->flags & FLAG_SUPPRESS_WARNINGS) == 0 ) {
Prev: Re: EPICS on Tru64unix and HP-UX Kazuro FURUKAWA
Next: calcoutRecord.h Ralph Lange
Index: 2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
