2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: launchpad and proxied web access
To: EPICS Core Talk <[email protected]>
Date: Wed, 16 Mar 2011 10:41:25 +0100
On 16.03.2011 01:22 Jeff Hill wrote:
Launchpad is pretty slow, taking maybe half an hour or so, creating a branch
here. I'm suspecting that this is related to the LANL firewall - see message
below. Any suggestions?
Run command: bzr branch
http://bazaar.launchpad.net/~epics-core/epics-base/3.15/
/hill/epicsInBazaar/3.15-ca-ref-man-maint/trunk --use-exis...
Got a 200 response when asking for multiple ranges, does your server at
proxyout.lanl.gov:8080 support range requests?
From HZB (no incoming proxy, via http):
> time bzr branch http://bazaar.launchpad.net/~epics-core/epics-base/3.15/
Branched 12221 revision(s).
bzr branch   62.06s user 1.40s system 60% cpu 1:44.10 total
From HZB (no incoming proxy, via ssh):
> time bzr branch bzr+ssh://[email protected]/~epics-core/epics-base/3.15/
bzr branch   41.54s user 1.36s system 58% cpu 1:12.84 total
From BNL (incoming proxy, via ssh, as http does not work through their proxy):
bzr branch   24.35s user 1.53s system 41% cpu 1:02.67 total
Did you try bzr+ssh transport? Seems to be faster.
~Ralph
launchpad and proxied web access Jeff Hill
Prev: RE: launchpad and proxied web access Jeff Hill
Next: ASIO and RTEMS Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: [Merge] lp:~johill-lanl/epics-base/ca-ref-man-maint into lp:epics-base Jeff Hill
