2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: src/ reorganization
To: "Andrew Johnson" <[email protected]>, <[email protected]>
Date: Fri, 17 Dec 2010 13:33:21 -0500
Ignore the previous.  I was having difficulty seeing how to fold asHost
into libCom since it depends on antelope, which uses libCom.  However,
it should be possible to link the relevant objects directly into the
antelope and flex binaries.
> -----Original Message-----
> From: Davidsaver, Michael
> Sent: Friday, December 17, 2010 12:33 PM
> To: Davidsaver, Michael; Andrew Johnson; [email protected]
> Andrew,
> > = split up src/ioc/as
> > asDbLib going to src/ioc/db and the asLib files to src/libCom/as.
> Did you intend that the libraries should be renamed as well?  Because
> of this split IOCs would link against libasHost.  So perhaps 'asHost'
> becomes just 'as' and 'asIoc' becomes 'asDb'?  And, how about
something
> longer then 'as'?  A quick google search doesn't find other uses, but
> perhaps 'libepicsAs' and 'libepicsAsDb' would be better?  Then again
we
> are using 'libdb' so maybe this isn't so important.
> Michael
src/ reorganization Davidsaver, Michael
RE: src/ reorganization Davidsaver, Michael
Re: src/ reorganization Andrew Johnson
Prev: RE: src/ reorganization Davidsaver, Michael
Next: Re: src/ reorganization Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
