2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Merge] lp:~anj/epics-base/remove-hpux-artifacts into lp:epics-base
To: [email protected], Jeff Hill <[email protected]>
Date: Thu, 12 Apr 2012 17:47:18 -0000
Andrew Johnson has proposed merging lp:~anj/epics-base/remove-hpux-artifacts into lp:epics-base.
Requested reviews:
  Jeff Hill (johill-lanl)
For more details, see:
https://code.launchpad.net/~anj/epics-base/remove-hpux-artifacts/+merge/101785
Jeff,
Please review these changes, which I'd like to merge into the 3.15 branch.  I don't think you'll have any problem with them, but I'd like your OK before I go ahead.
- Andrew
This branch removes various things that were added for HPUX-specific reasons.  Since we don't support HPUX any more they are no longer needed.
 * Comments in the form // X aCC <number>
 * The filterWarnings.pl script
 * Unnecessary return statements inside HP-specific #if ... #endif blocks
 * Many operator new(size_t) methods that just threw an exception
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
=== modified file 'documentation/README.1st'
--- documentation/README.1st	2011-10-28 23:27:50 +0000
+++ documentation/README.1st	2012-04-12 17:46:27 +0000
@@ -272,7 +272,6 @@
          cvsclean.pl             Remove all .#* files in directory tree
          dos2unix.pl             Converts text file from DOS CR/LF to unix ISO
          expandvars.pl           Tool to expand @VAR@ variables while copying a file
-         filterWarnings.pl       Filters warning messages during HP builds
          fullpathName.pl         Returns fullpath name of directory arg
          installEpics.pl         Installs built files into install directories
          makeIncludeDbd.pl       Creates *Include.dbd file from filename args files
=== modified file 'documentation/README.html'
--- documentation/README.html	2011-10-28 23:27:50 +0000
+++ documentation/README.html	2012-04-12 17:46:27 +0000
@@ -284,7 +284,6 @@
=== modified file 'src/ca/client/CASG.cpp'
--- src/ca/client/CASG.cpp	2010-08-10 21:05:46 +0000
+++ src/ca/client/CASG.cpp	2012-04-12 17:46:27 +0000
@@ -295,13 +295,6 @@
-void * CASG::operator new ( size_t ) // X aCC 361
-    // The HPUX compiler seems to require this even though no code
-    // calls it directly
-    throw std::logic_error ( "why is the compiler calling private operator new" );
 void CASG::operator delete ( void * )
     // Visual C++ .net appears to require operator delete if
=== modified file 'src/ca/client/access.cpp'
--- src/ca/client/access.cpp	2009-08-14 19:12:50 +0000
+++ src/ca/client/access.cpp	2012-04-12 17:46:27 +0000
@@ -433,7 +433,7 @@
 // extern "C"
-int epicsShareAPI ca_pend ( ca_real timeout, int early ) // X aCC 361
+int epicsShareAPI ca_pend ( ca_real timeout, int early )
     if ( early ) {
         return ca_pend_io ( timeout );
@@ -516,7 +516,7 @@
  *  CA_TEST_IO ()
-int epicsShareAPI ca_test_io () // X aCC 361
+int epicsShareAPI ca_test_io ()
     ca_client_context *pcac;
     int caStatus = fetchClientContext ( &pcac );
@@ -551,7 +551,7 @@
  * (if they call this routine again).
 // extern "C"
-const char * epicsShareAPI ca_message ( long ca_status ) // X aCC 361
+const char * epicsShareAPI ca_message ( long ca_status )
     unsigned msgNo = CA_EXTRACT_MSG_NO ( ca_status );
=== modified file 'src/ca/client/bhe.cpp'
--- src/ca/client/bhe.cpp	2010-11-04 16:19:54 +0000
+++ src/ca/client/bhe.cpp	2012-04-12 17:46:27 +0000
@@ -332,13 +332,6 @@
-void * bhe::operator new ( size_t ) // X aCC 361
 void bhe::operator delete ( void * )
=== modified file 'src/ca/client/bhe.h'
--- src/ca/client/bhe.h	2010-11-04 16:19:54 +0000
+++ src/ca/client/bhe.h	2012-04-12 17:46:27 +0000
@@ -87,7 +87,6 @@
                      const epicsTime & currentTime );
 	bhe ( const bhe & );
 	bhe & operator = ( const bhe & );
-    void * operator new ( size_t size );
     epicsShareFunc void operator delete ( void * );
=== modified file 'src/ca/client/ca_client_context.cpp'
--- src/ca/client/ca_client_context.cpp	2010-08-10 21:05:46 +0000
+++ src/ca/client/ca_client_context.cpp	2012-04-12 17:46:27 +0000
@@ -106,7 +106,7 @@
         osiSockIoctl_t yes = true;
-        int status = socket_ioctl ( this->sock, // X aCC 392
+        int status = socket_ioctl ( this->sock,
                                     FIONBIO, & yes);
         if ( status < 0 ) {
             char sockErrBuf[64];
@@ -126,7 +126,7 @@
         memset ( (char *)&addr, 0 , sizeof ( addr ) );
         addr.ia.sin_family = AF_INET;
         addr.ia.sin_addr.s_addr = htonl ( INADDR_ANY );
-        addr.ia.sin_port = htons ( PORT_ANY ); // X aCC 818
+        addr.ia.sin_port = htons ( PORT_ANY );
         int status = bind (this->sock, &addr.sa, sizeof (addr) );
         if ( status < 0 ) {
@@ -277,7 +277,7 @@
 int ca_client_context :: varArgsPrintFormated (
-    const char *pformat, va_list args ) const // X aCC 361
+    const char *pformat, va_list args ) const
     caPrintfFunc * pFunc;
=== modified file 'src/ca/client/cac.cpp'
--- src/ca/client/cac.cpp	2010-08-23 20:17:16 +0000
+++ src/ca/client/cac.cpp	2012-04-12 17:46:27 +0000
@@ -568,7 +568,7 @@
 void cac::transferChanToVirtCircuit (
-    unsigned cid, unsigned sid, // X aCC 431
+    unsigned cid, unsigned sid,
     ca_uint16_t typeCode, arrayElementCount count,
     unsigned minorVersionNumber, const osiSockAddr & addr,
@@ -787,7 +787,7 @@
 netSubscription & cac::subscriptionRequest (
     epicsGuard < epicsMutex > & guard,
     nciu & chan, privateInterfaceForIO & privChan,
-    unsigned type, // X aCC 361
+    unsigned type,
     arrayElementCount nElem, unsigned mask,
     cacStateNotify & notifyIn,
     bool chanIsInstalled )
@@ -1021,7 +1021,7 @@
 bool cac::writeExcep (
-    callbackManager & mgr, // X aCC 431
+    callbackManager & mgr,
     tcpiiu &, const caHdrLargeArray & hdr,
     const char * pCtx, unsigned status )
@@ -1093,7 +1093,7 @@
 bool cac::accessRightsRespAction (
-    callbackManager & mgr, tcpiiu &, // X aCC 431
+    callbackManager & mgr, tcpiiu &,
     const epicsTime &, const caHdrLargeArray & hdr, void * /* pMsgBody */ )
     epicsGuard < epicsMutex > guard ( this->mutex );
@@ -1110,7 +1110,7 @@
 bool cac::createChannelRespAction (
-    callbackManager & mgr, tcpiiu & iiu, // X aCC 431
+    callbackManager & mgr, tcpiiu & iiu,
@@ -1157,7 +1157,7 @@
 void cac::disconnectChannel (
-        epicsGuard < epicsMutex > & cbGuard, // X aCC 431
+        epicsGuard < epicsMutex > & cbGuard,
         epicsGuard < epicsMutex > & guard, nciu & chan )
     guard.assertIdenticalMutex ( this->mutex );
=== modified file 'src/ca/client/cac.h'
--- src/ca/client/cac.h	2011-06-01 22:22:12 +0000
+++ src/ca/client/cac.h	2012-04-12 17:46:27 +0000
@@ -55,7 +55,7 @@
 // used to control access to cac's recycle routines which
 // should only be indirectly invoked by CAC when its lock
 // is applied
-class cacRecycle {              // X aCC 655
+class cacRecycle {
 public:
     virtual void recycleReadNotifyIO (
         epicsGuard < epicsMutex > &, netReadNotifyIO &io ) = 0;
=== modified file 'src/ca/client/cacIO.h'
--- src/ca/client/cacIO.h	2009-02-11 00:50:28 +0000
+++ src/ca/client/cacIO.h	2012-04-12 17:46:27 +0000
@@ -69,7 +69,7 @@
 // 1) this should not be passing caerr.h status to the exception callback
 // 2) needless-to-say the data should be passed here using the new data access API
-class epicsShareClass cacWriteNotify { // X aCC 655
+class epicsShareClass cacWriteNotify {
 public:
     virtual ~cacWriteNotify () = 0;
     virtual void completion ( epicsGuard < epicsMutex > & ) = 0;
@@ -82,7 +82,7 @@
-class epicsShareClass cacReadNotify { // X aCC 655
+class epicsShareClass cacReadNotify {
 public:
     virtual ~cacReadNotify () = 0;
@@ -97,7 +97,7 @@
-class epicsShareClass cacStateNotify { // X aCC 655
+class epicsShareClass cacStateNotify {
 public:
     virtual ~cacStateNotify () = 0;
     virtual void current (
@@ -131,7 +131,7 @@
     bool f_operatorConfirmationRequest:1;
-class epicsShareClass cacChannelNotify { // X aCC 655
+class epicsShareClass cacChannelNotify {
 public:
     virtual ~cacChannelNotify () = 0;
     virtual void connectNotify ( epicsGuard < epicsMutex > & ) = 0;
@@ -258,7 +258,7 @@
 	cacChannel & operator = ( const cacChannel & );
-class epicsShareClass cacContext { // X aCC 655
+class epicsShareClass cacContext {
 public:
     virtual ~cacContext ();
     virtual cacChannel & createChannel (
@@ -277,7 +277,7 @@
         epicsGuard < epicsMutex > &, unsigned level ) const = 0;
-class epicsShareClass cacContextNotify { // X aCC 655
+class epicsShareClass cacContextNotify {
 public:
     virtual ~cacContextNotify () = 0;
     virtual cacContext & createNetworkContext (
@@ -297,7 +297,7 @@
 // **** Lock Hierarchy ****
 // callbackControl must be taken before mutualExclusion if both are held at
 // the same time
-class epicsShareClass cacService { // X aCC 655
+class epicsShareClass cacService {
 public:
     virtual ~cacService () = 0;
     virtual cacContext & contextCreate (
=== modified file 'src/ca/client/casw.cpp'
--- src/ca/client/casw.cpp	2006-11-18 00:42:32 +0000
+++ src/ca/client/casw.cpp	2012-04-12 17:46:27 +0000
@@ -131,7 +131,7 @@
-    status = socket_ioctl ( sock, FIONBIO, &yes ); // X aCC 392
+    status = socket_ioctl ( sock, FIONBIO, &yes );
     if ( status < 0 ) {
         epicsSocketConvertErrnoToString (
@@ -166,7 +166,7 @@
     osiSockIoctl_t no = false;
-    status = socket_ioctl ( sock, FIONBIO, &no ); // X aCC 392
+    status = socket_ioctl ( sock, FIONBIO, &no );
     if ( status < 0 ) {
=== modified file 'src/ca/client/comBuf.h'
--- src/ca/client/comBuf.h	2008-10-02 15:43:04 +0000
+++ src/ca/client/comBuf.h	2012-04-12 17:46:27 +0000
@@ -44,7 +44,7 @@
     virtual void release ( void * ) = 0;
-class wireSendAdapter { // X aCC 655
+class wireSendAdapter {
 public:
     virtual unsigned sendBytes ( const void * pBuf,
         unsigned nBytesInBuf,
@@ -65,7 +65,7 @@
     swioCircuitState circuitState;
-class wireRecvAdapter { // X aCC 655
+class wireRecvAdapter {
 public:
     virtual void recvBytes ( void * pBuf,
         unsigned nBytesInBuf, statusWireIO & ) = 0;
@@ -114,7 +114,6 @@
     unsigned nextWriteIndex;
     unsigned nextReadIndex;
     epicsUInt8 buf [ comBufSize ];
     template < class T >
     bool push ( const T * ); // disabled
=== modified file 'src/ca/client/comQueRecv.cpp'
--- src/ca/client/comQueRecv.cpp	2009-07-07 23:47:38 +0000
+++ src/ca/client/comQueRecv.cpp	2012-04-12 17:46:27 +0000
@@ -155,7 +155,7 @@
         unsigned byte3 = this->popUInt8();
         unsigned byte4 = this->popUInt8();
         tmp = static_cast <epicsUInt32>
-            ( ( byte1 << 24u ) | ( byte2 << 16u ) | //X aCC 392
+            ( ( byte1 << 24u ) | ( byte2 << 16u ) |
               ( byte3 << 8u ) | byte4 );
     else {
=== modified file 'src/ca/client/comQueSend.cpp'
--- src/ca/client/comQueSend.cpp	2008-10-02 15:43:04 +0000
+++ src/ca/client/comQueSend.cpp	2012-04-12 17:46:27 +0000
@@ -368,7 +368,7 @@
         // the above checks verify that the total size
         // is lest that 0xffffffff
         size = static_cast < ca_uint32_t >
-            ( dbr_size_n ( dataType, nElem ) ); // X aCC 392
+            ( dbr_size_n ( dataType, nElem ) );
         payloadSize = CA_MESSAGE_ALIGN ( size );
         this->insertRequestHeader ( request, payloadSize,
             static_cast <ca_uint16_t> ( dataType ),
=== modified file 'src/ca/client/disconnectGovernorTimer.cpp'
--- src/ca/client/disconnectGovernorTimer.cpp	2009-08-10 21:51:07 +0000
+++ src/ca/client/disconnectGovernorTimer.cpp	2012-04-12 17:46:27 +0000
@@ -65,7 +65,7 @@
 epicsTimerNotify::expireStatus disconnectGovernorTimer::expire (
-    const epicsTime & /* currentTime */ ) // X aCC 361
+    const epicsTime & /* currentTime */ )
     while ( nciu * pChan = chanList.get () ) {
=== modified file 'src/ca/client/disconnectGovernorTimer.h'
--- src/ca/client/disconnectGovernorTimer.h	2005-09-13 13:41:46 +0000
+++ src/ca/client/disconnectGovernorTimer.h	2012-04-12 17:46:27 +0000
@@ -43,7 +43,7 @@
 #include "caProto.h"
 #include "netiiu.h"
-class disconnectGovernorNotify { // X aCC 655
+class disconnectGovernorNotify {
 public:
     virtual ~disconnectGovernorNotify () = 0;
     virtual void govExpireNotify (
=== modified file 'src/ca/client/getCallback.cpp'
--- src/ca/client/getCallback.cpp	2009-08-13 22:43:21 +0000
+++ src/ca/client/getCallback.cpp	2012-04-12 17:46:27 +0000
@@ -90,13 +90,6 @@
-void * getCallback::operator new ( size_t ) // X aCC 361
 void getCallback::operator delete ( void * )
=== modified file 'src/ca/client/getCopy.cpp'
--- src/ca/client/getCopy.cpp	2009-08-13 22:46:47 +0000
+++ src/ca/client/getCopy.cpp	2012-04-12 17:46:27 +0000
@@ -105,13 +105,6 @@
-void * getCopy::operator new ( size_t ) // X aCC 361
 void getCopy::operator delete ( void * )
=== modified file 'src/ca/client/iocinf.cpp'
--- src/ca/client/iocinf.cpp	2010-08-10 21:05:46 +0000
+++ src/ca/client/iocinf.cpp	2012-04-12 17:46:27 +0000
@@ -133,7 +133,7 @@
         if ( pNode->addr.sa.sa_family == AF_INET ) {
-            pTmpNode = (osiSockAddrNode *) ellFirst (pDestList);    // X aCC 749
+            pTmpNode = (osiSockAddrNode *) ellFirst (pDestList);
             while ( pTmpNode ) {
                 if (pTmpNode->addr.sa.sa_family == AF_INET) {
                     if ( pNode->addr.ia.sin_addr.s_addr == pTmpNode->addr.ia.sin_addr.s_addr &&
@@ -149,7 +149,7 @@
                         break;
-                pTmpNode = (osiSockAddrNode *) ellNext (&pTmpNode->node); // X aCC 749
+                pTmpNode = (osiSockAddrNode *) ellNext (&pTmpNode->node);
             if (pNode) {
                 ellAdd (pDestList, &pNode->node);
@@ -168,12 +168,12 @@
     osiSockAddrNode *pNode;
-    pNode  = ( osiSockAddrNode * ) ellFirst ( pList );          // X aCC 749
+    pNode  = ( osiSockAddrNode * ) ellFirst ( pList );
     while ( pNode ) {
             pNode->addr.ia.sin_port = htons ( port );
-        pNode = ( osiSockAddrNode * ) ellNext ( &pNode->node ); // X aCC 749
+        pNode = ( osiSockAddrNode * ) ellNext ( &pNode->node );
@@ -192,9 +192,9 @@
      * dont load the list twice
-    assert ( ellCount (pList) == 0 ); // X aCC 392
+    assert ( ellCount (pList) == 0 );
-    ellInit ( &tmpList );             // X aCC 392
+    ellInit ( &tmpList );
      * Check to see if the user has disabled
@@ -217,12 +217,12 @@
     if (yes) {
 		ELLLIST bcastList;
         osiSockAddr addr;
-		ellInit ( &bcastList ); // X aCC 392
+		ellInit ( &bcastList );
         addr.ia.sin_family = AF_UNSPEC;
         osiSockDiscoverBroadcastAddresses ( &bcastList, sock, &addr );
         forcePort ( &bcastList, port );
 		removeDuplicateAddresses ( &tmpList, &bcastList, 1 );
-        if ( ellCount ( &tmpList ) == 0 ) { // X aCC 392
+        if ( ellCount ( &tmpList ) == 0 ) {
             osiSockAddrNode *pNewNode;
             pNewNode = (osiSockAddrNode *) calloc ( 1, sizeof (*pNewNode) );
             if ( pNewNode ) {
@@ -254,11 +254,11 @@
     ::printf ( "Channel Access Address List\n" );
-    pNode = (osiSockAddrNode *) ellFirst ( pList );           // X aCC 749
+    pNode = (osiSockAddrNode *) ellFirst ( pList );
     while (pNode) {
         char buf[64];
         ipAddrToA ( &pNode->addr.ia, buf, sizeof ( buf ) );
         ::printf ( "%s\n", buf );
-        pNode = (osiSockAddrNode *) ellNext ( &pNode->node ); // X aCC 749
+        pNode = (osiSockAddrNode *) ellNext ( &pNode->node );
=== modified file 'src/ca/client/msgForMultiplyDefinedPV.cpp'
--- src/ca/client/msgForMultiplyDefinedPV.cpp	2004-10-08 15:44:44 +0000
+++ src/ca/client/msgForMultiplyDefinedPV.cpp	2012-04-12 17:46:27 +0000
@@ -73,13 +73,6 @@
 #endif
-void * msgForMultiplyDefinedPV::operator new ( size_t ) // X aCC 361
 void msgForMultiplyDefinedPV::operator delete ( void * )
=== modified file 'src/ca/client/msgForMultiplyDefinedPV.h'
--- src/ca/client/msgForMultiplyDefinedPV.h	2004-10-08 15:39:09 +0000
+++ src/ca/client/msgForMultiplyDefinedPV.h	2012-04-12 17:46:27 +0000
@@ -39,7 +39,7 @@
 #   define epicsExportSharedSymbols
 #endif
-class callbackForMultiplyDefinedPV { // X aCC 655
+class callbackForMultiplyDefinedPV {
 public:
     virtual ~callbackForMultiplyDefinedPV () = 0;
     virtual void pvMultiplyDefinedNotify (
@@ -64,7 +64,6 @@
     void transactionComplete ( const char * pHostName );
 	msgForMultiplyDefinedPV ( const msgForMultiplyDefinedPV & );
 	msgForMultiplyDefinedPV & operator = ( const msgForMultiplyDefinedPV & );
=== modified file 'src/ca/client/nciu.cpp'
--- src/ca/client/nciu.cpp	2010-08-11 21:22:54 +0000
+++ src/ca/client/nciu.cpp	2012-04-12 17:46:27 +0000
@@ -94,13 +94,6 @@
     this->cacCtx.destroyChannel ( guard, *this );
-void * nciu::operator new ( size_t ) // X aCC 361
 void nciu::operator delete ( void * )
=== modified file 'src/ca/client/nciu.h'
--- src/ca/client/nciu.h	2010-08-11 22:37:56 +0000
+++ src/ca/client/nciu.h	2012-04-12 17:46:27 +0000
@@ -121,7 +121,7 @@
     friend class disconnectGovernorTimer;
-class privateInterfaceForIO { // X aCC 655
+class privateInterfaceForIO {
 public:
     virtual void ioCompletionNotify (
         epicsGuard < epicsMutex > &, class baseNMIU & ) = 0;
@@ -270,7 +270,6 @@
         epicsGuard < epicsMutex > & guard ) const throw ();
 	nciu ( const nciu & );
 	nciu & operator = ( const nciu & );
-    void * operator new ( size_t );
=== modified file 'src/ca/client/netIO.h'
--- src/ca/client/netIO.h	2010-08-11 21:22:54 +0000
+++ src/ca/client/netIO.h	2012-04-12 17:46:27 +0000
@@ -42,7 +42,7 @@
 class privateInterfaceForIO;
-class baseNMIU : public tsDLNode < baseNMIU >, // X aCC 655
+class baseNMIU : public tsDLNode < baseNMIU >,
         public chronIntIdRes < baseNMIU > {
 public:
     virtual void destroy (
@@ -106,7 +106,6 @@
     const unsigned mask;
     bool subscribed;
     class netSubscription * isSubscription ();
     void * operator new ( size_t,
         tsFreeList < class netSubscription, 1024, epicsMutexNOOP > & );
@@ -147,7 +146,6 @@
 private:
     cacReadNotify & notify;
     class privateInterfaceForIO & privateChanForIO;
         tsFreeList < class netReadNotifyIO, 1024, epicsMutexNOOP > & );
@@ -190,7 +188,6 @@
 private:
     cacWriteNotify & notify;
         tsFreeList < class netWriteNotifyIO, 1024, epicsMutexNOOP > & );
@@ -237,12 +234,12 @@
     class privateInterfaceForIO & chan, unsigned type, arrayElementCount count,
     unsigned mask, cacStateNotify &notify )
-    return new ( freeList ) netSubscription ( chan, type, // X aCC 930
+    return new ( freeList ) netSubscription ( chan, type,
                                 count, mask, notify );
 inline arrayElementCount netSubscription::getCount (
-    epicsGuard < epicsMutex > & guard, bool allow_zero ) const // X aCC 361
+    epicsGuard < epicsMutex > & guard, bool allow_zero ) const
     //guard.assertIdenticalMutex ( this->mutex );
     arrayElementCount nativeCount = this->privateChanForIO.nativeElementCount ( guard );
@@ -268,7 +265,7 @@
     tsFreeList < class netReadNotifyIO, 1024, epicsMutexNOOP > & freeList,
     privateInterfaceForIO & ioComplNotifIntf, cacReadNotify & notify )
-    return new ( freeList ) netReadNotifyIO ( ioComplNotifIntf, notify ); // X aCC 930
+    return new ( freeList ) netReadNotifyIO ( ioComplNotifIntf, notify );
 inline void * netReadNotifyIO::operator new ( size_t size,
@@ -289,7 +286,7 @@
     tsFreeList < class netWriteNotifyIO, 1024, epicsMutexNOOP > & freeList,
     privateInterfaceForIO & ioComplNotifyIntf, cacWriteNotify & notify )
-    return new ( freeList ) netWriteNotifyIO ( ioComplNotifyIntf, notify ); // X aCC 930
+    return new ( freeList ) netWriteNotifyIO ( ioComplNotifyIntf, notify );
 inline void * netWriteNotifyIO::operator new ( size_t size,
=== modified file 'src/ca/client/netReadNotifyIO.cpp'
--- src/ca/client/netReadNotifyIO.cpp	2004-10-08 15:44:44 +0000
+++ src/ca/client/netReadNotifyIO.cpp	2012-04-12 17:46:27 +0000
@@ -119,13 +119,6 @@
-void * netReadNotifyIO::operator new ( size_t ) // X aCC 361
 void netReadNotifyIO::operator delete ( void * )
=== modified file 'src/ca/client/netSubscription.cpp'
--- src/ca/client/netSubscription.cpp	2009-07-08 21:43:38 +0000
+++ src/ca/client/netSubscription.cpp	2012-04-12 17:46:27 +0000
@@ -170,13 +170,6 @@
         guard, chan, *this );
-void * netSubscription::operator new ( size_t ) // X aCC 361
 void netSubscription::operator delete ( void * )
=== modified file 'src/ca/client/netWriteNotifyIO.cpp'
--- src/ca/client/netWriteNotifyIO.cpp	2009-07-08 21:43:38 +0000
+++ src/ca/client/netWriteNotifyIO.cpp	2012-04-12 17:46:27 +0000
@@ -117,14 +117,6 @@
-void * netWriteNotifyIO::operator new ( size_t ) // X aCC 361
-        "why is the compiler calling private operator new" );
 void netWriteNotifyIO::operator delete ( void * )
=== modified file 'src/ca/client/netiiu.h'
--- src/ca/client/netiiu.h	2007-01-11 21:43:40 +0000
+++ src/ca/client/netiiu.h	2012-04-12 17:46:27 +0000
@@ -35,7 +35,7 @@
 class cac;
 class nciu;
-class netiiu { // X aCC 655
+class netiiu {
 public:
     virtual ~netiiu () = 0;
     virtual unsigned getHostName (
=== modified file 'src/ca/client/oldAccess.h'
--- src/ca/client/oldAccess.h	2009-08-21 00:53:55 +0000
+++ src/ca/client/oldAccess.h	2012-04-12 17:46:27 +0000
@@ -162,7 +162,6 @@
         unsigned type, arrayElementCount count );
 	oldChannelNotify ( const oldChannelNotify & );
 	oldChannelNotify & operator = ( const oldChannelNotify & );
@@ -195,7 +194,6 @@
         const char *pContext, unsigned type, arrayElementCount count );
 	getCopy ( const getCopy & );
 	getCopy & operator = ( const getCopy & );
@@ -221,7 +219,6 @@
         const char * pContext, unsigned type, arrayElementCount count );
 	getCallback ( const getCallback & );
 	getCallback & operator = ( const getCallback & );
@@ -245,7 +242,6 @@
 	putCallback ( const putCallback & );
 	putCallback & operator = ( const putCallback & );
@@ -278,7 +274,6 @@
 	oldSubscription ( const oldSubscription & );
 	oldSubscription & operator = ( const oldSubscription & );
=== modified file 'src/ca/client/oldChannelNotify.cpp'
--- src/ca/client/oldChannelNotify.cpp	2010-08-11 21:22:54 +0000
+++ src/ca/client/oldChannelNotify.cpp	2012-04-12 17:46:27 +0000
@@ -159,13 +159,6 @@
         __FILE__, __LINE__, *this, type, count, CA_OP_PUT );
-void * oldChannelNotify::operator new ( size_t ) // X aCC 361
 void oldChannelNotify::operator delete ( void * )
@@ -638,7 +631,7 @@
  * ca_state ()
-enum channel_state epicsShareAPI ca_state ( chid pChan ) // X aCC 361
+enum channel_state epicsShareAPI ca_state ( chid pChan )
     epicsGuard < epicsMutex > guard ( pChan->cacCtx.mutexRef () );
     if ( pChan->io.connected ( guard ) ) {
=== modified file 'src/ca/client/putCallback.cpp'
--- src/ca/client/putCallback.cpp	2009-08-13 22:44:30 +0000
+++ src/ca/client/putCallback.cpp	2012-04-12 17:46:27 +0000
@@ -90,13 +90,6 @@
-void * putCallback::operator new ( size_t ) // X aCC 361
 void putCallback::operator delete ( void * )
=== modified file 'src/ca/client/repeater.cpp'
--- src/ca/client/repeater.cpp	2009-08-24 17:03:17 +0000
+++ src/ca/client/repeater.cpp	2012-04-12 17:46:27 +0000
@@ -178,7 +178,7 @@
     return true;
-bool repeaterClient::sendConfirm () // X aCC 361
+bool repeaterClient::sendConfirm ()
     int status;
@@ -204,7 +204,7 @@
-bool repeaterClient::sendMessage ( const void *pBuf, unsigned bufSize ) // X aCC 361
+bool repeaterClient::sendMessage ( const void *pBuf, unsigned bufSize )
     int status;
@@ -245,13 +245,6 @@
 #endif
-void * repeaterClient::operator new ( size_t ) // X aCC 361
 void repeaterClient::operator delete ( void * )
@@ -304,7 +297,7 @@
     return false;
-bool repeaterClient::verify ()  // X aCC 361
+bool repeaterClient::verify ()
     SOCKET tmpSock;
     bool success = makeSocket ( this->port (), false, & tmpSock );
=== modified file 'src/ca/client/repeaterClient.h'
--- src/ca/client/repeaterClient.h	2004-10-04 18:55:40 +0000
+++ src/ca/client/repeaterClient.h	2012-04-12 17:46:27 +0000
@@ -64,7 +64,6 @@
     osiSockAddr from;
     SOCKET sock;
     unsigned short port () const;
=== modified file 'src/ca/client/repeaterSubscribeTimer.cpp'
--- src/ca/client/repeaterSubscribeTimer.cpp	2007-08-23 17:46:28 +0000
+++ src/ca/client/repeaterSubscribeTimer.cpp	2012-04-12 17:46:27 +0000
@@ -64,7 +64,7 @@
 epicsTimerNotify::expireStatus repeaterSubscribeTimer::
-    expire ( const epicsTime & /* currentTime */ )  // X aCC 361
+    expire ( const epicsTime & /* currentTime */ )
     static const unsigned nTriesToMsg = 50;
     if ( this->attempts > nTriesToMsg && ! this->once ) {
=== modified file 'src/ca/client/repeaterSubscribeTimer.h'
--- src/ca/client/repeaterSubscribeTimer.h	2010-11-04 16:19:54 +0000
+++ src/ca/client/repeaterSubscribeTimer.h	2012-04-12 17:46:27 +0000
@@ -43,7 +43,7 @@
 class epicsMutex;
 class cacContextNotify;
-class repeaterTimerNotify { // X aCC 655
+class repeaterTimerNotify {
 public:
     virtual ~repeaterTimerNotify () = 0;
     virtual void repeaterRegistrationMessage (
=== modified file 'src/ca/client/searchTimer.cpp'
--- src/ca/client/searchTimer.cpp	2009-08-10 21:51:07 +0000
+++ src/ca/client/searchTimer.cpp	2012-04-12 17:46:27 +0000
@@ -124,7 +124,7 @@
 // searchTimer::expire ()
 epicsTimerNotify::expireStatus searchTimer::expire (
-    const epicsTime & currentTime ) // X aCC 361
+    const epicsTime & currentTime )
=== modified file 'src/ca/client/searchTimer.h'
--- src/ca/client/searchTimer.h	2006-11-18 00:51:08 +0000
+++ src/ca/client/searchTimer.h	2012-04-12 17:46:27 +0000
@@ -43,7 +43,7 @@
 #include "netiiu.h"
-class searchTimerNotify { // X aCC 655
+class searchTimerNotify {
 public:
     virtual ~searchTimerNotify () = 0;
     virtual void boostChannel (
=== modified file 'src/ca/client/syncGroup.h'
--- src/ca/client/syncGroup.h	2007-08-23 17:46:28 +0000
+++ src/ca/client/syncGroup.h	2012-04-12 17:46:27 +0000
@@ -49,7 +49,7 @@
 // used to control access to CASG's recycle routines which
 // should only be indirectly invoked by CASG when its lock
 // is applied
-class casgRecycle {             // X aCC 655
+class casgRecycle {
 public:
     virtual void recycleSyncGroupWriteNotify (
         epicsGuard < epicsMutex > &, class syncGroupWriteNotify & io ) = 0;
@@ -104,7 +104,6 @@
     cacChannel::ioid id;
     bool idIsValid;
     bool ioComplete;
         tsFreeList < class syncGroupReadNotify, 128, epicsMutexNOOP > & );
@@ -145,7 +144,6 @@
     bool idIsValid;
     bool ioComplete;
         tsFreeList < class syncGroupWriteNotify, 128, epicsMutexNOOP > & );
@@ -215,7 +213,6 @@
 	CASG ( const CASG & );
 	CASG & operator = ( const CASG & );
     ~CASG ();
=== modified file 'src/ca/client/syncGroupReadNotify.cpp'
--- src/ca/client/syncGroupReadNotify.cpp	2007-08-23 17:46:28 +0000
+++ src/ca/client/syncGroupReadNotify.cpp	2012-04-12 17:46:27 +0000
@@ -58,7 +58,7 @@
     tsFreeList < class syncGroupReadNotify, 128, epicsMutexNOOP > & freeList,
     struct CASG & sg, chid chan, void * pValueIn )
-    return new ( freeList ) // X aCC 930
         syncGroupReadNotify ( sg, chan, pValueIn );
@@ -122,13 +122,6 @@
-void * syncGroupReadNotify::operator new ( size_t ) // X aCC 361
 void syncGroupReadNotify::operator delete ( void * )
=== modified file 'src/ca/client/syncGroupWriteNotify.cpp'
--- src/ca/client/syncGroupWriteNotify.cpp	2007-08-23 17:46:28 +0000
+++ src/ca/client/syncGroupWriteNotify.cpp	2012-04-12 17:46:27 +0000
@@ -112,13 +112,6 @@
-void * syncGroupWriteNotify::operator new ( size_t ) // X aCC 361
 void syncGroupWriteNotify::operator delete ( void * )
=== modified file 'src/ca/client/syncgrp.cpp'
--- src/ca/client/syncgrp.cpp	2007-01-11 22:02:47 +0000
+++ src/ca/client/syncgrp.cpp	2012-04-12 17:46:27 +0000
@@ -23,7 +23,7 @@
  * ca_sg_create()
-extern "C" int epicsShareAPI ca_sg_create ( CA_SYNC_GID * pgid ) // X aCC 361
+extern "C" int epicsShareAPI ca_sg_create ( CA_SYNC_GID * pgid )
     ca_client_context * pcac;
     int caStatus;
@@ -143,7 +143,7 @@
  * ca_sg_test
-extern "C" int epicsShareAPI ca_sg_test ( const CA_SYNC_GID gid ) // X aCC 361
+extern "C" int epicsShareAPI ca_sg_test ( const CA_SYNC_GID gid )
=== modified file 'src/ca/client/tcpRecvWatchdog.cpp'
--- src/ca/client/tcpRecvWatchdog.cpp	2006-12-05 19:56:28 +0000
+++ src/ca/client/tcpRecvWatchdog.cpp	2012-04-12 17:46:27 +0000
@@ -45,7 +45,7 @@
-tcpRecvWatchdog::expire ( const epicsTime & /* currentTime */ ) // X aCC 361
+tcpRecvWatchdog::expire ( const epicsTime & /* currentTime */ )
     if ( this->shuttingDown ) {
=== modified file 'src/ca/client/tcpiiu.cpp'
--- src/ca/client/tcpiiu.cpp	2011-01-15 00:53:33 +0000
+++ src/ca/client/tcpiiu.cpp	2012-04-12 17:46:27 +0000
@@ -1135,7 +1135,7 @@
-bool tcpiiu::setEchoRequestPending ( epicsGuard < epicsMutex > & guard ) // X aCC 361
+bool tcpiiu::setEchoRequestPending ( epicsGuard < epicsMutex > & guard )
@@ -1275,12 +1275,9 @@
         this->msgHeaderAvailable = false;
         this->curDataBytes = 0u;
-#   if defined ( __HP_aCC ) && _HP_aCC <= 033300
-        return false; // to make hpux compiler happy...
-#   endif
-void tcpiiu::hostNameSetRequest ( epicsGuard < epicsMutex > & guard ) // X aCC 431
+void tcpiiu::hostNameSetRequest ( epicsGuard < epicsMutex > & guard )
@@ -1310,7 +1307,7 @@
  * tcpiiu::userNameSetRequest ()
-void tcpiiu::userNameSetRequest ( epicsGuard < epicsMutex > & guard ) // X aCC 431
+void tcpiiu::userNameSetRequest ( epicsGuard < epicsMutex > & guard )
@@ -1338,7 +1335,7 @@
 void tcpiiu::disableFlowControlRequest (
-    epicsGuard < epicsMutex > & guard ) // X aCC 431
+    epicsGuard < epicsMutex > & guard )
@@ -1354,7 +1351,7 @@
 void tcpiiu::enableFlowControlRequest (
@@ -1369,7 +1366,7 @@
     minder.commit ();
-void tcpiiu::versionMessage ( epicsGuard < epicsMutex > & guard, // X aCC 431
+void tcpiiu::versionMessage ( epicsGuard < epicsMutex > & guard,
                              const cacChannel::priLev & priority )
@@ -1389,7 +1386,7 @@
     minder.commit ();
-void tcpiiu::echoRequest ( epicsGuard < epicsMutex > & guard ) // X aCC 431
+void tcpiiu::echoRequest ( epicsGuard < epicsMutex > & guard )
@@ -1410,7 +1407,7 @@
     minder.commit ();
-void tcpiiu::writeRequest ( epicsGuard < epicsMutex > & guard, // X aCC 431
+void tcpiiu::writeRequest ( epicsGuard < epicsMutex > & guard,
     nciu &chan, unsigned type, arrayElementCount nElem, const void *pValue )
@@ -1425,7 +1422,7 @@
-void tcpiiu::writeNotifyRequest ( epicsGuard < epicsMutex > & guard, // X aCC 431
+void tcpiiu::writeNotifyRequest ( epicsGuard < epicsMutex > & guard,
                                  nciu &chan, netWriteNotifyIO &io, unsigned type,
@@ -1444,7 +1441,7 @@
     minder.commit ();
-void tcpiiu::readNotifyRequest ( epicsGuard < epicsMutex > & guard, // X aCC 431
+void tcpiiu::readNotifyRequest ( epicsGuard < epicsMutex > & guard,
                                nciu & chan, netReadNotifyIO & io,
                                unsigned dataType, arrayElementCount nElem )
@@ -1477,7 +1474,7 @@
 void tcpiiu::createChannelRequest (
-    nciu & chan, epicsGuard < epicsMutex > & guard ) // X aCC 431
+    nciu & chan, epicsGuard < epicsMutex > & guard )
@@ -1525,7 +1522,7 @@
     minder.commit ();
-void tcpiiu::clearChannelRequest ( epicsGuard < epicsMutex > & guard, // X aCC 431
+void tcpiiu::clearChannelRequest ( epicsGuard < epicsMutex > & guard,
                                   ca_uint32_t sid, ca_uint32_t cid )
@@ -1547,7 +1544,7 @@
 // is to try again the next time that we reconnect
 void tcpiiu::subscriptionRequest (
-    epicsGuard < epicsMutex > & guard, // X aCC 431
     nciu & chan, netSubscription & subscr )
@@ -1599,7 +1596,7 @@
 void tcpiiu::subscriptionUpdateRequest (
@@ -1634,7 +1631,7 @@
     minder.commit ();
-void tcpiiu::subscriptionCancelRequest ( epicsGuard < epicsMutex > & guard, // X aCC 431
+void tcpiiu::subscriptionCancelRequest ( epicsGuard < epicsMutex > & guard,
@@ -2052,7 +2049,7 @@
     return false;
 #else
     osiSockIoctl_t bytesPending = 0; /* shut up purifys yapping */
                             FIONREAD, & bytesPending );
     if ( status >= 0 ) {
         if ( bytesPending > 0 ) {
=== modified file 'src/ca/client/test_event.cpp'
--- src/ca/client/test_event.cpp	2004-10-08 15:44:44 +0000
+++ src/ca/client/test_event.cpp	2012-04-12 17:46:27 +0000
@@ -78,7 +78,7 @@
         dbr_short_t *pvalue = (dbr_short_t *)pbuffer;
         for (i = 0; i < count; i++,pvalue++){
             if(count!=1 && (i%10 == 0)) printf("\n");
-            printf("%d ",* (short *)pvalue); // X aCC 392
+            printf("%d ",* (short *)pvalue);
         break;
@@ -96,7 +96,7 @@
         dbr_float_t *pvalue = (dbr_float_t *)pbuffer;
-            printf("%6.4f ",*(float *)pvalue); // X aCC 392
+            printf("%6.4f ",*(float *)pvalue);
         break;
=== modified file 'src/ca/client/udpiiu.cpp'
--- src/ca/client/udpiiu.cpp	2011-12-12 23:10:24 +0000
+++ src/ca/client/udpiiu.cpp	2012-04-12 17:46:27 +0000
@@ -201,7 +201,7 @@
     memset ( (char *)&addr, 0 , sizeof (addr) );
     if ( status < 0 ) {
@@ -471,7 +471,7 @@
     memset ( (char *) &msg, 0, sizeof (msg) );
-    AlignedWireRef < epicsUInt16 > ( msg.m_cmmd ) = REPEATER_REGISTER; // X aCC 818
+    AlignedWireRef < epicsUInt16 > ( msg.m_cmmd ) = REPEATER_REGISTER;
     msg.m_available = saddr.ia.sin_addr.s_addr;
=== modified file 'src/ca/client/virtualCircuit.h'
--- src/ca/client/virtualCircuit.h	2010-08-13 18:12:06 +0000
+++ src/ca/client/virtualCircuit.h	2012-04-12 17:46:27 +0000
@@ -335,7 +335,6 @@
 	tcpiiu ( const tcpiiu & );
 	tcpiiu & operator = ( const tcpiiu & );
@@ -372,7 +371,7 @@
 inline bool tcpiiu::alive (
-    epicsGuard < epicsMutex > & ) const // X aCC 361
+    epicsGuard < epicsMutex > & ) const
     return ( this->state == iiucs_connecting ||
         this->state == iiucs_connected );
=== modified file 'src/ca/legacy/gdd/aitConvert.h'
--- src/ca/legacy/gdd/aitConvert.h	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/gdd/aitConvert.h	2012-04-12 17:46:27 +0000
@@ -114,15 +114,15 @@
 inline void aitToNetOrder64(aitUint64* dest, aitUint64* src)
 	aitUint32 ait_temp_var_;
-	ait_temp_var_=(aitUint32)htonl(src[1]); // X aCC 392
-	dest[1]=(aitUint32)htonl(src[0]); // X aCC 392
+	ait_temp_var_=(aitUint32)htonl(src[1]);
+	dest[1]=(aitUint32)htonl(src[0]);
 	dest[0]=ait_temp_var_;
 inline void aitFromNetOrder64(aitUint64* dest, aitUint64* src)
-	ait_temp_var_=(aitUint32)ntohl(src[1]); // X aCC 392
-	dest[1]=(aitUint32)ntohl(src[0]); // X aCC 392
+	ait_temp_var_=(aitUint32)ntohl(src[1]);
+	dest[1]=(aitUint32)ntohl(src[0]);
=== modified file 'src/ca/legacy/gdd/gddAppTable.cc'
--- src/ca/legacy/gdd/gddAppTable.cc	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/gdd/gddAppTable.cc	2012-04-12 17:46:27 +0000
@@ -61,21 +61,6 @@
 	GenerateTypes();
-#if 0
-void* operator new(size_t x)
-	void* v = (void*)malloc(x);
-	fprintf(stderr,"%8.8x In operator new %d\n",v,(int)x);
-	return v;
-void operator delete(void* x)
-	fprintf(stderr,"%8.8x In operator delete\n",x);
-	free((char*)x);
-#endif
 gddApplicationTypeTable::~gddApplicationTypeTable(void)
 	unsigned i,j;
=== modified file 'src/ca/legacy/gdd/gddI.h'
--- src/ca/legacy/gdd/gddI.h	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/gdd/gddI.h	2012-04-12 17:46:27 +0000
@@ -79,12 +79,12 @@
 inline int gdd::isNetworkDataFormat(void) const
 	{ return !isLocalDataFormat() || aitLocalNetworkDataFormatSame; }
-inline void gdd::markConstant(void)		{ flags|=GDD_CONSTANT_MASK; } // X aCC 818
-inline void gdd::markFlat(void)			{ flags|=GDD_FLAT_MASK; } // X aCC 818
-inline void gdd::markManaged(void)		{ flags|=GDD_MANAGED_MASK; } // X aCC 818
-inline void gdd::markUnmanaged(void)	{ flags&=~GDD_MANAGED_MASK; } // X aCC 818
-inline void gdd::markLocalDataFormat(void)		{ flags&=~GDD_NET_MASK; } // X aCC 818
-inline void gdd::markNotLocalDataFormat(void)	{ flags|=GDD_NET_MASK; } // X aCC 818
+inline void gdd::markConstant(void)		{ flags|=GDD_CONSTANT_MASK; }
+inline void gdd::markFlat(void)			{ flags|=GDD_FLAT_MASK; }
+inline void gdd::markManaged(void)		{ flags|=GDD_MANAGED_MASK; }
+inline void gdd::markUnmanaged(void)	{ flags&=~GDD_MANAGED_MASK; }
+inline void gdd::markLocalDataFormat(void)		{ flags&=~GDD_NET_MASK; }
+inline void gdd::markNotLocalDataFormat(void)	{ flags|=GDD_NET_MASK; }
 inline void gdd::getTimeStamp(struct timespec* const ts) const { time_stamp.get(*ts); }
 inline void gdd::setTimeStamp(const struct timespec* const ts) { time_stamp=*ts; }
@@ -132,7 +132,7 @@
 		gddAutoPrint("gdd::noReferencing()",gddErrorNotAllowed);
 		rc=gddErrorNotAllowed;
-	else			flags|=GDD_NOREF_MASK; // X aCC 818
+	else			flags|=GDD_NOREF_MASK;
 	return rc;
 inline gddStatus gdd::reference(void) const
@@ -148,7 +148,7 @@
         rc = gddErrorNotAllowed;
     else if ( this->ref_cnt < 0xffffffff ) {
-        this->ref_cnt++; // X aCC 818
+        this->ref_cnt++;
     else {
         fprintf(stderr,"gdd reference count overflow!!\n");
@@ -399,10 +399,10 @@
 	if(primitiveType()==aitEnumString && dim==0)
 		aitString* str = (aitString*)dataAddress();
-		strcpy((char*)d,str->string()); // X aCC 392
+		strcpy((char*)d,str->string());
 	else if(primitiveType()==aitEnumFixedString && dim==0)
-		strcpy((char*)d,data.FString->fixed_string); // X aCC 392
+		strcpy((char*)d,data.FString->fixed_string);
 	else
 		aitConvert(aitEnumInt8,d,primitiveType(),dataPointer(),
 			getDataSizeElements());
=== modified file 'src/ca/legacy/gdd/gddUtilsI.h'
--- src/ca/legacy/gdd/gddUtilsI.h	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/gdd/gddUtilsI.h	2012-04-12 17:46:27 +0000
@@ -30,7 +30,7 @@
 inline gddDestructor::gddDestructor(void) { ref_cnt=0; arg=NULL; }
 inline gddDestructor::gddDestructor(void* usr_arg) { ref_cnt=0; arg=usr_arg; }
-inline void gddDestructor::reference(void)      { ref_cnt++; } // X aCC 818
+inline void gddDestructor::reference(void)      { ref_cnt++; }
 inline int gddDestructor::refCount(void) const  { return ref_cnt; }
 #endif
=== modified file 'src/ca/legacy/gdd/smartGDDPointer.h'
--- src/ca/legacy/gdd/smartGDDPointer.h	2009-08-31 23:21:37 +0000
+++ src/ca/legacy/gdd/smartGDDPointer.h	2012-04-12 17:46:27 +0000
@@ -157,13 +157,13 @@
-inline bool smartGDDPointerTemplate < T > :: operator ! () const // X aCC 361
+inline bool smartGDDPointerTemplate < T > :: operator ! () const
     return this->pValue ? false : true;
-inline bool smartGDDPointerTemplate < T > :: valid () const // X aCC 361
+inline bool smartGDDPointerTemplate < T > :: valid () const
     return this->pValue ? true : false;
=== modified file 'src/ca/legacy/pcas/example/directoryService/directoryServer.h'
--- src/ca/legacy/pcas/example/directoryService/directoryServer.h	2009-08-24 17:09:55 +0000
+++ src/ca/legacy/pcas/example/directoryService/directoryServer.h	2012-04-12 17:46:27 +0000
@@ -74,7 +74,7 @@
 // for this breaking out into a seperate class
 // from pvInfo)
-class pvEntry // X aCC 655
+class pvEntry
     : public stringId, public tsSLNode<pvEntry> {
 public:
     pvEntry (const pvInfo  &infoIn, directoryServer &casIn,
=== modified file 'src/ca/legacy/pcas/example/directoryService/main.cc'
--- src/ca/legacy/pcas/example/directoryService/main.cc	2009-07-09 15:27:43 +0000
+++ src/ca/legacy/pcas/example/directoryService/main.cc	2012-04-12 17:46:27 +0000
@@ -206,7 +206,4 @@
         nPV++;
-#if defined ( __HP_aCC ) && ( _HP_aCC <= 033300 )
-    return 0; // Make HP compiler happy
-#endif
=== modified file 'src/ca/legacy/pcas/generic/caNetAddr.cc'
--- src/ca/legacy/pcas/generic/caNetAddr.cc	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/pcas/generic/caNetAddr.cc	2012-04-12 17:46:27 +0000
@@ -71,7 +71,7 @@
     return this->type != casnaUDF;
-bool caNetAddr::operator == (const caNetAddr &rhs) const // X aCC 361
+bool caNetAddr::operator == (const caNetAddr &rhs) const
     if ( this->type != rhs.type ) {
         return false;
=== modified file 'src/ca/legacy/pcas/generic/caServer.cc'
--- src/ca/legacy/pcas/generic/caServer.cc	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/pcas/generic/caServer.cc	2012-04-12 17:46:27 +0000
@@ -65,7 +65,7 @@
 	return this->createPV ( ctx, pAliasName );
-casEventMask caServer::registerEvent (const char *pName) // X aCC 361
+casEventMask caServer::registerEvent (const char *pName)
 	if (this->pCAS) {
 		return this->pCAS->registerEvent(pName);
@@ -97,7 +97,7 @@
-unsigned caServer::getDebugLevel () const // X aCC 361
+unsigned caServer::getDebugLevel () const
     if (pCAS) {
         return this->pCAS->getDebugLevel();
@@ -108,7 +108,7 @@
-casEventMask caServer::valueEventMask () const // X aCC 361
+casEventMask caServer::valueEventMask () const
     if (pCAS) {
         return this->pCAS->valueEventMask();
@@ -119,7 +119,7 @@
-casEventMask caServer::logEventMask () const // X aCC 361
+casEventMask caServer::logEventMask () const
     if (pCAS) {
         return this->pCAS->logEventMask();
@@ -130,7 +130,7 @@
-casEventMask caServer::alarmEventMask () const // X aCC 361
+casEventMask caServer::alarmEventMask () const
     if ( pCAS ) {
         return this->pCAS->alarmEventMask ();
@@ -146,7 +146,7 @@
     return fileDescriptorManager.createTimer ();
-unsigned caServer::subscriptionEventsProcessed () const // X aCC 361
+unsigned caServer::subscriptionEventsProcessed () const
     if ( pCAS ) {
         return this->pCAS->subscriptionEventsProcessed ();
@@ -156,7 +156,7 @@
-unsigned caServer::subscriptionEventsPosted () const // X aCC 361
+unsigned caServer::subscriptionEventsPosted () const
     if ( pCAS ) {
         return this->pCAS->subscriptionEventsPosted ();
=== modified file 'src/ca/legacy/pcas/generic/casChannel.cc'
--- src/ca/legacy/pcas/generic/casChannel.cc	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/pcas/generic/casChannel.cc	2012-04-12 17:46:27 +0000
@@ -37,7 +37,7 @@
     this->destroy ();
-casPV * casChannel::getPV () // X aCC 361
+casPV * casChannel::getPV ()
     if ( this->pChanI ) {
 	    casPVI & pvi = this->pChanI->getPVI ();
=== modified file 'src/ca/legacy/pcas/generic/casDGClient.cc'
--- src/ca/legacy/pcas/generic/casDGClient.cc	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/pcas/generic/casDGClient.cc	2012-04-12 17:46:27 +0000
@@ -448,7 +448,7 @@
 // casDGClient::xRecv ()
-inBufClient::fillCondition casDGClient::xRecv (char *pBufIn, bufSizeT nBytesToRecv, // X aCC 361
+inBufClient::fillCondition casDGClient::xRecv (char *pBufIn, bufSizeT nBytesToRecv,
         fillParameter parm, bufSizeT &nByesRecv)
     const char *pAfter = pBufIn + nBytesToRecv;
=== modified file 'src/ca/legacy/pcas/generic/casMonEvent.cc'
--- src/ca/legacy/pcas/generic/casMonEvent.cc	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/pcas/generic/casMonEvent.cc	2012-04-12 17:46:27 +0000
@@ -57,13 +57,6 @@
 #endif
-void * casMonEvent::operator new ( size_t ) // X aCC 361
 void casMonEvent::operator delete ( void * )
=== modified file 'src/ca/legacy/pcas/generic/casMonEvent.h'
--- src/ca/legacy/pcas/generic/casMonEvent.h	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/pcas/generic/casMonEvent.h	2012-04-12 17:46:27 +0000
@@ -49,7 +49,6 @@
 private:
     class casMonitor & monitor;
 	smartConstGDDPointer pValue;
 	caStatus cbFunc (
         casCoreClient &,
=== modified file 'src/ca/legacy/pcas/generic/casMonitor.cc'
--- src/ca/legacy/pcas/generic/casMonitor.cc	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/pcas/generic/casMonitor.cc	2012-04-12 17:46:27 +0000
@@ -77,7 +77,7 @@
             this->overFlowEvent.swapValues ( *pLog );
 			eventLogQue.insertAfter ( *pLog, this->overFlowEvent );
             assert ( this->nPend != UCHAR_MAX );
-		    this->nPend++; // X aCC 818
+		    this->nPend++;
 		else {
 			// replace the old OVF value with the current one
@@ -97,7 +97,7 @@
         pLog->assign ( event );
+		this->nPend++;
     eventLogQue.add ( *pLog );
@@ -117,7 +117,7 @@
     client.getCAS().incrEventsProcessedCounter ();
     assert ( this->nPend != 0u );
-	this->nPend--; // X aCC 818
+	this->nPend--;
 	// delete event object if it isnt a cache entry
 	// saved in the call back object
=== modified file 'src/ca/legacy/pcas/generic/casMonitor.h'
--- src/ca/legacy/pcas/generic/casMonitor.h	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/pcas/generic/casMonitor.h	2012-04-12 17:46:27 +0000
@@ -39,7 +39,7 @@
 class casMonitor;
 class casClientMutex;
-class casMonitorCallbackInterface { // X aCC 655
+class casMonitorCallbackInterface {
 public:
 	virtual caStatus casMonitorCallBack (
         epicsGuard < casClientMutex > &, casMonitor &,
@@ -87,7 +87,6 @@
 	unsigned char nPend;
     bool destroyPending;
 	bool ovf;
 	casMonitor ( const casMonitor & );
 	casMonitor & operator = ( const casMonitor & );
=== modified file 'src/ca/legacy/pcas/generic/casPVI.cc'
--- src/ca/legacy/pcas/generic/casPVI.cc	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/pcas/generic/casPVI.cc	2012-04-12 17:46:27 +0000
@@ -317,7 +317,7 @@
     return pMon;
-caServer *casPVI::getExtServer () const // X aCC 361
+caServer *casPVI::getExtServer () const
 	if ( this->pCAS ) {
@@ -415,7 +415,7 @@
 	this->ioBlockedList::signal();
-caStatus  casPVI::bestDBRType ( unsigned & dbrType ) // X aCC 361
+caStatus  casPVI::bestDBRType ( unsigned & dbrType )
 	aitEnum bestAIT = this->bestExternalType ();
=== modified file 'src/ca/legacy/pcas/generic/casStrmClient.cc'
--- src/ca/legacy/pcas/generic/casStrmClient.cc	2010-09-29 05:44:47 +0000
+++ src/ca/legacy/pcas/generic/casStrmClient.cc	2012-04-12 17:46:27 +0000
@@ -1629,7 +1629,7 @@
     if ( ! pvar.getPV()->pPVI ) {
         // @#$!* Tornado 2 Cygnus GNU compiler bugs
 #       if ! defined (__GNUC__) || __GNUC__ > 2 || ( __GNUC__ == 2 && __GNUC_MINOR__ >= 92 )
-            pvar.getPV()->pPVI = new ( std::nothrow ) // X aCC 930
+            pvar.getPV()->pPVI = new ( std::nothrow )
                         casPVI ( *pvar.getPV() );
 #       else
             try {
@@ -1678,7 +1678,7 @@
     if ( ! pChan->pChanI ) {
-            pChan->pChanI = new ( std::nothrow ) // X aCC 930
+            pChan->pChanI = new ( std::nothrow )
                 casChannelI ( * this, *pChan,
                     * pvar.getPV()->pPVI, hdr.m_cid );
 #       else
@@ -1848,7 +1848,7 @@
     assert ( hdr.m_cid == chan.getCID() );
     status = this->out.copyInHeader ( CA_PROTO_CREATE_CHAN, 0,
         static_cast <ca_uint16_t> ( nativeTypeDBR ),
-        static_cast <ca_uint32_t> ( nativeCount ), // X aCC 392
+        static_cast <ca_uint32_t> ( nativeCount ),
         chan.getCID(), chan.getSID(), 0 );
     if ( status != S_cas_success ) {
         this->out.popCtx ( outctx );
@@ -2150,7 +2150,7 @@
     class channelDestroyEvent * pEvent =
-        new ( std::nothrow ) class channelDestroyEvent ( // X aCC 930
+        new ( std::nothrow ) class channelDestroyEvent (
             immediateUninstallNeeded ? & chan : 0,
             chan.getSID() );
     if ( pEvent ) {
=== modified file 'src/ca/legacy/pcas/generic/casdef.h'
--- src/ca/legacy/pcas/generic/casdef.h	2009-08-06 01:36:30 +0000
+++ src/ca/legacy/pcas/generic/casdef.h	2012-04-12 17:46:27 +0000
@@ -113,7 +113,7 @@
 class casCtx;
 class casChannel;
-class epicsShareClass pvExistReturn { // X aCC 361
+class epicsShareClass pvExistReturn {
 public:
     // most server tools will use this
     pvExistReturn ( pvExistReturnEnum s = pverDoesNotExistHere );
=== modified file 'src/ca/legacy/pcas/generic/chanIntfForPV.h'
--- src/ca/legacy/pcas/generic/chanIntfForPV.h	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/pcas/generic/chanIntfForPV.h	2012-04-12 17:46:27 +0000
@@ -41,7 +41,7 @@
 class casEventMask;
 class gdd;
-class casChannelDestroyFromPV { // X aCC 655
+class casChannelDestroyFromPV {
 public:
     virtual void postDestroyEvent () = 0;
 protected:
=== modified file 'src/ca/legacy/pcas/generic/inBuf.cc'
--- src/ca/legacy/pcas/generic/inBuf.cc	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/pcas/generic/inBuf.cc	2012-04-12 17:46:27 +0000
@@ -117,7 +117,7 @@
 // inBuf::pushCtx ()
-const inBufCtx inBuf::pushCtx ( bufSizeT headerSize, // X aCC 361
+const inBufCtx inBuf::pushCtx ( bufSizeT headerSize,
                                bufSizeT bodySize )
     if ( headerSize + bodySize > ( this->bytesInBuffer - this->nextReadIndex ) ||
@@ -140,7 +140,7 @@
 // inBuf::popCtx ()
-bufSizeT inBuf::popCtx ( const inBufCtx &ctx ) // X aCC 361
+bufSizeT inBuf::popCtx ( const inBufCtx &ctx )
     if ( ctx.stat==inBufCtx::pushCtxSuccess ) {
         bufSizeT bytesRemoved = this->nextReadIndex;
=== modified file 'src/ca/legacy/pcas/generic/inBuf.h'
--- src/ca/legacy/pcas/generic/inBuf.h	2009-07-30 23:48:43 +0000
+++ src/ca/legacy/pcas/generic/inBuf.h	2012-04-12 17:46:27 +0000
@@ -44,7 +44,7 @@
     bufSizeT nextReadIndex;
-class inBufClient {             // X aCC 655
+class inBufClient {
 public:
     enum fillCondition { casFillNone,  casFillProgress,
         casFillDisconnect };
=== modified file 'src/ca/legacy/pcas/generic/outBuf.cc'
--- src/ca/legacy/pcas/generic/outBuf.cc	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/pcas/generic/outBuf.cc	2012-04-12 17:46:27 +0000
@@ -265,7 +265,7 @@
 // outBuf::pushCtx ()
-const outBufCtx outBuf::pushCtx ( bufSizeT headerSize, // X aCC 361
+const outBufCtx outBuf::pushCtx ( bufSizeT headerSize,
                                  bufSizeT maxBodySize,
                                  void *&pHeader )
@@ -292,7 +292,7 @@
 // outBuf::popCtx ()
-bufSizeT outBuf::popCtx (const outBufCtx &ctx) // X aCC 361
+bufSizeT outBuf::popCtx (const outBufCtx &ctx)
     if (ctx.stat==outBufCtx::pushCtxSuccess) {
         bufSizeT bytesAdded = this->stack;
=== modified file 'src/ca/legacy/pcas/generic/outBuf.h'
--- src/ca/legacy/pcas/generic/outBuf.h	2009-07-25 00:43:28 +0000
+++ src/ca/legacy/pcas/generic/outBuf.h	2012-04-12 17:46:27 +0000
@@ -45,7 +45,7 @@
 	bufSizeT stack;
-class outBufClient {            // X aCC 655
+class outBufClient {
 public:
     enum flushCondition {
         flushNone = 0,
=== modified file 'src/ca/legacy/pcas/io/bsdSocket/caServerIO.cc'
--- src/ca/legacy/pcas/io/bsdSocket/caServerIO.cc	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/pcas/io/bsdSocket/caServerIO.cc	2012-04-12 17:46:27 +0000
@@ -167,7 +167,7 @@
 // getToken()
-static char *getToken(const char **ppString, // X aCC 361
+static char *getToken(const char **ppString,
                       char *pBuf, unsigned bufSIze)
     const char *pToken;
=== modified file 'src/ca/legacy/pcas/io/bsdSocket/casDGIntfIO.cc'
--- src/ca/legacy/pcas/io/bsdSocket/casDGIntfIO.cc	2009-08-04 19:10:30 +0000
+++ src/ca/legacy/pcas/io/bsdSocket/casDGIntfIO.cc	2012-04-12 17:46:27 +0000
@@ -297,7 +297,7 @@
-    int status = socket_ioctl ( this->sock, FIONBIO, &yes ); // X aCC 392
+    int status = socket_ioctl ( this->sock, FIONBIO, &yes );
     if ( status < 0 ) {
         epicsSocketConvertErrnoToString ( sockErrBuf, sizeof ( sockErrBuf ) );
@@ -307,7 +307,7 @@
     if ( this->bcastRecvSock != INVALID_SOCKET ) {
         yes = true;
-        int status = socket_ioctl ( this->bcastRecvSock, // X aCC 392
+        int status = socket_ioctl ( this->bcastRecvSock,
                                     FIONBIO, &yes );
         if ( status < 0 ) {
@@ -319,7 +319,7 @@
-casDGIntfIO::osdRecv ( char * pBufIn, bufSizeT size, // X aCC 361
+casDGIntfIO::osdRecv ( char * pBufIn, bufSizeT size,
     fillParameter parm, bufSizeT & actualSize, caNetAddr & fromOut )
     int status;
@@ -366,7 +366,7 @@
 outBufClient::flushCondition
-casDGIntfIO::osdSend ( const char * pBufIn, bufSizeT size, // X aCC 361
+casDGIntfIO::osdSend ( const char * pBufIn, bufSizeT size,
                       const caNetAddr & to )
     int	status;
=== modified file 'src/ca/legacy/pcas/io/bsdSocket/casIntfIO.cc'
--- src/ca/legacy/pcas/io/bsdSocket/casIntfIO.cc	2010-08-10 21:05:46 +0000
+++ src/ca/legacy/pcas/io/bsdSocket/casIntfIO.cc	2012-04-12 17:46:27 +0000
@@ -198,7 +198,7 @@
     int status;
-    status = socket_ioctl(this->sock, FIONBIO, &yes); // X aCC 392
+    status = socket_ioctl(this->sock, FIONBIO, &yes);
     if ( status < 0 ) {
=== modified file 'src/ca/legacy/pcas/io/bsdSocket/casStreamIO.cc'
--- src/ca/legacy/pcas/io/bsdSocket/casStreamIO.cc	2010-08-10 21:05:46 +0000
+++ src/ca/legacy/pcas/io/bsdSocket/casStreamIO.cc	2012-04-12 17:46:27 +0000
@@ -168,7 +168,7 @@
 // casStreamIO::osdRecv()
-casStreamIO::osdRecv ( char * pInBuf, bufSizeT nBytes, // X aCC 361
+casStreamIO::osdRecv ( char * pInBuf, bufSizeT nBytes,
                       bufSizeT & nBytesActual )
     int nchars;
@@ -250,7 +250,7 @@
 	int status;
 	if (status>=0) {
 		this->blockingFlag = xIsntBlocking;
=== modified file 'src/ca/legacy/pcas/io/bsdSocket/ipIgnoreEntry.cpp'
--- src/ca/legacy/pcas/io/bsdSocket/ipIgnoreEntry.cpp	2004-10-08 14:58:59 +0000
+++ src/ca/legacy/pcas/io/bsdSocket/ipIgnoreEntry.cpp	2012-04-12 17:46:27 +0000
@@ -67,13 +67,6 @@
 #endif
-void * ipIgnoreEntry::operator new ( size_t ) // X aCC 361
 void ipIgnoreEntry::operator delete ( void * )
=== modified file 'src/ca/legacy/pcas/io/bsdSocket/ipIgnoreEntry.h'
--- src/ca/legacy/pcas/io/bsdSocket/ipIgnoreEntry.h	2010-10-05 19:27:37 +0000
+++ src/ca/legacy/pcas/io/bsdSocket/ipIgnoreEntry.h	2012-04-12 17:46:27 +0000
@@ -44,7 +44,6 @@
     unsigned ipAddr;
 	ipIgnoreEntry ( const ipIgnoreEntry & );
 	ipIgnoreEntry & operator = ( const ipIgnoreEntry & );
=== modified file 'src/ioc/db/dbCAC.h'
--- src/ioc/db/dbCAC.h	2011-06-01 22:22:12 +0000
+++ src/ioc/db/dbCAC.h	2012-04-12 17:46:27 +0000
@@ -62,7 +62,7 @@
 class dbPutNotifyBlocker;
 class dbSubscriptionIO;
-class dbBaseIO                  //  X aCC 655
+class dbBaseIO
     : public chronIntIdRes < dbBaseIO > {
 public:
     virtual dbSubscriptionIO * isSubscription () = 0;
@@ -110,7 +110,6 @@
     dbSubscriptionIO ( const dbSubscriptionIO & );
     dbSubscriptionIO & operator = ( const dbSubscriptionIO & );
     virtual ~dbSubscriptionIO ();
=== modified file 'src/ioc/db/dbChannelIO.cpp'
--- src/ioc/db/dbChannelIO.cpp	2010-10-05 19:27:37 +0000
+++ src/ioc/db/dbChannelIO.cpp	2012-04-12 17:46:27 +0000
@@ -204,13 +204,6 @@
     return freeList.allocate ( size );
-void * dbChannelIO::operator new ( size_t ) // X aCC 361
 #ifdef CXX_PLACEMENT_DELETE
 void dbChannelIO::operator delete ( void *pCadaver,
     tsFreeList < dbChannelIO, 256, epicsMutexNOOP > & freeList )
=== modified file 'src/ioc/db/dbChannelIO.h'
--- src/ioc/db/dbChannelIO.h	2010-10-05 19:27:37 +0000
+++ src/ioc/db/dbChannelIO.h	2012-04-12 17:46:27 +0000
@@ -111,7 +111,6 @@
         epicsGuard < epicsMutex > & ) const;
 	dbChannelIO ( const dbChannelIO & );
 	dbChannelIO & operator = ( const dbChannelIO & );
=== modified file 'src/ioc/db/dbContext.cpp'
--- src/ioc/db/dbContext.cpp	2010-10-05 19:27:37 +0000
+++ src/ioc/db/dbContext.cpp	2012-04-12 17:46:27 +0000
@@ -83,7 +83,7 @@
-cacChannel & dbContext::createChannel ( // X aCC 361
+cacChannel & dbContext::createChannel (
     epicsGuard < epicsMutex > & guard, const char * pName,
     cacChannelNotify & notifyIn, cacChannel::priLev priority )
=== modified file 'src/ioc/db/dbPutNotifyBlocker.cpp'
--- src/ioc/db/dbPutNotifyBlocker.cpp	2011-10-19 18:07:00 +0000
+++ src/ioc/db/dbPutNotifyBlocker.cpp	2012-04-12 17:46:27 +0000
@@ -212,13 +212,6 @@
-void * dbPutNotifyBlocker::operator new ( size_t ) // X aCC 361
 void dbPutNotifyBlocker::operator delete ( void *pCadaver,
     tsFreeList < dbPutNotifyBlocker, 64, epicsMutexNOOP > & freeList )
=== modified file 'src/ioc/db/dbPutNotifyBlocker.h'
--- src/ioc/db/dbPutNotifyBlocker.h	2010-10-05 19:27:37 +0000
+++ src/ioc/db/dbPutNotifyBlocker.h	2012-04-12 17:46:27 +0000
@@ -82,7 +82,6 @@
 	dbPutNotifyBlocker ( const dbPutNotifyBlocker & );
 	dbPutNotifyBlocker & operator = ( const dbPutNotifyBlocker & );
     virtual ~dbPutNotifyBlocker ();
=== modified file 'src/ioc/db/dbSubscriptionIO.cpp'
--- src/ioc/db/dbSubscriptionIO.cpp	2010-10-05 19:27:37 +0000
+++ src/ioc/db/dbSubscriptionIO.cpp	2012-04-12 17:46:27 +0000
@@ -94,13 +94,6 @@
         this->chan.pName(guard), this->type, this->count );
-void * dbSubscriptionIO::operator new ( size_t ) // X aCC 361
 void dbSubscriptionIO::operator delete ( void * )
=== modified file 'src/libCom/cxxTemplates/resourceLib.h'
--- src/libCom/cxxTemplates/resourceLib.h	2010-10-05 19:27:37 +0000
+++ src/libCom/cxxTemplates/resourceLib.h	2012-04-12 17:46:27 +0000
@@ -296,7 +296,7 @@
 // remove a res from the resTable
 template <class T, class ID>
-T * resTable<T,ID>::remove ( const ID & idIn ) // X aCC 361
+T * resTable<T,ID>::remove ( const ID & idIn )
     if ( this->pTable ) {
         // search list for idIn and remove the first match
@@ -341,7 +341,7 @@
 // resTable::lookup ()
-inline T * resTable<T,ID>::lookup ( const ID & idIn ) const // X aCC 361
+inline T * resTable<T,ID>::lookup ( const ID & idIn ) const
         tsSLList<T> & list = this->pTable [ this->hash ( idIn ) ];
@@ -514,7 +514,7 @@
-inline unsigned resTable<T,ID>::tableSize () const // X aCC 361
+inline unsigned resTable<T,ID>::tableSize () const
         return ( this->hashIxMask + 1 ) + this->nextSplitIndex;
@@ -1010,7 +1010,7 @@
 // intId::operator == ()
 template <class T, unsigned MIN_INDEX_WIDTH, unsigned MAX_ID_WIDTH>
-inline bool intId<T, MIN_INDEX_WIDTH, MAX_ID_WIDTH>::operator == // X aCC 361
+inline bool intId<T, MIN_INDEX_WIDTH, MAX_ID_WIDTH>::operator ==
         (const intId<T, MIN_INDEX_WIDTH, MAX_ID_WIDTH> &idIn) const
     return this->id == idIn.id;
@@ -1020,7 +1020,7 @@
 // intId::getId ()
-inline const T intId<T, MIN_INDEX_WIDTH, MAX_ID_WIDTH>::getId () const // X aCC 361
+inline const T intId<T, MIN_INDEX_WIDTH, MAX_ID_WIDTH>::getId () const
     return this->id;
@@ -1067,7 +1067,7 @@
 // intId::hash()
-inline resTableIndex intId<T, MIN_INDEX_WIDTH, MAX_ID_WIDTH>::hash () const // X aCC 361
+inline resTableIndex intId<T, MIN_INDEX_WIDTH, MAX_ID_WIDTH>::hash () const
     return integerHash ( MIN_INDEX_WIDTH, MAX_ID_WIDTH, this->id );
=== modified file 'src/libCom/fdmgr/fdmgr.cpp'
--- src/libCom/fdmgr/fdmgr.cpp	2004-10-08 15:12:20 +0000
+++ src/libCom/fdmgr/fdmgr.cpp	2012-04-12 17:46:27 +0000
@@ -228,7 +228,7 @@
     return 0;
-extern "C" epicsShareFunc int epicsShareAPI fdmgr_add_callback ( // X aCC 361
+extern "C" epicsShareFunc int epicsShareAPI fdmgr_add_callback (
     fdctx *pfdctx, SOCKET fd, enum fdi_type fdi, pCallBackFDMgr pFunc, void *pParam)
     oldFdmgr *pfdm = static_cast <oldFdmgr *> (pfdctx);
@@ -270,7 +270,7 @@
-extern "C" epicsShareFunc int epicsShareAPI fdmgr_clear_callback ( // X aCC 361
+extern "C" epicsShareFunc int epicsShareAPI fdmgr_clear_callback (
     fdctx *pfdctx, SOCKET fd, enum fdi_type	fdi)
=== modified file 'src/libCom/misc/ipAddrToAsciiAsynchronous.cpp'
--- src/libCom/misc/ipAddrToAsciiAsynchronous.cpp	2008-10-21 20:26:48 +0000
+++ src/libCom/misc/ipAddrToAsciiAsynchronous.cpp	2012-04-12 17:46:27 +0000
@@ -61,7 +61,6 @@
     bool pending;
     void ipAddrToAscii ( const osiSockAddr &, ipAddrToAsciiCallBack & );
     void release ();
     friend class ipAddrToAsciiEnginePrivate;
     ipAddrToAsciiTransactionPrivate & operator = ( const ipAddrToAsciiTransactionPrivate & );
@@ -272,13 +271,6 @@
 #endif
-void * ipAddrToAsciiTransactionPrivate::operator new ( size_t ) // X aCC 361
 void ipAddrToAsciiTransactionPrivate::operator delete ( void * )
=== modified file 'src/libCom/misc/ipAddrToAsciiAsynchronous.h'
--- src/libCom/misc/ipAddrToAsciiAsynchronous.h	2010-10-05 19:27:37 +0000
+++ src/libCom/misc/ipAddrToAsciiAsynchronous.h	2012-04-12 17:46:27 +0000
@@ -36,7 +36,7 @@
     virtual ~ipAddrToAsciiCallBack () = 0;
-class epicsShareClass ipAddrToAsciiTransaction { // X aCC 655
+class epicsShareClass ipAddrToAsciiTransaction {
 public:
     virtual void release () = 0;
     virtual void ipAddrToAscii ( const osiSockAddr &, ipAddrToAsciiCallBack & ) = 0;
@@ -46,7 +46,7 @@
     virtual ~ipAddrToAsciiTransaction () = 0;
-class epicsShareClass ipAddrToAsciiEngine { // X aCC 655
+class epicsShareClass ipAddrToAsciiEngine {
 public:
     virtual ipAddrToAsciiTransaction & createTransaction () = 0;
=== modified file 'src/libCom/osi/epicsMutex.cpp'
--- src/libCom/osi/epicsMutex.cpp	2010-03-17 01:09:51 +0000
+++ src/libCom/osi/epicsMutex.cpp	2012-04-12 17:46:27 +0000
@@ -239,7 +239,7 @@
-bool epicsMutex::tryLock () // X aCC 361
+bool epicsMutex::tryLock ()
     epicsMutexLockStatus status = epicsMutexTryLock ( this->id );
     if ( status == epicsMutexLockOK ) {
=== modified file 'src/libCom/osi/os/posix/osdTime.cpp'
--- src/libCom/osi/os/posix/osdTime.cpp	2008-09-15 20:07:23 +0000
+++ src/libCom/osi/os/posix/osdTime.cpp	2012-04-12 17:46:27 +0000
@@ -60,7 +60,7 @@
 static int done = timeRegister();
-int epicsTime_gmtime ( const time_t *pAnsiTime, // X aCC 361
+int epicsTime_gmtime ( const time_t *pAnsiTime,
                        struct tm *pTM )
     struct tm * pRet = gmtime_r ( pAnsiTime, pTM );
@@ -72,7 +72,7 @@
-int epicsTime_localtime ( const time_t *clock, // X aCC 361
+int epicsTime_localtime ( const time_t *clock,
                           struct tm *result )
     struct tm * pRet = localtime_r ( clock, result );
=== modified file 'src/libCom/timer/epicsTimer.h'
--- src/libCom/timer/epicsTimer.h	2010-11-04 16:19:54 +0000
+++ src/libCom/timer/epicsTimer.h	2012-04-12 17:46:27 +0000
@@ -47,7 +47,7 @@
     virtual void show ( unsigned int level ) const;
-class epicsShareClass epicsTimer {              /* X aCC 655 */
+class epicsShareClass epicsTimer {
 public:
     /* calls cancel (see warning below) and then destroys the timer */
     virtual void destroy () = 0;
@@ -70,7 +70,7 @@
     virtual ~epicsTimer () = 0; /* protected => delete() must not be called */
-class epicsTimerQueue {         /* X aCC 655 */
+class epicsTimerQueue {
 public:
     virtual epicsTimer & createTimer () = 0;
     virtual void show ( unsigned int level ) const = 0;
@@ -78,7 +78,7 @@
     epicsShareFunc virtual ~epicsTimerQueue () = 0;
-class epicsTimerQueueActive /* X aCC 655 */
+class epicsTimerQueueActive
     : public epicsTimerQueue {
 public:
     static epicsShareFunc epicsTimerQueueActive & allocate (
@@ -88,7 +88,7 @@
     epicsShareFunc virtual ~epicsTimerQueueActive () = 0;
-class epicsTimerQueueNotify {   /* X aCC 655 */
+class epicsTimerQueueNotify {
 public:
     /* called when a new timer is inserted into the queue and the */
     /* delay to the next expire has changed */
@@ -100,7 +100,7 @@
     epicsShareFunc virtual ~epicsTimerQueueNotify () = 0;
-class epicsTimerQueuePassive /* X aCC 655 */
+class epicsTimerQueuePassive
 public:
     static epicsShareFunc epicsTimerQueuePassive & create ( epicsTimerQueueNotify & );
=== modified file 'src/libCom/timer/timer.cpp'
--- src/libCom/timer/timer.cpp	2009-08-10 21:41:59 +0000
+++ src/libCom/timer/timer.cpp	2012-04-12 17:46:27 +0000
@@ -221,13 +221,6 @@
-void * timer::operator new ( size_t ) // X aCC 361
 void timer::operator delete ( void * )
@@ -239,13 +232,6 @@
         __FILE__, __LINE__ );
-void * epicsTimerForC::operator new ( size_t ) // X aCC 361
 void epicsTimerForC::operator delete ( void * )
=== modified file 'src/libCom/timer/timerPrivate.h'
--- src/libCom/timer/timerPrivate.h	2010-10-05 19:27:37 +0000
+++ src/libCom/timer/timerPrivate.h	2012-04-12 17:46:27 +0000
@@ -60,7 +60,6 @@
     // because if I declare placement new and delete, but
     // comment out the placement delete definition there are
     // no undefined symbols.
     friend class timerQueue;
@@ -83,7 +82,6 @@
@@ -118,7 +116,7 @@
     friend struct epicsTimerForC;
-class timerQueueActiveMgrPrivate { // X aCC 655
+class timerQueueActiveMgrPrivate {
 public:
     timerQueueActiveMgrPrivate ();
 protected:
=== modified file 'src/std/softIoc/softMain.cpp'
--- src/std/softIoc/softMain.cpp	2010-10-05 19:27:37 +0000
+++ src/std/softIoc/softMain.cpp	2012-04-12 17:46:27 +0000
@@ -129,7 +129,7 @@
     softIoc_registerRecordDeviceDriver(pdbbase);
-    registryFunctionAdd("exit", (REGISTRYFUNCTION) exitSubroutine); // X aCC 331
+    registryFunctionAdd("exit", (REGISTRYFUNCTION) exitSubroutine);
     while (argc>1 && **argv == '-') {
 	switch ((*argv)[1]) {
=== modified file 'src/template/base/top/caServerApp/exPV.cc'
--- src/template/base/top/caServerApp/exPV.cc	2003-04-01 19:54:32 +0000
+++ src/template/base/top/caServerApp/exPV.cc	2012-04-12 17:46:27 +0000
@@ -107,7 +107,7 @@
 // exScanTimer::expire ()
-exPV::expire ( const epicsTime & /*currentTime*/ ) // X aCC 361
+exPV::expire ( const epicsTime & /*currentTime*/ )
     this->scan();
     if ( this->scanOn && this->getScanPeriod() > 0.0 ) {
=== modified file 'src/template/base/top/caServerApp/exServer.cc'
--- src/template/base/top/caServerApp/exServer.cc	2009-08-14 00:24:09 +0000
+++ src/template/base/top/caServerApp/exServer.cc	2012-04-12 17:46:27 +0000
@@ -167,7 +167,7 @@
 // exServer::pvExistTest()
-pvExistReturn exServer::pvExistTest // X aCC 361
+pvExistReturn exServer::pvExistTest
     ( const casCtx& ctxIn, const char * pPVName )
@@ -214,7 +214,7 @@
 // exServer::pvAttach()
-pvAttachReturn exServer::pvAttach // X aCC 361
+pvAttachReturn exServer::pvAttach
     (const casCtx &ctx, const char *pName)
=== modified file 'src/template/base/top/caServerApp/exServer.h'
--- src/template/base/top/caServerApp/exServer.h	2009-08-18 00:32:48 +0000
+++ src/template/base/top/caServerApp/exServer.h	2012-04-12 17:46:27 +0000
@@ -103,7 +103,7 @@
 // from pvInfo)
+class pvEntry
     : public stringId, public tsSLNode < pvEntry > {
 public:
     pvEntry ( pvInfo  &infoIn, exServer & casIn,
=== modified file 'src/template/base/top/caServerApp/exVectorPV.cc'
--- src/template/base/top/caServerApp/exVectorPV.cc	2005-10-27 23:56:05 +0000
+++ src/template/base/top/caServerApp/exVectorPV.cc	2012-04-12 17:46:27 +0000
@@ -45,7 +45,7 @@
 // exVectorPV::maxBound()
-aitIndex exVectorPV::maxBound (unsigned dimension) const // X aCC 361
+aitIndex exVectorPV::maxBound (unsigned dimension) const
     if (dimension==0u) {
         return this->info.getElementCount();
=== modified file 'src/tools/Makefile'
--- src/tools/Makefile	2012-03-13 23:00:46 +0000
+++ src/tools/Makefile	2012-04-12 17:46:27 +0000
@@ -36,7 +36,6 @@
 PERL_SCRIPTS += cvsclean.pl
 PERL_SCRIPTS += dos2unix.pl
 PERL_SCRIPTS += expandVars.pl
-PERL_SCRIPTS += filterWarnings.pl
 PERL_SCRIPTS += fullPathName.pl
 PERL_SCRIPTS += installEpics.pl
 PERL_SCRIPTS += makeDbDepends.pl
=== removed file 'src/tools/filterWarnings.pl'
--- src/tools/filterWarnings.pl	2010-10-05 19:27:37 +0000
+++ src/tools/filterWarnings.pl	1970-01-01 00:00:00 +0000
@@ -1,54 +0,0 @@
-eval 'exec perl -S $0 ${1+"$@"}'      # -*- Mode: perl -*-
-	if $running_under_some_shell; # filterWarnings.pl
-# Copyright (c) 2002 The University of Chicago, as Operator of Argonne
-#     National Laboratory.
-# Copyright (c) 2002 The Regents of the University of California, as
-#     Operator of Los Alamos National Laboratory.
-# Copyright (c) 2002 Berliner Elektronenspeicherringgesellschaft fuer
-#     Synchrotronstrahlung.
-# EPICS BASE Versions 3.13.7
-# and higher are distributed subject to a Software License Agreement found
-# in file LICENSE that is included with this distribution.
-# $Revision-Id$
-#  Author: Ralph Lange
-use Text::Wrap;
-my ($errline, $errno, $codeline, $pointline);
-$Text::Wrap::columns = $ENV{COLUMNS} if $ENV{COLUMNS};
-sub Usage
-    print "Usage:\n";
-    print "<compile line> 2>&1 | $0\n";
-    exit 2;
-# Invalid whit space filter on solaris not implemented
-#if ( $ENV{"EPICS_HOST_ARCH"} =~ m/solaris-sparc/ ) {
-#  while ( $errline = <> ) {
-#    if ( $errline !~ m/invalid white space character in directive/ ) {
-#      print $errline;
-#} else {
-  while ( $errline = <> ) {
-    if ( $errline =~ m/^(Warning|Error)/ ) {
-      ($errno) = ($errline =~ m/.* ([0-9]+):/);
-      $codeline = <>;
-      $pointline = <>;
-      next if $codeline =~ m|/[/*]\s*X.*aCC[^a-zA-Z]*$errno|;
-      print wrap ("", "    ", $errline);
-      print $codeline;
-      print $pointline;
[Merge] lp:~anj/epics-base/remove-hpux-artifacts into lp:epics-base noreply
Prev: [Merge] lp:~anj/epics-base/compiled-dbd into lp:epics-base noreply
Next: Problem installing EPICS QT Client manta santosh aditya santosh_aditya
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: [Merge] lp:~anj/epics-base/remove-hpux-artifacts into lp:epics-base noreply
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
