2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Base 3.14.11 Release Timetable
To: "'Andrew Johnson'" <[email protected]>, <[email protected]>
Date: Tue, 10 Feb 2009 09:42:36 -0700
> I guess this is my first announcement of that timetable, does anyone have
> any comments?
Sounds ok, but I suspect that you are hoping that there is an implementation of the "client remembers what IOC it used to be connected to" change for that release? I reserve an option to whine depending on how cleanly that can be implemented :-). I could have a look at that and give you an estimate if you are interested.
It might also be interesting to implement an experimental 64 bit native windows build for this release.
Jeff
www.aps.anl.gov/epics/base/R3-14/10-docs/KnownProblems.html (which
> > lists another 5 patches) it begins to look like a 3.14.10.1 bug-fix
> release
> > could be a profitable move...
> Actually I'm working towards R3.14.11 next; the 4-digit releases generally
> mean that we fixed a major bug in the very-recently-released 3-digit one
> but
> added no new functionality.  CVS currently has a few new things in it so a
> 4-digit release is not appropriate.
> APS has a shutdown coming up in April/May, and if possible I'd like the
> release out by mid-April so we can upgrade our IOCs then.  This will have
> some interaction with the Codeathon, but I haven't worked out how yet.
> any
> comments?
> - Andrew
> The best FOSS code is written to be read by other humans -- Harold Welte
Re: Base 3.14.11 Release Timetable Andrew Johnson
Re: NTP issues with rtems 4.9 and EPICS R3.14.10 Benjamin Franksen
Prev: Re: Base 3.14.11 Release Timetable Benjamin Franksen
Next: Re: Base 3.14.11 Release Timetable Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Base 3.14.11 Release Timetable Andrew Johnson
