2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: class library header file naming and install conventions
To: [email protected]
Date: Tue, 15 Mar 2011 09:55:24 -0600
On Monday 14 March 2011 18:11:03 Jeff Hill wrote:
> o The C++ namespace is pdq (class lib names must be all lower case letters)
> o The master header file's name is pdq.h
> o Each exported class named Xxxx has a header file named pdq/Xxxx.h
> o The master header file has '#include "pdq/Xxxx.h"' for each exported
> class
> o The pdq.h is installed to $(EPICS_BASE)/include/pdq.h
> o The pdq/Xxxx.h are installed to $(EPICS_BASE)/include/pdq/Xxxx.h
Actually those should be $(INSTALL_LOCATION)/include/... since we do support
installation outside of the Base tree if so configured.
> o The build system appears to implement this type of install now if, in the
> build area, one has something like src/pdq/lib/pdq which contains the
> header files (where they are installed from). Is that what we want? That
> (redundant pdq in the path) could be initially somewhat confusing to the
> uninitiated, and I don't see any reason to place the header files in a
> subdirectory other than to avoid changing the build system?
Using the new build layout in lp:~mdavidsaver/epics-base/reorg-src all the
source and header files for the module would be in src/<something>/pdq with a
master Makefile in src/<something> that pulls in a Makefile fragment from
src/<something>/pdq thus the pdq in the path is not redundant.  Note that
<something> can have multiple path components.
> o The c/c++ files are named src/pdq/lib/Xxxx.cpp
Like Ralph I don't see the purpose of the 'lib' part and it would actually
break the new build layout.
> o The documentation master goes in src/pdq/doc/pdq.html
> o Maybe the class interface documentation goes in src/pdq/doc/pdq/Xxxx.html
> (same concerns about redundant pdq in the path)
The documentation master should be with the source code in src/<something>/pdq
from where (if it's included in the HTMLS variable) the current build system
can install it into $(INSTALL_LOCATION)/html or I believe into a sub-directory
named in the HTMLS_DIR variable, or (if it's included in the DOCS variable)
into the $(INSTALL_LOCATION)/doc directory.
As Ralph said, documentation should be installed (see the INSTALL_LOCATION
point above).  I would encourage considering the use of a standard tool like
doxygen, I think once you start writing in-line documentation it should make
future maintenance easier, although I've rarely used it myself because
introducing it after-the-fact is hard.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
RE: class library header file naming and install conventions Jeff Hill
Prev: Re: class library header file naming and install conventions Ralph Lange
Next: RE: class library header file naming and install conventions Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: class library header file naming and install conventions Jeff Hill
