2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: some issues with "lp:epics-base" in bazaar
To: Jeff Hill <[email protected]>
Cc: "'EPICS Core Talk'" <[email protected]>
Date: Fri, 13 Aug 2010 17:09:10 -0500
On Friday 13 August 2010 16:26:27 Jeff Hill wrote:
> I found two significant bugs in base today, and if I fix them only on my
> cvs main trunk ancestor branch there is a risk that they will be lost when
> attempting to break that tree into independent merges. So I tried to
> refresh my existing R3.14 development area. That didn?t work so I threw out
> that one and tried to load a fresh one but there are still some issues.
> In any case when I try to download from the URL "lp:epics-base" using
> bazaar explorer I see the error message below. I think this worked before,
> but perhaps I am doing something stupid? In any case loading code from
> "https://code.launchpad.net/epics-base"; does work just fine.
> Invalid url supplied to transport:
> "file:///home/phoebus3/ANJ/epics/base/export/base.bzr/trunk/": Win32 file
> urls start with file:///x:/, where x is a valid drive letter
This is a known but benign problem with Bazaar explorer when you point it to a
lightweight checkout.  I reported it as a bug several months ago, see here:
  https://bugs.launchpad.net/bzr-explorer/+bug/550989
If you want to get rid of the message don't do a lightweight checkout.  I
think a regular checkout should be fine, but I do know for sure that a normal
branch is.  However you can just ignore the message if you have disk space
issues and prefer to stay lightweight.
BTW there is a known issue with the current 3.14 branch version that crept in
with the ca-over-tcp branch merge; it segfaults at shutdown of the client
library when the tcpSendThread tries to use an already dead mutex.  Ralph is
looking at that right now, so don't go chasing it yourself without checking
with him first.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
RE: some issues with "lp:epics-base" in bazaar Jeff Hill
Prev: some issues with "lp:epics-base" in bazaar Jeff Hill
Next: build error on R3.14 trunk Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: some issues with "lp:epics-base" in bazaar Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
