2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Bug in macLib
To: "Eric Norum" <[email protected]>, "Andrew Johnson" <[email protected]>
Cc: Core-Talk <[email protected]>
Date: Wed, 31 Mar 2010 08:43:19 -0500
Hi Eric,
I may be missing something, but this code actually looks OK to me.  Note
that valend is a pointer, not a counter.  So if valend actually points
to the last character in the buffer then the statement
            if ( v <= valend ) *v   = '\0';
should be OK, right?
But it's certainly possible that valend has not been set correctly, and
that it is pointing to one character past the end of the buffer.  I have
not looked into that.
-----Original Message-----
Sent: Tuesday, March 30, 2010 6:46 PM
To: Andrew Johnson
Cc: Mark Rivers; Core-Talk
Subject: Re: Bug in macLib
Hmm.....
Check the last 'if' statement in mcaCore.c: trans....
static void trans( MAC_HANDLE *handle, MAC_ENTRY *entry, int level,
                   const char *term, const char **rawval, char **value,
                   char *valend )
    char quote;
    const char *r;
    char *v;
    int discard;
    int macRef;
    /* return immediately if raw value is NULL */
    if ( *rawval == NULL ) return;
    /* discard quotes and escapes if level is > 0 (i.e. if these aren't
       the user's quotes and escapes) */
    discard = ( level > 0 );
    /* debug output */
    if ( handle->debug & 2 )
        printf( "trans-> entry = %p, level = %d, maxlen = %u, discard =
%s, "
        "rawval = %s\n", entry, level, (unsigned int)(valend - *value),
discard ? "T" : "F", *rawval );
    /* initially not in quotes */
    quote = 0;
    /* scan characters until hit terminator or end of string */
    for ( r = *rawval, v = *value; strchr( term, *r ) == NULL; r++ ) {
        /* handle quoted characters (quotes are discarded if in name) */
        if ( quote ) {
            if ( *r == quote ) {
                quote = 0;
                if ( discard ) continue;
        else if ( *r == '"' || *r == '\'' ) {
            quote = *r;
        /* macro reference if '$' followed by '(' or '{' */
        macRef = ( *r == '$' &&
                   *( r + 1 ) != '\0' &&
                   strchr( "({", *( r + 1 ) ) != NULL );
        /* macros are not expanded in single quotes */
        if ( macRef && quote != '\'' ) {
            /* Handle macro reference */
            refer ( handle, entry, level, &r, &v, valend );
        else {
            /* handle escaped characters (escape is discarded if in
name) */
            if ( *r == '\\' && *( r + 1 ) != '\0' ) {
                if ( v < valend && !discard ) *v++ = '\\';
                if ( v < valend ) *v++ = *++r;
            /* copy character to output */
            else {
                if ( v < valend ) *v++ = *r;
            /* ensure string remains properly terminated */
Eric Norum
[email protected]
Re: Bug in macLib Eric Norum
Bug in macLib Mark Rivers
Re: Bug in macLib Andrew Johnson
Prev: Re: Bug in macLib Eric Norum
Next: Re: Bug in macLib Eric Norum
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
