I'd go further. Until this test is OSI-ified it should be removed from the build!
Here's what happens when I remove the include of unistd.h:
make[3]: Entering directory `/usr/local/epics/src/base/devel/src/libCom/test/O.RTEMS-uC5282'
/usr/local/rtems/rtems-4.10/bin/m68k-rtems4.10-gcc --pipe -B/usr/local/rtems/rtems-4.10/m68k-rtems4.10/uC5282/lib/ -specs bsp_specs -qrtems -fasm -c -mcpu=5282 -DUNIX -O2 -g -g -Wall -DMY_DO_BOOTP=NULL -I. -I../O.Common -I. -I.. -I../../../../include/os/RTEMS -I../../../../include ../buckTest.c
../buckTest.c: In function 'buckTest':
../buckTest.c:75:9: warning: implicit declaration of function 'sysconf'
../buckTest.c:75:29: error: '_SC_CLK_TCK' undeclared (first use in this function)
../buckTest.c:75:29: note: each undeclared identifier is reported only once for each function it appears in
make[3]: *** [buckTest.o] Error 1
make[3]: Leaving directory `/usr/local/epics/src/base/devel/src/libCom/test/O.RTEMS-uC5282'
On Aug 13, 2010, at 3:49 PM, Andrew Johnson wrote:
> On Friday 13 August 2010 17:10:49 Jeff Hill wrote:
>> FWIW, I see the following error when building the R3.14 trunk on windows.
>> cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE
>> /D_CRT_NONST
>> DC_NO_DEPRECATE /Zi /RTCsu /W3 /w44355 /MDd -I.
>> -I..\\O.Common -I.
>> -I.. -I..\\..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\..\\include
>> buckTest.c
>> buckTest.c
>> ..\buckTest.c(12) : fatal error C1083: Cannot open include file:
>> 'unistd.h': No such file or directory
> I see from the log that unistd.h was added by Eric, apparently to get this to
> build on RTEMS 4.10, but when I remove it I see no errors or warnings with
> RTEMS 4.10 or 4.9.2. I am getting a load of *other* build failures with 4.10,
> but that's probably just our configuration here (which is evidently missing
> Eric's tender ministrations).
> I propose to delete unistd.h again from buckTest.c unless someone can explain
> why it's needed.
> - Andrew
> The best FOSS code is written to be read by other humans -- Harald Welte
Eric Norum
[email protected]
- Re: build error on R3.14 trunk Andrew Johnson
- build error on R3.14 trunk Jeff Hill
RE: some issues with "lp:epics-base" in bazaar Jeff Hill
<2010>
2025
<2010>
2025
