Hi Benjamin,
On 2011-11-25 Benjamin Franksen wrote:
> Compiling this under windows gives a link error 'symbol dbBptNotMonotonic
> not defined'. See https://bugs.launchpad.net/bugs/894276. The solution is
> to properly declare this variable in a header file (dbStaticLib.h) with
> epicsShareExtern (is the cleaner solution anyway). A patch for this fix is
> attached. It solves the problem on Windows for me (32bit VM).
I applied an equivalent patch (I hadn't committed your original change
verbatim so it needed a slightly different fix) and tested on Mingw, Cygwin
and Win32. The change has been committed to LP.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- EPICS Base 3.14.12.2-pre1 available for testing Andrew Johnson
- Re: EPICS Base 3.14.12.2-pre1 available for testing Andrew Johnson
- Re: EPICS Base 3.14.12.2-pre1 available for testing Benjamin Franksen
EPICS Contract Position - Please alert your subscribers. Ken Reed
<2011>
2025
Contribtions for R3.14.12.2-rc1 Andrew Johnson
<2011>
2025
