Subject: |
Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base |
Andrew Johnson <[email protected]> |
To: |
Jeff Hill <[email protected]> |
Date: |
Thu, 01 Sep 2011 18:34:00 -0000 |
Review: Needs Fixing
Hi Jeff,
Unfortunately this branch cannot be merged easily. The src/libCom/osi/compiler directory and all of its contents here do not share a history with their equivalents in the compiler-specific branch which I just merged. This is the commit revid that did the mkdir operation here:
revid:[email protected]
This is the revid from the compiler-specific branch:
As a result, Bazaar thinks they are separate directories and won't merge the file contents. You can't play fast-and-loose with this kind of thing like we did with CVS; if you don't follow its rules you don't get to use its nice features.
I can merge the atomics code by losing all your commit history on this branch, but your epicsThreadOnce-atomics-based branch will have similar difficulties since it's based off this branch. I suggest you stop further development until we've worked out how to proceed.
- Andrew
https://code.launchpad.net/~epics-core/epics-base/epicsR3.15-atomics/+merge/73613
Your team EPICS Core Developers is subscribed to branch lp:~epics-core/epics-base/3.15-buildCompilerSpecific.
- [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
[Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base noreply
Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Andrew Johnson
<2011>
2025
Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
<2011>
2025
