2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS R3.14.9 and vxWorks
Cc: "Kasemir, Kay" <[email protected]>, "Thompson, David H." <[email protected]>, EPICS Core Talk <[email protected]>
Date: Wed, 11 Apr 2007 07:09:32 -0700
On Tue, 2007-04-10 at 18:13 -0500, Andrew Johnson wrote:
> Ernest L. Williams Jr. wrote:
> > In the case of an ioc application, the application source code does not
> > change between a vxWorks 5.5.x and vxWorks 6.x kernel.
> Sure; in this case the branch would only be needed to give you the two
> separate build trees, until you can get the vxWorks 5.5.x IOCs upgraded
> to vxWorks 6.x - I'm assuming that this would be one of the main points
> of introducing vxWorks 6 IOCs in the first place.  As I said, it also
> gives the engineer responsible for the IOC area an incentive to upgrade
> his/her IOCs quickly...
Sounds good.
> > However, in the case of a "share top" which contains drivers such as
> > vxStats there will be an impact.  So, vxStats is riddle with "ifdefs" or
> > a new branch is made.  In the case of vxStats we will be working on some
> > abstraction layer to hide vxWorks API changes.
> Actually I would expect vxStats to be the one support application that
> really would have to be different for different versions of vxWorks,
> since it probably relies on the OS APIs that tend to be on the fringes
> of normal functionality and thus change between major versions.  The
> advantage of starting a new IOC branch in this case is that you can link
> to a completely different vxStats support application for vxWorks 6, and
> you wouldn't need any of the ifdef stuff or an abstraction layer at all
> (Actually you can do that with a different target architecture too, you
> just have to create a configure/RELEASE.Common.vxWorks6-ppc604_long file
> in each IOC area to override the configure/RELEASE setting).
That is awesome.  I did not know you could do that with the RELEASE
file.
Ernest
> > The compiler options are actually CPU specific and BSP specific.
> > One example is the altivec support, but you already handle this with an
> > altivec suffix in the target name.  I agree that the options may not be
> > necessary always.
> Adding the altivec really makes it a different CPU, so it has to be a
> different target architecture.  I'd be interested in any other examples
> you can find though.
> - Andrew
EPICS R3.14.9 and vxWorks Ernest L. Williams Jr.
Re: EPICS R3.14.9 and vxWorks Andrew Johnson
Re: EPICS R3.14.9 and vxWorks Ernest L. Williams Jr.
Prev: Re: EPICS R3.14.9 and vxWorks Ralph Lange
Next: Re: EPICS R3.14.9 and vxWorks Ernest L. Williams Jr.
Index: 2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS R3.14.9 and vxWorks Ernest L. Williams Jr.
Next: [Fwd: Track on control system evolution] News from EPICS - proposed topics Matthias Clausen
