2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 541396] Re: initialize VAL of an mbbi/o record with a string
To: [email protected]
Date: Fri, 02 Apr 2010 16:13:58 -0000
** Also affects: epics-base/trunk
   Importance: Wishlist
     Assignee: Andrew Johnson (anj)
       Status: Triaged
https://bugs.launchpad.net/bugs/541396
You received this bug notification because you are a member of EPICS
Core Developers, which is a direct subscriber.
Status in EPICS Base: Triaged
Status in EPICS Base trunk series: Triaged
Bug description:
With the following record in a db file
record(mbbo,"TEST:mbbo") {
	field(VAL,"Zero")
	field(ZRST,"Zero")
	field(ONST,"One")
I get
dbLoadRecords("test.db", "")
Error   Last token ")"
input line:     field(VAL,"Zero")
   in: path "."  file test.db line 2
I think it would be nice to be able to initialize an mbbo or mbbi record with one of the configured string values.
Original Mantis Bug: mantis-373
    http://www.aps.anl.gov/epics/mantis/view_bug_page.php?f_id=373
Prev: Re: naming the operating system independence layer Ralph Lange
Next: RE: missing monitors Davidsaver, Michael
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Bug 541396] Re: initialize VAL of an mbbi/o record with a string Benjamin Franksen
Next: Bug in macLib Mark Rivers
