On 28.10.2010 18:59, Ben Franksen wrote:
Regarding the choice of which task will get the semahore if more than
one is waiting, I will for now assume that this is (intentionally) left
unspecified. This means I will have to implement FIFO order on top of
epicsEvent. The only other solution would be to extend the interface
with another constructor and then implement FIFO order *inside*
epicsEvent for those systems that do not support that natively (which
is what you wrote above, so maybe you *did* get the point I was trying
to make and I didn't get yours. Whatever ;-).
My current idea is to wait for your FIFO implementation and then see if
that can be moved into epicsEvent... ;-)
Ralph
- Re: epicsEvent Ralph Lange
- Re: epicsEvent Ben Franksen
RTEMS tests -- epicsThreadOnce broken? Eric Norum
Re: RTEMS tests -- epicsThreadOnce broken? Andrew Johnson
<2010>
2025
Re: epicsEvent Eric Norum
<2010>
2025
