2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base
Date: Thu, 03 Mar 2011 23:13:08 -0000
> My version of this reorg branch is at lp:~anj/epics-base/reorg-src for you to
> look at.  I did include a few more changes, generating a stdRecords.dbd file
> in std/rec/Makefile is one obvious DRY improvement.
Ok, looks fine, so I've replaced my origin branch with yours.
The diff on the merge request page seems to be confused, but from looking at the branch page directly, I think I pushed the correct version.
https://code.launchpad.net/~mdavidsaver/epics-base/reorg-src/+merge/44296
Your team EPICS Core Developers is requested to review the proposed merge of lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base.
Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base Andrew Johnson
Prev: Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base Andrew Johnson
Next: Fwd: C++ compatibility Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base Andrew Johnson
