2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: os independent interface to socket sendmsg/recvmsg
To: Michael Davidsaver <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Tue, 15 Mar 2011 14:04:54 -0700
Once upon a time I had a look at building the libboost package (which I believe asio needs) for RTEMS.
I ran aground trying to get the libboost and RTEMS build systems to play together.
If you've had success with this it would be great to get it folded back into the RTEMS or libboost distribution.
On Mar 15, 2011, at 12:55 PM, Andrew Johnson wrote:
> On Tuesday 15 March 2011 09:42:22 Michael Davidsaver wrote:
>> http://think-async.com/Asio/AsioAndBoostAsio
>>> and perhaps people might complain that there is another
>>> component to install,
>> 1) ASIO is headers only
>>>  and of course we would need to see if boost is really
>>> portable to the many different CPU architectures in embedded systems.
>> There is nothing intrinsically architecture specific about socket
>> operations.  It is mostly a function of compiler support.
> Looks interesting, have you tried building with it for RTEMS or vxWorks?
> - Andrew
> An error is only a mistake if you don't learn from it.
> When you learn something from it, it becomes a lesson.
Eric Norum
[email protected]
Re: os independent interface to socket sendmsg/recvmsg Andrew Johnson
os independent interface to socket sendmsg/recvmsg Jeff Hill
Prev: Re: class library header file naming and install conventions Bruce Hill
Next: Re: os independent interface to socket sendmsg/recvmsg Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: os independent interface to socket sendmsg/recvmsg Andrew Johnson
