2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Redundancy Patch: rsrv
To: EPICS core-talk <[email protected]>
Date: Thu, 15 Nov 2007 17:36:49 -0600
Modified
# source files
(18) base-3.14.9/src/rsrv/camsgtask.c
    Destroy client connenctions when the IOC is SLAVE.
(19) base-3.14.9/src/rsrv/caservertask.c
    Register CAS-TCP task at RMT. Stop responding the client connection
    request when the IOC is SLAVE.
(20) base-3.14.9/src/rsrv/cast_server.c
    Inactivate CAS-UDP task when the IOC is SLAVE.
(21) base-3.14.9/src/rsrv/online_notify.c
    Inactivate CAS-beacon task when the IOC is SLAVE.
Added
(2) base-3.14.9/src/rsrv/rmtDrvIf.h
    The head file for RMT driver interface.
Index: src/rsrv/camsgtask.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/rsrv/camsgtask.c,v
retrieving revision 1.54.2.6
diff -u -b -r1.54.2.6 camsgtask.c
--- src/rsrv/camsgtask.c	26 Oct 2005 21:59:03 -0000	1.54.2.6
+++ src/rsrv/camsgtask.c	12 Nov 2007 18:22:33 -0000
@@ -14,6 +14,12 @@
  *  Date:   6-88
+modification history
+Oct.16,2007,Gongfa Liu  destroy client connenctions when the IOC is SLAVE.
 #include <stddef.h>
 #include <stdlib.h>
@@ -33,6 +39,8 @@
 #include "rsrv.h"
 #include "server.h"
+extern int masterFlagForCAS; /* by Gongfa Liu */
  *  camsgtask()
@@ -155,6 +163,8 @@
             epicsPrintf ("CAS: forcing disconnect from %s\n", buf);
                 break;
+        if(masterFlagForCAS == FALSE) client->disconnect = TRUE; /* by Gongfa Liu */
     LOCK_CLIENTQ;
Index: src/rsrv/caservertask.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/rsrv/caservertask.c,v
retrieving revision 1.105.2.15
diff -u -b -r1.105.2.15 caservertask.c
--- src/rsrv/caservertask.c	28 Nov 2006 18:51:16 -0000	1.105.2.15
+++ src/rsrv/caservertask.c	12 Nov 2007 18:22:33 -0000
@@ -16,6 +16,13 @@
  *  Date:   5-88
+Oct.16,2007,Gongfa Liu  register CAS-TCP task at RMT. stop responding the
+                        client connection request when the IOC is SLAVE.
 #include <stddef.h>
 #include <stdlib.h>
 #include <stdio.h>
@@ -45,6 +52,37 @@
 #define GLBLSOURCE
 #include "server.h"
+/* added by Gongfa Liu */
+#include "epicsThread.h"
+#include "epicsFindSymbol.h"
+#include "rmtDrvIf.h"
+#ifndef vxWorks
+#define BOOL int
+#define LOCAL static
+#define IMPORT extern
+#define TRUE 1
+#define FALSE 0
+#endif
+typedef struct {
+    BOOL            run;            /* scan task is running */
+    BOOL            activeFlag;     /* flag to check if loop is running */
+    const char     *instanceName;
+    epicsThreadId   tid;            /* task id of driver instance */
+} castcpPrivateType;
+int masterFlagForCAS = FALSE;
+static STATUS castcpStart(castcpPrivateType *ppvt);
+static STATUS castcpStop(castcpPrivateType *ppvt);
+static STATUS castcpGetStatus(castcpPrivateType *ppvt, drvStatusType *pstatus);
+static STATUS castcpGetInfo(castcpPrivateType *ppvt, char *pString, short *psize, char *prequestString);
+static STATUS castcpStartUpdate(castcpPrivateType *ppvt, updateMode mode);
 #define DELETE_TASK(NAME)\
 if(threadNameToId(NAME)!=0)threadDestroy(threadNameToId(NAME));
@@ -72,6 +110,46 @@
     epicsThreadId tid;
     int portChange;
+    /* added by Gongfa Liu                               */
+    /* register at RMT                                   */
+    rmtEntryTabType   castcpRegistry;
+    castcpPrivateType   castcpPvt;
+    const rmtInfoTabType  *prmtInfoTab;
+    STATUS (*prmtRegister)() = NULL;
+    long status1;
+    castcpRegistry.type                = "cas-tcp";
+    castcpRegistry.instanceName        = epicsThreadGetNameSelf();
+    castcpRegistry.testTimeTypical     = 0;
+    castcpRegistry.pPrvt               = (void *)&castcpPvt;
+    castcpRegistry.pStart              = (RMTSUPFUN)castcpStart;
+    castcpRegistry.pStop               = (RMTSUPFUN)castcpStop;
+    castcpRegistry.pTestIO             = NULL;
+    castcpRegistry.pGetStatus          = (RMTSUPFUN)castcpGetStatus;
+    castcpRegistry.pShutdown           = NULL;
+    castcpRegistry.pGetInfo            = (RMTSUPFUN)castcpGetInfo;
+    castcpRegistry.pGetUpdate          = NULL;
+    castcpRegistry.pStartUpdate        = (RMTSUPFUN)castcpStartUpdate;
+    castcpRegistry.pStopUpdate         = NULL;
+    castcpPvt.instanceName        = castcpRegistry.instanceName;
+    castcpPvt.tid                 = epicsThreadGetIdSelf();
+    castcpPvt.run                 = FALSE;
+    castcpPvt.activeFlag          = TRUE; /* always TRUE when no testIO */
+    prmtRegister = (RMTSUPFUN)epicsFindSymbol("rmtRegister");
+    if(prmtRegister == NULL)
+        printf("Non redundant IOC!!!\n");
+        masterFlagForCAS = TRUE; /* let flag is TRUE */
+    else
+        status1 = (*prmtRegister)(&castcpRegistry, &prmtInfoTab);
     epicsSignalInstallSigPipeIgnore ();
     taskwdInsert ( epicsThreadGetIdSelf (), NULL, NULL );
@@ -219,6 +297,7 @@
                 continue;
+        while (masterFlagForCAS == FALSE) epicsThreadSleep(0.1); /* sleep here when slave, by Gongfa Liu */
@@ -929,3 +1008,81 @@
 	UNLOCK_CLIENTQ;
+/* some functions for RMT driver interface                    */
+    printf("%s: castcpStart\n", ppvt->instanceName);
+    ppvt->run = TRUE;
+    return(OK);
+    printf("%s: castcpStop\n", ppvt->instanceName);
+    ppvt->run = FALSE;
+    masterFlagForCAS = FALSE;
+    return(OK);
+    pstatus->mode = ppvt->run ? MODE_run : MODE_stop;
+    pstatus->testResult = TEST_undefined;
+    if(  epicsThreadIsSuspended(ppvt->tid) )
+        pstatus->error = INVALID_ERROR;
+    else
+        pstatus->error = NO_ERROR;
+    pstatus->updateBusy = FALSE;
+    pstatus->inSync = TRUE;
+    pstatus->activeFlag = ppvt->activeFlag;
+    /* ppvt->activeFlag = FALSE;  */ /* activeFlag shuold be kept TRUE when no TestIO */
+    return(OK);
+    char castcpTaskInfo[100];
+    sprintf(castcpTaskInfo,"<XML><NAME>%s</NAME><STATUS>%s</STATUS></XML>",
+            ppvt->instanceName, ppvt->run ? "active" : "inactive");
+    if(prequestString && strlen(prequestString))
+        printf("%s: castcpGetInfo with request\n", ppvt->instanceName);
+    else
+        printf("%s: castcpGetInfo without request\n", ppvt->instanceName);
+    if (psize != NULL && pString != NULL)
+        if (*psize > sizeof(castcpTaskInfo))
+            strcpy (pString, castcpTaskInfo);
+        else
+            *psize = sizeof(castcpTaskInfo)+1;
+        printf("%s\n", castcpTaskInfo);
+        return(OK);
+    else
+        return(ERROR);
+    printf("%s: castcpStartUpdate\n", ppvt->instanceName);
+    if (ppvt->run) return(ERROR);
+    else return(OK);
Index: src/rsrv/cast_server.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/rsrv/cast_server.c,v
retrieving revision 1.78.2.9
diff -u -b -r1.78.2.9 cast_server.c
--- src/rsrv/cast_server.c	7 Dec 2006 19:55:08 -0000	1.78.2.9
+++ src/rsrv/cast_server.c	12 Nov 2007 18:22:33 -0000
@@ -30,6 +30,11 @@
  *  pend which could lock up the cast server.
+Oct.16,2007,Gongfa Liu  inactivate CAS-UDP task when the IOC is SLAVE.
 #include <stddef.h>
 #include <stdlib.h>
@@ -50,6 +55,8 @@
 #include "server.h"
 #include "rsrv.h"
 #define TIMEOUT 60.0 /* sec */
@@ -311,5 +318,6 @@
             cas_send_dg_msg (prsrv_cast_client);
             clean_addrq ();
Index: src/rsrv/online_notify.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/rsrv/online_notify.c,v
retrieving revision 1.57.2.12
diff -u -b -r1.57.2.12 online_notify.c
--- src/rsrv/online_notify.c	18 Nov 2006 00:29:04 -0000	1.57.2.12
+++ src/rsrv/online_notify.c	12 Nov 2007 18:22:33 -0000
@@ -19,6 +19,12 @@
+Oct.16,2007,Gongfa Liu  inactivate CAS-beacon task when the IOC is SLAVE.
 #include <stddef.h>
 #include <stdlib.h>
 #include <stdio.h>
@@ -38,6 +44,8 @@
 #define epicsExportSharedSymbols
 #include "server.h"
+extern int masterFlagForCAS; /* Added by Gongfa Liu */
  * forcePort ()
@@ -285,6 +293,9 @@
         beaconCounter++; /* expected to overflow */
Index: src/rsrv/rmtDrvIf.h
--- /dev/null	2007-11-05 13:05:14.280278523 -0600
+++ src/rsrv/rmtDrvIf.h	2007-11-01 08:22:16.000000000 -0500
@@ -0,0 +1,63 @@
+* Copyright (c) 2006 Stiftung Deutsches Elektronen-Synchrotron,
+* Member of the Helmholtz Association, (DESY), HAMBURG, GERMANY.
+* Redundancy IOC codes are distributed subject to a Software License Agreement
+* found in file LICENSE.txt that is included with this distribution.
+#ifndef INCLrmtDrvIfh  /* Include-file already inserted ?  */
+#define INCLrmtDrvIfh  /* defined macro flags insertion    */
+#ifndef vxWorks
+#define OK	0
+#define ERROR	-1
+typedef long	STATUS;
+#endif
+typedef enum {UPDATE_full, UPDATE_data} updateMode;
+typedef enum {MODE_stop, MODE_run, MODE_standby, MODE_test} modeType;
+typedef enum {TEST_undefined, TEST_ok, TEST_error, TEST_timeout, TEST_aborted} testResultType;
+typedef enum {NO_ERROR, WARNING_ERROR, INVALID_ERROR} errorType;
+typedef struct {
+	modeType mode;
+	testResultType testResult;
+	errorType error;
+	int updateBusy;	/* single update running */
+	int inSync;	/* 1 == up-to-date with updates */
+	int activeFlag;	/* set to TRUE by activity, cleared by getStatus() */
+} drvStatusType;
+/* special driver type for watchdog */
+#define               WATCHDOG        "WATCHDOG"
+typedef STATUS	(*RMTSUPFUN)();
+typedef void	(*RMTCALLBACK)(int, testResultType);
+typedef struct {
+	const char		*type;
+	unsigned short		testTimeTypical;
+	void			*pPrvt;
+	RMTSUPFUN		pStart;
+	RMTSUPFUN		pStop;
+	RMTSUPFUN		pTestIO;
+	RMTSUPFUN		pGetStatus;
+	RMTSUPFUN		pShutdown;
+	RMTSUPFUN		pGetInfo;
+	RMTSUPFUN		pGetUpdate;
+	RMTSUPFUN		pStartUpdate;
+	RMTSUPFUN		pStopUpdate;
+} rmtEntryTabType;
+typedef struct {
+	const char		*partnerIPPrivate;
+	short			preferredMaster;
+} rmtInfoTabType;
+STATUS  rmtRegister(rmtEntryTabType *prmtEntryTab,
+	const rmtInfoTabType **pprmtInfoTab);
+#endif			 /* end of insertions	*/
Re: Redundancy Patch: rsrv Andrew Johnson
Prev: Redundancy Patch: iocsh Andrew Johnson
Next: Redundancy Patch: makeBaseApp Andrew Johnson
Index: 2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Redundancy Patch: iocsh Andrew Johnson
Next: Re: Redundancy Patch: rsrv Andrew Johnson
