2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: New RTOS cross with linux+RT_PREEMPT patch
To: [email protected]
Date: Tue, 15 May 2012 11:09:57 -0500
Hi Ernest,
On 2012-05-15 Ernest L. Williams Jr. wrote:
> Here at SLAC we are working with a new RTOS (soft real-time)
> As the development continues forward, I hope it approaches hard-real time.
RTLinux is a commercial product from Wind River, is that what you're using?
If not you should pick a different target name.  I'm aware that there is an
Open RTLinux license available for academic, research and free software
projects, but that's using the same code as the commercial product.
> We are proposing the following name in <BASE>/configure/os
> CONFIG.Common.rtlinux-x86
> CONFIG_SITE.Common.rtlinux-x86
> The above is support Intel-based targets.
> Another target we have is a freescale P2020
> CONFIG.Common.rtlinux-ppcP2020
> CONFIG_SITE.Common.rtlinux-ppcP2020
Will these targets be using the standard Linux OS_CLASS or do they require
their own versions of the OS-dependent files under src/libCom/osi/os?
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: New RTOS cross with linux+RT_PREEMPT patch Ernest L. Williams Jr.
Prev: New RTOS cross with linux+RT_PREEMPT patch Ernest L. Williams Jr.
Next: Re: New RTOS cross with linux+RT_PREEMPT patch Ernest L. Williams Jr.
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
