2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: GNU make multiple jobs option
To: Janet Anderson <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Thu, 25 Oct 2007 14:20:47 -0500
Janet Anderson wrote:
Yesterday I committed changes to the EPICS base R3.14 branch and the main trunk to allow the GNU make "-j jobs" option to work when building EPICS base. I also made a change in the makeBaseApp.pl templates to allow the -j option when building new ioc applications . There is a note about the -j change in the R3.14 branch release notes.
Note that Janet's parallel build rules that support the -j option require the use of $(eval ...) which was introduced in GNU Make version 3.81. Serial compilation still works on older versions of Make as before, but if you give a -j option the build will fail since many of the dependencies won't have been set.
On our 8-core Linux box the performance gain is obvious; building Base for Linux and one RTEMS target came down from 6 minutes to 2 minutes in my test.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
GNU make multiple jobs option Janet Anderson
Prev: GNU make multiple jobs option Janet Anderson
Next: epicsTime.cpp Strangeness Denison, PN (Peter)
Index: 2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
