2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTYP field through the PV Gateway
To: Ralph Lange <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Fri, 9 Jan 2009 10:28:32 -0600
Hi Ralph,
On Friday 09 January 2009 03:55:19 Ralph Lange wrote:
> sorry for being smartass without looking at the code - I'm still on
> vacation, at home, without a full-size computer that would be able to
> run a reasonable editor or EPICS. The EPICS/CA code just doesn't fit
> onto my PDA screen....
No problem, sorry if I came across a little rudely.
> Does that mean that the CA client doesn't do anything special and doing
> a "caget XXX.RTYP" issues a value DBR type request?
Correct, attributes look just like a read-only DBF_STRING field to CA clients
or when read through a DBF_INLINK:
epics> dbpf anjHost:sin.INP anjHost:sin.RTYP
DBR_STRING:          "anjHost:sin.RTYP NPP NMS"
epics> dbpf anjHost:sin.PROC 1
DBR_UCHAR:          1         0x1
epics> dbgf anjHost:sin
DBR_STRING:          "stringin"
> Ernest: Why do you see a DBR_CLASS_NAME request at the Gateway, then?
If you use the "PV Info" menu item on MEDM, it does a ca_get() using
DBR_CLASS_NAME to display the record type in the resulting dialog box.
I think the original idea was that CA client programs should regard PV names
as black boxes and not try and replace the field name part in one, so the
record type was made available by adding the DBR_CLASS_NAME data type and
that's what MEDM used.  In practice though someone wanted to be able to use
the regular caget as DBF_STRING for this, so attributes and RTYP were added.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Re: RTYP field through the PV Gateway Andrew Johnson
Re: RTYP field through the PV Gateway Ralph Lange
Prev: Re: RTYP field through the PV Gateway Ernest L. Williams Jr.
Next: Re: makeBaseApp.pl Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Dates for a Codeathon at Brookhaven? Andrew Johnson
