2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Very slow reconnection to medm after IOC reboot
To: "'Mark Rivers'" <[email protected]>, "'Andrew Johnson'" <[email protected]>
Cc: "'Core-Talk'" <[email protected]>
Date: Mon, 9 Feb 2009 10:29:41 -0700
Mark,
Sifting my mail today. Sorry about delay responding. This is a side effect
of the fix for Mantis 302. I created, and closed out, Mantis 331. See the
diff below. The problem is only in R3.14.10 on Intel arch.
cvs diff -wb -- iocinf.cpp (in directory
C:\hill\R3.14.dll_hell_fix\epics\base\src\ca\)
Index: iocinf.cpp
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/ca/iocinf.cpp,v
retrieving revision 1.23.2.5
diff -u -b -w -b -r1.23.2.5 iocinf.cpp
--- iocinf.cpp	22 Sep 2008 18:20:56 -0000	1.23.2.5
+++ iocinf.cpp	9 Feb 2009 16:48:55 -0000
@@ -97,7 +97,7 @@
             continue;
-        if ( ignoreNonDefaultPort && addr.sin_port != port ) {
+        if ( ignoreNonDefaultPort && ntohs ( addr.sin_port ) != port ) {
             continue;
Jeff
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Wednesday, February 04, 2009 1:45 PM
> To: Jeff Hill; Andrew Johnson
> Cc: Core-Talk
> Jeff,
> I have now proven that there is a change in the behavior of the beacon
> address list from 3.14.8.2 to 3.14.10 on both Linux and Win32.  Linux
> and Win32 seem to behave identically, contrary to what I originally
> thought.
> On 3.14.10 if EPICS_CA_AUTO_ADDR_LIST=NO and EPICS_CA_ADDR_LIST is
> manually set (even to the same as the default would be if
> EPICS_CA_AUTO_ADDR_LIST were YES) then the beacon address list is empty.
> On 3.14.8.2 this is not the case, even if EPICS_CA_AUTO_ADDR_LIST=NO
> then a correct beacon address list is created.
> Here is the proof on a Linux system running 3.14.10:
> Here is what I get with EPICS_CA_ADDR_LIST and EPICS_CA_AUTO_ADDR_LIST
> undefined:
> epics> epicsPrtEnvParams
> EPICS_AR_PORT: 7002
> EPICS_CAS_AUTO_BEACON_ADDR_LIST is undefined
> EPICS_CAS_BEACON_ADDR_LIST is undefined
> EPICS_CAS_BEACON_PERIOD is undefined
> EPICS_CAS_BEACON_PORT is undefined
> EPICS_CAS_IGNORE_ADDR_LIST is undefined
> EPICS_CAS_INTF_ADDR_LIST is undefined
> EPICS_CAS_SERVER_PORT is undefined
> EPICS_CA_ADDR_LIST is undefined
> EPICS_CA_AUTO_ADDR_LIST: YES
> EPICS_CA_BEACON_PERIOD: 15.0
> EPICS_CA_CONN_TMO: 30.0
> EPICS_CA_MAX_ARRAY_BYTES: 10000000
> EPICS_CA_MAX_SEARCH_PERIOD: 300.0
> EPICS_CA_REPEATER_PORT: 5065
> EPICS_CA_SERVER_PORT: 5064
> EPICS_CMD_PROTO_PORT is undefined
> EPICS_IOC_LOG_FILE_COMMAND is undefined
> EPICS_IOC_LOG_FILE_LIMIT: 10000000
> EPICS_IOC_LOG_FILE_NAME: /home/epics/logs/IOC.log
> EPICS_IOC_LOG_INET is undefined
> EPICS_IOC_LOG_PORT: 7004
> EPICS_TIMEZONE: CUS::360:030902:110202
> EPICS_TS_NTP_INET is undefined
> IOCSH_HISTSIZE: 50
> IOCSH_PS1: epics>
> epics> casr 20
> There are currently 282784 bytes on the server's free list
> 6 client(s), 422 channel(s), 422 event(s) (monitors) 0 putNotify(s)
> 14 small buffers (16384 bytes ea), and 0 jumbo buffers (10000024 bytes
> ea)
> The server's resource id conversion table:
> Bucket entries in use = 90 bytes in use = 17844
> Bucket entries/hash id - mean = 0.021973 std dev = 0.146594 max = 1
> The server's array size limit is 10000024 bytes max
> Channel Access Address List
> 164.54.160.255:5065
> So that is fine the beacon Channel Access Address List is set to
> 164.54.160.255:5065, which is correct. Now here is what I get with
> EPICS_CA_AUTO_ADDR_LIST=NO and EPICS_CA_ADDR_LIST=164.54.160.255, i.e.
> the same as the default value if it is not manually set.
> EPICS_AR_PORT: 7002
> EPICS_CA_ADDR_LIST: 164.54.160.255
> EPICS_CA_AUTO_ADDR_LIST: NO
> IOCSH_HISTSIZE: 50
> IOCSH_PS1: epics>
> epics> casr 20
> ea)
> epics>
> So the Channel Access Address List is undefined if
> EPICS_CA_AUTO_ADDR_LIST is NO.
> This is definitely new behavior.  In this case no beacons are sent, and
> hence clients will be very slow to reconnect.
> Here is the output when I run a 3.14.8.2 IOC on the same Linux system
> with the same environment variable settings.
> epics> coreRelease
> ###  EPICS IOC CORE built on Oct  6 2008
> ###  EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
> EPICS_AR_PORT: 7002
> EPICS_TIMEZONE: CUS::360:040202:102902
> IOCSH_HISTSIZE: 50
> IOCSH_PS1: epics>
> epics> casr 20
> There are currently 285316 bytes on the server's free list
> 6 client(s), 443 channel(s), 443 event(s) (monitors) 0 putNotify(s)
> ea)
> Bucket entries in use = 69 bytes in use = 17508
> Bucket entries/hash id - mean = 0.016846 std dev = 0.128693 max = 1
> 164.54.160.255:5065
> So on 3.14.8.2 it builds a correct beacon address list, even if
> EPICS_CA_AUTO_ADDR_LIST=NO.
> Mark
RE: Very slow reconnection to medm after IOC reboot Mark Rivers
RE: Very slow reconnection to medm after IOC reboot Jeff Hill
Prev: EPICS role Phill Bateman
Next: RE: Very slow reconnection to medm after IOC reboot Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Very slow reconnection to medm after IOC reboot Mark Rivers
Next: EPICS role Phill Bateman
