2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Two CA client questions
To: "Jeff Hill" <[email protected]>
Cc: [email protected]
Date: Sun, 14 Nov 2010 22:47:26 +0100
Hi Jeff
I have two technical CA (client) questions.
(1) The sequencer currently employs an "auxiliary task" which performs
no work other than calling
  ca_pend_event(10.0)
in an endless loop. Note that the context is created with
ca_enable_preemptive_callback.
I would be glad if I could get rid of this extra task, as I believe it
is not necessary, but before I throw it out I'd rather make sure that
there are no unwanted side-effects. Could such a task perhaps improve
latency in certain situations? A comment in the code says this allows
for connect/disconnect event processing, and it gets started with a
slightly higher priority than the regular sequencer tasks. It is quite
possible that the comment is out-dated, or just plain wrong.
(2) If I create a context (with ca_enable_preemptive_callback) in one
task, then attach to this context in another task, then delete the
first task without destroying the context. Does the second one continue
to work with the same context? In other words, is the task that created
the context in any way "privileged" over tasks that merely attach to an
existing context? I think not, but I want to be sure.
Cheers
Ben
"Never confuse what is natural with what is habitual."
                                   -- attributed to Mahatma Gandhi
RE: Two CA client questions Jeff Hill
Prev: Patch to subArray record Michael Abbott
Next: RE: Two CA client questions Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
