Hi all.Since the beginning of this year we have random crashes of the tNet task in one of our new IOCs. We do not get any help from Wind River.We are going to get a WRS specialist to DESY to help us set up the IOC to enable us tracing back the problem when the next crash occurs. I have my doubts that this will happen soon and that we can set it up with our IOCs where the shell is still running locally ... we'll see. Meanwhile I hope to get some ideas from you.Since the Net task is down we can only use the local console with VGS output. Therefore I have real screen shots taken with my camera.You can find the page fault info and the tt output in the two jpg files attached. (also the lkAddr and the checkStack output)There's more information about the individual memory locations but I do not want to fill your mailbox with my garbage. In case you might have an idea an more debug information would help - let me know there's more information available. For now we have no clue what could be the root cause.We have two IOCs running with the same vxWorks image one of them is more heavily loaded then the other - where heavy means 20% CPU instead of 15%. The two CPUs are compact PCI CPUs from Kontron in Germany vxWorks image based on version 6.7 Craches happen at intervals between a week and two months. Our plans:- Get a WRS specialist to help us set up the IOC to catch the root cause and trace it back - Install a PC with wireshark and monitor the traffic to disk- analyze the Ethernet traffic and filter out any -non IP- traffic to the IOC by setting up filters in the Cisco router before the IOC Any other idea? Of course any help is highly appreciated. Cheers Matthias Attachment:
tNet0-TaskTrace.JPG Attachment:
tNet0-PageFault.JPG Attachment:
lkAddr-0x0039d09e.JPG Attachment:
ANJ, 02 Feb 2012 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
