2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Bug in macLib
To: "Andrew Johnson" <[email protected]>, "Eric Norum" <[email protected]>
Cc: Core-Talk <[email protected]>
Date: Tue, 11 May 2010 15:35:06 -0500
Andrew,
This problem is serious for me, but it is not yet in the list of known
problems for 3.14.11, and there is no patch.  I want to release
areaDetector R1-6, but it has startup scripts with long input lines,
resulting in crashing due to this bug.
-----Original Message-----
Sent: Wednesday, March 31, 2010 10:53 AM
To: Eric Norum
Cc: Mark Rivers; Core-Talk
Subject: Re: Bug in macLib
On Wednesday 31 March 2010 08:58:28 Eric Norum wrote:
> > I may be missing something, but this code actually looks OK to me.
Note
> > that valend is a pointer, not a counter.  So if valend actually
points
> > to the last character in the buffer then the statement
> >            if ( v <= valend ) *v   = '\0';
> > should be OK, right?
> Nope.
> Despite its name, "valend" actually points to the location just past
the
> end of the buffer.
I'm convinced that the original intention was as Mark suggests, which is
obvious if you look at the two other calls to trans() which both
allocate
buffers of size maxlen+1.  Also two of the four functions that call
macExpandString() give it a maxlen value which is explicitly 1 less than
their
available buffer size.
Unfortunately the documentation (src/libCom/macLib/macLibREADME) doesn't
say
anything about the maxlen parameter, and this really doesn't follow the
C
standard, so I would be in favour of checking and changing the meaning
of the
maxlen argument to macExpandString() but *not* the valend pointer in
trans(),
which I believe is being used correctly in all cases.
Eric's proposed change to trans() is wrong, this code is pretty subtle
and
there are several other places in trans() which you'd have to change to
match.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: Bug in macLib Andrew Johnson
Re: Bug in macLib Eric Norum
Prev: Re: [Question #110395]: push fails? Ralph Lange
Next: Re: Bug in macLib Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Bug in macLib Andrew Johnson
