On Friday 29 October 2010 11:12:25 you wrote:
> BTW -- when you make the change to extend the sleep in the epicsThreadOnce
> test will you add the test I added for epicsEvent semantic tests to
> epicsEventTest.cpp and the appDevGuide? Or is that too big for now -- and
> will be in 3.15?
Adding tests to a -pre release is fine as long as they're supposed to pass;
I've not actually looked at your patch yet though. You forgot to attach the
appdev patch to that message.
> Thanks for the epicsThreadOnce test fix!
I think I'll actually fix it with the additional epicsEventSignal() and
epicsEventMustWait() which I've just written:
=== modified file 'src/libCom/test/epicsThreadOnceTest.c'
--- src/libCom/test/epicsThreadOnceTest.c 2010-10-05 19:27:37 +0000
+++ src/libCom/test/epicsThreadOnceTest.c 2010-10-29 16:19:13 +0000
@@ -22,6 +22,7 @@
epicsThreadOnceId twiceFlag = EPICS_THREAD_ONCE_INIT;
epicsMutexId lock;
epicsEventId go;
+epicsEventId done;
int runCount = 0;
int initCount = 0;
@@ -49,6 +50,8 @@
epicsMutexMustLock(lock);
doneCount++;
+ if (doneCount == runCount)
+ epicsEventSignal(done);
epicsMutexUnlock(lock);
@@ -79,6 +82,7 @@
testPlan(3 + NUM_ONCE_THREADS);
go = epicsEventMustCreate(epicsEventEmpty);
+ done = epicsEventMustCreate(epicsEventEmpty);
lock = epicsMutexMustCreate();
for (i = 0; i < NUM_ONCE_THREADS; i++) {
@@ -93,11 +97,12 @@
testOk(runCount == NUM_ONCE_THREADS, "runCount = %d", runCount);
epicsEventSignal(go);
- epicsThreadSleep(0.1);
+ epicsEventMustWait(done);
testOk(doneCount == NUM_ONCE_THREADS, "doneCount = %d", doneCount);
testDiag("init was run by %s", initBy);
+ testDiag("Expecting thread recurse to suspend:");
tid = epicsThreadCreate("recurse", epicsThreadPriorityMedium,
epicsThreadGetStackSize(epicsThreadStackSmall),
recurseThread, 0);
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
Re: RTEMS tests -- epicsThreadOnce broken? Eric Norum
epicsEvent semantics Eric Norum
<2010>
2025
<2010>
2025
