2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Merge] lp:~epics-core/epics-base/server-side-plugins into lp:epics-base
To: [email protected], Ralph Lange <[email protected]>
Date: Wed, 30 May 2012 18:11:19 -0000
mdavidsaver has proposed merging lp:~epics-core/epics-base/server-side-plugins into lp:epics-base.
Requested reviews:
  Ralph Lange (ralph-lange)
  EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~epics-core/epics-base/server-side-plugins/+merge/108028
This branch takes the changes from
lp:~ralph-lange/epics-base/server-side-plugins
And updates them to the current 3.15 branch.  So when reviewing the changes please check also for unintentionally reverted changes from the 3.15 branch.
The attached diff has been truncated due to its size.
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/server-side-plugins into lp:epics-base.
=== modified file '.bzrignore'
--- .bzrignore	2009-12-23 21:06:44 +0000
+++ .bzrignore	2012-05-30 18:10:27 +0000
@@ -6,3 +6,6 @@
 ./include
 ./templates
 **/O.*
+./.cproject
+./.project
+./.settings
=== modified file 'configure/RULES.Db'
--- configure/RULES.Db	2012-05-29 21:44:49 +0000
+++ configure/RULES.Db	2012-05-30 18:10:27 +0000
@@ -397,12 +397,12 @@
 %_registerRecordDeviceDriver.cpp: $(COMMON_DIR)/%.dbd
 	@$(RM) $@ $*.tmp
-	$(REGISTERRECORDDEVICEDRIVER) $< $(basename $@) $(IOC_INST_TOP) > $*.tmp
+	$(REGISTERRECORDDEVICEDRIVER) $(DBDFLAGS) $< $(basename $@) $(IOC_INST_TOP) > $*.tmp
 	$(MV) $*.tmp $@
 %_registerRecordDeviceDriver.cpp: %.dbd
 	@$(RM) $@ $*.tmp
 	$(MV) $*.tmp $@
 .PRECIOUS: %_registerRecordDeviceDriver.cpp
=== modified file 'src/Makefile'
--- src/Makefile	2012-03-14 20:27:40 +0000
+++ src/Makefile	2012-05-30 18:10:27 +0000
@@ -69,6 +69,10 @@
 DIRS += std
 std_DEPEND_DIRS = ioc libCom/RTEMS
+DIRS += ioc/db/filters/test
+ioc/db/filters/test_DEPEND_DIRS = ioc std libCom/RTEMS
 include $(TOP)/configure/RULES_DIRS
=== modified file 'src/ioc/as/asDbLib.c'
--- src/ioc/as/asDbLib.c	2012-05-03 17:19:34 +0000
+++ src/ioc/as/asDbLib.c	2012-05-30 18:10:27 +0000
@@ -6,7 +6,7 @@
 *     Operator of Los Alamos National Laboratory.
 * EPICS BASE Versions 3.13.7
 * and higher are distributed subject to a Software License Agreement found
-* in file LICENSE that is included with this distribution.
+* in file LICENSE that is included with this distribution.
 /* Author:  Marty Kraimer Date:    02-11-94*/
@@ -27,7 +27,7 @@
 #include "caeventmask.h"
 #include "callback.h"
 #include "dbStaticLib.h"
-#include "dbAddr.h"
+#include "dbChannel.h"
 #include "dbAccess.h"
 #include "db_field_log.h"
 #include "dbEvent.h"
@@ -40,7 +40,7 @@
 static char	*psubstitutions=NULL;
 static epicsThreadId	asInitTheadId=0;
 static int	firstTime = TRUE;
 static long asDbAddRecords(void)
     DBENTRY	dbentry;
@@ -98,7 +98,7 @@
     return(0);
 static void asSpcAsCallback(struct dbCommon *precord)
     asChangeGroup(&precord->asp, precord->asg);
@@ -109,7 +109,7 @@
     int *firstTime = (int *)arg;
     *firstTime = FALSE;
 static long asInitCommon(void)
     long	status;
@@ -117,7 +117,7 @@
     int		wasFirstTime = firstTime;
     static epicsThreadOnceId asInitCommonOnceFlag = EPICS_THREAD_ONCE_INIT;
     epicsThreadOnce(&asInitCommonOnceFlag,asInitCommonOnce,(void *)&firstTime);
     if(wasFirstTime) {
         if(!pacf) return(0); /*access security will NEVER be turned on*/
@@ -148,7 +148,7 @@
     return(asInitCommon());
 static void wdCallback(void *arg)
     ASDBCALLBACK *pcallback = (ASDBCALLBACK *)arg;
@@ -195,23 +195,15 @@
     return(0);
-int epicsShareAPI asDbGetAsl(void *paddress)
+int epicsShareAPI asDbGetAsl(struct dbChannel *chan)
-    DBADDR	*paddr = paddress;
-    dbFldDes	*pflddes;
-    pflddes = paddr->pfldDes;
-    return((int)pflddes->as_level);
+    return dbChannelFldDes(chan)->as_level;
-void * epicsShareAPI asDbGetMemberPvt(void *paddress)
+void * epicsShareAPI asDbGetMemberPvt(struct dbChannel *chan)
-    dbCommon	*precord;
-    precord = paddr->precord;
-    return((void *)precord->asp);
+    return dbChannelRecord(chan)->asp;
 static void astacCallback(ASCLIENTPVT clientPvt,asClientStatus status)
@@ -259,7 +251,7 @@
     return(0);
 static void myMemberCallback(ASMEMBERPVT memPvt,FILE *fp)
     dbCommon	*precord;
=== modified file 'src/ioc/as/asDbLib.h'
--- src/ioc/as/asDbLib.h	2010-10-05 19:27:37 +0000
+++ src/ioc/as/asDbLib.h	2012-05-30 18:10:27 +0000
@@ -5,12 +5,12 @@
 /* share/epicsH/dbAsLib.h	*/
 /*  $Revision-Id$ */
 /* Author:  Marty Kraimer Date:    02-23-94*/
 #ifndef INCdbAsLibh
 #define INCdbAsLibh
@@ -22,6 +22,8 @@
     long	status;
 } ASDBCALLBACK;
+struct dbChannel;
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -30,8 +32,8 @@
 epicsShareFunc int epicsShareAPI asSetSubstitutions(const char *substitutions);
 epicsShareFunc int epicsShareAPI asInit(void);
 epicsShareFunc int epicsShareAPI asInitAsyn(ASDBCALLBACK *pcallback);
-epicsShareFunc int epicsShareAPI asDbGetAsl( void *paddr);
-epicsShareFunc void *  epicsShareAPI asDbGetMemberPvt( void *paddr);
+epicsShareFunc int epicsShareAPI asDbGetAsl(struct dbChannel *chan);
+epicsShareFunc void * epicsShareAPI asDbGetMemberPvt(struct dbChannel *chan);
 epicsShareFunc int epicsShareAPI asdbdump(void);
 epicsShareFunc int epicsShareAPI asdbdumpFP(FILE *fp);
 epicsShareFunc int epicsShareAPI aspuag(const char *uagname);
=== modified file 'src/ioc/db/Makefile'
--- src/ioc/db/Makefile	2011-11-14 23:38:36 +0000
+++ src/ioc/db/Makefile	2012-05-30 18:10:27 +0000
@@ -17,9 +17,12 @@
 INC += dbCa.h
 INC += dbAddr.h
 INC += dbBkpt.h
+INC += dbChannel.h
 INC += dbConvert.h
 INC += dbConvertFast.h
+INC += dbExtractArray.h
 INC += dbEvent.h
+INC += dbLink.h
 INC += dbLock.h
 INC += dbNotify.h
 INC += dbScan.h
@@ -30,6 +33,8 @@
 INC += initHooks.h
 INC += recGbl.h
 INC += dbIocRegister.h
+INC += chfPlugin.h
+INC += dbState.h
 INC += db_access_routines.h
 INC += db_convert.h
@@ -50,11 +55,17 @@
 DBDINC += $(basename $(menuGlobal_DBD))
 DBDINC += dbCommon
+DBD_INSTALLS += ../db/filters/filters.dbd
 dbCore_SRCS += dbLock.c
 dbCore_SRCS += dbAccess.c
 dbCore_SRCS += dbBkpt.c
+dbCore_SRCS += dbChannel.c
 dbCore_SRCS += dbConvert.c
 dbCore_SRCS += dbFastLinkConv.c
+dbCore_SRCS += dbExtractArray.c
+dbCore_SRCS += dbLink.c
 dbCore_SRCS += dbNotify.c
 dbCore_SRCS += dbScan.c
 dbCore_SRCS += dbEvent.c
@@ -74,4 +85,13 @@
 dbCore_SRCS += dbContextReadNotifyCache.cpp
 dbCore_SRCS += templateInstances.cpp
 dbCore_SRCS += dbIocRegister.c
+dbCore_SRCS += chfPlugin.c
+dbCore_SRCS += dbState.c
+SRC_DIRS += $(IOCDIR)/db/filters
+dbCore_SRCS += ts.c
+dbCore_SRCS += dbnd.c
+dbCore_SRCS += arr.c
+dbCore_SRCS += sync.c
=== added file 'src/ioc/db/chfPlugin.c'
--- src/ioc/db/chfPlugin.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/chfPlugin.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,641 @@
+* Copyright (c) 2010 Brookhaven National Laboratory.
+* Copyright (c) 2010 Helmholtz-Zentrum Berlin
+*     fuer Materialien und Energie GmbH.
+* EPICS BASE is distributed subject to a Software License Agreement found
+ *  Author: Ralph Lange <[email protected]>
+/* Based on the linkoptions utility by Michael Davidsaver (BNL) */
+#include <stdio.h>
+#include <stdlib.h>
+#include <errno.h>
+#include <string.h>
+#include <limits.h>
+#include <math.h>
+#include <dbDefs.h>
+#include <dbStaticLib.h>
+#include <epicsTypes.h>
+#include <epicsString.h>
+#include <errlog.h>
+#include <shareLib.h>
+#define epicsExportSharedSymbols
+#include "chfPlugin.h"
+#ifndef HUGE_VALF
+#  define HUGE_VALF HUGE_VAL
+#endif
+#ifndef HUGE_VALL
+#  define HUGE_VALL (-(HUGE_VAL))
+#endif
+ * Data for a chfPlugin
+typedef struct chfPlugin {
+    const chfPluginArgDef *opts;
+    size_t nopts;
+    epicsUInt32 *required;
+    const chfPluginIf *pif;
+} chfPlugin;
+ * Parser state data for a chfFilter (chfPlugin instance)
+typedef struct chfFilter {
+    const chfPlugin *plugin;
+    epicsUInt32 *found;
+    void *puser;
+    epicsInt16 nextParam;
+} chfFilter;
+/* Data types we get from the parser */
+typedef enum chfPluginType {
+    chfPluginTypeBool,
+    chfPluginTypeInt,
+    chfPluginTypeDouble,
+    chfPluginTypeString
+} chfPluginType;
+ * Convert the (long) integer value 'val' to the type named in 'opt->optType'
+ * and store the result at 'user + opt->offset'.
+static int store_integer_value(const chfPluginArgDef *opt, void *user, long val)
+    long *ival;
+    int *eval;
+    const chfPluginEnumType *emap;
+    double *dval;
+    char *sval;
+    char buff[22];              /* 2^64 = 1.8e+19, so 20 digits plus sign max */
+/*    printf("Got an integer for %s (type %d): %ld\n", opt->name, opt->optType, val); */
+    if (!opt->convert && opt->optType != chfPluginArgInt32) {
+        return -1;
+    switch (opt->optType) {
+    case chfPluginArgInt32:
+        ival = (long*) ((char*)user + opt->offset);
+        *ival = val;
+        break;
+    case chfPluginArgBoolean:
+        eval = (int*) ((char*)user + opt->offset);
+        *eval = !!val;
+        break;
+    case chfPluginArgDouble:
+        dval = (double*) ((char*)user + opt->offset);
+        *dval = (double) val;
+        break;
+    case chfPluginArgString:
+        sval = ((char*)user + opt->offset);
+        sprintf(buff, "%ld", val);
+        if (strlen(buff) > opt->size-1) {
+            return -1;
+        strncpy(sval, buff, opt->size-1);
+        sval[opt->size-1]='\0';
+        break;
+    case chfPluginArgEnum:
+        for (emap = opt->enums; emap && emap->name; emap++) {
+            if (val == emap->value) {
+                *eval = val;
+                break;
+        if (!emap || !emap->name) {
+            return -1;
+        break;
+    case chfPluginArgInvalid:
+        return -1;
+    return 0;
+ * Convert the (int) boolean value 'val' to the type named in 'opt->optType'
+static int store_boolean_value(const chfPluginArgDef *opt, void *user, int val)
+    long *ival;
+    int *eval;
+    double *dval;
+    char *sval;
+/*    printf("Got a boolean for %s (type %d): %d\n", opt->name, opt->optType, val); */
+    if (!opt->convert && opt->optType != chfPluginArgBoolean) {
+        return -1;
+        *ival = val;
+        break;
+        *eval = val;
+        break;
+        *dval = val ? 1. : 0.;
+        break;
+        if ((val ? 4 : 5) > opt->size-1) {
+            return -1;
+        strncpy(sval, (val ? "true" : "false"), opt->size-1);
+        break;
+        return -1;
+    return 0;
+ * Convert the double value 'val' to the type named in 'opt->optType'
+static int store_double_value(const chfPluginArgDef *opt, void *user, double val)
+    long *ival;
+    int *eval;
+    double *dval;
+    char *sval;
+    int i;
+    printf("Got a double for %s (type %d, convert: %s): %g\n",
+           opt->name, opt->optType, opt->convert?"yes":"no", val);
+    if (!opt->convert && opt->optType != chfPluginArgDouble) {
+        return -1;
+        if (val < LONG_MIN || val > LONG_MAX) {
+            return -1;
+        *ival = (long) val;
+        break;
+        *eval = (val != 0.) ? 1 : 0;
+        break;
+        *dval = val;
+        break;
+        if (opt->size <= 8) {       /* Play it safe: 3 exp + 2 sign + 'e' + '.' */
+            return -1;
+        i = snprintf(sval, opt->size, "%.*g", opt->size - 7, val);
+        if (i >= opt->size) {
+            return -1;
+        break;
+        return -1;
+    return 0;
+ * Convert the (char*) string value 'val' to the type named in 'opt->optType'
+static int store_string_value(const chfPluginArgDef *opt, void *user, const char *val, size_t len)
+    long *ival;
+    int *eval;
+    double *dval;
+    char *sval;
+    char *end;
+    int i;
+/*    printf("Got a string for %s (type %d): %.*s\n", opt->name, opt->optType, len, val); */
+    if (!opt->convert && opt->optType != chfPluginArgString && opt->optType != chfPluginArgEnum) {
+        return -1;
+        *ival = strtol(val, &end, 0);
+        /* test for the myriad error conditions which strtol may use */
+        if (*ival == LONG_MAX || *ival == LONG_MIN || end == val) {
+            return -1;
+        break;
+        if (strncasecmp(val, "true", len) == 0) {
+            *eval = 1;
+        } else if (strncasecmp(val, "false", len) == 0) {
+            *eval = 0;
+        } else {
+            i = strtol(val, &end, 0);
+            if (i > INT_MAX || i < INT_MIN || end == val) {
+                return -1;
+            *eval = !!i;
+        break;
+        *dval = strtod(val, &end);
+        /* Indicates errors in the same manner as strtol */
+        if (*dval==HUGE_VALF||*dval==HUGE_VALL||end==val )
+            return -1;
+        break;
+        i = opt->size-1 < len ? opt->size-1 : len;
+        strncpy(sval, val, i);
+        sval[i] = '\0';
+        break;
+            if (strncmp(emap->name, val, len) == 0) {
+                *eval = emap->value;
+                break;
+        if( !emap || !emap->name ) {
+            return -1;
+        break;
+        return -1;
+    return 0;
+static void freeInstanceData(chfFilter *f)
+    free(f->found);  /* FIXME: Use a free-list */
+    free(f);         /* FIXME: Use a free-list */
+ * chFilterIf callbacks
+/* First entry point when a new filter instance is created.
+ * All per-instance allocations happen here.
+static parse_result parse_start(chFilter *filter)
+    chfPlugin *p = (chfPlugin*) filter->plug->puser;
+    chfFilter *f;
+    /* Filter context */
+    /* FIXME: Use a free-list */
+    f = calloc(1, sizeof(chfFilter));
+    if (!f) {
+        fprintf(stderr,"chfFilterCtx calloc failed\n");
+        goto errfctx;
+    f->nextParam = -1;
+    /* Bit array to find missing required keys */
+    f->found = calloc( (p->nopts/32)+1, sizeof(epicsUInt32) );
+    if (!f->found) {
+        fprintf(stderr,"chfConfigParseStart: bit array calloc failed\n");
+        goto errbitarray;
+    /* Call the plugin to allocate its structure, it returns NULL on error */
+    if (p->pif->allocPvt) {
+        if ((f->puser = p->pif->allocPvt()) == NULL)
+            goto errplugin;
+    filter->puser = (void*) f;
+    return parse_continue;
+    errplugin:
+    errbitarray:
+    errfctx:
+    return parse_stop;
+static void parse_abort(chFilter *filter) {
+    chfFilter *f = (chfFilter*) filter->puser;
+    /* Call the plugin to tell it we're aborting */
+    if (p->pif->parse_error) p->pif->parse_error(f->puser);
+    if (p->pif->freePvt) p->pif->freePvt(f->puser);
+    freeInstanceData(f);
+static parse_result parse_end(chFilter *filter)
+    int i;
+    /* Check if all required arguments were supplied */
+    for(i = 0; i < (p->nopts/32)+1; i++) {
+        if ((f->found[i] & p->required[i]) != p->required[i]) {
+    /* Call the plugin to tell it we're done */
+    if (p->pif->parse_ok) {
+        if (p->pif->parse_ok(f->puser)) {
+static parse_result parse_boolean(chFilter *filter, int boolVal)
+    const chfPluginArgDef *opts = ((chfPlugin*)filter->plug->puser)->opts;
+    chfFilter *f =  (chfFilter*)filter->puser;
+    if (f->nextParam < 0 || store_boolean_value(&opts[f->nextParam], f->puser, boolVal)) {
+    } else {
+static parse_result parse_integer(chFilter *filter, long integerVal)
+    if (f->nextParam < 0 || store_integer_value(&opts[f->nextParam], f->puser, integerVal)) {
+    } else {
+static parse_result parse_double(chFilter *filter, double doubleVal)
+    if (f->nextParam < 0 || store_double_value(&opts[f->nextParam], f->puser, doubleVal)) {
+    } else {
+static parse_result parse_string(chFilter *filter, const char *stringVal, size_t stringLen)
+    if (f->nextParam < 0 || store_string_value(&opts[f->nextParam], f->puser, stringVal, stringLen)) {
+    } else {
+static parse_result parse_start_map(chFilter *filter)
+static parse_result parse_map_key(chFilter *filter, const char *key, size_t stringLen)
+    const chfPluginArgDef *cur;
+    int i;
+    for(cur = opts, i = 0; cur && cur->name; cur++, i++) {
+        if (strncmp(key, cur->name, stringLen) == 0) {
+            f->nextParam = i;
+            break;
+    if (f->nextParam == -1) {
+    f->found[i/32] |= 1<<(i%32);
+static parse_result parse_end_map(chFilter *filter)
+static long channel_open(chFilter *filter)
+    if (p->pif->channel_open) return p->pif->channel_open(filter->chan, f->puser);
+    else return 0;
+static void channel_register_pre(chFilter *filter,
+                                 chPostEventFunc **cb_out, void **arg_out, db_field_log *probe)
+    if (p->pif->channelRegisterPre)
+        p->pif->channelRegisterPre(filter->chan, f->puser, cb_out, arg_out, probe);
+static void channel_register_post(chFilter *filter,
+    if (p->pif->channelRegisterPost)
+        p->pif->channelRegisterPost(filter->chan, f->puser, cb_out, arg_out, probe);
+static void channel_report(chFilter *filter, int level, const unsigned short indent)
+    if (p->pif->channel_report)
+        p->pif->channel_report(filter->chan, f->puser, level, indent);
+static void channel_close(chFilter *filter)
+    if (p->pif->channel_close) p->pif->channel_close(filter->chan, f->puser);
+ * chFilterIf for the wrapper
+ * we just support a simple one-level map, and no arrays
+static chFilterIf wrapper_fif = {
+    parse_start,
+    parse_abort,
+    parse_end,
+    NULL, /* parse_null, */
+    parse_boolean,
+    parse_integer,
+    parse_double,
+    parse_string,
+    parse_start_map,
+    parse_map_key,
+    parse_end_map,
+    NULL, /* parse_start_array, */
+    NULL, /* parse_end_array, */
+    channel_open,
+    channel_register_pre,
+    channel_register_post,
+    channel_report,
+    channel_close
+const char* chfPluginEnumString(const chfPluginEnumType *emap, int i, const char* def)
+    for(; emap && emap->name; emap++) {
+        if ( i == emap->value ) {
+            return emap->name;
+    return def;
+int chfPluginRegister(const char* key, const chfPluginIf *pif, const chfPluginArgDef* opts)
+    chfPlugin *p;
+    size_t i;
+    epicsUInt32 *reqd;
+    /* Check and count options */
+    for (i = 0, cur = opts; cur && cur->name; i++, cur++) {
+        switch(cur->optType) {
+            if (cur->size < sizeof(long)) {
+                errlogPrintf("Plugin %s: provided storage (%d bytes) for %s is too small for long (%lu)\n",
+                             key, cur->size, cur->name,
+                             (unsigned long) sizeof(long));
+                return -1;
+            break;
+            if (cur->size < 1) {
+                errlogPrintf("Plugin %s: provided storage (%d bytes) for %s is too small for boolean (%lu)\n",
+                             (unsigned long) sizeof(char));
+                return -1;
+            break;
+            if (cur->size < sizeof(double)) {
+                errlogPrintf("Plugin %s: provided storage (%d bytes) for %s is too small for double (%lu)\n",
+                             (unsigned long) sizeof(double));
+                return -1;
+            break;
+            if (cur->size < sizeof(char*)) {
+                  /* Catch if someone has given us a char* instead of a char[]
+                   * Also means that char buffers must be >=4.
+                errlogPrintf("Plugin %s: provided storage (%d bytes) for %s is too small for string (>= %lu)\n",
+                             (unsigned long) sizeof(char*));
+                return -1;
+            break;
+            if (cur->size < sizeof(int)) {
+                errlogPrintf("Plugin %s: provided storage (%d bytes) for %s is too small for enum (%lu)\n",
+                             (unsigned long) sizeof(int));
+                return -1;
+            break;
+            errlogPrintf("Plugin %s: storage type for %s is not defined\n",
+                         key, cur->name);
+            return -1;
+            break;
+    /* Bit array used to find missing required keys */
+    reqd = dbCalloc((i/32)+1, sizeof(epicsUInt32));
+    if (!reqd) {
+        fprintf(stderr,"Plugin %s: bit array calloc failed\n", key);
+        return -1;
+        if (cur->required) reqd[i/32] |= 1 << (i%32);
+    /* Plugin data */
+    p = dbCalloc(1, sizeof(chfPlugin));
+    p->pif = pif;
+    p->opts = opts;
+    p->nopts = i;
+    p->required = reqd;
+    dbRegisterFilter(key, &wrapper_fif, p);
+    return 0;
=== added file 'src/ioc/db/chfPlugin.h'
--- src/ioc/db/chfPlugin.h	1970-01-01 00:00:00 +0000
+++ src/ioc/db/chfPlugin.h	2012-05-30 18:10:27 +0000
@@ -0,0 +1,280 @@
+#ifndef CHFPLUGIN_H
+#define CHFPLUGIN_H
+#include <dbChannel.h>
+struct db_field_log;
+/** @file chfPlugin.h
+ * @brief Channel filter simplified plugins.
+ * Utility layer to allow an easier (reduced) interface for
+ * channel filter plugins.
+ * Parsing the configuration arguments of a channel filter plugin
+ * is done according to an argument description table provided by the plugin.
+ * The parser stores the results directly into a user supplied structure
+ * after appropriate type conversion.
+ * To specify the arguments, a chfPluginArgDef table must be defined
+ * for the user structure. This table has to be specified when the plugin registers.
+ * The plugin is responsible to register an init function using
+ * epicsExportRegistrar() and the accompanying registrar() directive in the dbd,
+ * and call chfPluginRegister() from within the init function.
+ * For example:
+ * typedef struct myStruct {
+ *   ... other stuff
+ *   epicsUInt32 ival;
+ *   double      dval;
+ *   epicsUInt32 ival2;
+ *   int         enumval;
+ *   char       strval[20];
+ * } myStruct;
+ * static const
+ * chfPluginEnumType colorEnum[] = { {"Red",1}, {"Green",2}, {"Blue",3}, {NULL,0} };
+ * static const
+ * chfPluginDef myStructDef[] = {
+ *   chfInt32 (myStruct, ival,    "Integer" , 0, 0),
+ *   chfInt32 (myStruct, ival2,   "Second"  , 1, 0),
+ *   chfDouble(myStruct, dval,    "Double"  , 1, 0),
+ *   chfString(myStruct, strval , "String"  , 1, 0),
+ *   chfEnum  (myStruct, enumval, "Color"   , 1, 0, colorEnum),
+ *   chfPluginEnd
+ * Note: The 4th argument specifies the parameter to be required (1) or optional (0),
+ *       the 5th whether converting to the required type is allowed (1), or
+ *       type mismatches are an error (0).
+#ifdef __cplusplus
+extern "C" {
+#endif
+/** @brief Channel filter simplified plugin interface.
+ * The routines in this structure must be implemented by each filter plugin.
+typedef struct chfPluginIf {
+    /* Memory management */
+    /** @brief Allocate private resources.
+     * <em>Called before parsing starts.</em>
+     * The plugin should allocate its per-instance structures,
+     * returning a pointer to them or NULL requesting an abort of the operation.
+     * allocPvt may be set to NULL, if no resource allocation is needed.
+     * @return Pointer to private structure, NULL if operation is to be aborted.
+    void * (* allocPvt) (void);
+    /** @brief Free private resources.
+     * <em>Called as part of abort or shutdown.</em>
+     * The plugin should release any resources allocated for this filter;
+     * no further calls through this interface will be made.
+     * freePvt may be set to NULL, if no resources need to be released.
+     * @param pvt Pointer to private structure.
+    void (* freePvt) (void *pvt);
+    /* Parameter parsing results */
+    /** @brief A parsing error occurred.
+     * <em>Called after parsing failed with an error.</em>
+    void (* parse_error) (void *pvt);
+    /** @brief Configuration has been parsed successfully.
+     * <em>Called after parsing has finished ok.</em>
+     * The plugin may check the validity of the parsed data,
+     * returning -1 to request an abort of the operation.
+     * @return 0 for success, -1 if operation is to be aborted.
+    int (* parse_ok) (void *pvt);
+    /* Channel operations */
+    /** @brief Open channel.
+     * <em>Called as part of the channel connection setup.</em>
+     * @param chan dbChannel for which the connection is being made.
+    long (* channel_open) (dbChannel *chan, void *pvt);
+    /** @brief Register callbacks for pre-event-queue operation.
+     * This function is called to establish the stack of plugins that an event
+     * is passed through between the database and the event queue.
+     * The plugin must set pe_out to point to its own post-event callback in order
+     * to be called when a data update is sent from the database towards the
+     * event queue.
+     * The plugin may find out the type of data it will receive by looking at 'probe'.
+     * If the plugin will change the data type and/or size, it must update 'probe'
+     * accordingly.
+     * @param cb_out Pointer to this plugin's post-event callback (NULL to bypass
+     *        this plugin).
+     * @param arg_out Argument that must be supplied when calling
+     *        this plugin's post-event callback.
+    void (* channelRegisterPre) (dbChannel *chan, void *pvt,
+                                 db_field_log *probe);
+    /** @brief Register callbacks for post-event-queue operation.
+     * is passed through between the event queue and the final user (CA server or
+     * database access).
+     * to be called when a data update is sent from the event queue towards the
+     * final user.
+     * accordingly.
+     *        this plugin).
+    void (* channelRegisterPost) (dbChannel *chan, void *pvt,
+    /** @brief Channel report request.
+     * <em>Called as part of show... routines.</em>
+     * @param chan dbChannel for which the report is requested.
+     * @param level Interest level.
+     * @param indent Number of spaces to print before each output line.
+    void (* channel_report) (dbChannel *chan, void *pvt, int level, const unsigned short indent);
+    /* FIXME: More filter routines here ... */
+    /** @brief Channel close request.
+     * <em>Called as part of connection shutdown.</em>
+     * @param chan dbChannel for which the connection is being shut down.
+    void (* channel_close) (dbChannel *chan, void *pvt);
+} chfPluginIf;
+typedef enum chfPluginArg {
+    chfPluginArgInvalid=0,
+    chfPluginArgBoolean,
+    chfPluginArgInt32,
+    chfPluginArgDouble,
+    chfPluginArgString,
+    chfPluginArgEnum
+} chfPluginArg;
+typedef struct chfPluginEnumType {
+    const char *name;
+    const int value;
+} chfPluginEnumType;
+typedef struct chfPluginArgDef {
+    const char * name;
+    chfPluginArg optType;
+    int required:1;
+    int convert:1;
+    epicsUInt32 offset;
+    epicsUInt32 size;
+    const chfPluginEnumType *enums;
+} chfPluginArgDef;
+#define chfInt32(Struct, Member, Name, Req, Conv) \
+{Name, chfPluginArgInt32, Req, Conv, OFFSET(Struct, Member), sizeof( ((Struct*)0)->Member ), NULL}
+#define chfBoolean(Struct, Member, Name, Req, Conv) \
+{Name, chfPluginArgBoolean, Req, Conv, OFFSET(Struct, Member), sizeof( ((Struct*)0)->Member ), NULL}
+#define chfDouble(Struct, Member, Name, Req, Conv) \
+{Name, chfPluginArgDouble, Req, Conv, OFFSET(Struct, Member), sizeof( ((Struct*)0)->Member ), NULL}
+#define chfString(Struct, Member, Name, Req, Conv) \
+{Name, chfPluginArgString, Req, Conv, OFFSET(Struct, Member), sizeof( ((Struct*)0)->Member ), NULL}
+#define chfEnum(Struct, Member, Name, Req, Conv, Enums) \
+{Name, chfPluginArgEnum, Req, Conv, OFFSET(Struct, Member), sizeof( ((Struct*)0)->Member ), Enums}
+#define chfPluginArgEnd {0}
+/* Extra output when parsing and converting */
+#define CHFPLUGINDEBUG 1
+/** @brief Return the string associated with Enum index 'i'.
+ * @param Enums A null-terminated array of string/integer pairs.
+ * @param i An Enum index.
+ * @param def String to be returned when 'i' isn't a valid Enum index.
+ * @return The string associated with 'i'.
+epicsShareFunc const char* chfPluginEnumString(const chfPluginEnumType *Enums, int i, const char* def);
+/** @brief Register a plugin.
+ * @param key The plugin name key that clients will use.
+ * @param pif Pointer to the plugin's interface.
+ * @param opts Pointer to the configuration argument description table.
+epicsShareFunc int chfPluginRegister(const char* key, const chfPluginIf *pif, const chfPluginArgDef* opts);
+#ifdef __cplusplus
+#endif
+#endif // CHFPLUGIN_H
=== modified file 'src/ioc/db/dbAccess.c'
--- src/ioc/db/dbAccess.c	2012-02-20 16:01:04 +0000
+++ src/ioc/db/dbAccess.c	2012-05-30 18:10:27 +0000
@@ -1,21 +1,22 @@
 * Copyright (c) 2002 The University of Chicago, as Operator of Argonne
 *     National Laboratory.
 * Copyright (c) 2002 The Regents of the University of California, as
-* EPICS BASE Versions 3.13.7
-* and higher are distributed subject to a Software License Agreement found
-/* dbAccess.c */
-/* $Revision-Id$ */
  *      Original Author: Bob Dalesio
  *      Current Author:  Marty Kraimer
- *      Date:            11-7-90
+ *                       Andrew Johnson <[email protected]>
+ *                       Ralph Lange <[email protected]>
 #include <stddef.h>
 #include <stdlib.h>
 #include <stdarg.h>
@@ -46,6 +47,7 @@
 #include "dbAddr.h"
 #include "dbScan.h"
+#include "dbLink.h"
 #include "dbLock.h"
 #include "dbConvert.h"
@@ -89,17 +91,6 @@
 /* The following is to handle SPC_AS */
 static SPC_ASCALLBACK spcAsCallback = 0;
-static void inherit_severity(const struct pv_link *ppv_link,
-    dbCommon *pdest, epicsEnum16 stat, epicsEnum16 sevr)
-    switch(ppv_link->pvlMask&pvlOptMsMode) {
-        case pvlOptNMS: break;
-        case pvlOptMSI: if (sevr < INVALID_ALARM) break;
-        case pvlOptMS:  recGblSetSevr(pdest,LINK_ALARM,sevr); break;
-        case pvlOptMSS: recGblSetSevr(pdest,stat,sevr); break;
 void epicsShareAPI dbSpcAsRegisterCallback(SPC_ASCALLBACK func)
@@ -113,7 +104,7 @@
     dbCommon 	*precord = paddr->precord;
     long	status=0;
     long	special=paddr->special;
     prset = dbGetRset(paddr);
     if(special<100) { /*global processing*/
 	if((special==SPC_NOMOD) && (pass==0)) {
@@ -139,7 +130,7 @@
     return(0);
 static void get_enum_strs(DBADDR *paddr, char **ppbuffer,
 	struct rset *prset,long	*options)
@@ -199,7 +190,7 @@
 	*ppbuffer = ((char *)*ppbuffer) + dbr_enumStrs_size;
 	return;
 static void get_graphics(DBADDR *paddr, char **ppbuffer,
@@ -239,7 +230,7 @@
 	return;
 static void get_control(DBADDR *paddr, char **ppbuffer,
@@ -279,7 +270,7 @@
 	return;
 static void get_alarm(DBADDR *paddr, char **ppbuffer,
@@ -324,35 +315,44 @@
 	return;
-static void getOptions(DBADDR *paddr,char **poriginal,long *options,void *pflin)
+ * This code relies on *poriginal being aligned and all increments done by the
+ * blocks only changing the buffer pointer in a way that does not break alignment.
+static void getOptions(DBADDR *paddr, char **poriginal, long *options,
+        void *pflin)
 	db_field_log	*pfl= (db_field_log *)pflin;
 	struct rset	*prset;
-	short		field_type=paddr->field_type;
+        short		field_type;
 	dbCommon	*pcommon;
 	char		*pbuffer = *poriginal;
+        if (!pfl || pfl->type == dbfl_type_rec)
+            field_type = paddr->field_type;
+        else
+            field_type = pfl->field_type;
 	prset=dbGetRset(paddr);
 	/* Process options */
 	pcommon = paddr->precord;
 	if( (*options) & DBR_STATUS ) {
 	    unsigned short *pushort = (unsigned short *)pbuffer;
-	    if(pfl!=NULL) {
-		*pushort++ = pfl->stat;
-		*pushort++ = pfl->sevr;
-	    } else {
-		*pushort++ = pcommon->stat;
-		*pushort++ = pcommon->sevr;
+            if (!pfl || pfl->type == dbfl_type_rec) {
+                *pushort++ = pcommon->stat;
+                *pushort++ = pcommon->sevr;
+            } else {
+                *pushort++ = pfl->stat;
+                *pushort++ = pfl->sevr;
 	    *pushort++ = pcommon->acks;
 	    *pushort++ = pcommon->ackt;
 	    pbuffer = (char *)pushort;
 	if( (*options) & DBR_UNITS ) {
 	    memset(pbuffer,'\0',dbr_units_size);
-	    if( prset && prset->get_units ){
+	    if( prset && prset->get_units ){
 		(*prset->get_units)(paddr, pbuffer);
 		pbuffer[DB_UNITS_SIZE-1] = '\0';
 	    } else {
@@ -363,7 +363,7 @@
 	if( (*options) & DBR_PRECISION ) {
 	    memset(pbuffer, '\0', dbr_precision_size);
 	    if((field_type==DBF_FLOAT || field_type==DBF_DOUBLE)
-	    &&  prset && prset->get_precision ){
+	    &&  prset && prset->get_precision ){
 		(*prset->get_precision)(paddr,pbuffer);
 	    } else {
 		*options ^= DBR_PRECISION; /*Turn off DBR_PRECISION*/
@@ -373,12 +373,12 @@
 	if( (*options) & DBR_TIME ) {
 	    epicsUInt32 *ptime = (epicsUInt32 *)pbuffer;
-	    if(pfl!=NULL) {
-		*ptime++ = pfl->time.secPastEpoch;
-		*ptime++ = pfl->time.nsec;
-	    } else {
-		*ptime++ = pcommon->time.secPastEpoch;
-		*ptime++ = pcommon->time.nsec;
+                *ptime++ = pcommon->time.secPastEpoch;
+                *ptime++ = pcommon->time.nsec;
+            } else {
+                *ptime++ = pfl->time.secPastEpoch;
+                *ptime++ = pfl->time.nsec;
 	    pbuffer = (char *)ptime;
@@ -392,7 +392,7 @@
 	    get_alarm(paddr, &pbuffer, prset, options);
 	*poriginal = pbuffer;
 struct rset * epicsShareAPI dbGetRset(const struct dbAddr *paddr)
 	struct dbFldDes *pfldDes = paddr->pfldDes;
@@ -419,10 +419,10 @@
 int epicsShareAPI dbIsValueField(const struct dbFldDes *pdbFldDes)
-    if(pdbFldDes->pdbRecordType->indvalFlddes == pdbFldDes->indRecordType)
-	return(TRUE);
+    if (pdbFldDes->pdbRecordType->indvalFlddes == pdbFldDes->indRecordType)
+        return TRUE;
     else
-	return(FALSE);
+        return FALSE;
 int epicsShareAPI dbGetFieldIndex(const struct dbAddr *paddr)
@@ -430,50 +430,6 @@
     return paddr->pfldDes->indRecordType;
-long epicsShareAPI dbGetNelements(const struct link *plink,long *nelements)
-    switch(plink->type) {
-    case CONSTANT:
-	*nelements = 0;
-	return(0);
-    case DB_LINK: {
-	    DBADDR *paddr = (DBADDR *)plink->value.pv_link.pvt;
-	    *nelements = paddr->no_elements;
-	    return(0);
-    case CA_LINK:
-	return(dbCaGetNelements(plink,nelements));
-    default:
-	break;
-    return(S_db_badField);
-int epicsShareAPI dbIsLinkConnected(const struct link *plink)
-	case DB_LINK: return(TRUE);
-	case CA_LINK: return(dbCaIsLinkConnected(plink));
-	default: break;
-    return(FALSE);
-int epicsShareAPI dbGetLinkDBFtype(const struct link *plink)
-	case DB_LINK:
-	    return((int)paddr->field_type);
-	case CA_LINK: return(dbCaGetLinkDBFtype(plink));
-	default: break;
-    return(-1);
  *  Process a record if its scan field is passive.
  *     Will notify if processing is complete by callback.
@@ -481,50 +437,15 @@
 long epicsShareAPI dbScanPassive(dbCommon *pfrom, dbCommon *pto)
-    long status;
     /* if not passive just return success */
-    if(pto->scan != 0) return(0);
-    if(pfrom && pfrom->ppn) dbNotifyAdd(pfrom,pto);
-    status = dbProcess(pto);
-    return(status);
-/*KLUDGE: Following needed so that dbPutLink to PROC field works correctly*/
-long epicsShareAPI dbScanLink(dbCommon *pfrom, dbCommon *pto)
-    long		status;
-    unsigned char	pact;
-    pact = pfrom->pact;
-    pfrom->pact = TRUE;
-    pfrom->pact = pact;
-    return(status);
-void epicsShareAPI dbScanFwdLink(struct link *plink)
-    struct pv_link      *pvlink;
-    short               fwdLinkValue;
-    if(plink->type!=DB_LINK && plink->type!=CA_LINK) return;
-    pvlink = &plink->value.pv_link;
-    precord = pvlink->precord;
-    if(plink->type==DB_LINK) {
-        dbAddr *paddr = (dbAddr *)plink->value.pv_link.pvt;
-        dbScanPassive(precord,paddr->precord);
-        return;
-    if(!(pvlink->pvlMask & pvlOptFWD)) return;
-    fwdLinkValue = 1;
-    dbCaPutLink(plink,DBR_SHORT,&fwdLinkValue,1);
-    return;
+    if (pto->scan != 0)
+        return 0;
+    if (pfrom && pfrom->ppn)
+        dbNotifyAdd(pfrom,pto);
+    return dbProcess(pto);
  *   Process the record.
  *     1.  Check for breakpoints.
@@ -536,121 +457,127 @@
 long epicsShareAPI dbProcess(dbCommon *precord)
-	struct rset	*prset = precord->rset;
-	dbRecordType	*pdbRecordType = precord->rdes;
-	unsigned char	tpro=precord->tpro;
-	long		status = 0;
-        int             *ptrace;
-	int		set_trace=FALSE;
-	dbFldDes	*pdbFldDes;
-        int             callNotifyCompletion = FALSE;
-        ptrace = dbLockSetAddrTrace(precord);
+    struct rset *prset = precord->rset;
+    dbRecordType *pdbRecordType = precord->rdes;
+    unsigned char tpro = precord->tpro;
+    long status = 0;
+    int *ptrace;
+    int	set_trace = FALSE;
+    dbFldDes *pdbFldDes;
+    int callNotifyCompletion = FALSE;
+    ptrace = dbLockSetAddrTrace(precord);
+     *  Note that it is likely that if any changes are made
+     *   to dbProcess() corresponding changes will have to
+     *   be made in the breakpoint handler.
+    /* see if there are any stopped records or breakpoints */
+    if (lset_stack_count != 0) {
-         *  Note that it is likely that if any changes are made
-         *   to dbProcess() corresponding changes will have to
-         *   be made in the breakpoint handler.
+         *  Check to see if the record should be processed
+         *   and activate breakpoint accordingly.  If this
+         *   function call returns non-zero, skip record
+         *   support and fall out of dbProcess().  This is
+         *   done so that a dbContTask() can be spawned to
+         *   take over record processing for the lock set
+         *   containing a breakpoint.
-        /* see if there are any stopped records or breakpoints */
-        if (lset_stack_count != 0) {
-            *  Check to see if the record should be processed
-            *   and activate breakpoint accordingly.  If this
-            *   function call returns non-zero, skip record
-            *   support and fall out of dbProcess().  This is
-            *   done so that a dbContTask() can be spawned to
-            *   take over record processing for the lock set
-            *   containing a breakpoint.
-            if (dbBkpt(precord))
-                goto all_done;
-	/* check for trace processing*/
-	if (tpro) {
-                if(*ptrace==0) {
-                        *ptrace = 1;
-			set_trace = TRUE;
-	/* If already active dont process */
-	if (precord->pact) {
-		unsigned short	monitor_mask;
-		if (*ptrace) printf("%s: Active %s\n",
-                        epicsThreadGetNameSelf(), precord->name);
-		/* raise scan alarm after MAX_LOCK times */
-		if (precord->stat==SCAN_ALARM) goto all_done;
-		if (precord->lcnt++ !=MAX_LOCK) goto all_done;
-		if (precord->sevr>=INVALID_ALARM) goto all_done;
-		recGblSetSevr(precord, SCAN_ALARM, INVALID_ALARM);
-		monitor_mask = recGblResetAlarms(precord);
-		monitor_mask |= DBE_VALUE|DBE_LOG;
-		pdbFldDes = pdbRecordType->papFldDes[pdbRecordType->indvalFlddes];
-		db_post_events(precord,
-			(void *)(((char *)precord) + pdbFldDes->offset),
-			monitor_mask);
-		goto all_done;
-        else precord->lcnt = 0;
-        *  Check the record disable link.  A record will not be
-        *    processed if the value retrieved through this link
-        *    is equal to constant set in the record's disv field.
-        status = dbGetLink(&(precord->sdis),DBR_SHORT,&(precord->disa),0,0);
-	/* if disabled check disable alarm severity and return success */
-	if (precord->disa == precord->disv) {
-		if(*ptrace) printf("%s: Disabled %s\n",
-		/*take care of caching and notifyCompletion*/
-		precord->rpro = FALSE;
-		precord->putf = FALSE;
-                callNotifyCompletion = TRUE;
-		/* raise disable alarm */
-		if (precord->stat==DISABLE_ALARM) goto all_done;
-		precord->sevr = precord->diss;
-		precord->stat = DISABLE_ALARM;
-		precord->nsev = 0;
-		precord->nsta = 0;
-		db_post_events(precord, &precord->stat, DBE_VALUE);
-		db_post_events(precord, &precord->sevr, DBE_VALUE);
-			DBE_VALUE|DBE_ALARM);
-		goto all_done;
-	/* locate record processing routine */
-        /* put this in iocInit() !!! */
-	if (!(prset=precord->rset) || !(prset->process)) {
-		precord->pact=1;/*set pact TRUE so error is issued only once*/
-		recGblRecordError(S_db_noRSET, (void *)precord, "dbProcess");
-		status = S_db_noRSET;
-		if (*ptrace) printf("%s: No RSET for %s\n",
-		goto all_done;
-	if(*ptrace) printf("%s: Process %s\n",
-	/* process record */
-	status = (*prset->process)(precord);
-        /* Print record's fields if PRINT_MASK set in breakpoint field */
-                dbPrint(precord);
+        if (dbBkpt(precord))
+            goto all_done;
+    /* check for trace processing*/
+    if (tpro) {
+        if(*ptrace==0) {
+            *ptrace = 1;
+            set_trace = TRUE;
+    /* If already active dont process */
+    if (precord->pact) {
+        unsigned short	monitor_mask;
+        if (*ptrace)
+            printf("%s: Active %s\n",
+                    epicsThreadGetNameSelf(), precord->name);
+        /* raise scan alarm after MAX_LOCK times */
+        if (precord->stat==SCAN_ALARM) goto all_done;
+        if (precord->lcnt++ !=MAX_LOCK) goto all_done;
+        if (precord->sevr>=INVALID_ALARM) goto all_done;
+        recGblSetSevr(precord, SCAN_ALARM, INVALID_ALARM);
+        monitor_mask = recGblResetAlarms(precord);
+        monitor_mask |= DBE_VALUE|DBE_LOG;
+        pdbFldDes = pdbRecordType->papFldDes[pdbRecordType->indvalFlddes];
+        db_post_events(precord,
+                (void *)(((char *)precord) + pdbFldDes->offset),
+                monitor_mask);
+        goto all_done;
+    else precord->lcnt = 0;
+     *  Check the record disable link.  A record will not be
+     *    processed if the value retrieved through this link
+     *    is equal to constant set in the record's disv field.
+    status = dbGetLink(&precord->sdis, DBR_SHORT, &precord->disa, 0, 0);
+    /* if disabled check disable alarm severity and return success */
+    if (precord->disa == precord->disv) {
+        if(*ptrace)
+            printf("%s: Disabled %s\n",
+        /*take care of caching and notifyCompletion*/
+        precord->rpro = FALSE;
+        precord->putf = FALSE;
+        callNotifyCompletion = TRUE;
+        /* raise disable alarm */
+        if (precord->stat==DISABLE_ALARM) goto all_done;
+        precord->sevr = precord->diss;
+        precord->stat = DISABLE_ALARM;
+        precord->nsev = 0;
+        precord->nsta = 0;
+        db_post_events(precord, &precord->stat, DBE_VALUE);
+        db_post_events(precord, &precord->sevr, DBE_VALUE);
+                DBE_VALUE|DBE_ALARM);
+        goto all_done;
+    /* locate record processing routine */
+    /* FIXME: put this in iocInit() !!! */
+    if (!(prset=precord->rset) || !(prset->process)) {
+        precord->pact=1;/*set pact TRUE so error is issued only once*/
+        recGblRecordError(S_db_noRSET, (void *)precord, "dbProcess");
+        status = S_db_noRSET;
+        if (*ptrace)
+            printf("%s: No RSET for %s\n",
+        goto all_done;
+    if(*ptrace)
+        printf("%s: Process %s\n",
+    /* process record */
+    status = (*prset->process)(precord);
+    /* Print record's fields if PRINT_MASK set in breakpoint field */
+        dbPrint(precord);
 all_done:
-	if (set_trace) *ptrace = 0;
-	if(callNotifyCompletion && precord->ppn) dbNotifyCompletion(precord);
-	return(status);
+    if (set_trace) *ptrace = 0;
+    if(callNotifyCompletion && precord->ppn) dbNotifyCompletion(precord);
+    return(status);
  *  Fill out a database structure (*paddr) for
  *    a record given by the name "pname."
@@ -726,59 +653,7 @@
     dbFinishEntry(&dbEntry);
     return status;
-/* JOH 10-19-04 */
-static char * dbCopyInNameComponentOfPV (
-    char * pBuf, unsigned bufLen, const char * pComponent )
-    unsigned compLen = strlen ( pComponent );
-    if ( compLen < bufLen ) {
-        strcpy ( pBuf, pComponent );
-        return pBuf + compLen;
-    else {
-        unsigned reducedSize = bufLen - 1u;
-        strncpy ( pBuf, pComponent, reducedSize );
-        pBuf[reducedSize] = '\0';
-        return pBuf + reducedSize;
- *  Copies PV name into pBuf of length bufLen
- *    Returns the number of bytes written to pBuf
- *      not including null termination.
- *  JOH 10-19-04
-unsigned dbNameOfPV (
-    const dbAddr * paddr, char * pBuf, unsigned bufLen )
-    dbFldDes * pfldDes = paddr->pfldDes;
-    char * pBufTmp = pBuf;
-    if ( bufLen == 0u ) {
-        return 0u;
-    pBufTmp = dbCopyInNameComponentOfPV (
-        pBufTmp, bufLen, paddr->precord->name );
-        pBufTmp, bufLen - ( pBufTmp - pBuf ), "." );
-        pBufTmp, bufLen - ( pBufTmp - pBuf ), pfldDes->name );
-    return pBufTmp - pBuf;
- *    Returns the number of bytes in the PV name
- *    JOH 10-19-04
-unsigned dbNameSizeOfPV ( const dbAddr * paddr )
-    unsigned recNameLen = strlen ( paddr->precord->name );
-    unsigned fieldNameLen = strlen ( pfldDes->name );
-    return recNameLen + fieldNameLen + 1;
 long epicsShareAPI dbValueSize(short dbr_type)
     /* sizes for value associated with each DBR request type */
@@ -826,222 +701,117 @@
     return dbReadDatabase(&pdbbase, file, 0, subs);
-long epicsShareAPI dbGetLinkValue(struct link *plink, short dbrType,
-    void *pbuffer, long *poptions, long *pnRequest)
-    long status = 0;
-    if (plink->type == CONSTANT) {
-        if (poptions) *poptions = 0;
-        if (pnRequest) *pnRequest = 0;
-    } else if (plink->type == DB_LINK) {
-        struct pv_link *ppv_link = &(plink->value.pv_link);
-        DBADDR         *paddr = ppv_link->pvt;
-        dbCommon       *precord = plink->value.pv_link.precord;
-        /* scan passive records with links that are process passive  */
-        if (ppv_link->pvlMask&pvlOptPP) {
-            dbCommon *pfrom = paddr->precord;
-            pact = precord->pact;
-            precord->pact = TRUE;
-            status = dbScanPassive(precord,pfrom);
-            precord->pact = pact;
-            if (status) return status;
-        if(precord!= paddr->precord) {
-            inherit_severity(ppv_link,precord,paddr->precord->stat,paddr->precord->sevr);
-        if (ppv_link->getCvt && ppv_link->lastGetdbrType == dbrType) {
-            status = ppv_link->getCvt(paddr->pfield, pbuffer, paddr);
-        } else {
-            unsigned short dbfType = paddr->field_type;
-            long       no_elements = paddr->no_elements;
-            if (dbrType < 0 || dbrType > DBR_ENUM ||
-                dbfType > DBF_DEVICE) {
-                status = S_db_badDbrtype;
-                recGblRecordError(status, precord, "GetLinkValue Failed");
-                recGblSetSevr(precord, LINK_ALARM, INVALID_ALARM);
-                return status;
-            /*  attempt to make a fast link */
-            if ((!poptions || *poptions == 0) &&
-                no_elements == 1 &&
-                (!pnRequest || *pnRequest == 1) &&
-                paddr->special != SPC_ATTRIBUTE) {
-                ppv_link->getCvt = dbFastGetConvertRoutine[dbfType][dbrType];
-            } else {
-                ppv_link->getCvt = 0;
-                status = dbGet(paddr, dbrType, pbuffer, poptions, pnRequest, NULL);
-        ppv_link->lastGetdbrType = dbrType;
-        if (status) {
-            recGblRecordError(status, precord, "dbGetLinkValue");
-    } else if (plink->type == CA_LINK) {
-        struct dbCommon *precord = plink->value.pv_link.precord;
-        const struct pv_link *pcalink = &plink->value.pv_link;
-        epicsEnum16 sevr, stat;
-        status=dbCaGetLink(plink,dbrType,pbuffer,&stat,&sevr,pnRequest);
-        if (status) {
-        } else {
-            inherit_severity(pcalink,precord,stat,sevr);
-    } else {
-        cantProceed("dbGetLinkValue: Illegal link type");
-    return status;
-long epicsShareAPI dbPutLinkValue(struct link *plink, short dbrType,
-    const void *pbuffer, long nRequest)
-    long status = 0;
-    if (plink->type == DB_LINK) {
-        struct dbCommon *psource = plink->value.pv_link.precord;
-        struct pv_link *ppv_link = &plink->value.pv_link;
-        DBADDR *paddr = (DBADDR *)ppv_link->pvt;
-        dbCommon *pdest = paddr->precord;
-        status = dbPut(paddr, dbrType, pbuffer, nRequest);
-        inherit_severity(ppv_link,pdest,psource->nsta,psource->nsev);
-        if (paddr->pfield == (void *)&pdest->proc ||
-            (ppv_link->pvlMask & pvlOptPP && pdest->scan == 0)) {
-            /*if dbPutField caused asyn record to process */
-            /* ask for reprocessing*/
-            if (pdest->putf) {
-                pdest->rpro = TRUE;
-            } else { /* otherwise ask for the record to be processed*/
-                status = dbScanLink(psource, pdest);
-        if (status)
-            recGblSetSevr(psource, LINK_ALARM, INVALID_ALARM);
-        status = dbCaPutLink(plink, dbrType, pbuffer, nRequest);
-        if (status < 0)
-    } else {
-        cantProceed("dbPutLinkValue: Illegal link type");
-    return status;
+static long getLinkValue(DBADDR *paddr, short dbrType,
+    char *pbuf, long *nRequest)
+    dbCommon *precord = paddr->precord;
+    dbFldDes *pfldDes = paddr->pfldDes;
+    int maxlen;
+    DBENTRY dbEntry;
+    long status;
+    switch (dbrType) {
+    case DBR_STRING:
+        maxlen = MAX_STRING_SIZE - 1;
+        if (nRequest && *nRequest > 1) *nRequest = 1;
+        break;
+    case DBR_CHAR:
+    case DBR_UCHAR:
+            if (nRequest && *nRequest > 0) {
+            maxlen = *nRequest - 1;
+            break;
+        /* else fall through ... */
+    default:
+        return S_db_badDbrtype;
+    dbInitEntry(pdbbase, &dbEntry);
+    status = dbFindRecord(&dbEntry, precord->name);
+    if (!status) status = dbFindField(&dbEntry, pfldDes->name);
+    if (!status) {
+        char *rtnString = dbGetString(&dbEntry);
+        strncpy(pbuf, rtnString, --maxlen);
+        pbuf[maxlen] = 0;
+    dbFinishEntry(&dbEntry);
+    return status;
+static long getAttrValue(DBADDR *paddr, short dbrType,
+    int maxlen;
+    if (!paddr->pfield) return S_db_badField;
+    case DBR_STRING:
+        break;
+    case DBR_CHAR:
+    case DBR_UCHAR:
+            break;
+    default:
+    strncpy(pbuf, paddr->pfield, --maxlen);
+    pbuf[maxlen] = 0;
+    return 0;
 long epicsShareAPI dbGetField(DBADDR *paddr,short dbrType,
     void *pbuffer, long *options, long *nRequest, void *pflin)
-    short dbfType = paddr->field_type;
     long status = 0;
     dbScanLock(precord);
-    if (dbfType >= DBF_INLINK && dbfType <= DBF_FWDLINK) {
-        DBENTRY dbEntry;
-        dbFldDes *pfldDes = paddr->pfldDes;
-        char *rtnString;
-        char *pbuf = (char *)pbuffer;
-        int maxlen;
-        if (options && (*options))
-            getOptions(paddr, &pbuf, options, pflin);
-        if (nRequest && *nRequest == 0) goto done;
-        switch (dbrType) {
-        case DBR_STRING:
-            maxlen = MAX_STRING_SIZE - 1;
-            if (nRequest && *nRequest > 1) *nRequest = 1;
-            break;
-        case DBR_CHAR:
-        case DBR_UCHAR:
-            if (nRequest && *nRequest > 0) {
-                maxlen = *nRequest - 1;
-                break;
-            /* else fall through ... */
-        default:
-            goto done;
-        dbInitEntry(pdbbase, &dbEntry);
-        status = dbFindRecord(&dbEntry, precord->name);
-        if (!status) status = dbFindField(&dbEntry, pfldDes->name);
-        if (!status) {
-            rtnString = dbGetString(&dbEntry);
-            strncpy(pbuf, rtnString, maxlen);
-            pbuf[maxlen] = 0;
-        dbFinishEntry(&dbEntry);
-    } else {
-        status = dbGet(paddr, dbrType, pbuffer, options, nRequest, pflin);
-done:
+    status = dbGet(paddr, dbrType, pbuffer, options, nRequest, pflin);
     dbScanUnlock(precord);
     return status;
 long epicsShareAPI dbGet(DBADDR *paddr, short dbrType,
+    char *pbuf = pbuffer;
     db_field_log *pfl = (db_field_log *)pflin;
-    short field_type  = paddr->field_type;
+    short field_type;
+    long no_elements;
     long offset;
     struct rset *prset;
     long status = 0;
-    if (options && *options) {
-        char *pbuf = pbuffer;
+    if (options && *options)
-        pbuffer = pbuf;
-    if (nRequest && *nRequest == 0) return 0;
-    if (paddr->special == SPC_ATTRIBUTE) {
-        int maxlen;
-        if (!paddr->pfield) return S_db_badField;
-        case DBR_STRING:
-            break;
-        case DBR_CHAR:
-        case DBR_UCHAR:
-                break;
-        default:
-            return S_db_badDbrtype;
-        strncpy(pbuf, (char *)paddr->pfield, maxlen);
-        pbuf[maxlen] = 0;
+    if (nRequest && *nRequest == 0)
         return 0;
+        no_elements = paddr->no_elements;
+    } else {
+        no_elements = pfl->no_elements;
+    if (field_type >= DBF_INLINK && field_type <= DBF_FWDLINK)
+        return getLinkValue(paddr, dbrType, pbuf, nRequest);
+    if (paddr->special == SPC_ATTRIBUTE)
+        return getAttrValue(paddr, dbrType, pbuf, nRequest);
     /* Check for valid request */
     if (INVALID_DB_REQ(dbrType) || field_type > DBF_DEVICE) {
         char message[80];
@@ -1052,7 +822,8 @@
     /* check for array */
-    if (paddr->special == SPC_DBADDR &&
+    if ((!pfl || pfl->type == dbfl_type_rec) &&
+        paddr->special == SPC_DBADDR &&
         no_elements > 1 &&
         (prset = dbGetRset(paddr)) &&
         prset->get_array_info) {
@@ -1062,15 +833,20 @@
     if (offset == 0 && (!nRequest || no_elements == 1)) {
         if (nRequest) *nRequest = 1;
-        if (pfl != NULL) {
+            status = dbFastGetConvertRoutine[field_type][dbrType]
+                (paddr->pfield, pbuffer, paddr);
+        } else {
             DBADDR localAddr = *paddr; /* Structure copy */
-            localAddr.pfield = (char *)&pfl->field;
+            localAddr.field_type = pfl->field_type;
+            localAddr.field_size = pfl->field_size;
+            localAddr.no_elements = pfl->no_elements;
+            if (pfl->type == dbfl_type_val)
+                localAddr.pfield = (char *) &pfl->u.v.field;
+            else
+                localAddr.pfield = (char *)  pfl->u.r.field;
                 (localAddr.pfield, pbuffer, &localAddr);
-        } else {
-            status = dbFastGetConvertRoutine[field_type][dbrType]
-                (paddr->pfield, pbuffer, paddr);
     } else {
         long n;
@@ -1094,18 +870,23 @@
         /* convert database field  and place it in the buffer */
         if (n <= 0) {
             ;/*do nothing*/
-        } else if (pfl) {
+        } else if (!pfl || pfl->type == dbfl_type_rec) {
+            status = convert(paddr, pbuffer, n, no_elements, offset);
+        } else {
+            else
             status = convert(&localAddr, pbuffer, n, no_elements, offset);
-        } else {
-            status = convert(paddr, pbuffer, n, no_elements, offset);
     return status;
 devSup* epicsShareAPI dbDTYPtoDevSup(dbRecordType *prdes, int dtyp) {
     return (devSup *)ellNth(&prdes->devList, dtyp+1);
@@ -1125,10 +906,9 @@
     long        special = paddr->special;
-    DBLINK      *plink = (DBLINK *)paddr->pfield;
+    struct link *plink = (struct link *)paddr->pfield;
     const char  *pstring = (const char *)pbuffer;
     DBENTRY     dbEntry;
-    DBADDR      dbaddr;
     struct dsxt *old_dsxt = NULL;
     struct dset *new_dset = NULL;
     struct dsxt *new_dsxt = NULL;
@@ -1199,21 +979,8 @@
     switch (plink->type) { /* Old link type */
     case DB_LINK:
-        free(plink->value.pv_link.pvt);
-        plink->value.pv_link.pvt = 0;
-        plink->type = PV_LINK;
-        plink->value.pv_link.getCvt = 0;
-        plink->value.pv_link.pvlMask = 0;
-        plink->value.pv_link.lastGetdbrType = 0;
-        dbLockSetSplit(precord);
-        break;
     case CA_LINK:
-        dbCaRemoveLink(plink);
+    	dbRemoveLink(plink);
         break;
     case CONSTANT:
@@ -1260,35 +1027,7 @@
     switch (plink->type) { /* New link type */
     case PV_LINK:
-        if (plink == &precord->tsel)
-            recGblTSELwasModified(plink);
-        plink->value.pv_link.precord = precord;
-        if (!(plink->value.pv_link.pvlMask & (pvlOptCA|pvlOptCP|pvlOptCPP)) &&
-            (dbNameToAddr(plink->value.pv_link.pvname, &dbaddr) == 0)) {
-            /* It's a DB link */
-            DBADDR      *pdbAddr;
-            plink->type = DB_LINK;
-            pdbAddr = dbMalloc(sizeof(struct dbAddr));
-            *pdbAddr = dbaddr; /* NB: structure copy */;
-            plink->value.pv_link.pvt = pdbAddr;
-            dbLockSetRecordLock(pdbAddr->precord);
-            dbLockSetMerge(precord, pdbAddr->precord);
-        } else { /* Make it a CA link */
-            char        *pperiod;
-            plink->type = CA_LINK;
-            if (pfldDes->field_type == DBF_INLINK) {
-                plink->value.pv_link.pvlMask |= pvlOptInpNative;
-            dbCaAddLink(plink);
-            if (pfldDes->field_type == DBF_FWDLINK) {
-                pperiod = strrchr(plink->value.pv_link.pvname, '.');
-                if (pperiod && strstr(pperiod, "PROC"))
-                    plink->value.pv_link.pvlMask |= pvlOptFWD;
+        dbAddLink(precord, plink, pfldDes->field_type);
         break;
     case CONSTANT:
@@ -1316,7 +1055,7 @@
 postScanEvent:
     if (scan != precord->scan)
-        db_post_events(precord, &precord->scan, DBE_VALUE|DBE_LOG);
+        db_post_events(precord, &precord->scan, DBE_VALUE | DBE_LOG);
 unlock:
     dbLockSetGblUnlock();
 finish:
@@ -1337,8 +1076,7 @@
         return S_db_noMod;
     /*check for putField disabled*/
-    if (precord->disp &&
-        (void *)(&precord->disp) != paddr->pfield)
+    if (precord->disp && paddr->pfield != &precord->disp)
         return S_db_putDisabled;
@@ -1347,7 +1085,7 @@
     if (status == 0) {
-        if (paddr->pfield == (void *)&precord->proc ||
+        if (paddr->pfield == &precord->proc ||
             (pfldDes->process_passive &&
              precord->scan == 0 &&
              dbrType < DBR_PUT_ACKT)) {
@@ -1366,16 +1104,18 @@
     return status;
-static long putAckt(DBADDR *paddr, const unsigned short *pbuffer, long nRequest,
+static long putAckt(DBADDR *paddr, const void *pbuffer, long nRequest,
     long no_elements, long offset)
+    const unsigned short *ptrans = pbuffer;
-    if (*pbuffer == precord->ackt) return 0;
-    precord->ackt = *pbuffer;
+    if (*ptrans == precord->ackt) return 0;
+    precord->ackt = *ptrans;
     db_post_events(precord, &precord->ackt, DBE_VALUE | DBE_ALARM);
-    if (!precord->ackt && precord->acks > precord->sevr) {
+    if (!precord->ackt &&
+        precord->acks > precord->sevr) {
         precord->acks = precord->sevr;
         db_post_events(precord, &precord->acks, DBE_VALUE | DBE_ALARM);
@@ -1383,19 +1123,20 @@
     return 0;
-static long putAcks(DBADDR *paddr, const unsigned short *pbuffer, long nRequest,
+static long putAcks(DBADDR *paddr, const void *pbuffer, long nRequest,
+    const unsigned short *psev = pbuffer;
-    if (*pbuffer >= precord->acks) {
+    if (*psev >= precord->acks) {
         precord->acks = 0;
+        db_post_events(precord, &precord->acks, DBE_VALUE | DBE_ALARM);
         db_post_events(precord, NULL, DBE_ALARM);
-        db_post_events(precord, &precord->acks, DBE_VALUE | DBE_ALARM);
     return 0;
 long epicsShareAPI dbPut(DBADDR *paddr, short dbrType,
@@ -1403,17 +1144,17 @@
-    long offset;
     long status = 0;
     dbFldDes *pfldDes;
     int isValueField;
-    if (special == SPC_ATTRIBUTE) return S_db_noMod;
+    if (special == SPC_ATTRIBUTE)
+        return S_db_noMod;
     if (dbrType == DBR_PUT_ACKT && field_type <= DBF_DEVICE) {
-        return putAckt(paddr, (unsigned short *)pbuffer, 1, 1, 0);
+        return putAckt(paddr, pbuffer, 1, 1, 0);
     } else if (dbrType == DBR_PUT_ACKS && field_type <= DBF_DEVICE) {
-        return putAcks(paddr, (unsigned short *)pbuffer, 1, 1, 0);
+        return putAcks(paddr, pbuffer, 1, 1, 0);
     } else if (INVALID_DB_REQ(dbrType) || field_type > DBF_DEVICE) {
         char message[80];
@@ -1432,6 +1173,7 @@
             paddr->pfield, paddr);
     } else {
         struct rset *prset = dbGetRset(paddr);
+        long offset = 0;
             prset && prset->get_array_info) {
@@ -1439,8 +1181,6 @@
             status = prset->get_array_info(paddr, &dummy, &offset);
-        else
-            offset = 0;
         if (no_elements < nRequest) nRequest = no_elements;
         status = dbPutConvertRoutine[dbrType][field_type](paddr, pbuffer,
             nRequest, no_elements, offset);
@@ -1471,140 +1211,4 @@
     return status;
-/* various utility routines */
-long epicsShareAPI dbGetControlLimits(
-    const struct link *plink,double *low, double *high)
-    struct buffer {
-        DBRctrlDouble
-        double value;
-    } buffer;
-    DBADDR *paddr;
-    long options = DBR_CTRL_DOUBLE;
-    long number_elements = 0;
-    long status;
-    if(plink->type == CA_LINK) return(dbCaGetControlLimits(plink,low,high));
-    if(plink->type !=DB_LINK) return(S_db_notFound);
-    paddr = (DBADDR *)plink->value.pv_link.pvt;
-    status = dbGet(paddr,DBR_DOUBLE,&buffer,&options,&number_elements,0);
-    if(status) return(status);
-    *low = buffer.lower_ctrl_limit;
-    *high = buffer.upper_ctrl_limit;
-    return(0);
-long epicsShareAPI dbGetGraphicLimits(
-    struct buffer {
-        DBRgrDouble
-        double value;
-    } buffer;
-    DBADDR *paddr;
-    long options = DBR_GR_DOUBLE;
-    long status;
-    if(plink->type == CA_LINK) return(dbCaGetGraphicLimits(plink,low,high));
-    *low = buffer.lower_disp_limit;
-    *high = buffer.upper_disp_limit;
-    return(0);
-long epicsShareAPI dbGetAlarmLimits(const struct link *plink,
-	double *lolo, double *low, double *high, double *hihi)
-    struct buffer {
-        DBRalDouble
-        double value;
-    } buffer;
-    DBADDR *paddr;
-    long options = DBR_AL_DOUBLE;
-    long status;
-        return(dbCaGetAlarmLimits(plink,lolo,low,high,hihi));
-    *lolo = buffer.lower_alarm_limit;
-    *low = buffer.lower_warning_limit;
-    *high = buffer.upper_warning_limit;
-    *hihi = buffer.upper_alarm_limit;
-    return(0);
-long epicsShareAPI dbGetPrecision(const struct link *plink,short *precision)
-    struct buffer {
-        DBRprecision
-        double value;
-    } buffer;
-    DBADDR *paddr;
-    long options = DBR_PRECISION;
-    long status;
-    if(plink->type == CA_LINK) return(dbCaGetPrecision(plink,precision));
-    *precision = buffer.precision.dp;
-    return(0);
-long epicsShareAPI dbGetUnits(
-    const struct link *plink,char *units,int unitsSize)
-    struct buffer {
-        DBRunits
-        double value;
-    } buffer;
-    DBADDR *paddr;
-    long options = DBR_UNITS;
-    long status;
-    if(plink->type == CA_LINK) return(dbCaGetUnits(plink,units,unitsSize));
-    strncpy(units,buffer.units,unitsSize);
-    return(0);
-long epicsShareAPI dbGetAlarm(const struct link *plink,
-    epicsEnum16 *status,epicsEnum16 *severity)
-    DBADDR *paddr;
-    if(plink->type == CA_LINK) return(dbCaGetAlarm(plink,status,severity));
-    if (status) *status = paddr->precord->stat;
-    if (severity) *severity = paddr->precord->sevr;
-    return(0);
-long epicsShareAPI dbGetTimeStamp(const struct link *plink,epicsTimeStamp *pstamp)
-    DBADDR *paddr;
-    if (plink->type == CA_LINK)
-        return dbCaGetTimeStamp(plink,pstamp);
-    if (plink->type != DB_LINK)
-        return S_db_notFound;
-    *pstamp = paddr->precord->time;
-    return 0;
=== modified file 'src/ioc/db/dbAccess.h'
--- src/ioc/db/dbAccess.h	2002-07-12 21:35:43 +0000
+++ src/ioc/db/dbAccess.h	2012-05-30 18:10:27 +0000
@@ -3,8 +3,7 @@
 /* dbAccess.h	*/
@@ -22,6 +21,7 @@
 #include "dbAddr.h"
 #include "dbLock.h"
 #include "dbAccessDefs.h"
 #include "dbCa.h"
 #include "dbCommon.h"
=== modified file 'src/ioc/db/dbAccessDefs.h'
--- src/ioc/db/dbAccessDefs.h	2010-10-05 19:27:37 +0000
+++ src/ioc/db/dbAccessDefs.h	2012-05-30 18:10:27 +0000
@@ -3,9 +3,8 @@
 /* dbAccessDefs.h	*/
 /* $Revision-Id$ */
@@ -20,6 +19,8 @@
 #include "epicsTypes.h"
 #include "epicsTime.h"
+#include "dbBase.h"
+#include "dbAddr.h"
 #ifdef INCLdb_accessh_epicsExportSharedSymbols
 #   define epicsExportSharedSymbols
@@ -47,7 +48,7 @@
 #define DBR_CTRL_DOUBLE 0x00000100
 #define DBR_AL_LONG     0x00000200
 #define DBR_AL_DOUBLE   0x00000400
  * The next page contains macros for defining requests.
  * As an example the following defines a buffer to accept an array
@@ -69,7 +70,7 @@
  * options = DBR_STATUS|DBR_TIME;
  * number_elements = 10;
  * rtnval=dbGetField(paddr,DBR_FLOAT,&buffer,&options,&number_elements);
  * When dbGetField returns:
  *	rtnval is error status (0 means success)
  *	options has a bit set for each option that was accepted
@@ -97,7 +98,7 @@
  * MYBUFFER *pbuf1;
  * MYBUFFER buf;
 /* Macros for defining each option */
 #define DBRstatus \
 	epicsUInt16	status;		/* alarm status */\
@@ -143,7 +144,7 @@
         epicsFloat64    upper_warning_limit;\
         epicsFloat64    lower_warning_limit;\
         epicsFloat64    lower_alarm_limit;
 /*  structures for each option type             */
 struct dbr_status       {DBRstatus};
 struct dbr_units        {DBRunits};
@@ -198,25 +199,6 @@
 #define S_db_cntSpwn    (M_dbAccess|63) /*Cannot spawn dbContTask*/
 #define S_db_cntCont    (M_dbAccess|65) /*Cannot resume dbContTask*/
 #define S_db_noMemory   (M_dbAccess|66) /*unable to allocate data structure from pool*/
-/* Global Database Access Routines*/
-#define dbGetLink(PLNK, DBRTYPE, PBUFFER, OPTIONS, NREQUEST) \
-    ( ( ( (PLNK)->type == CONSTANT ) && \
-        ( (NREQUEST) == 0) &&\
-        ( (OPTIONS) == 0) ) \
-      ? 0 \
-      : dbGetLinkValue((PLNK),(DBRTYPE), \
-        (void *)(PBUFFER), (OPTIONS), (NREQUEST) ) )
-#define dbPutLink(PLNK, DBRTYPE, PBUFFER, NREQUEST) \
-    ( ( (PLNK)->type == CONSTANT) \
-      ? 0 \
-      : dbPutLinkValue( (PLNK), (DBRTYPE), (void *)(PBUFFER), (NREQUEST) ) )
-#define dbGetPdbAddrFromLink(PLNK) \
-    ( ( (PLNK)->type != DB_LINK ) \
-      ? 0 \
-      : ( ( (struct dbAddr *)( (PLNK)->value.pv_link.pvt) ) ) )
-#define dbGetSevr(PLINK,PSEVERITY) \
-    dbGetAlarm((PLINK),NULL,(PSEVERITY))
 epicsShareFunc long epicsShareAPI dbPutSpecial(struct dbAddr *paddr,int pass);
 epicsShareFunc struct rset * epicsShareAPI dbGetRset(const struct dbAddr *paddr);
@@ -224,51 +206,24 @@
     const char *recordTypename,const char *name,const char*value);
 epicsShareFunc int epicsShareAPI dbIsValueField(const struct dbFldDes *pdbFldDes);
 epicsShareFunc int epicsShareAPI dbGetFieldIndex(const struct dbAddr *paddr);
-epicsShareFunc long epicsShareAPI dbGetNelements(
-    const struct link *plink,long *nelements);
-epicsShareFunc int epicsShareAPI dbIsLinkConnected(const struct link *plink);
-epicsShareFunc int epicsShareAPI dbGetLinkDBFtype(const struct link *plink);
-epicsShareFunc long epicsShareAPI dbScanLink(
-    struct dbCommon *pfrom, struct dbCommon *pto);
 epicsShareFunc long epicsShareAPI dbScanPassive(
     struct dbCommon *pfrom,struct dbCommon *pto);
-epicsShareFunc void epicsShareAPI dbScanFwdLink(struct link *plink);
 epicsShareFunc long epicsShareAPI dbProcess(struct dbCommon *precord);
 epicsShareFunc long epicsShareAPI dbNameToAddr(
     const char *pname,struct dbAddr *);
 epicsShareFunc devSup* epicsShareAPI dbDTYPtoDevSup(dbRecordType *prdes, int dtyp);
 epicsShareFunc devSup* epicsShareAPI dbDSETtoDevSup(dbRecordType *prdes, struct dset *pdset);
-epicsShareFunc long epicsShareAPI dbGetLinkValue(
-    struct link *,short dbrType,void *pbuffer,long *options,long *nRequest);
 epicsShareFunc long epicsShareAPI dbGetField(
     struct dbAddr *,short dbrType,void *pbuffer,long *options,
     long *nRequest,void *pfl);
 epicsShareFunc long epicsShareAPI dbGet(
-epicsShareFunc long epicsShareAPI dbPutLinkValue(
-    struct link *,short dbrType,const void *pbuffer,long nRequest);
 epicsShareFunc long epicsShareAPI dbPutField(
     struct dbAddr *,short dbrType,const void *pbuffer,long nRequest);
 epicsShareFunc long epicsShareAPI dbPut(
-epicsShareFunc long epicsShareAPI dbGetControlLimits(
-    const struct link *plink,double *low, double *high);
-epicsShareFunc long epicsShareAPI dbGetGraphicLimits(
-epicsShareFunc long epicsShareAPI dbGetAlarmLimits(
-    const struct link *plink,double *lolo, double *low, double *high, double *hihi);
-epicsShareFunc long epicsShareAPI dbGetPrecision(
-    const struct link *plink,short *precision);
-epicsShareFunc long epicsShareAPI dbGetUnits(
-    const struct link *plink,char *units,int unitsSize);
-epicsShareFunc long epicsShareAPI dbGetAlarm(
-    const struct link *plink, epicsEnum16 *status,epicsEnum16 *severity);
-epicsShareFunc long epicsShareAPI dbGetTimeStamp(
-    const struct link *plink,epicsTimeStamp *pstamp);
 typedef void(*SPC_ASCALLBACK)(struct dbCommon *);
 /*dbSpcAsRegisterCallback called by access security */
 epicsShareFunc void epicsShareAPI dbSpcAsRegisterCallback(SPC_ASCALLBACK func);
=== modified file 'src/ioc/db/dbAddr.h'
--- src/ioc/db/dbAddr.h	2008-08-15 18:58:18 +0000
+++ src/ioc/db/dbAddr.h	2012-05-30 18:10:27 +0000
@@ -4,7 +4,7 @@
 #ifndef dbAddrh
@@ -27,7 +27,4 @@
 typedef dbAddr DBADDR;
-unsigned dbNameOfPV (const dbAddr * paddr, char * pBuf, unsigned bufLen);
-unsigned dbNameSizeOfPV (const dbAddr * paddr);
 #endif /* dbAddrh */
=== modified file 'src/ioc/db/dbBkpt.c'
--- src/ioc/db/dbBkpt.c	2010-10-05 19:27:37 +0000
+++ src/ioc/db/dbBkpt.c	2012-05-30 18:10:27 +0000
@@ -65,6 +65,7 @@
 #include "dbAddr.h"
 #include "dbScan.h"
 #include "dbLock.h"
 #include "recGbl.h"
 #include "dbTest.h"
=== modified file 'src/ioc/db/dbCAC.h'
--- src/ioc/db/dbCAC.h	2011-06-01 22:22:12 +0000
+++ src/ioc/db/dbCAC.h	2012-05-30 18:10:27 +0000
@@ -5,7 +5,7 @@
  *  $Revision-Id$
@@ -49,7 +49,7 @@
 #include "db_access.h"
 #include "dbNotify.h"
 #include "dbLock.h"
 #include "db_convert.h"
@@ -75,25 +75,25 @@
     virtual ~dbBaseIO() {}
-extern "C" void dbSubscriptionEventCallback ( void *pPrivate, struct dbAddr *paddr,
+extern "C" void dbSubscriptionEventCallback ( void *pPrivate, struct dbChannel *dbch,
     int eventsRemaining, struct db_field_log *pfl );
-class dbSubscriptionIO :
-    public tsDLNode < dbSubscriptionIO >,
+class dbSubscriptionIO :
+    public tsDLNode < dbSubscriptionIO >,
     public dbBaseIO {
 public:
-    dbSubscriptionIO (
+    dbSubscriptionIO (
         epicsGuard < epicsMutex > &, epicsMutex &,
-        dbContext &, dbChannelIO &, struct dbAddr &, cacStateNotify &,
+        dbContext &, dbChannelIO &, struct dbChannel *, cacStateNotify &,
         unsigned type, unsigned long count, unsigned mask, dbEventCtx );
     void destructor ( epicsGuard < epicsMutex > & );
     void unsubscribe ( epicsGuard < epicsMutex > & );
     void channelDeleteException ( epicsGuard < epicsMutex > & );
     void show ( epicsGuard < epicsMutex > &, unsigned level ) const;
     void show ( unsigned level ) const;
-    void * operator new ( size_t size,
+    void * operator new ( size_t size,
         tsFreeList < dbSubscriptionIO, 256, epicsMutexNOOP > & );
-    epicsPlacementDeleteOperator (( void *,
+    epicsPlacementDeleteOperator (( void *,
         tsFreeList < dbSubscriptionIO, 256, epicsMutexNOOP > & ))
 private:
     epicsMutex & mutex;
@@ -104,8 +104,8 @@
     unsigned type;
     unsigned id;
     dbSubscriptionIO * isSubscription ();
-    friend void dbSubscriptionEventCallback (
-        void * pPrivate, struct dbAddr * paddr,
+    friend void dbSubscriptionEventCallback (
+        void * pPrivate, struct dbChannel * dbch,
         int eventsRemaining, struct db_field_log * pfl );
     dbSubscriptionIO ( const dbSubscriptionIO & );
     dbSubscriptionIO & operator = ( const dbSubscriptionIO & );
@@ -149,8 +149,8 @@
 class dbContextReadNotifyCache  {
 public:
     dbContextReadNotifyCache ( epicsMutex & );
-    void callReadNotify ( epicsGuard < epicsMutex > &,
-        struct dbAddr & addr, unsigned type, unsigned long count,
+    void callReadNotify ( epicsGuard < epicsMutex > &,
+        struct dbChannel * dbch, unsigned type, unsigned long count,
             cacReadNotify & notify );
 private:
@@ -162,29 +162,29 @@
 class dbContext : public cacContext {
 public:
-    dbContext ( epicsMutex & cbMutex, epicsMutex & mutex,
+    dbContext ( epicsMutex & cbMutex, epicsMutex & mutex,
         cacContextNotify & notify );
     virtual ~dbContext ();
     void destroyChannel ( epicsGuard < epicsMutex > &, dbChannelIO & );
-    void callStateNotify ( struct dbAddr &addr, unsigned type, unsigned long count,
+    void callStateNotify ( struct dbChannel * dbch, unsigned type, unsigned long count,
             const struct db_field_log * pfl, cacStateNotify & notify );
-    void subscribe (
+    void subscribe (
-            struct dbAddr & addr, dbChannelIO & chan,
-            unsigned type, unsigned long count, unsigned mask,
+            struct dbChannel * dbch, dbChannelIO & chan,
+            unsigned type, unsigned long count, unsigned mask,
             cacStateNotify & notify, cacChannel::ioid * pId );
-    void initiatePutNotify (
-            epicsGuard < epicsMutex > &, dbChannelIO &, struct dbAddr &,
-            unsigned type, unsigned long count, const void * pValue,
-            cacWriteNotify & notify, cacChannel::ioid * pId );
+    void initiatePutNotify (
+            epicsGuard < epicsMutex > &, dbChannelIO &, struct dbChannel *,
+            unsigned type, unsigned long count, const void * pValue,
+            cacWriteNotify & notify, cacChannel::ioid * pId );
     void showAllIO ( const dbChannelIO & chan, unsigned level ) const;
-    void destroyAllIO (
+    void destroyAllIO (
         epicsGuard < epicsMutex > &, dbChannelIO & chan );
-    void ioCancel ( epicsGuard < epicsMutex > &,
+    void ioCancel ( epicsGuard < epicsMutex > &,
         dbChannelIO & chan, const cacChannel::ioid &id );
     void ioShow ( epicsGuard < epicsMutex > &,
         const cacChannel::ioid & id, unsigned level ) const;
@@ -202,11 +202,11 @@
     epics_auto_ptr < cacContext > pNetContext;
     char * pStateNotifyCache;
-    cacChannel & createChannel (
+    cacChannel & createChannel (
-        const char * pChannelName, cacChannelNotify &,
+        const char * pChannelName, cacChannelNotify &,
         cacChannel::priLev );
-    void flush (
+    void flush (
     unsigned circuitCount (
         epicsGuard < epicsMutex > & ) const;
@@ -214,7 +214,7 @@
     unsigned beaconAnomaliesSinceProgramStart (
-    void show (
+    void show (
     dbContext ( const dbContext & );
@@ -226,17 +226,17 @@
-inline dbContextPrivateListOfIO::~dbContextPrivateListOfIO ()
+inline dbContextPrivateListOfIO::~dbContextPrivateListOfIO ()
     assert ( ! this->pBlocker );
-inline void dbContext::callReadNotify (
-    epicsGuard < epicsMutex > & guard, struct dbAddr &addr,
+inline void dbContext::callReadNotify (
+    epicsGuard < epicsMutex > & guard, struct dbChannel * dbch,
     unsigned type, unsigned long count, cacReadNotify & notifyIn )
     guard.assertIdenticalMutex ( this-> mutex );
-    this->readNotifyCache.callReadNotify ( guard, addr, type, count, notifyIn );
+    this->readNotifyCache.callReadNotify ( guard, dbch, type, count, notifyIn );
 #endif // dbCACh
=== modified file 'src/ioc/db/dbCa.c'
--- src/ioc/db/dbCa.c	2012-05-04 18:38:59 +0000
+++ src/ioc/db/dbCa.c	2012-05-30 18:10:27 +0000
@@ -411,6 +411,13 @@
     return pca->isConnected;
+void dbCaScanFwdLink(struct link *plink) {
+    short fwdLinkValue = 1;
+    if (plink->value.pv_link.pvlMask & pvlOptFWD)
+        dbCaPutLink(plink, DBR_SHORT, &fwdLinkValue, 1);
 #define pcaGetCheck \
     assert(plink); \
     if (plink->type != CA_LINK) return -1; \
@@ -639,7 +646,7 @@
 static void eventCallback(struct event_handler_args arg)
     caLink *pca = (caLink *)arg.usr;
-    DBLINK *plink;
+    struct link *plink;
     size_t size;
     dbCommon *precord = 0;
     struct dbr_time_double *pdbr_time_double;
=== modified file 'src/ioc/db/dbCa.h'
--- src/ioc/db/dbCa.h	2009-04-29 18:24:25 +0000
+++ src/ioc/db/dbCa.h	2012-05-30 18:10:27 +0000
@@ -40,6 +40,7 @@
 #define dbCaPutLink(plink, dbrType, pbuffer, nRequest) \
     dbCaPutLinkCallback((plink), (dbrType), (pbuffer), (nRequest), 0, 0)
 epicsShareFunc int dbCaIsLinkConnected(const struct link *plink);
+epicsShareFunc void dbCaScanFwdLink(struct link *plink);
 /* The following are available after the link is connected*/
 epicsShareFunc long dbCaGetNelements(const struct link *plink,
=== added file 'src/ioc/db/dbChannel.c'
--- src/ioc/db/dbChannel.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/dbChannel.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,864 @@
+* Copyright (c) 2010 UChicago Argonne LLC, as Operator of Argonne
+*     National Laboratory.
+* Copyright (c) 2010 Brookhaven National Laboratory.
+* Copyright (c) 2010 Helmholtz-Zentrum Berlin
+*     fuer Materialien und Energie GmbH.
+* EPICS BASE is distributed subject to a Software License Agreement found
+* in file LICENSE that is included with this distribution.
+ *  Author: Andrew Johnson <[email protected]>
+#include <stdio.h>
+#include <string.h>
+#include "cantProceed.h"
+#include "dbChannel.h"
+#include "dbCommon.h"
+#include "dbEvent.h"
+#include "link.h"
+#include <freeList.h>
+#include "dbAccessDefs.h"
+#include "dbLock.h"
+#include "dbStaticLib.h"
+#include "epicsAssert.h"
+#include "errlog.h"
+#include "gpHash.h"
+#include "recSup.h"
+#include "special.h"
+#include "yajl_parse.h"
+/* The following is defined in db_convert.h */
+extern unsigned short dbDBRnewToDBRold[DBR_ENUM+1];
+typedef struct parseContext {
+    dbChannel *chan;
+    chFilter *filter;
+    int depth;
+} parseContext;
+#define CALLIF(rtn) !rtn ? parse_stop : rtn
+static void *dbchStringFreeList;
+void dbChannelInit (void)
+    if (!dbchStringFreeList) {
+        freeListInitPvt(&dbchStringFreeList,
+            sizeof(epicsOldString), 128);
+static void chf_value(parseContext *parser, parse_result *presult)
+    chFilter *filter = parser->filter;
+    if (*presult == parse_stop || parser->depth > 0)
+        return;
+    parser->filter = NULL;
+    if (filter->plug->fif->parse_end(filter) == parse_continue) {
+        ellAdd(&parser->chan->filters, &filter->list_node);
+    } else {
+        free(filter); // FIXME: Use free-list
+        *presult = parse_stop;
+static int chf_null(void * ctx)
+    parseContext *parser = (parseContext *) ctx;
+    parse_result result;
+    assert(filter);
+    result = CALLIF(filter->plug->fif->parse_null)(filter );
+    chf_value(parser, &result);
+    return result;
+static int chf_boolean(void * ctx, int boolVal)
+    assert(filter);
+    result = CALLIF(filter->plug->fif->parse_boolean)(filter , boolVal);
+    return result;
+static int chf_integer(void * ctx, long integerVal)
+    assert(filter);
+    result = CALLIF(filter->plug->fif->parse_integer)(filter , integerVal);
+    return result;
+static int chf_double(void * ctx, double doubleVal)
+    assert(filter);
+    result = CALLIF(filter->plug->fif->parse_double)(filter , doubleVal);
+    return result;
+static int chf_string(void * ctx, const unsigned char * stringVal,
+        unsigned int stringLen)
+    assert(filter);
+    result = CALLIF(filter->plug->fif->parse_string)(filter , (const char *) stringVal, stringLen);
+    return result;
+static int chf_start_map(void * ctx)
+    if (!filter) {
+        assert(parser->depth == 0);
+        return parse_continue; /* Opening '{' */
+    ++parser->depth;
+    return CALLIF(filter->plug->fif->parse_start_map)(filter );
+static int chf_map_key(void * ctx, const unsigned char * key,
+    const chFilterPlugin *plug;
+    if (filter) {
+        assert(parser->depth > 0);
+        return CALLIF(filter->plug->fif->parse_map_key)(filter , (const char *) key, stringLen);
+    plug = dbFindFilter((const char *) key, stringLen);
+    if (!plug) {
+        printf("dbChannelCreate: Channel filter '%.*s' not found\n", stringLen, key);
+    filter = (chFilter *) callocMustSucceed(1, sizeof(*filter), "Creating dbChannel filter");
+    filter->chan = parser->chan;
+    filter->plug = plug;
+    filter->puser = NULL;
+    result = plug->fif->parse_start(filter);
+    if (result == parse_continue) {
+        parser->filter = filter;
+    } else {
+    return result;
+static int chf_end_map(void * ctx)
+    if (!filter) {
+        return parse_continue; /* Final closing '}' */
+    result = CALLIF(filter->plug->fif->parse_end_map)(filter );
+    --parser->depth;
+    return result;
+static int chf_start_array(void * ctx)
+    assert(filter);
+    ++parser->depth;
+    return CALLIF(filter->plug->fif->parse_start_array)(filter );
+static int chf_end_array(void * ctx)
+    assert(filter);
+    result = CALLIF(filter->plug->fif->parse_end_array)(filter );
+    --parser->depth;
+    return result;
+static const yajl_callbacks chf_callbacks =
+    { chf_null, chf_boolean, chf_integer, chf_double, NULL, chf_string,
+      chf_start_map, chf_map_key, chf_end_map, chf_start_array, chf_end_array };
+static const yajl_parser_config chf_config =
+    { 0, 1 }; /* allowComments = NO , checkUTF8 = YES */
+static void * chf_malloc(void *ctx, unsigned int sz)
+    return malloc(sz); /* FIXME: free-list */
+static void * chf_realloc(void *ctx, void *ptr, unsigned int sz)
+    return realloc(ptr, sz); /* FIXME: free-list */
+static void chf_free(void *ctx, void *ptr)
+    return free(ptr); /* FIXME: free-list */
+static const yajl_alloc_funcs chf_alloc =
+    { chf_malloc, chf_realloc, chf_free };
+static long chf_parse(dbChannel *chan, const char **pjson)
+    parseContext parser =
+        { chan, NULL, 0 };
+    yajl_handle yh = yajl_alloc(&chf_callbacks, &chf_config, &chf_alloc, &parser);
+    const char *json = *pjson;
+    size_t jlen = strlen(json);
+    yajl_status ys;
+    long status;
+    if (!yh)
+        return S_db_noMemory;
+    ys = yajl_parse(yh, (const unsigned char *) json, jlen);
+    if (ys == yajl_status_insufficient_data)
+        ys = yajl_parse_complete(yh);
+    switch (ys) {
+    case yajl_status_ok:
+        status = 0;
+        *pjson += yajl_get_bytes_consumed(yh);
+        break;
+    case yajl_status_error: {
+        unsigned char *err;
+        err = yajl_get_error(yh, 1, (const unsigned char *) json, jlen);
+        printf("dbChannelCreate: %s\n", err);
+        yajl_free_error(yh, err);
+    } /* fall through */
+    default:
+        status = S_db_notFound;
+    if (parser.filter) {
+        assert(status);
+        parser.filter->plug->fif->parse_abort(parser.filter);
+        free(parser.filter); /* FIXME: free-list */
+    yajl_free(yh);
+    return status;
+static long pvNameLookup(DBENTRY *pdbe, const char **ppname)
+    long status;
+    dbInitEntry(pdbbase, pdbe);
+    status = dbFindRecordPart(pdbe, ppname);
+    if (status)
+        return status;
+    if (**ppname == '.')
+        ++*ppname;
+    status = dbFindFieldPart(pdbe, ppname);
+    if (status == S_dbLib_fieldNotFound)
+        status = dbGetAttributePart(pdbe, ppname);
+    return status;
+long dbChannelTest(const char *name)
+    DBENTRY dbEntry;
+    long status;
+    if (!name || !*name || !pdbbase)
+        return S_db_notFound;
+    status = pvNameLookup(&dbEntry, &name);
+    return status;
+#define TRY(Func, Arg) \
+if (Func) { \
+    result = Func Arg; \
+    if (result != parse_continue) goto failure; \
+static long parseArrayRange(dbChannel* chan, const char *pname, const char **ppnext) {
+    epicsInt32 start = 0;
+    epicsInt32 end = -1;
+    epicsInt32 incr = 1;
+    epicsInt32 l;
+    char *pnext;
+    short exist;
+    chFilter *filter;
+    long status = 0;
+    /* If no number is present, strtol() returns 0 and sets pnext=pname,
+       else pnext points to the first char after the number */
+    pname++;
+    l = strtol(pname, &pnext, 0);
+    exist = pnext - pname;
+    if (exist) start = l;
+    pname = pnext;
+    if (*pname == ']' && exist) {
+        end = start;
+        goto insertplug;
+    if (*pname != ':') {
+        status = S_dbLib_fieldNotFound;
+        goto finish;
+    pname++;
+    pname = pnext;
+    if (*pname == ']') {
+        if (exist) end = l;
+        goto insertplug;
+    if (exist) incr = l;
+        goto finish;
+    pname++;
+    pname = pnext;
+    if (*pname != ']') {
+        goto finish;
+    insertplug:
+    pname++;
+    *ppnext = pname;
+    plug = dbFindFilter("arr", 3);
+    if (!plug) {
+        goto finish;
+    /* FIXME: Use a free-list */
+    filter = (chFilter *) callocMustSucceed(1, sizeof(*filter), "Creating 'arr' dbChannel filter");
+    filter->chan = chan;
+    TRY(filter->plug->fif->parse_start, (filter));
+    TRY(filter->plug->fif->parse_start_map, (filter));
+    if (start != 0) {
+        TRY(filter->plug->fif->parse_map_key, (filter, "s", 1));
+        TRY(filter->plug->fif->parse_integer, (filter, start));
+    if (incr != 1) {
+        TRY(filter->plug->fif->parse_map_key, (filter, "i", 1));
+        TRY(filter->plug->fif->parse_integer, (filter, incr));
+    if (end != -1) {
+        TRY(filter->plug->fif->parse_map_key, (filter, "e", 1));
+        TRY(filter->plug->fif->parse_integer, (filter, end));
+    TRY(filter->plug->fif->parse_end_map, (filter));
+    TRY(filter->plug->fif->parse_end, (filter));
+    ellAdd(&chan->filters, &filter->list_node);
+    return 0;
+    failure:
+    finish:
+    return status;
+/* Stolen from dbAccess.c: */
+static short mapDBFToDBR[DBF_NTYPES] =
+    /* DBF_STRING   => */DBR_STRING,
+    /* DBF_CHAR     => */DBR_CHAR,
+    /* DBF_UCHAR    => */DBR_UCHAR,
+    /* DBF_SHORT    => */DBR_SHORT,
+    /* DBF_USHORT   => */DBR_USHORT,
+    /* DBF_LONG     => */DBR_LONG,
+    /* DBF_ULONG    => */DBR_ULONG,
+    /* DBF_FLOAT    => */DBR_FLOAT,
+    /* DBF_DOUBLE   => */DBR_DOUBLE,
+    /* DBF_ENUM,    => */DBR_ENUM,
+    /* DBF_MENU,    => */DBR_ENUM,
+    /* DBF_DEVICE   => */DBR_ENUM,
+    /* DBF_INLINK   => */DBR_STRING,
+    /* DBF_OUTLINK  => */DBR_STRING,
+    /* DBF_FWDLINK  => */DBR_STRING,
+    /* DBF_NOACCESS => */DBR_NOACCESS };
+dbChannel * dbChannelCreate(const char *name)
+    const char *pname = name;
+    DBENTRY dbEntry;
+    dbChannel *chan = NULL;
+    dbAddr *paddr;
+    dbFldDes *pflddes;
+    long status;
+    short dbfType;
+        return NULL;
+    status = pvNameLookup(&dbEntry, &pname);
+    if (status)
+        goto finish;
+    /* FIXME: Use free-list */
+    chan = (dbChannel *) callocMustSucceed(1, sizeof(*chan), "dbChannelCreate");
+    chan->name = strdup(name);  /* FIXME: free-list */
+    ellInit(&chan->filters);
+    ellInit(&chan->pre_chain);
+    ellInit(&chan->post_chain);
+    paddr = &chan->addr;
+    pflddes = dbEntry.pflddes;
+    dbfType = pflddes->field_type;
+    paddr->precord = dbEntry.precnode->precord;
+    paddr->pfield = dbEntry.pfield;
+    paddr->pfldDes = pflddes;
+    paddr->no_elements = 1;
+    paddr->field_type = dbfType;
+    paddr->field_size = pflddes->size;
+    paddr->special = pflddes->special;
+    paddr->dbr_field_type = mapDBFToDBR[dbfType];
+    /* Handle field modifiers */
+    if (*pname) {
+        if (*pname == '$') {
+            /* Some field types can be accessed as char arrays */
+            if (dbfType == DBF_STRING) {
+                paddr->no_elements = pflddes->size;
+                paddr->field_type = DBF_CHAR;
+                paddr->field_size = 1;
+                paddr->dbr_field_type = DBR_CHAR;
+            } else if (dbfType >= DBF_INLINK && dbfType <= DBF_FWDLINK) {
+                /* Clients see a char array, but keep original dbfType */
+                paddr->no_elements = PVNAME_STRINGSZ + 12;
+            } else {
+                goto finish;
+            pname++;
+        if (*pname == '[') {
+            status = parseArrayRange(chan, pname, &pname);
+            if (status) goto finish;
+        /* JSON may follow */
+        if (*pname == '{') {
+            status = chf_parse(chan, &pname);
+        /* Make sure there's nothing else */
+        if (*pname) {
+            goto finish;
+    if (paddr->special == SPC_DBADDR) {
+        struct rset *prset = dbGetRset(paddr);
+        /* Let record type modify the dbAddr */
+        if (prset && prset->cvt_dbaddr) {
+            status = prset->cvt_dbaddr(paddr);
+finish:
+    if (status && chan) {
+        dbChannelDelete(chan);
+        chan = NULL;
+    return chan;
+db_field_log* dbChannelRunPreChain(dbChannel *chan, db_field_log *pLogIn) {
+    chFilter *filter;
+    ELLNODE *node;
+    db_field_log *pLog = pLogIn;
+    for (node = ellFirst(&chan->pre_chain); node && pLog; node = ellNext(node)) {
+        filter = CONTAINER(node, chFilter, pre_node);
+        pLog = filter->pre_func(filter->pre_arg, chan, pLog);
+    return pLog;
+db_field_log* dbChannelRunPostChain(dbChannel *chan, db_field_log *pLogIn) {
+    chFilter *filter;
+    ELLNODE *node;
+    for (node = ellFirst(&chan->post_chain); node && pLog; node = ellNext(node)) {
+        filter = CONTAINER(node, chFilter, post_node);
+        pLog = filter->post_func(filter->post_arg, chan, pLog);
+    return pLog;
+long dbChannelOpen(dbChannel *chan)
+    chFilter *filter;
+    chPostEventFunc *func;
+    void *arg;
+    long status;
+    ELLNODE *node;
+    for (node = ellFirst(&chan->filters); node; node = ellNext(node)) {
+        filter = CONTAINER(node, chFilter, list_node);
+         /* Call channel_open */
+        status = 0;
+        if (filter->plug->fif->channel_open)
+            status = filter->plug->fif->channel_open(filter);
+        if (status) return status;
+    /* Set up type probe */
+    db_field_log probe;
+    db_field_log p;
+    probe.field_type  = dbChannelFieldType(chan);
+    probe.no_elements = dbChannelElements(chan);
+    probe.field_size  = dbChannelFieldSize(chan);
+    p = probe;
+     * Build up the pre- and post-event-queue filter chains
+     * Separate loops because the probe must reach the filters in the right order.
+        func = NULL;
+        arg = NULL;
+        if (filter->plug->fif->channel_register_pre) {
+            filter->plug->fif->channel_register_pre(filter, &func, &arg, &p);
+            if (func) {
+                ellAdd(&chan->pre_chain, &filter->pre_node);
+                filter->pre_func = func;
+                filter->pre_arg  = arg;
+                probe = p;
+        func = NULL;
+        arg = NULL;
+        if (filter->plug->fif->channel_register_post) {
+            filter->plug->fif->channel_register_post(filter, &func, &arg, &p);
+            if (func) {
+                ellAdd(&chan->post_chain, &filter->post_node);
+                filter->post_func = func;
+                filter->post_arg  = arg;
+                probe = p;
+    /* Save probe results */
+    chan->final_no_elements  = probe.no_elements;
+    chan->final_field_size   = probe.field_size;
+    chan->final_type         = probe.field_type;
+    chan->dbr_final_type     = dbDBRnewToDBRold[mapDBFToDBR[probe.field_type]];
+    return 0;
+/* FIXME: For performance we should make these one-liners into macros,
+ * or try to make them inline if all our compilers can do that.
+const char * dbChannelName(dbChannel *chan)
+    return chan->name;
+struct dbCommon * dbChannelRecord(dbChannel *chan)
+    return chan->addr.precord;
+struct dbFldDes * dbChannelFldDes(dbChannel *chan)
+    return chan->addr.pfldDes;
+long dbChannelElements(dbChannel *chan)
+    return chan->addr.no_elements;
+short dbChannelFieldType(dbChannel *chan)
+    return chan->addr.field_type;
+short dbChannelExportType(dbChannel *chan)
+    return chan->addr.dbr_field_type;
+short dbChannelFieldSize(dbChannel *chan)
+    return chan->addr.field_size;
+long dbChannelFinalElements(dbChannel *chan)
+    return chan->final_no_elements;
+short dbChannelFinalFieldType(dbChannel *chan)
+    return chan->final_type;
+short dbChannelFinalExportType(dbChannel *chan)
+    return chan->dbr_final_type;
+short dbChannelFinalFieldSize(dbChannel *chan)
+    return chan->final_field_size;
+short dbChannelSpecial(dbChannel *chan)
+    return chan->addr.special;
+void * dbChannelField(dbChannel *chan)
+    /* Channel filters do not get to interpose here since there are many
+     * places where the field pointer is compared with the address of a
+     * specific record field, so they can't modify the pointer value.
+    return chan->addr.pfield;
+/* Only use dbChannelGet() if the record is already locked. */
+long dbChannelGet(dbChannel *chan, short type, void *pbuffer,
+        long *options, long *nRequest, void *pfl)
+    /* FIXME: Vector through chan->get() ? */
+    return dbGet(&chan->addr, type, pbuffer, options, nRequest, pfl);
+long dbChannelGetField(dbChannel *chan, short dbrType, void *pbuffer,
+    dbCommon *precord = chan->addr.precord;
+    long status = 0;
+    dbScanLock(precord);
+    status = dbChannelGet(chan, dbrType, pbuffer, options, nRequest, pfl);
+    dbScanUnlock(precord);
+    return status;
+/* Only use dbChannelPut() if the record is already locked.
+ * This routine doesn't work on link fields, ignores DISP, and
+ * doesn't trigger record processing on PROC or pp(TRUE).
+long dbChannelPut(dbChannel *chan, short type, const void *pbuffer,
+        long nRequest)
+    /* FIXME: Vector through chan->put() ? */
+    return dbPut(&chan->addr, type, pbuffer, nRequest);
+long dbChannelPutField(dbChannel *chan, short type, const void *pbuffer,
+        long nRequest)
+    /* FIXME: Vector through chan->putField() ? */
+    return dbPutField(&chan->addr, type, pbuffer, nRequest);
+void dbChannelShow(dbChannel *chan, int level, const unsigned short indent)
+    long elems = chan->addr.no_elements;
+    long felems = chan->final_no_elements;
+    int count = ellCount(&chan->filters);
+    int pre   = ellCount(&chan->pre_chain);
+    int post  = ellCount(&chan->post_chain);
+    printf("%*schannel name: %s\n", indent, "", chan->name);
+    /* FIXME: show field_type as text */
+    printf("%*s  field_type=%d (%dB), %ld element%s, %d filter%s", indent, "",
+           chan->addr.field_type, chan->addr.field_size, elems, elems == 1 ? "" : "s",
+           count, count == 1 ? "" : "s");
+    if (count)
+        printf(" (%d pre eventq, %d post eventq)\n", pre, post);
+    else
+        printf("\n");
+    if (level > 0)
+        dbChannelFilterShow(chan, level - 1, indent + 2);
+    if (count) {
+        printf("%*s  final field_type=%d (%dB), %ld element%s\n", indent, "",
+               chan->final_type, chan->final_field_size, felems, felems == 1 ? "" : "s");
+void dbChannelFilterShow(dbChannel *chan, int level, const unsigned short indent)
+    chFilter *filter = (chFilter *) ellFirst(&chan->filters);
+    while (filter) {
+        filter->plug->fif->channel_report(filter, level, indent);
+        filter = (chFilter *) ellNext(&filter->list_node);
+void dbChannelDelete(dbChannel *chan)
+    chFilter *filter;
+    /* Close filters in reverse order */
+    while ((filter = (chFilter *) ellPop(&chan->filters))) {
+        filter->plug->fif->channel_close(filter);
+        free(filter);
+    free((char *) chan->name);   // FIXME: Use free-list
+    free(chan); // FIXME: Use free-list
+static void freeArray(db_field_log *pfl) {
+    if (pfl->field_type == DBF_STRING && pfl->no_elements == 1) {
+        freeListFree(dbchStringFreeList, pfl->u.r.field);
+    } else {
+        free(pfl->u.r.field);
+void dbChannelMakeArrayCopy(void *pvt, db_field_log *pfl, dbChannel *chan)
+    void *p;
+    if (!pfl->type == dbfl_type_rec) return;
+    struct dbCommon *prec = dbChannelRecord(chan);
+    pfl->type = dbfl_type_ref;
+    pfl->stat = prec->stat;
+    pfl->sevr = prec->sevr;
+    pfl->time = prec->time;
+    pfl->field_type  = chan->addr.field_type;
+    pfl->no_elements = chan->addr.no_elements;
+    pfl->field_size  = chan->addr.field_size;
+    pfl->u.r.dtor = freeArray;
+    pfl->u.r.pvt = pvt;
+        p = freeListCalloc(dbchStringFreeList);
+    } else {
+        p = calloc(pfl->no_elements, pfl->field_size);
+    if (p) dbGet(&chan->addr, mapDBFToDBR[pfl->field_type], p, NULL, &pfl->no_elements, NULL);
+    pfl->u.r.field = p;
+/* FIXME: Do these belong in a different file? */
+void dbRegisterFilter(const char *name, const chFilterIf *fif, void *puser)
+    GPHENTRY *pgph;
+    chFilterPlugin *pfilt;
+    if (!pdbbase) {
+        printf("dbRegisterFilter: pdbbase not set!\n");
+        return;
+    pgph = gphFind(pdbbase->pgpHash, name, &pdbbase->filterList);
+    if (pgph)
+        return;
+    pfilt = dbCalloc(1, sizeof(chFilterPlugin));
+    pfilt->name = strdup(name);
+    pfilt->fif = fif;
+    pfilt->puser = puser;
+    ellAdd(&pdbbase->filterList, &pfilt->node);
+    pgph = gphAdd(pdbbase->pgpHash, pfilt->name, &pdbbase->filterList);
+    if (!pgph) {
+        free((void *) pfilt->name);
+        free(pfilt);
+        printf("dbRegisterFilter: gphAdd failed\n");
+        return;
+    pgph->userPvt = pfilt;
+const chFilterPlugin * dbFindFilter(const char *name, size_t len)
+    GPHENTRY *pgph = gphFindParse(pdbbase->pgpHash, name, len,
+            &pdbbase->filterList);
+    if (!pgph)
+        return NULL;
+    return (chFilterPlugin *) pgph->userPvt;
=== added file 'src/ioc/db/dbChannel.h'
--- src/ioc/db/dbChannel.h	1970-01-01 00:00:00 +0000
+++ src/ioc/db/dbChannel.h	2012-05-30 18:10:27 +0000
@@ -0,0 +1,181 @@
+ *          Ralph Lange <[email protected]>
+#ifndef INC_dbChannel_H
+#define INC_dbChannel_H
+#include "dbDefs.h"
+#include "ellLib.h"
+#include "epicsTypes.h"
+#include "errMdef.h"
+#include "shareLib.h"
+#include "db_field_log.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * event subscription
+typedef struct evSubscrip {
+    ELLNODE                 node;
+    struct dbChannel        *chan;
+    EVENTFUNC               *user_sub;
+    void                    *user_arg;
+    struct event_que        *ev_que;
+    db_field_log            **pLastLog;
+    unsigned long           npend;  /* n times this event is on the queue */
+    unsigned long           nreplace;  /* n times replacing event on the queue */
+    unsigned char           select;
+    char                    useValque;
+    char                    callBackInProgress;
+    char                    enabled;
+} evSubscrip;
+typedef struct chFilter chFilter;
+/* A dbChannel points to a record field, and can have multiple filters */
+typedef struct dbChannel {
+    const char *name;
+    dbAddr addr;              /* address structure for record/field */
+    long  final_no_elements;  /* final number of elements (arrays) */
+    short final_field_size;   /* final size of element */
+    short final_type;         /* final type of database field */
+    short dbr_final_type;     /* final field type as seen by database request */
+    ELLLIST filters;          /* list of filters as created from JSON */
+    ELLLIST pre_chain;        /* list of filters to be called pre-event-queue */
+    ELLLIST post_chain;       /* list of filters to be called post-event-queue */
+} dbChannel;
+/* Prototype for the post event function that is called in filter stacks */
+typedef db_field_log* (chPostEventFunc)(void *pvt, dbChannel *chan, db_field_log *pLog);
+/* Return values from chFilterIf->parse_* routines: */
+typedef enum {
+    parse_stop, parse_continue
+} parse_result;
+/* These routines must be implemented by each filter plug-in */
+typedef struct chFilterIf {
+    /* Parsing event handlers: */
+    parse_result (* parse_start)(chFilter *filter);
+    /* If parse_start() returns parse_continue for a filter, one of
+     * parse_abort() or parse_end() will later be called for that same
+     * filter.
+    void (* parse_abort)(chFilter *filter);
+    /* If parse_abort() is called it should release any memory allocated
+     * for this filter; no further parse_...() calls will be made;
+    parse_result (* parse_end)(chFilter *filter);
+    /* If parse_end() returns parse_stop it should have released any
+     * memory allocated for this filter; no further parse_...() calls will
+     * be made in this case.
+    parse_result (* parse_null)(chFilter *filter);
+    parse_result (* parse_boolean)(chFilter *filter, int boolVal);
+    parse_result (* parse_integer)(chFilter *filter, long integerVal);
+    parse_result (* parse_double)(chFilter *filter, double doubleVal);
+    parse_result (* parse_string)(chFilter *filter, const char *stringVal,
+            size_t stringLen); /* NB: stringVal is not zero-terminated: */
+    parse_result (* parse_start_map)(chFilter *filter);
+    parse_result (* parse_map_key)(chFilter *filter, const char *key,
+            size_t stringLen); /* NB: key is not zero-terminated: */
+    parse_result (* parse_end_map)(chFilter *filter);
+    parse_result (* parse_start_array)(chFilter *filter);
+    parse_result (* parse_end_array)(chFilter *filter);
+    /* Channel operations: */
+    long (* channel_open)(chFilter *filter);
+    void (* channel_register_pre) (chFilter *filter, chPostEventFunc **cb_out, void **arg_out, db_field_log *probe);
+    void (* channel_register_post)(chFilter *filter, chPostEventFunc **cb_out, void **arg_out, db_field_log *probe);
+    void (* channel_report)(chFilter *filter, int level, const unsigned short indent);
+    /* FIXME: More filter routines here ... */
+    void (* channel_close)(chFilter *filter);
+} chFilterIf;
+/* A chFilterPlugin holds data for a filter plugin */
+typedef struct chFilterPlugin {
+    ELLNODE node;
+    const char *name;
+    const chFilterIf *fif;
+    void *puser;
+} chFilterPlugin;
+/* A chFilter holds data for a single filter instance */
+struct chFilter {
+    ELLNODE list_node;
+    ELLNODE pre_node;
+    ELLNODE post_node;
+    dbChannel *chan;
+    chPostEventFunc *pre_func;
+    void *pre_arg;
+    chPostEventFunc *post_func;
+    void *post_arg;
+    void *puser;
+struct dbCommon;
+struct dbFldDes;
+epicsShareFunc void dbChannelInit (void);
+epicsShareFunc long dbChannelTest(const char *name);
+epicsShareFunc dbChannel * dbChannelCreate(const char *name);
+epicsShareFunc long dbChannelOpen(dbChannel *chan);
+epicsShareFunc const char * dbChannelName(dbChannel *chan);
+epicsShareFunc struct dbCommon * dbChannelRecord(dbChannel *chan);
+epicsShareFunc struct dbFldDes * dbChannelFldDes(dbChannel *chan);
+epicsShareFunc long dbChannelElements(dbChannel *chan);
+epicsShareFunc short dbChannelFieldType(dbChannel *chan);
+epicsShareFunc short dbChannelExportType(dbChannel *chan);
+epicsShareFunc short dbChannelFieldSize(dbChannel *chan);
+epicsShareFunc long dbChannelFinalElements(dbChannel *chan);
+epicsShareFunc short dbChannelFinalFieldType(dbChannel *chan);
+epicsShareFunc short dbChannelFinalExportType(dbChannel *chan);
+epicsShareFunc short dbChannelFinalElementSize(dbChannel *chan);
+epicsShareFunc short dbChannelSpecial(dbChannel *chan);
+epicsShareFunc void * dbChannelField(dbChannel *chan);
+epicsShareFunc long dbChannelGet(dbChannel *chan, short type,
+        void *pbuffer, long *options, long *nRequest, void *pfl);
+epicsShareFunc long dbChannelGetField(dbChannel *chan, short type,
+epicsShareFunc long dbChannelPut(dbChannel *chan, short type,
+        const void *pbuffer, long nRequest);
+epicsShareFunc long dbChannelPutField(dbChannel *chan, short type,
+epicsShareFunc void dbChannelShow(dbChannel *chan, int level,
+        const unsigned short indent);
+epicsShareFunc void dbChannelFilterShow(dbChannel *chan, int level,
+epicsShareFunc void dbChannelDelete(dbChannel *chan);
+epicsShareFunc void dbRegisterFilter(const char *key, const chFilterIf *fif, void *puser);
+epicsShareFunc db_field_log* dbChannelRunPreChain(dbChannel *chan, db_field_log *pLogIn);
+epicsShareFunc db_field_log* dbChannelRunPostChain(dbChannel *chan, db_field_log *pLogIn);
+epicsShareFunc const chFilterPlugin * dbFindFilter(const char *key, size_t len);
+epicsShareFunc void dbChannelMakeArrayCopy(void *pvt, db_field_log *pfl, dbChannel *chan);
+#ifdef __cplusplus
+#endif
+#endif /* INC_dbChannel_H */
=== modified file 'src/ioc/db/dbChannelIO.cpp'
--- src/ioc/db/dbChannelIO.cpp	2010-10-05 19:27:37 +0000
+++ src/ioc/db/dbChannelIO.cpp	2012-05-30 18:10:27 +0000
@@ -4,20 +4,20 @@
 * Copyright (c) 2002 The Regents of the University of California, as
 *     Operator of Los Alamos National Laboratory.
-* in file LICENSE that is included with this distribution.
  *  $Revision-Id$
  *                    L O S  A L A M O S
  *              Los Alamos National Laboratory
  *               Los Alamos, New Mexico 87545
  *  Copyright, 1986, The Regents of the University of California.
  *	Author Jeffrey O. Hill
  *	[email protected]
  *	505 665 1831
@@ -40,15 +40,12 @@
 #include "dbChannelIO.h"
 #include "dbPutNotifyBlocker.h"
-dbChannelIO::dbChannelIO (
-    epicsMutex & mutexIn, cacChannelNotify & notify,
-    const dbAddr & addrIn, dbContext & serviceIO ) :
-    cacChannel ( notify ), mutex ( mutexIn ), serviceIO ( serviceIO ),
-    addr ( addrIn )
+dbChannelIO::dbChannelIO (
+    epicsMutex & mutexIn, cacChannelNotify & notify,
+    dbChannel * dbchIn, dbContext & serviceIO ) :
+    cacChannel ( notify ), mutex ( mutexIn ), serviceIO ( serviceIO ),
+    dbch ( dbchIn )
-    unsigned bufLen = dbNameSizeOfPV ( & this->addr ) + 1;
-    this->pNameStr.reset ( new char [ bufLen ] );
-    dbNameOfPV ( & this->addr, this->pNameStr.get (), bufLen );
 void dbChannelIO::initiateConnect ( epicsGuard < epicsMutex > & guard )
@@ -57,7 +54,7 @@
     this->notify().connectNotify ( guard );
-dbChannelIO::~dbChannelIO ()
+dbChannelIO::~dbChannelIO ()
@@ -65,48 +62,49 @@
     guard.assertIdenticalMutex ( this->mutex );
     this->serviceIO.destroyAllIO ( guard, *this );
+    dbChannelDelete ( this->dbch );
     this->~dbChannelIO ();
-void dbChannelIO::destroy (
+void dbChannelIO::destroy (
     this->serviceIO.destroyChannel ( guard, *this );
-    // dont access this pointer after above call because
-    // object nolonger exists
+    // don't access this pointer after above call because
+    // object no longer exists
-cacChannel::ioStatus dbChannelIO::read (
-     epicsGuard < epicsMutex > & guard, unsigned type,
-     unsigned long count, cacReadNotify & notify, ioid * )
+cacChannel::ioStatus dbChannelIO::read (
+     epicsGuard < epicsMutex > & guard, unsigned type,
+     unsigned long count, cacReadNotify & notify, ioid * )
-    this->serviceIO.callReadNotify ( guard, this->addr,
+    this->serviceIO.callReadNotify ( guard, this->dbch,
         type, count, notify );
     return iosSynch;
-void dbChannelIO::write (
+void dbChannelIO::write (
     unsigned long count, const void *pValue )
     epicsGuardRelease < epicsMutex > unguard ( guard );
     if ( count > LONG_MAX ) {
         throw outOfBounds();
-    int status = db_put_field ( &this->addr, type, pValue,
+    int status = dbChannel_put ( this->dbch, type, pValue,
         static_cast <long> (count) );
     if ( status ) {
-        throw std::logic_error (
+        throw std::logic_error (
            "db_put_field() completed unsuccessfully" );
-cacChannel::ioStatus dbChannelIO::write (
-    unsigned long count, const void * pValue,
-    cacWriteNotify & notify, ioid * pId )
+cacChannel::ioStatus dbChannelIO::write (
+    unsigned long count, const void * pValue,
+    cacWriteNotify & notify, ioid * pId )
@@ -114,24 +112,24 @@
-    this->serviceIO.initiatePutNotify (
-        guard, *this, this->addr,
+    this->serviceIO.initiatePutNotify (
+        guard, *this, this->dbch,
         type, count, pValue, notify, pId );
     return iosAsynch;
-void dbChannelIO::subscribe (
-    epicsGuard < epicsMutex > & guard, unsigned type, unsigned long count,
-    unsigned mask, cacStateNotify & notify, ioid * pId )
+void dbChannelIO::subscribe (
+    epicsGuard < epicsMutex > & guard, unsigned type, unsigned long count,
+    unsigned mask, cacStateNotify & notify, ioid * pId )
-    this->serviceIO.subscribe (
-        guard, this->addr, *this,
+    this->serviceIO.subscribe (
+        guard, this->dbch, *this,
         type, count, mask, notify, pId );
-void dbChannelIO::ioCancel (
+void dbChannelIO::ioCancel (
     epicsGuard < epicsMutex > & mutualExclusionGuard,
     const ioid & id )
@@ -139,7 +137,7 @@
     this->serviceIO.ioCancel ( mutualExclusionGuard, *this, id );
-void dbChannelIO::ioShow (
+void dbChannelIO::ioShow (
     const ioid & id, unsigned level ) const
@@ -147,31 +145,35 @@
     this->serviceIO.ioShow ( guard, id, level );
-void dbChannelIO::show (
+void dbChannelIO::show (
     epicsGuard < epicsMutex > & guard, unsigned level ) const
-    printf ("channel at %p attached to local database record %s\n",
-        static_cast <const void *> ( this ), this->addr.precord->name );
+    printf ("channel at %p attached to local database record %s\n",
+        static_cast <const void *> ( this ),
+        dbChannelRecord ( this->dbch ) -> name );
     if ( level > 0u ) {
-        printf ( "\ttype %s, element count %li, field at %p\n",
-            dbf_type_to_text ( this->addr.dbr_field_type ), this->addr.no_elements,
-            this->addr.pfield );
-    if ( level > 1u ) {
-        this->serviceIO.show ( level - 2u );
-        this->serviceIO.showAllIO ( *this, level - 2u );
+        printf ( "        type %s, element count %li, field at %p\n",
+            dbf_type_to_text ( dbChannelExportType ( this->dbch ) ),
+            dbChannelElements ( this->dbch ),
+            dbChannelField ( this->dbch ) );
+        if ( level > 1u ) {
+            dbChannelFilterShow ( this->dbch, level - 2u, 8 );
+            this->serviceIO.show ( level - 2u );
+            this->serviceIO.showAllIO ( *this, level - 2u );
 unsigned long dbChannelIO::nativeElementCount (
-    epicsGuard < epicsMutex > & guard ) const
+    epicsGuard < epicsMutex > & guard ) const
-    if ( this->addr.no_elements >= 0u ) {
-        return static_cast < unsigned long > ( this->addr.no_elements );
+    long elements = dbChannelElements ( this->dbch );
+    if ( elements >= 0u ) {
+        return static_cast < unsigned long > ( elements );
     return 0u;
@@ -181,24 +183,30 @@
     epicsGuard < epicsMutex > & guard ) const throw ()
-    return this->pNameStr.get ();
+    return dbChannelName ( this->dbch );
 unsigned dbChannelIO::getName (
     char * pBuf, unsigned bufLen ) const throw ()
-    return dbNameOfPV ( & this->addr, pBuf, bufLen );
+    const char *name = dbChannelName ( this->dbch );
+    size_t len = strlen ( name );
+    strncpy ( pBuf, name, bufLen );
+    if (len < bufLen)
+        return len;
+    pBuf[--bufLen] = '\0';
+    return bufLen;
 short dbChannelIO::nativeType (
-    return this->addr.dbr_field_type;
+    return dbChannelExportType( this->dbch );
-void * dbChannelIO::operator new ( size_t size,
+void * dbChannelIO::operator new ( size_t size,
     tsFreeList < dbChannelIO, 256, epicsMutexNOOP > & freeList )
     return freeList.allocate ( size );
@@ -212,7 +220,7 @@
 #ifdef CXX_PLACEMENT_DELETE
-void dbChannelIO::operator delete ( void *pCadaver,
+void dbChannelIO::operator delete ( void *pCadaver,
     freeList.release ( pCadaver );
=== modified file 'src/ioc/db/dbChannelIO.h'
--- src/ioc/db/dbChannelIO.h	2010-10-05 19:27:37 +0000
+++ src/ioc/db/dbChannelIO.h	2012-05-30 18:10:27 +0000
@@ -5,7 +5,7 @@
 * EPICS BASE Versions 3.13.7
 * and higher are distributed subject to a Software License Agreement found
@@ -44,65 +44,64 @@
 class dbChannelIO : public cacChannel, public dbContextPrivateListOfIO {
 public:
-    dbChannelIO (
-        epicsMutex &, cacChannelNotify &,
-        const dbAddr &, dbContext & );
-    void destructor (
+    dbChannelIO (
+        epicsMutex &, cacChannelNotify &,
+        dbChannel *, dbContext & );
+    void destructor (
     void destroy (
         epicsGuard < epicsMutex > & mutualExclusionGuard );
-    void show (
+    void show (
     unsigned getName (
         char * pBuf, unsigned bufLen ) const throw ();
     const char * pName (
         epicsGuard < epicsMutex > & ) const throw ();
         tsFreeList < dbChannelIO, 256, epicsMutexNOOP > & );
         tsFreeList < dbChannelIO, 256, epicsMutexNOOP > & ))
 protected:
     ~dbChannelIO ();
 private:
     epicsMutex & mutex;
     dbContext & serviceIO;
-    dbAddr addr;
-    epics_auto_ptr < char, eapt_array > pNameStr;
+    dbChannel * dbch;
     void initiateConnect (
-    unsigned requestMessageBytesPending (
-        epicsGuard < epicsMutex > & );
-    void flush (
-    ioStatus read (
+    unsigned requestMessageBytesPending (
+        epicsGuard < epicsMutex > & );
+    void flush (
+    ioStatus read (
         cacReadNotify &, ioid * );
-    void write (
+    void write (
         const void * pvalue );
-    ioStatus write (
+    ioStatus write (
         const void * pvalue, cacWriteNotify &, ioid * );
-    void subscribe (
+    void subscribe (
         unsigned mask, cacStateNotify &notify, ioid * );
-    void ioCancel (
+    void ioCancel (
         const ioid & );
-    void ioShow (
+    void ioShow (
         const ioid &, unsigned level ) const;
     short nativeType (
@@ -115,18 +114,18 @@
     void operator delete ( void * );
-inline void dbChannelIO::callReadNotify (
+inline void dbChannelIO::callReadNotify (
-    this->serviceIO.callReadNotify ( guard, this->addr, type, count, notify );
+    this->serviceIO.callReadNotify ( guard, this->dbch, type, count, notify );
-inline void dbChannelIO::callStateNotify ( unsigned type, unsigned long count,
+inline void dbChannelIO::callStateNotify ( unsigned type, unsigned long count,
         const struct db_field_log *pfl, cacStateNotify &notify )
-    this->serviceIO.callStateNotify ( this->addr, type, count, pfl, notify );
+    this->serviceIO.callStateNotify ( this->dbch, type, count, pfl, notify );
=== modified file 'src/ioc/db/dbContext.cpp'
--- src/ioc/db/dbContext.cpp	2010-10-05 19:27:37 +0000
+++ src/ioc/db/dbContext.cpp	2012-05-30 18:10:27 +0000
@@ -4,19 +4,19 @@
  *  $Revision-Id$
  *                    L O S  A L A M O S
  *	[email protected]
  *	505 665 1831
@@ -33,6 +33,7 @@
 #include "epicsEvent.h"
 #include "epicsThread.h"
 #include "errlog.h"
 #define epicsExportSharedSymbols
 #include "db_access_routines.h"
@@ -43,20 +44,20 @@
 class dbService : public cacService {
 public:
     ~dbService () {}
-    cacContext & contextCreate (
-        epicsMutex & mutualExclusion,
-        epicsMutex & callbackControl,
+    cacContext & contextCreate (
+        epicsMutex & mutualExclusion,
+        epicsMutex & callbackControl,
         cacContextNotify & );
 static dbService dbs;
-cacContext & dbService::contextCreate (
+cacContext & dbService::contextCreate (
-    return * new dbContext ( callbackControl,
+    return * new dbContext ( callbackControl,
         mutualExclusion, notify );
@@ -67,9 +68,9 @@
 dbBaseIO::dbBaseIO () {}
-dbContext::dbContext ( epicsMutex & cbMutexIn,
+dbContext::dbContext ( epicsMutex & cbMutexIn,
         epicsMutex & mutexIn, cacContextNotify & notifyIn ) :
-    readNotifyCache ( mutexIn ), ctx ( 0 ),
+    readNotifyCache ( mutexIn ), ctx ( 0 ),
     stateNotifyCacheSize ( 0 ), mutex ( mutexIn ), cbMutex ( cbMutexIn ),
     notify ( notifyIn ), pNetContext ( 0 ), pStateNotifyCache ( 0 )
@@ -84,41 +85,41 @@
 cacChannel & dbContext::createChannel ( // X aCC 361
-    epicsGuard < epicsMutex > & guard, const char * pName,
+    epicsGuard < epicsMutex > & guard, const char * pName,
     cacChannelNotify & notifyIn, cacChannel::priLev priority )
-    struct dbAddr addr;
-    int status;
-        // dont know if the database might call a put callback
-        // while holding its lock ...
-        epicsGuardRelease < epicsMutex > unguard ( guard );
-        status = db_name_to_addr ( pName, & addr );
-    if ( status ) {
+    dbChannel *dbch = dbChannel_create ( pName );
+    if ( ! dbch ) {
         if ( ! this->pNetContext.get() ) {
             this->pNetContext.reset (
-                & this->notify.createNetworkContext (
+                & this->notify.createNetworkContext (
                     this->mutex, this->cbMutex ) );
         return this->pNetContext->createChannel (
                     guard, pName, notifyIn, priority );
-    else if ( ca_preemtive_callback_is_enabled () ) {
-        return * new ( this->dbChannelIOFreeList )
-            dbChannelIO ( this->mutex, notifyIn, addr, *this );
-    else {
-        errlogPrintf (
+    if ( ! ca_preemtive_callback_is_enabled () ) {
+        dbChannelDelete ( dbch );
+        errlogPrintf (
             "dbContext: preemptive callback required for direct in\n"
             "memory interfacing of CA channels to the DB.\n" );
         throw cacChannel::unsupportedByService ();
+    try {
+        return * new ( this->dbChannelIOFreeList )
+            dbChannelIO ( this->mutex, notifyIn, dbch, *this );
+    catch (...) {
+        throw;
-void dbContext::destroyChannel (
+void dbContext::destroyChannel (
     epicsGuard < epicsMutex > & guard, dbChannelIO & chan )
@@ -134,30 +135,30 @@
     this->dbChannelIOFreeList.release ( & chan );
-void dbContext::callStateNotify ( struct dbAddr & addr,
-        const struct db_field_log * pfl,
+void dbContext::callStateNotify ( struct dbChannel * dbch,
+        const struct db_field_log * pfl,
         cacStateNotify & notifyIn )
     unsigned long size = dbr_size_n ( type, count );
     if ( type > INT_MAX ) {
         epicsGuard < epicsMutex > guard ( this->mutex );
-        notifyIn.exception ( guard, ECA_BADTYPE,
-            "type code out of range (high side)",
+        notifyIn.exception ( guard, ECA_BADTYPE,
+            "type code out of range (high side)",
             type, count );
         return;
     if ( count > INT_MAX ) {
-        notifyIn.exception ( guard, ECA_BADCOUNT,
+        notifyIn.exception ( guard, ECA_BADCOUNT,
             "element count out of range (high side)",
             type, count);
         return;
-    // no need to lock this because state notify is
+    // no need to lock this because state notify is
     // called from only one event queue consumer thread
     if ( this->stateNotifyCacheSize < size) {
         char * pTmp = new char [size];
@@ -166,14 +167,14 @@
         this->stateNotifyCacheSize = size;
     void *pvfl = (void *) pfl;
-    int status = db_get_field ( &addr, static_cast <int> ( type ),
+    int status = dbChannel_get ( dbch, static_cast <int> ( type ),
                     this->pStateNotifyCache, static_cast <int> ( count ), pvfl );
     if ( status ) {
-        notifyIn.exception ( guard, ECA_GETFAIL,
-            "db_get_field() completed unsuccessfuly", type, count );
+        notifyIn.exception ( guard, ECA_GETFAIL,
+            "dbChannel_get() completed unsuccessfully", type, count );
-    else {
+    else {
         notifyIn.current ( guard, type, count, this->pStateNotifyCache );
@@ -185,10 +186,10 @@
     assert ( status == ECA_NORMAL );
-void dbContext::subscribe (
+void dbContext::subscribe (
     cacStateNotify & notifyIn, cacChannel::ioid * pId )
@@ -214,12 +215,12 @@
             unsigned selfPriority = epicsThreadGetPrioritySelf ();
             unsigned above;
-            epicsThreadBooleanStatus tbs =
+            epicsThreadBooleanStatus tbs =
                 epicsThreadLowestPriorityLevelAbove ( selfPriority, &above );
             if ( tbs != epicsThreadBooleanStatusSuccess ) {
                 above = selfPriority;
-            int status = db_start_events ( tmpctx, "CAC-event",
+            int status = db_start_events ( tmpctx, "CAC-event",
                 cacAttachClientCtx, ca_current_context (), above );
             if ( status ) {
                 db_close_events ( tmpctx );
@@ -227,7 +228,7 @@
         if ( this->ctx ) {
-            // another thread tried to simultaneously setup
+            // another thread tried to simultaneously setup
             // the event system
@@ -237,9 +238,9 @@
     dbSubscriptionIO & subscr =
-        * new ( this->dbSubscriptionIOFreeList )
-        dbSubscriptionIO ( guard, this->mutex, *this, chan,
-            addr, notifyIn, type, count, mask, this->ctx );
+        * new ( this->dbSubscriptionIOFreeList )
+        dbSubscriptionIO ( guard, this->mutex, *this, chan,
+            dbch, notifyIn, type, count, mask, this->ctx );
     chan.dbContextPrivateListOfIO::eventq.add ( subscr );
     this->ioTable.idAssignAdd ( subscr );
@@ -248,27 +249,27 @@
-void dbContext::initiatePutNotify (
+void dbContext::initiatePutNotify (
-    dbChannelIO & chan, struct dbAddr & addr,
+    dbChannelIO & chan, struct dbChannel * dbch,
     cacWriteNotify & notifyIn, cacChannel::ioid * pId )
     if ( ! chan.dbContextPrivateListOfIO::pBlocker ) {
-        chan.dbContextPrivateListOfIO::pBlocker =
-            new ( this->dbPutNotifyBlockerFreeList )
+        chan.dbContextPrivateListOfIO::pBlocker =
+            new ( this->dbPutNotifyBlockerFreeList )
                 dbPutNotifyBlocker ( this->mutex );
         this->ioTable.idAssignAdd ( *chan.dbContextPrivateListOfIO::pBlocker );
-    chan.dbContextPrivateListOfIO::pBlocker->initiatePutNotify (
-        guard, notifyIn, addr, type, count, pValue );
+    chan.dbContextPrivateListOfIO::pBlocker->initiatePutNotify (
+        guard, notifyIn, dbch, type, count, pValue );
     if ( pId ) {
         *pId = chan.dbContextPrivateListOfIO::pBlocker->getId ();
-void dbContext::destroyAllIO (
+void dbContext::destroyAllIO (
@@ -284,7 +285,7 @@
     while ( ( pIO = tmp.get() ) ) {
-        // This prevents a db event callback from coming
+        // This prevents a db event callback from coming
         // through after the notify IO is deleted
         pIO->unsubscribe ( guard );
         // If they call ioCancel() here it will be ignored
@@ -301,8 +302,8 @@
-void dbContext::ioCancel (
-    epicsGuard < epicsMutex > & guard, dbChannelIO & chan,
+void dbContext::ioCancel (
+    epicsGuard < epicsMutex > & guard, dbChannelIO & chan,
@@ -325,8 +326,8 @@
-void dbContext::ioShow (
-    epicsGuard < epicsMutex > & guard, const cacChannel::ioid &id,
+void dbContext::ioShow (
+    epicsGuard < epicsMutex > & guard, const cacChannel::ioid &id,
@@ -339,7 +340,7 @@
 void dbContext::showAllIO ( const dbChannelIO & chan, unsigned level ) const
-    tsDLIterConst < dbSubscriptionIO > pItem =
+    tsDLIterConst < dbSubscriptionIO > pItem =
         chan.dbContextPrivateListOfIO::eventq.firstIter ();
     while ( pItem.valid () ) {
         pItem->show ( guard, level );
@@ -356,14 +357,14 @@
     this->show ( guard, level );
-void dbContext::show (
+void dbContext::show (
-    printf ( "dbContext at %p\n",
+    printf ( "dbContext at %p\n",
         static_cast <const void *> ( this ) );
     if ( level > 0u ) {
-        printf ( "\tevent call back cache location %p, and its size %lu\n",
+        printf ( "\tevent call back cache location %p, and its size %lu\n",
             static_cast <void *> ( this->pStateNotifyCache ), this->stateNotifyCacheSize );
         this->readNotifyCache.show ( guard, level - 1 );
@@ -375,7 +376,7 @@
-void dbContext::flush (
+void dbContext::flush (
=== modified file 'src/ioc/db/dbContextReadNotifyCache.cpp'
--- src/ioc/db/dbContextReadNotifyCache.cpp	2010-10-05 19:27:37 +0000
+++ src/ioc/db/dbContextReadNotifyCache.cpp	2012-05-30 18:10:27 +0000
@@ -5,7 +5,7 @@
@@ -30,11 +30,11 @@
 class privateAutoDestroyPtr {
 public:
-    privateAutoDestroyPtr (
+    privateAutoDestroyPtr (
         dbContextReadNotifyCacheAllocator & allocator, unsigned long size ) :
         _allocator ( allocator ), _p ( allocator.alloc ( size ) ) {}
     ~privateAutoDestroyPtr () { _allocator.free ( _p ); }
-	char * get () const { return _p; }
+	char * get () const { return _p; }
 private:
     dbContextReadNotifyCacheAllocator & _allocator;
     char * _p;
@@ -43,28 +43,28 @@
 // extra effort taken here to not hold the lock when calling the callback
-void dbContextReadNotifyCache::callReadNotify (
-    epicsGuard < epicsMutex > & guard, struct dbAddr & addr,
+void dbContextReadNotifyCache::callReadNotify (
 	unsigned type, unsigned long count, cacReadNotify & notify )
     guard.assertIdenticalMutex ( _mutex );
-        notify.exception ( guard, ECA_BADTYPE,
+        notify.exception ( guard, ECA_BADTYPE,
             type, count );
         return;
-    if ( addr.no_elements < 0 ) {
-        notify.exception ( guard, ECA_BADCOUNT,
+    if ( dbChannelElements(dbch) < 0 ) {
+        notify.exception ( guard, ECA_BADCOUNT,
             "database has negetive element count",
             type, count);
         return;
-    if ( count > static_cast < unsigned > ( addr.no_elements ) ) {
+    if ( count > static_cast < unsigned long > ( dbChannelElements(dbch) ) ) {
             type, count);
         return;
@@ -75,21 +75,21 @@
     int status;
-        status = db_get_field ( &addr, static_cast <int> ( type ),
-                    ptr.get (), static_cast <int> ( count ), 0 );
+        status = dbChannel_get ( dbch, static_cast <int> ( type ),
+                    ptr.get (), static_cast <long> ( count ), 0 );
     if ( status ) {
-        notify.exception ( guard, ECA_GETFAIL,
+        notify.exception ( guard, ECA_GETFAIL,
             type, count );
-    else {
-        notify.completion (
+    else {
+        notify.completion (
             guard, type, count, ptr.get () );
-void dbContextReadNotifyCache::show (
+void dbContextReadNotifyCache::show (
@@ -155,8 +155,8 @@
             pNext = _pReadNotifyCache->pNext;
             count++;
-        printf ( "\tcount %lu and size %lu\n",
-            static_cast < unsigned long > ( count ),
+        printf ( "\tcount %lu and size %lu\n",
+            static_cast < unsigned long > ( count ),
             _readNotifyCacheSize );
=== modified file 'src/ioc/db/dbEvent.c'
--- src/ioc/db/dbEvent.c	2011-10-19 18:07:00 +0000
+++ src/ioc/db/dbEvent.c	2012-05-30 18:10:27 +0000
@@ -1,19 +1,20 @@
 * Copyright (c) 2002 The University of Chicago, as Operator of Argonne
-* EPICS BASE Versions 3.13.7
-* and higher are distributed subject to a Software License Agreement found
-/* dbEvent.c */
-/* $Revision-Id$ */
-/* routines for scheduling events to lower priority tasks via the RT kernel */
- *  Author:     Jeffrey O. Hill
- *      Date:            4-1-89
+ *  Author: Jeffrey O. Hill <[email protected]>
 #include <stddef.h>
 #include <stdlib.h>
@@ -39,6 +40,7 @@
 #include "dbAddr.h"
 #include "dbLock.h"
@@ -49,51 +51,33 @@
 #define EVENTQEMPTY     ((struct evSubscrip *)NULL)
- * event subscruiption
-struct evSubscrip {
-    ELLNODE                 node;
-    struct dbAddr           *paddr;
-    EVENTFUNC               *user_sub;
-    void                    *user_arg;
-    struct event_que        *ev_que;
-    db_field_log            *pLastLog;
-    unsigned long           npend;  /* n times this event is on the queue */
-    unsigned long           nreplace;  /* n times replacing event on the queue */
-    unsigned char           select;
-    char                    valque;
-    char                    callBackInProgress;
-    char                    enabled;
  * really a ring buffer
 struct event_que {
     /* lock writers to the ring buffer only */
     /* readers must never slow up writers */
     epicsMutexId            writelock;
-    db_field_log            valque[EVENTQUESIZE];
+    db_field_log            *valque[EVENTQUESIZE];
     struct evSubscrip       *evque[EVENTQUESIZE];
     struct event_que        *nextque;       /* in case que quota exceeded */
     struct event_user       *evUser;        /* event user parent struct */
     unsigned short          putix;
     unsigned short          getix;
     unsigned short          quota;          /* the number of assigned entries*/
-    unsigned short          nDuplicates;    /* N events duplicated on this q */
+    unsigned short          nDuplicates;    /* N events duplicated on this q */
     unsigned short          nCanceled;      /* the number of canceled entries */
 struct event_user {
     struct event_que    firstque;       /* the first event que */
     epicsMutexId        lock;
     epicsEventId        ppendsem;       /* Wait while empty */
     epicsEventId        pflush_sem;     /* wait for flush */
     EXTRALABORFUNC      *extralabor_sub;/* off load to event task */
     void                *extralabor_arg;/* parameter to above */
     epicsThreadId       taskid;         /* event handler task id */
     struct evSubscrip   *pSuicideEvent; /* event that is deleteing itself */
     unsigned            queovr;         /* event que overflow count */
@@ -114,34 +98,28 @@
 #define RNGINC(OLD)\
 ( (unsigned short) ( (OLD) >= (EVENTQUESIZE-1) ? 0 : (OLD)+1 ) )
-#define LOCKEVQUE(EV_QUE)\
-epicsMutexMustLock((EV_QUE)->writelock);
-#define UNLOCKEVQUE(EV_QUE)\
-epicsMutexUnlock((EV_QUE)->writelock);
-#define LOCKREC(RECPTR)\
-epicsMutexMustLock((RECPTR)->mlok);
-#define UNLOCKREC(RECPTR)\
-epicsMutexUnlock((RECPTR)->mlok);
+#define LOCKEVQUE(EV_QUE)   epicsMutexMustLock((EV_QUE)->writelock)
+#define UNLOCKEVQUE(EV_QUE) epicsMutexUnlock((EV_QUE)->writelock)
+#define LOCKREC(RECPTR)     epicsMutexMustLock((RECPTR)->mlok)
+#define UNLOCKREC(RECPTR)   epicsMutexUnlock((RECPTR)->mlok)
 static void *dbevEventUserFreeList;
 static void *dbevEventQueueFreeList;
-static void *dbevEventBlockFreeList;
+static void *dbevEventSubscriptionFreeList;
+static void *dbevFieldLogFreeList;
 static char *EVENT_PEND_NAME = "eventTask";
 static struct evSubscrip canceledEvent;
-static unsigned short ringSpace ( const struct event_que *pevq )
+static unsigned short ringSpace ( const struct event_que *pevq )
     if ( pevq->evque[pevq->putix] == EVENTQEMPTY ) {
         if ( pevq->getix > pevq->putix ) {
             return ( unsigned short ) ( pevq->getix - pevq->putix );
         else {
-            return ( unsigned short ) ( ( EVENTQUESIZE + pevq->getix ) - pevq->putix );
+            return ( unsigned short ) ( ( EVENTQUESIZE + pevq->getix ) - pevq->putix );
     return 0;
@@ -163,7 +141,7 @@
     DBADDR              addr;
     long                status;
     struct evSubscrip   *pevent;
-    dbFldDes 		    *pdbFldDes;
+    dbFldDes            *pdbFldDes;
     if ( ! pname ) return DB_EVENT_OK;
     status = dbNameToAddr ( pname, &addr );
@@ -172,7 +150,7 @@
         return DB_EVENT_ERROR;
-    LOCKREC ( addr.precord );
+    LOCKREC (addr.precord);
     pevent = (struct evSubscrip *) ellFirst ( &addr.precord->mlis );
@@ -186,16 +164,16 @@
         ellCount ( &addr.precord->mlis ) );
     while ( pevent ) {
-	    pdbFldDes = pevent->paddr->pfldDes;
+        pdbFldDes = dbChannelFldDes(pevent->chan);
         if ( level > 0 ) {
 	        printf ( "%4.4s", pdbFldDes->name );
 	        printf ( " { " );
-	        if ( pevent->select & DBE_VALUE ) printf( "VALUE " );
-	        if ( pevent->select & DBE_LOG ) printf( "LOG " );
-	        if ( pevent->select & DBE_ALARM ) printf( "ALARM " );
-	        if ( pevent->select & DBE_PROPERTY ) printf( "PROPERTY " );
+                if ( pevent->select & DBE_VALUE ) printf( "VALUE " );
+                if ( pevent->select & DBE_LOG ) printf( "LOG " );
+                if ( pevent->select & DBE_ALARM ) printf( "ALARM " );
+                if ( pevent->select & DBE_PROPERTY ) printf( "PROPERTY " );
 	        printf ( "}" );
             if ( pevent->npend ) {
@@ -210,15 +188,15 @@
                 taskId = ( void * ) pevent->ev_que->evUser->taskid;
                 UNLOCKEVQUE(pevent->ev_que);
                 if ( nEntriesFree == 0u ) {
-                    printf ( ", thread=%p, queue full",
+                    printf ( ", thread=%p, queue full",
                         (void *) taskId );
                 else if ( nEntriesFree == EVENTQUESIZE ) {
-                    printf ( ", thread=%p, queue empty",
+                    printf ( ", thread=%p, queue empty",
                         (void *) taskId );
                 else {
-                    printf ( ", thread=%p, unused entries=%u",
+                    printf ( ", thread=%p, unused entries=%u",
                         (void *) taskId, nEntriesFree );
@@ -229,7 +207,7 @@
                 if ( pevent->nreplace ) {
                     printf (", discarded by replacement=%ld", pevent->nreplace);
-                if ( ! pevent->valque ) {
+                if ( ! pevent->useValque ) {
                     printf (", queueing disabled" );
@@ -245,19 +223,19 @@
             if ( level > 3 ) {
-                printf ( ", ev %p, ev que %p, ev user %p",
-                    ( void * ) pevent,
-                    ( void * ) pevent->ev_que,
+                printf ( ", ev %p, ev que %p, ev user %p",
+                    ( void * ) pevent,
+                    ( void * ) pevent->ev_que,
                     ( void * ) pevent->ev_que->evUser );
 	        printf( "\n" );
-	    pevent = (struct evSubscrip *) ellNext ( &pevent->node );
+            pevent = (struct evSubscrip *) ellNext ( &pevent->node );
-    UNLOCKREC ( addr.precord );
+    UNLOCKREC (addr.precord);
     return DB_EVENT_OK;
@@ -268,32 +246,36 @@
  * Initialize the event facility for this task. Must be called at least once
  * by each task which uses the db event facility
  * returns: ptr to event user block or NULL if memory can't be allocated
 dbEventCtx epicsShareAPI db_init_events (void)
     struct event_user * evUser;
     if (!dbevEventUserFreeList) {
-        freeListInitPvt(&dbevEventUserFreeList,
+        freeListInitPvt(&dbevEventUserFreeList,
             sizeof(struct event_user),8);
     if (!dbevEventQueueFreeList) {
-        freeListInitPvt(&dbevEventQueueFreeList,
+        freeListInitPvt(&dbevEventQueueFreeList,
             sizeof(struct event_que),8);
-    if (!dbevEventBlockFreeList) {
-        freeListInitPvt(&dbevEventBlockFreeList,
+    if (!dbevEventSubscriptionFreeList) {
+        freeListInitPvt(&dbevEventSubscriptionFreeList,
             sizeof(struct evSubscrip),256);
-    evUser = (struct event_user *)
+    if (!dbevFieldLogFreeList) {
+        freeListInitPvt(&dbevFieldLogFreeList,
+            sizeof(struct db_field_log),2048);
+    evUser = (struct event_user *)
         freeListCalloc(dbevEventUserFreeList);
     if (!evUser) {
         return NULL;
     evUser->firstque.evUser = evUser;
     evUser->firstque.writelock = epicsMutexCreate();
     if (!evUser->firstque.writelock) {
@@ -304,7 +286,7 @@
     if (!evUser->ppendsem) {
         epicsMutexDestroy (evUser->firstque.writelock);
         return NULL;
     evUser->pflush_sem = epicsEventCreate(epicsEventEmpty);
     if (!evUser->pflush_sem) {
@@ -327,7 +309,7 @@
  *  DB_CLOSE_EVENTS()
  *  evUser block and additional event queues
  *  deallocated when the event thread terminates
  *  itself
@@ -341,7 +323,7 @@
      * Exit not forced on event blocks for now - this is left to channel
      * access and any other tasks using this facility which can find them
      * more efficiently.
      * NOTE: not deleting events before calling this routine could be
      * hazardous to the system's health.
@@ -375,7 +357,7 @@
  * DB_ADD_EVENT()
 dbEventSubscription epicsShareAPI db_add_event (
-    dbEventCtx ctx, struct dbAddr *paddr,
+    dbEventCtx ctx, struct dbChannel *chan,
     EVENTFUNC *user_sub, void *user_arg, unsigned select)
     struct event_user * const evUser = (struct event_user *) ctx;
@@ -389,7 +371,7 @@
         return NULL;
-    pevent = freeListCalloc ( dbevEventBlockFreeList );
+    pevent = freeListCalloc (dbevEventSubscriptionFreeList);
     if ( ! pevent ) {
         return NULL;
@@ -422,7 +404,7 @@
     epicsMutexUnlock ( evUser->lock );
     if ( ! ev_que ) {
-        freeListFree ( dbevEventBlockFreeList, pevent );
+        freeListFree ( dbevEventSubscriptionFreeList, pevent );
         return NULL;
@@ -430,7 +412,7 @@
     pevent->nreplace =  0ul;
     pevent->user_sub =  user_sub;
     pevent->user_arg =  user_arg;
-    pevent->paddr =     paddr;
+    pevent->chan =      chan;
     pevent->select =    (unsigned char) select;
     pevent->pLastLog =  NULL; /* not yet in the queue */
     pevent->callBackInProgress = FALSE;
@@ -442,12 +424,12 @@
      * communication (for other types they get whatever happens to be
      * there upon wakeup)
-    if( paddr->no_elements == 1 &&
-        paddr->field_size <= sizeof(union native_value)) {
-        pevent->valque = TRUE;
+    if( dbChannelElements(chan) == 1 &&
+        dbChannelFieldSize(chan) <= sizeof(union native_value)) {
+        pevent->useValque = TRUE;
     else {
-        pevent->valque = FALSE;
+        pevent->useValque = FALSE;
     return pevent;
@@ -456,93 +438,93 @@
  * db_event_enable()
-void epicsShareAPI db_event_enable (dbEventSubscription es)
+void epicsShareAPI db_event_enable (dbEventSubscription event)
-    struct evSubscrip * const pevent = (struct evSubscrip *) es;
-    struct dbCommon * const precord =
-                (struct dbCommon *) pevent->paddr->precord;
+    struct evSubscrip * const pevent = (struct evSubscrip *) event;
+    struct dbCommon * const precord = dbChannelRecord(pevent->chan);
-    LOCKREC(precord);
+    LOCKREC (precord);
     if ( ! pevent->enabled ) {
         ellAdd (&precord->mlis, &pevent->node);
         pevent->enabled = TRUE;
-    UNLOCKREC(precord);
+    UNLOCKREC (precord);
  * db_event_disable()
-void epicsShareAPI db_event_disable (dbEventSubscription es)
+void epicsShareAPI db_event_disable (dbEventSubscription event)
-    LOCKREC(precord);
     if ( pevent->enabled ) {
         ellDelete(&precord->mlis, &pevent->node);
         pevent->enabled = FALSE;
  * event_remove()
  * event queue lock _must_ be applied
+ * this nulls the entry in the queue, but doesn't delete the db_field_log chunk
-static void event_remove ( struct event_que *ev_que,
+static void event_remove ( struct event_que *ev_que,
     unsigned short index, struct evSubscrip *placeHolder )
-    struct evSubscrip * const pEvent = ev_que->evque[index];
+    struct evSubscrip * const pevent = ev_que->evque[index];
     ev_que->evque[index] = placeHolder;
-    if ( pEvent->npend == 1u ) {
-        pEvent->pLastLog = NULL;
+    ev_que->valque[index] = NULL;
+    if ( pevent->npend == 1u ) {
+        pevent->pLastLog = NULL;
     else {
-        assert ( pEvent->npend > 1u );
+        assert ( pevent->npend > 1u );
         assert ( ev_que->nDuplicates >= 1u );
         ev_que->nDuplicates--;
-    pEvent->npend--;
+    pevent->npend--;
  * DB_CANCEL_EVENT()
- * This routine does not prevent two threads from deleting
+ * This routine does not prevent two threads from deleting
  * the same block at the same time.
-void epicsShareAPI db_cancel_event (dbEventSubscription es)
+void epicsShareAPI db_cancel_event (dbEventSubscription event)
-    struct evSubscrip * const pevent = ( struct evSubscrip * ) es;
-    db_event_disable ( es );
+    db_event_disable ( event );
-     * flag the event as canceled by NULLing out the callback handler
+     * flag the event as canceled by NULLing out the callback handler
      * make certain that the event isnt being accessed while
      * its call back changes
-    LOCKEVQUE ( pevent->ev_que )
+    LOCKEVQUE (pevent->ev_que);
     pevent->user_sub = NULL;
      * purge this event from the queue
-     * Its better to take this approach rather than waiting
+     * Its better to take this approach rather than waiting
      * for the event thread to finish removing this event
      * from the queue because the event thread will not
-     * process if we are in flow control mode. Since blocking
+     * process if we are in flow control mode. Since blocking
      * here will block CA's TCP input queue then a dead lock
      * would be possible.
-    for (   getix = pevent->ev_que->getix;
+    for (   getix = pevent->ev_que->getix;
             pevent->ev_que->evque[getix] != EVENTQEMPTY; ) {
         if ( pevent->ev_que->evque[getix] == pevent ) {
             assert ( pevent->ev_que->nCanceled < USHRT_MAX );
@@ -561,17 +543,17 @@
     else {
         while ( pevent->callBackInProgress ) {
-            UNLOCKEVQUE ( pevent->ev_que )
+            UNLOCKEVQUE (pevent->ev_que);
             epicsEventMustWait ( pevent->ev_que->evUser->pflush_sem );
     pevent->ev_que->quota -= EVENTENTRIES;
     return;
@@ -585,7 +567,7 @@
-	epicsMutexMustLock ( evUser->lock );
+    epicsMutexMustLock ( evUser->lock );
     while ( evUser->extraLaborBusy ) {
         epicsThreadSleep(0.1);
@@ -640,38 +622,90 @@
- *  DB_POST_SINGLE_EVENT_PRIVATE()
+ *  DB_CREATE_EVENT_LOG()
  *  NOTE: This assumes that the db scan lock is already applied
-static void db_post_single_event_private (struct evSubscrip *event)
-    struct event_que * const ev_que = event->ev_que;
-    db_field_log * pLog;
+ *        (as it copies data from the record)
+db_field_log* epicsShareAPI db_create_event_log (struct evSubscrip *pevent)
+    db_field_log *pLog = (db_field_log *) freeListCalloc(dbevFieldLogFreeList);
+    if (pLog) {
+        struct dbChannel *chan = pevent->chan;
+        pLog->ctx = dbfl_context_event;
+        if (pevent->useValque) {
+            pLog->type = dbfl_type_val;
+            pLog->stat = prec->stat;
+            pLog->sevr = prec->sevr;
+            pLog->time = prec->time;
+            pLog->field_type  = dbChannelFieldType(chan);
+            pLog->no_elements = dbChannelElements(chan);
+             * use memcpy to avoid a bus error on
+             * union copy of char in the db at an odd
+             * address
+            memcpy(&pLog->u.v.field,
+                   dbChannelField(chan),
+                   dbChannelFieldSize(chan));
+        } else {
+            pLog->type = dbfl_type_rec;
+    return pLog;
+ *  DB_CREATE_READ_LOG()
+db_field_log* epicsShareAPI db_create_read_log (struct dbChannel *chan)
+    if (pLog) {
+        pLog->ctx  = dbfl_context_read;
+    return pLog;
+ *  DB_QUEUE_EVENT_LOG()
+static void db_queue_event_log (evSubscrip *pevent, db_field_log *pLog)
     int firstEventFlag;
     unsigned rngSpace;
+    ev_que = pevent->ev_que;
      * evUser ring buffer must be locked for the multiple
      * threads writing/reading it
-    LOCKEVQUE(ev_que)
+    LOCKEVQUE (ev_que);
-     * if we have an event on the queue and we are
-     * not saving the current value (because this is a
-     * string or an array) then ignore duplicate
-     * events (saving them without the current valuye
-     * serves no purpose)
+     * if we have an event on the queue and both the last
+     * event on the queue and the current event are emtpy
+     * (i.e. of type dbfl_type_rec), simply ignore duplicate
+     * events (saving empty events serves no purpose)
-    if (!event->valque && event->npend>0u) {
-        UNLOCKEVQUE(ev_que)
+    if (pevent->npend > 0u &&
+        (*pevent->pLastLog)->type == dbfl_type_rec &&
+        pLog->type == dbfl_type_rec) {
+        db_delete_field_log(pLog);
+        UNLOCKEVQUE (ev_que);
         return;
-     * add to task local event que
+     * add to task local event que
@@ -680,34 +714,38 @@
      * then replace the last event on the queue (for this monitor)
     rngSpace = ringSpace ( ev_que );
-    if ( event->npend>0u &&
+    if ( pevent->npend>0u &&
         (ev_que->evUser->flowCtrlMode || rngSpace<=EVENTSPERQUE) ) {
          * replace last event if no space is left
-        pLog = event->pLastLog;
-        event->nreplace++;
+        if (*pevent->pLastLog) {
+            db_delete_field_log(*pevent->pLastLog);
+            *pevent->pLastLog = pLog;
+        pevent->nreplace++;
-         * the event task has already been notified about
+         * the event task has already been notified about
          * this so we dont need to post the semaphore
         firstEventFlag = 0;
- 	 * Otherwise, the current entry must be available.
+     * Otherwise, the current entry must be available.
      * Fill it in and advance the ring buffer.
     else {
         assert ( ev_que->evque[ev_que->putix] == EVENTQEMPTY );
-        pLog = &ev_que->valque[ev_que->putix];
-        ev_que->evque[ev_que->putix] = event;
-        if (event->npend>0u) {
+        ev_que->evque[ev_que->putix] = pevent;
+        ev_que->valque[ev_que->putix] = pLog;
+        pevent->pLastLog = &ev_que->valque[ev_que->putix];
+        if (pevent->npend>0u) {
             ev_que->nDuplicates++;
-        event->npend++;
-         * if the ring buffer was empty before
-         * adding this event
+        pevent->npend++;
+         * if the ring buffer was empty before
+         * adding this event
         if (rngSpace==EVENTQUESIZE) {
             firstEventFlag = 1;
@@ -718,39 +756,21 @@
         ev_que->putix = RNGINC ( ev_que->putix );
-    if (pLog && event->valque) {
-        struct dbCommon *precord = event->paddr->precord;
-        pLog->stat = precord->stat;
-        pLog->sevr = precord->sevr;
-        pLog->time = precord->time;
-         * use memcpy to avoid a bus error on
-         * union copy of char in the db at an odd
-         * address
-        memcpy( (char *)&pLog->field,
-            (char *)event->paddr->pfield,
-            event->paddr->field_size);
-        event->pLastLog = pLog;
-     * its more efficent to notify the event handler
+     * its more efficent to notify the event handler
      * only after the event is ready and the lock
      * is off in case it runs at a higher priority
      * than the caller here.
     if (firstEventFlag) {
-         * notify the event handler
+         * notify the event handler
         epicsEventSignal(ev_que->evUser->ppendsem);
  *  DB_POST_EVENTS()
@@ -763,28 +783,30 @@
 void            *pField,
 unsigned int    caEventMask
-    struct dbCommon * const pdbc = (struct dbCommon *)pRecord;
-    struct evSubscrip * event;
-    if (pdbc->mlis.count == 0) return DB_EVENT_OK; /* no monitors set */
-    LOCKREC(pdbc);
-    for (event = (struct evSubscrip *) pdbc->mlis.node.next;
-        event; event = (struct evSubscrip *) event->node.next){
+    struct dbCommon   * const prec = (struct dbCommon *) pRecord;
+    struct evSubscrip *pevent;
+    if (prec->mlis.count == 0) return DB_EVENT_OK;       /* no monitors set */
+    LOCKREC (prec);
+    for (pevent = (struct evSubscrip *) prec->mlis.node.next;
+        pevent; pevent = (struct evSubscrip *) pevent->node.next){
          * Only send event msg if they are waiting on the field which
          * changed or pval==NULL and waiting on alarms and alarms changed
-        if ( (event->paddr->pfield == (void *)pField || pField==NULL) &&
-            (caEventMask & event->select) ) {
-            db_post_single_event_private (event);
+        if ( (dbChannelField(pevent->chan) == (void *)pField || pField==NULL) &&
+            (caEventMask & pevent->select)) {
+            db_field_log *pLog = db_create_event_log(pevent);
+            pLog = dbChannelRunPreChain(pevent->chan, pLog);
+            if (pLog) db_queue_event_log(pevent, pLog);
-    UNLOCKREC(pdbc);
+    UNLOCKREC (prec);
     return DB_EVENT_OK;
@@ -792,14 +814,18 @@
  *  DB_POST_SINGLE_EVENT()
-void epicsShareAPI db_post_single_event (dbEventSubscription es)
-    struct evSubscrip * const event = (struct evSubscrip *) es;
-    struct dbCommon * const precord = event->paddr->precord;
-    dbScanLock (precord);
-    dbScanUnlock (precord);
+void epicsShareAPI db_post_single_event (dbEventSubscription event)
+    struct dbCommon * const prec = dbChannelRecord(pevent->chan);
+    dbScanLock (prec);
+    db_queue_event_log(pevent, pLog);
+    dbScanUnlock (prec);
@@ -808,31 +834,35 @@
 static int event_read ( struct event_que *ev_que )
     db_field_log *pfl;
-    void ( *user_sub ) ( void *user_arg, struct dbAddr *paddr,
+    void ( *user_sub ) ( void *user_arg, struct dbChannel *chan,
             int eventsRemaining, db_field_log *pfl );
-    LOCKEVQUE ( ev_que )
      * if in flow control mode drain duplicates and then
      * suspend processing events until flow control
      * mode is over
     if ( ev_que->evUser->flowCtrlMode && ev_que->nDuplicates == 0u ) {
-        UNLOCKEVQUE(ev_que);
         return DB_EVENT_OK;
     while ( ev_que->evque[ev_que->getix] != EVENTQEMPTY ) {
-        db_field_log fl = ev_que->valque[ev_que->getix];
-        struct evSubscrip *event = ev_que->evque[ev_que->getix];
+        pfl = ev_que->valque[ev_que->getix];
+        struct evSubscrip *pevent = ev_que->evque[ev_que->getix];
-        if ( event == &canceledEvent ) {
+        if ( pevent == &canceledEvent ) {
             ev_que->evque[ev_que->getix] = EVENTQEMPTY;
+            if (ev_que->valque[ev_que->getix]) {
+                db_delete_field_log(ev_que->valque[ev_que->getix]);
+                ev_que->valque[ev_que->getix] = NULL;
             ev_que->getix = RNGINC ( ev_que->getix );
             assert ( ev_que->nCanceled > 0 );
             ev_que->nCanceled--;
@@ -844,12 +874,6 @@
          * communication. (for other types they get whatever happens
          * to be there upon wakeup)
-        if ( event->valque ) {
-            pfl = &fl;
-        else {
-            pfl = NULL;
         event_remove ( ev_que, ev_que->getix, EVENTQEMPTY );
@@ -858,29 +882,34 @@
          * create a local copy of the call back parameters while
          * we still have the lock
-        user_sub = event->user_sub;
+        user_sub = pevent->user_sub;
          * Next event pointer can be used by event tasks to determine
          * if more events are waiting in the queue
          * Must remove the lock here so that we dont deadlock if
-         * this calls dbGetField() and blocks on the record lock,
-         * dbPutField() is in progress in another task, it has the
-         * record lock, and it is calling db_post_events() waiting
+         * this calls dbGetField() and blocks on the record lock,
+         * dbPutField() is in progress in another task, it has the
+         * record lock, and it is calling db_post_events() waiting
          * for the event queue lock (which this thread now has).
         if ( user_sub ) {
              * This provides a way to test to see if an event is in use
-             * despite the fact that the event queue does not point to
-             * it.
+             * despite the fact that the event queue does not point to
+             * it.
-            event->callBackInProgress = TRUE;
-            UNLOCKEVQUE ( ev_que )
-            ( *user_sub ) ( event->user_arg, event->paddr,
+            pevent->callBackInProgress = TRUE;
+            /* Run post-event-queue filter chain */
+            if (ellCount(&pevent->chan->post_chain)) {
+                dbChannelRunPostChain(pevent->chan, pfl);
+            /* Issue user callback */
+            ( *user_sub ) ( pevent->user_arg, pevent->chan,
                 ev_que->evque[ev_que->getix] != EVENTQEMPTY, pfl );
              * check to see if this event has been canceled each
@@ -889,22 +918,23 @@
              * complete sem if there are no longer any events on the
              * queue
-            if ( ev_que->evUser->pSuicideEvent == event ) {
+            if ( ev_que->evUser->pSuicideEvent == pevent ) {
                 ev_que->evUser->pSuicideEvent = NULL;
             else {
-                if ( event->user_sub==NULL && event->npend==0u ) {
-                    event->callBackInProgress = FALSE;
+                if ( pevent->user_sub==NULL && pevent->npend==0u ) {
+                    pevent->callBackInProgress = FALSE;
                     epicsEventSignal ( ev_que->evUser->pflush_sem );
                 else {
+        db_delete_field_log(pfl);
     return DB_EVENT_OK;
@@ -924,7 +954,7 @@
     taskwdInsert ( epicsThreadGetIdSelf(), NULL, NULL );
-    do{
+    do {
         void (*pExtraLaborSub) (void *);
         void *pExtraLaborArg;
         epicsEventMustWait(evUser->ppendsem);
@@ -951,7 +981,7 @@
         evUser->extraLaborBusy = FALSE;
-        for ( ev_que = &evUser->firstque; ev_que;
+        for ( ev_que = &evUser->firstque; ev_que;
                 ev_que = ev_que->nextque ) {
             event_read (ev_que);
@@ -959,7 +989,7 @@
-    } while( ! evUser->pendexit );
+    } while ( ! evUser->pendexit );
     epicsMutexDestroy(evUser->firstque.writelock);
@@ -967,7 +997,7 @@
         ev_que = evUser->firstque.nextque;
-        while(ev_que){
+        while (ev_que) {
             nextque = ev_que->nextque;
             epicsMutexDestroy(ev_que->writelock);
             freeListFree(dbevEventQueueFreeList, ev_que);
@@ -990,15 +1020,15 @@
  * DB_START_EVENTS()
 int epicsShareAPI db_start_events (
-    dbEventCtx ctx,const char *taskname, void (*init_func)(void *),
+    dbEventCtx ctx,const char *taskname, void (*init_func)(void *),
     void *init_func_arg, unsigned osiPriority )
-      * only one ca_pend_event thread may be
+      * only one ca_pend_event thread may be
       * started for each evUser
      if (evUser->taskid) {
@@ -1044,7 +1074,7 @@
     evUser->flowCtrlMode = TRUE;
      * notify the event handler task
     epicsEventSignal(evUser->ppendsem);
@@ -1063,13 +1093,24 @@
     evUser->flowCtrlMode = FALSE;
     epicsEventSignal (evUser->ppendsem);
 #ifdef DEBUG
     printf("fc off %lu\n", tickGet());
 #endif
+ * db_delete_field_log()
+void epicsShareAPI db_delete_field_log (db_field_log *pfl)
+    if (pfl) {
+        /* Free field if reference type field log and dtor is set */
+        if (pfl->type == dbfl_type_ref && pfl->u.r.dtor) pfl->u.r.dtor(pfl);
+        /* Free the field log chunk */
+        freeListFree(dbevFieldLogFreeList, pfl);
=== modified file 'src/ioc/db/dbEvent.h'
--- src/ioc/db/dbEvent.h	2010-10-05 19:27:37 +0000
+++ src/ioc/db/dbEvent.h	2012-05-30 18:10:27 +0000
@@ -1,17 +1,19 @@
+* Copyright (c) 2010 Brookhaven National Laboratory.
+* Copyright (c) 2010 Helmholtz-Zentrum Berlin
+*     fuer Materialien und Energie GmbH.
 *     National Laboratory.
+* EPICS BASE is distributed subject to a Software License Agreement found
+* in file LICENSE that is included with this distribution.
- *      $Revision-Id$
- *      Author: Jeff Hill
- *      Date: 	030393
 #ifndef INCLdbEventh
@@ -34,8 +36,9 @@
 extern "C" {
 #endif
-struct dbAddr;
+struct dbChannel;
 struct db_field_log;
+struct evSubscrip;
 epicsShareFunc int epicsShareAPI db_event_list (
     const char *name, unsigned level);
@@ -49,7 +52,7 @@
 typedef void EXTRALABORFUNC (void *extralabor_arg);
 epicsShareFunc dbEventCtx epicsShareAPI db_init_events (void);
 epicsShareFunc int epicsShareAPI db_start_events (
-    dbEventCtx ctx, const char *taskname, void (*init_func)(void *),
+    dbEventCtx ctx, const char *taskname, void (*init_func)(void *),
     void *init_func_arg, unsigned osiPriority );
 epicsShareFunc void epicsShareAPI db_close_events (dbEventCtx ctx);
 epicsShareFunc void epicsShareAPI db_event_flow_ctrl_mode_on (dbEventCtx ctx);
@@ -60,18 +63,22 @@
 epicsShareFunc int epicsShareAPI db_post_extra_labor (dbEventCtx ctx);
 epicsShareFunc void epicsShareAPI db_event_change_priority ( dbEventCtx ctx, unsigned epicsPriority );
-typedef void EVENTFUNC (void *user_arg, struct dbAddr *paddr,
+typedef void EVENTFUNC (void *user_arg, struct dbChannel *chan,
 	int eventsRemaining, struct db_field_log *pfl);
 typedef void * dbEventSubscription;
 epicsShareFunc dbEventSubscription epicsShareAPI db_add_event (
     EVENTFUNC *user_sub, void *user_arg, unsigned select);
 epicsShareFunc void epicsShareAPI db_cancel_event (dbEventSubscription es);
 epicsShareFunc void epicsShareAPI db_post_single_event (dbEventSubscription es);
 epicsShareFunc void epicsShareAPI db_event_enable (dbEventSubscription es);
 epicsShareFunc void epicsShareAPI db_event_disable (dbEventSubscription es);
+epicsShareFunc struct db_field_log* epicsShareAPI db_create_event_log (struct evSubscrip *pevent);
+epicsShareFunc struct db_field_log* epicsShareAPI db_create_read_log (struct dbChannel *chan);
+epicsShareFunc void epicsShareAPI db_delete_field_log (struct db_field_log *pfl);
 #define DB_EVENT_OK 0
 #define DB_EVENT_ERROR (-1)
=== added file 'src/ioc/db/dbExtractArray.c'
--- src/ioc/db/dbExtractArray.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/dbExtractArray.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,84 @@
+* Copyright (c) 2002 The University of Chicago, as Operator of Argonne
+*     National Laboratory.
+* Copyright (c) 2002 The Regents of the University of California, as
+*     Operator of Los Alamos National Laboratory.
+ *  Author: Ralph Lange <[email protected]>
+ *  based on dbConvert.c
+ *  written by: Bob Dalesio, Marty Kraimer
+#include <string.h>
+#include "dbAddr.h"
+#define epicsExportSharedSymbols
+#include "dbExtractArray.h"
+void dbExtractArrayFromRec(const dbAddr *paddr, void *pto,
+                           long nRequest, long no_elements, long offset, long increment)
+    char *pdst = (char *) pto;
+    char *psrc = (char *) paddr->pfield;
+    long nUpperPart;
+    int i;
+    short srcSize = paddr->field_size;
+    short dstSize = srcSize;
+    char isString = (paddr->field_type == DBF_STRING);
+    if (nRequest > no_elements) nRequest = no_elements;
+    if (isString && srcSize > MAX_STRING_SIZE) dstSize = MAX_STRING_SIZE;
+    if (increment == 1 && dstSize == srcSize) {
+        nUpperPart = nRequest < no_elements - offset ? nRequest : no_elements - offset;
+        memcpy(pdst, &psrc[offset * srcSize], dstSize * nUpperPart);
+        if (nRequest > nUpperPart)
+            memcpy(&pdst[dstSize * nUpperPart], psrc, dstSize * (nRequest - nUpperPart));
+        if (isString)
+            for (i = 1; i <= nRequest; i++)
+                pdst[dstSize*i-1] = '\0';
+    } else {
+        for (; nRequest > 0; nRequest--, pdst += dstSize, offset += increment) {
+            offset %= no_elements;
+            memcpy(pdst, &psrc[offset*srcSize], dstSize);
+            if (isString) pdst[dstSize-1] = '\0';
+void dbExtractArrayFromBuf(const void *pfrom, void *pto,
+                           short field_size, short field_type,
+    char *psrc = (char *) pfrom;
+    int i;
+    short srcSize = field_size;
+    char isString = (field_type == DBF_STRING);
+    if (offset > no_elements - 1) offset = no_elements - 1;
+    if (isString && dstSize >= MAX_STRING_SIZE) dstSize = MAX_STRING_SIZE - 1;
+    if (increment == 1) {
+        memcpy(pdst, &psrc[offset * srcSize], dstSize * nRequest);
+        if (isString)
+                pdst[dstSize*i] = '\0';
+    } else {
+        for (; nRequest > 0; nRequest--, pdst += srcSize, offset += increment) {
+            if (isString) pdst[dstSize] = '\0';
=== added file 'src/ioc/db/dbExtractArray.h'
--- src/ioc/db/dbExtractArray.h	1970-01-01 00:00:00 +0000
+++ src/ioc/db/dbExtractArray.h	2012-05-30 18:10:27 +0000
@@ -0,0 +1,34 @@
+* Copyright (c) 2009 UChicago Argonne LLC, as Operator of Argonne
+#ifndef INC_dbExtractArray_H
+#define INC_dbExtractArray_H
+#include "dbFldTypes.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
+epicsShareFunc void dbExtractArrayFromRec(const DBADDR *paddr, void *pto,
+                                          long nRequest, long no_elements, long offset, long increment);
+epicsShareFunc void dbExtractArrayFromBuf(const void *pfrom, void *pto,
+#ifdef __cplusplus
+#endif
+#endif // INC_dbExtractArray_H
=== modified file 'src/ioc/db/dbIocRegister.c'
--- src/ioc/db/dbIocRegister.c	2012-04-10 22:10:50 +0000
+++ src/ioc/db/dbIocRegister.c	2012-05-30 18:10:27 +0000
@@ -21,6 +21,7 @@
 #include "dbNotify.h"
 #include "callback.h"
 #include "dbIocRegister.h"
+#include "dbState.h"
 /* dbLoadDatabase */
 static const iocshArg dbLoadDatabaseArg0 = { "file name",iocshArgString};
@@ -297,6 +298,51 @@
     callbackSetQueueSize(args[0].ival);
+/* dbStateCreate */
+static const iocshArg dbStateCreateArg0 = { "name", iocshArgString };
+static const iocshArg * const dbStateCreateArgs[] = { &dbStateCreateArg0 };
+static const iocshFuncDef dbStateCreateFuncDef = { "dbStateCreate", 1, dbStateCreateArgs };
+static void dbStateCreateCallFunc (const iocshArgBuf *args)
+    dbStateCreate(args[0].sval);
+/* dbStateSet */
+static const iocshArg dbStateSetArg0 = { "id", iocshArgInt };
+static const iocshArg * const dbStateSetArgs[] = { &dbStateSetArg0 };
+static const iocshFuncDef dbStateSetFuncDef = { "dbStateSet", 1, dbStateSetArgs };
+static void dbStateSetCallFunc (const iocshArgBuf *args)
+    dbStateSet((dbStateId) args[0].ival);
+/* dbStateClear */
+static const iocshArg dbStateClearArg0 = { "id", iocshArgInt };
+static const iocshArg * const dbStateClearArgs[] = { &dbStateClearArg0 };
+static const iocshFuncDef dbStateClearFuncDef = { "dbStateClear", 1, dbStateClearArgs };
+static void dbStateClearCallFunc (const iocshArgBuf *args)
+    dbStateClear((dbStateId) args[0].ival);
+/* dbStateShow */
+static const iocshArg dbStateShowArg0 = { "id", iocshArgInt };
+static const iocshArg dbStateShowArg1 = { "level", iocshArgInt };
+static const iocshArg * const dbStateShowArgs[] = { &dbStateShowArg0, &dbStateShowArg1 };
+static const iocshFuncDef dbStateShowFuncDef = { "dbStateShow", 2, dbStateShowArgs };
+static void dbStateShowCallFunc (const iocshArgBuf *args)
+    dbStateShow((dbStateId) args[0].ival, args[1].ival);
+/* dbStateShowAll */
+static const iocshArg dbStateShowAllArg0 = { "level", iocshArgInt };
+static const iocshArg * const dbStateShowAllArgs[] = { &dbStateShowAllArg0 };
+static const iocshFuncDef dbStateShowAllFuncDef = { "dbStateShowAll", 1, dbStateShowAllArgs };
+static void dbStateShowAllCallFunc (const iocshArgBuf *args)
+    dbStateShowAll(args[0].ival);
 void epicsShareAPI dbIocRegister(void)
@@ -342,4 +388,10 @@
     iocshRegister(&scanpiolFuncDef,scanpiolCallFunc);
     iocshRegister(&callbackSetQueueSizeFuncDef,callbackSetQueueSizeCallFunc);
+    iocshRegister(&dbStateCreateFuncDef, dbStateCreateCallFunc);
+    iocshRegister(&dbStateSetFuncDef, dbStateSetCallFunc);
+    iocshRegister(&dbStateClearFuncDef, dbStateClearCallFunc);
+    iocshRegister(&dbStateShowFuncDef, dbStateShowCallFunc);
+    iocshRegister(&dbStateShowAllFuncDef, dbStateShowAllCallFunc);
=== added file 'src/ioc/db/dbLink.c'
--- src/ioc/db/dbLink.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/dbLink.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,648 @@
+* Copyright (c) 2010 UChicago Argonne LLC, as Operator of Argonne
+ *     National Laboratory.
+ * Copyright (c) 2002 The Regents of the University of California, as
+ *     Operator of Los Alamos National Laboratory.
+ * EPICS BASE is distributed subject to a Software License Agreement found
+ * in file LICENSE that is included with this distribution.
+/* dbLink.c */
+/* $Id$ */
+ *      Original Authors: Bob Dalesio, Marty Kraimer
+ *      Current Author: Andrew Johnson
+#include <stddef.h>
+#include <stdlib.h>
+#include <stdarg.h>
+#include <stdio.h>
+#include "epicsThread.h"
+#include "errlog.h"
+#include "cantProceed.h"
+#include "cvtFast.h"
+#include "epicsTime.h"
+#include "alarm.h"
+#include "dbStaticLib.h"
+#include "dbBase.h"
+#include "link.h"
+#include "recSup.h"
+#include "devSup.h"
+#include "caeventmask.h"
+#include "dbCommon.h"
+#include "special.h"
+#include "dbLink.h"
+#include "callback.h"
+#include "dbScan.h"
+#include "dbLock.h"
+#include "dbEvent.h"
+#include "dbConvert.h"
+#include "dbConvertFast.h"
+#include "epicsEvent.h"
+#include "dbCa.h"
+#include "dbBkpt.h"
+#include "dbNotify.h"
+#include "dbAccessDefs.h"
+#include "recGbl.h"
+static void inherit_severity(const struct pv_link *ppv_link, dbCommon *pdest,
+        epicsEnum16 stat, epicsEnum16 sevr)
+    switch (ppv_link->pvlMask & pvlOptMsMode) {
+    case pvlOptNMS:
+        break;
+    case pvlOptMSI:
+        if (sevr < INVALID_ALARM)
+            break;
+        /* Fall through */
+    case pvlOptMS:
+        recGblSetSevr(pdest, LINK_ALARM, sevr);
+        break;
+    case pvlOptMSS:
+        recGblSetSevr(pdest, stat, sevr);
+        break;
+/***************************** Constant Links *****************************/
+static long dbConstLoadLink(struct link *plink, short dbrType, void *pbuffer)
+    if (!plink->value.constantStr)
+        return S_db_badField;
+    /* Constant strings are always numeric */
+    if (dbrType== DBF_MENU || dbrType == DBF_ENUM || dbrType == DBF_DEVICE)
+        dbrType = DBF_USHORT;
+    return dbFastPutConvertRoutine[DBR_STRING][dbrType]
+            (plink->value.constantStr, pbuffer, NULL);
+static long dbConstGetNelements(const struct link *plink, long *nelements)
+    *nelements = 0;
+    return 0;
+static long dbConstGetLink(struct link *plink, short dbrType, void *pbuffer,
+        epicsEnum16 *pstat, epicsEnum16 *psevr, long *pnRequest)
+    if (pnRequest)
+        *pnRequest = 0;
+    return 0;
+/***************************** Database Links *****************************/
+static long dbDbInitLink(struct link *plink, short dbfType)
+    DBADDR dbaddr;
+    long status;
+    DBADDR *pdbAddr;
+    status = dbNameToAddr(plink->value.pv_link.pvname, &dbaddr);
+    if (status)
+        return status;
+    plink->type = DB_LINK;
+    pdbAddr = dbCalloc(1, sizeof(struct dbAddr));
+    *pdbAddr = dbaddr; /* structure copy */
+    plink->value.pv_link.pvt = pdbAddr;
+    return 0;
+static long dbDbAddLink(struct link *plink, short dbfType)
+    long status = dbDbInitLink(plink, dbfType);
+    if (!status) {
+        DBADDR *pdbAddr = (DBADDR *) plink->value.pv_link.pvt;
+        dbCommon *precord = plink->value.pv_link.precord;
+        dbLockSetRecordLock(pdbAddr->precord);
+        dbLockSetMerge(precord, pdbAddr->precord);
+    return status;
+static void dbDbRemoveLink(struct link *plink)
+    free(plink->value.pv_link.pvt);
+    plink->value.pv_link.pvt = 0;
+    plink->value.pv_link.getCvt = 0;
+    plink->value.pv_link.lastGetdbrType = 0;
+    plink->type = PV_LINK;
+    dbLockSetSplit(plink->value.pv_link.precord);
+static int dbDbIsLinkConnected(const struct link *plink)
+    return TRUE;
+static int dbDbGetDBFtype(const struct link *plink)
+    DBADDR *paddr = (DBADDR *) plink->value.pv_link.pvt;
+    return paddr->field_type;
+static long dbDbGetElements(const struct link *plink, long *nelements)
+    *nelements = paddr->no_elements;
+    return 0;
+static long dbDbGetValue(struct link *plink, short dbrType, void *pbuffer,
+    struct pv_link *ppv_link = &plink->value.pv_link;
+    DBADDR *paddr = ppv_link->pvt;
+    long status;
+    /* scan passive records if link is process passive  */
+    if (ppv_link->pvlMask & pvlOptPP) {
+        unsigned char pact = precord->pact;
+        precord->pact = TRUE;
+        status = dbScanPassive(precord, paddr->precord);
+        precord->pact = pact;
+        if (status)
+            return status;
+    *pstat = paddr->precord->stat;
+    *psevr = paddr->precord->sevr;
+    if (ppv_link->getCvt && ppv_link->lastGetdbrType == dbrType) {
+        status = ppv_link->getCvt(paddr->pfield, pbuffer, paddr);
+    } else {
+        unsigned short dbfType = paddr->field_type;
+        if (dbrType < 0 || dbrType > DBR_ENUM || dbfType > DBF_DEVICE)
+            return S_db_badDbrtype;
+        if (paddr->no_elements == 1 && (!pnRequest || *pnRequest == 1)
+                && paddr->special != SPC_ATTRIBUTE) {
+            ppv_link->getCvt = dbFastGetConvertRoutine[dbfType][dbrType];
+        } else {
+            ppv_link->getCvt = NULL;
+            status = dbGet(paddr, dbrType, pbuffer, NULL, pnRequest, NULL);
+        ppv_link->lastGetdbrType = dbrType;
+    return status;
+static long dbDbGetControlLimits(const struct link *plink, double *low,
+        double *high)
+    struct buffer {
+        DBRctrlDouble
+        double value;
+    } buffer;
+    long options = DBR_CTRL_DOUBLE;
+    long number_elements = 0;
+    long status = dbGet(paddr, DBR_DOUBLE, &buffer, &options, &number_elements,
+            NULL);
+    if (status)
+        return status;
+    *low = buffer.lower_ctrl_limit;
+    *high = buffer.upper_ctrl_limit;
+    return 0;
+static long dbDbGetGraphicLimits(const struct link *plink, double *low,
+        double *high)
+    struct buffer {
+        DBRgrDouble
+        double value;
+    } buffer;
+    long options = DBR_GR_DOUBLE;
+            NULL);
+    if (status)
+        return status;
+    *low = buffer.lower_disp_limit;
+    *high = buffer.upper_disp_limit;
+    return 0;
+static long dbDbGetAlarmLimits(const struct link *plink, double *lolo,
+        double *low, double *high, double *hihi)
+    struct buffer {
+        DBRalDouble
+        double value;
+    } buffer;
+    long options = DBR_AL_DOUBLE;
+            0);
+    if (status)
+        return status;
+    *lolo = buffer.lower_alarm_limit;
+    *low = buffer.lower_warning_limit;
+    *high = buffer.upper_warning_limit;
+    *hihi = buffer.upper_alarm_limit;
+    return 0;
+static long dbDbGetPrecision(const struct link *plink, short *precision)
+    struct buffer {
+        DBRprecision
+        double value;
+    } buffer;
+    long options = DBR_PRECISION;
+            0);
+    if (status)
+        return status;
+    *precision = buffer.precision.dp;
+    return 0;
+static long dbDbGetUnits(const struct link *plink, char *units, int unitsSize)
+    struct buffer {
+        DBRunits
+        double value;
+    } buffer;
+    long options = DBR_UNITS;
+            0);
+    if (status)
+        return status;
+    strncpy(units, buffer.units, unitsSize);
+    return 0;
+static long dbDbGetAlarm(const struct link *plink, epicsEnum16 *status,
+        epicsEnum16 *severity)
+    if (status)
+        *status = paddr->precord->stat;
+    if (severity)
+        *severity = paddr->precord->sevr;
+    return 0;
+static long dbDbGetTimeStamp(const struct link *plink, epicsTimeStamp *pstamp)
+    *pstamp = paddr->precord->time;
+    return 0;
+static long dbDbPutValue(struct link *plink, short dbrType,
+    struct dbCommon *psrce = ppv_link->precord;
+    DBADDR *paddr = (DBADDR *) ppv_link->pvt;
+    dbCommon *pdest = paddr->precord;
+    long status = dbPut(paddr, dbrType, pbuffer, nRequest);
+    inherit_severity(ppv_link, pdest, psrce->nsta, psrce->nsev);
+    if (status)
+        return status;
+    if (paddr->pfield == (void *) &pdest->proc ||
+            (ppv_link->pvlMask & pvlOptPP && pdest->scan == 0)) {
+        /* if dbPutField caused asyn record to process */
+        /* ask for reprocessing*/
+        if (pdest->putf) {
+            pdest->rpro = TRUE;
+        } else { /* process dest record with source's PACT true */
+            unsigned char pact;
+            if (psrce && psrce->ppn)
+                dbNotifyAdd(psrce, pdest);
+            pact = psrce->pact;
+            psrce->pact = TRUE;
+            status = dbProcess(pdest);
+            psrce->pact = pact;
+    return status;
+static void dbDbScanFwdLink(struct link *plink)
+    dbAddr *paddr = (dbAddr *) plink->value.pv_link.pvt;
+    dbScanPassive(precord, paddr->precord);
+lset dbDb_lset = { dbDbInitLink, dbDbAddLink, NULL, dbDbRemoveLink,
+        dbDbIsLinkConnected, dbDbGetDBFtype, dbDbGetElements, dbDbGetValue,
+        dbDbGetControlLimits, dbDbGetGraphicLimits, dbDbGetAlarmLimits,
+        dbDbGetPrecision, dbDbGetUnits, dbDbGetAlarm, dbDbGetTimeStamp,
+        dbDbPutValue, dbDbScanFwdLink };
+/***************************** Generic Link API *****************************/
+void dbInitLink(struct dbCommon *precord, struct link *plink, short dbfType)
+    plink->value.pv_link.precord = precord;
+    if (plink == &precord->tsel)
+        recGblTSELwasModified(plink);
+    if (!(plink->value.pv_link.pvlMask & (pvlOptCA | pvlOptCP | pvlOptCPP))) {
+        /* Make it a DB link if possible */
+        if (!dbDbInitLink(plink, dbfType))
+            return;
+    /* Make it a CA link */
+    if (dbfType == DBF_INLINK)
+        plink->value.pv_link.pvlMask |= pvlOptInpNative;
+    dbCaAddLink(plink);
+    if (dbfType == DBF_FWDLINK) {
+        char *pperiod = strrchr(plink->value.pv_link.pvname, '.');
+        if (pperiod && strstr(pperiod, "PROC")) {
+            plink->value.pv_link.pvlMask |= pvlOptFWD;
+        } else {
+            errlogPrintf("%s.FLNK is a Channel Access Link "
+                " but does not link to a PROC field\n", precord->name);
+void dbAddLink(struct dbCommon *precord, struct link *plink, short dbfType)
+        /* Can we make it a DB link? */
+        if (!dbDbAddLink(plink, dbfType))
+            return;
+long dbLoadLink(struct link *plink, short dbrType, void *pbuffer)
+    switch (plink->type) {
+    case CONSTANT:
+        return dbConstLoadLink(plink, dbrType, pbuffer);
+    return S_db_notFound;
+void dbRemoveLink(struct link *plink)
+    case DB_LINK:
+        dbDbRemoveLink(plink);
+        break;
+    case CA_LINK:
+        dbCaRemoveLink(plink);
+        break;
+    default:
+        cantProceed("dbRemoveLink: Unexpected link type %d\n", plink->type);
+    plink->value.pv_link.pvlMask = 0;
+int dbIsLinkConnected(const struct link *plink)
+    case DB_LINK:
+        return dbDbIsLinkConnected(plink);
+    case CA_LINK:
+        return dbCaIsLinkConnected(plink);
+    return FALSE;
+int dbGetLinkDBFtype(const struct link *plink)
+    case DB_LINK:
+        return dbDbGetDBFtype(plink);
+    case CA_LINK:
+        return dbCaGetLinkDBFtype(plink);
+    return -1;
+long dbGetNelements(const struct link *plink, long *nelements)
+    case CONSTANT:
+        return dbConstGetNelements(plink, nelements);
+    case DB_LINK:
+        return dbDbGetElements(plink, nelements);
+    case CA_LINK:
+        return dbCaGetNelements(plink, nelements);
+long dbGetLinkValue(struct link *plink, short dbrType, void *pbuffer,
+        long *poptions, long *pnRequest)
+    struct dbCommon *precord = plink->value.pv_link.precord;
+    epicsEnum16 sevr = 0, stat = 0;
+    long status;
+    if (poptions && *poptions) {
+        printf("dbGetLinkValue: Use of poptions no longer supported\n");
+        *poptions = 0;
+    case CONSTANT:
+        status = dbConstGetLink(plink, dbrType, pbuffer, &stat, &sevr,
+                pnRequest);
+        break;
+    case DB_LINK:
+        status = dbDbGetValue(plink, dbrType, pbuffer, &stat, &sevr, pnRequest);
+        break;
+    case CA_LINK:
+        status = dbCaGetLink(plink, dbrType, pbuffer, &stat, &sevr, pnRequest);
+        break;
+    default:
+        cantProceed("dbGetLinkValue: Illegal link type %d\n", plink->type);
+        status = -1;
+    if (status) {
+        recGblSetSevr(precord, LINK_ALARM, INVALID_ALARM);
+    } else {
+        inherit_severity(&plink->value.pv_link, precord, stat, sevr);
+    return status;
+long dbGetControlLimits(const struct link *plink, double *low, double *high)
+    case DB_LINK:
+        return dbDbGetControlLimits(plink, low, high);
+    case CA_LINK:
+        return dbCaGetControlLimits(plink, low, high);
+long dbGetGraphicLimits(const struct link *plink, double *low, double *high)
+    case DB_LINK:
+        return dbDbGetGraphicLimits(plink, low, high);
+    case CA_LINK:
+        return dbCaGetGraphicLimits(plink, low, high);
+long dbGetAlarmLimits(const struct link *plink, double *lolo, double *low,
+        double *high, double *hihi)
+    case DB_LINK:
+        return dbDbGetAlarmLimits(plink, lolo, low, high, hihi);
+    case CA_LINK:
+        return dbCaGetAlarmLimits(plink, lolo, low, high, hihi);
+long dbGetPrecision(const struct link *plink, short *precision)
+    case DB_LINK:
+        return dbDbGetPrecision(plink, precision);
+    case CA_LINK:
+        return dbCaGetPrecision(plink, precision);
+long dbGetUnits(const struct link *plink, char *units, int unitsSize)
+    case DB_LINK:
+        return dbDbGetUnits(plink, units, unitsSize);
+    case CA_LINK:
+        return dbCaGetUnits(plink, units, unitsSize);
+long dbGetAlarm(const struct link *plink, epicsEnum16 *status,
+    case DB_LINK:
+        return dbDbGetAlarm(plink, status, severity);
+    case CA_LINK:
+        return dbCaGetAlarm(plink, status, severity);
+long dbGetTimeStamp(const struct link *plink, epicsTimeStamp *pstamp)
+    case DB_LINK:
+        return dbDbGetTimeStamp(plink, pstamp);
+    case CA_LINK:
+        return dbCaGetTimeStamp(plink, pstamp);
+long dbPutLinkValue(struct link *plink, short dbrType, const void *pbuffer,
+        long nRequest)
+    long status;
+    case DB_LINK:
+        status = dbDbPutValue(plink, dbrType, pbuffer, nRequest);
+        break;
+    case CA_LINK:
+        status = dbCaPutLink(plink, dbrType, pbuffer, nRequest);
+        break;
+    default:
+        cantProceed("dbPutLinkValue: Illegal link type %d\n", plink->type);
+        status = -1;
+    if (status) {
+    return status;
+void dbScanFwdLink(struct link *plink)
+    case DB_LINK:
+        dbDbScanFwdLink(plink);
+        break;
+    case CA_LINK:
+        dbCaScanFwdLink(plink);
+        break;
=== added file 'src/ioc/db/dbLink.h'
--- src/ioc/db/dbLink.h	1970-01-01 00:00:00 +0000
+++ src/ioc/db/dbLink.h	2012-05-30 18:10:27 +0000
@@ -0,0 +1,94 @@
+* Copyright (c) 2010 The UChicago Argonne LLC, as Operator of Argonne
+ * dbLink.h
+ *  Created on: Mar 21, 2010
+ *      Author: Andrew Johnson
+#ifndef INC_dbLink_H
+#define INC_dbLink_H
+#include "link.h"
+#include "shareLib.h"
+#include "epicsTypes.h"
+typedef struct lset {
+    long (*initLink)(struct link *plink, short dbfType);
+    long (*addLink)(struct link *plink, short dbfType);
+    long (*loadLink)(struct link *plink, short dbrType, void *pbuffer);
+    void (*removeLink)(struct link *plink);
+    int (*isLinkConnected)(const struct link *plink);
+    int (*getDBFtype)(const struct link *plink);
+    long (*getElements)(const struct link *plink, long *nelements);
+    long (*getValue)(struct link *plink, short dbrType, void *pbuffer,
+            epicsEnum16 *pstat, epicsEnum16 *psevr,	long *pnRequest);
+    long (*getControlLimits)(const struct link *plink, double *lo, double *hi);
+    long (*getGraphicLimits)(const struct link *plink, double *lo, double *hi);
+    long (*getAlarmLimits)(const struct link *plink, double *lolo, double *lo,
+            double *hi, double *hihi);
+    long (*getPrecision)(const struct link *plink, short *precision);
+    long (*getUnits)(const struct link *plink, char *units, int unitsSize);
+    long (*getAlarm)(const struct link *plink, epicsEnum16 *status,
+            epicsEnum16 *severity);
+    long (*getTimeStamp)(const struct link *plink, epicsTimeStamp *pstamp);
+    long (*putValue)(struct link *plink, short dbrType,
+            const void *pbuffer, long nRequest);
+    void (*scanFwdLink)(struct link *plink);
+} lset;
+#define dbGetLink(PLNK, DBRTYPE, PBUFFER, OPTIONS, NREQUEST) \
+    ( ( ( (PLNK)->type == CONSTANT ) && \
+        ( (NREQUEST) == 0) && \
+        ( (OPTIONS) == 0) ) \
+      ? 0 \
+      : dbGetLinkValue((PLNK),(DBRTYPE), \
+        (void *)(PBUFFER), (OPTIONS), (NREQUEST) ) )
+#define dbPutLink(PLNK, DBRTYPE, PBUFFER, NREQUEST) \
+    ( ( (PLNK)->type == CONSTANT) \
+      ? 0 \
+      : dbPutLinkValue( (PLNK), (DBRTYPE), (void *)(PBUFFER), (NREQUEST) ) )
+#define dbGetSevr(PLINK, PSEVERITY) \
+    dbGetAlarm((PLINK), NULL, (PSEVERITY));
+epicsShareFunc void dbInitLink(struct dbCommon *precord, struct link *plink,
+        short dbfType);
+epicsShareFunc void dbAddLink(struct dbCommon *precord, struct link *plink,
+        short dbfType);
+epicsShareFunc long dbLoadLink(struct link *plink, short dbrType,
+        void *pbuffer);
+epicsShareFunc void dbRemoveLink(struct link *plink);
+epicsShareFunc long dbGetNelements(const struct link *plink, long *nelements);
+epicsShareFunc int dbIsLinkConnected(const struct link *plink);
+epicsShareFunc int dbGetLinkDBFtype(const struct link *plink);
+epicsShareFunc long dbGetLinkValue(struct link *, short dbrType, void *pbuffer,
+        long *options, long *nRequest);
+epicsShareFunc long dbGetControlLimits(const struct link *plink, double *low,
+        double *high);
+epicsShareFunc long dbGetGraphicLimits(const struct link *plink, double *low,
+        double *high);
+epicsShareFunc long dbGetAlarmLimits(const struct link *plink, double *lolo,
+        double *low, double *high, double *hihi);
+epicsShareFunc long dbGetPrecision(const struct link *plink, short *precision);
+epicsShareFunc long dbGetUnits(const struct link *plink, char *units,
+        int unitsSize);
+epicsShareFunc long dbGetAlarm(const struct link *plink, epicsEnum16 *status,
+epicsShareFunc long dbGetTimeStamp(const struct link *plink,
+        epicsTimeStamp *pstamp);
+epicsShareFunc long dbPutLinkValue(struct link *, short dbrType,
+epicsShareFunc void dbScanFwdLink(struct link *plink);
+#endif /* INC_dbLink_H */
=== modified file 'src/ioc/db/dbNotify.c'
--- src/ioc/db/dbNotify.c	2010-10-05 19:27:37 +0000
+++ src/ioc/db/dbNotify.c	2012-05-30 18:10:27 +0000
@@ -5,15 +5,15 @@
-* in file LICENSE that is included with this distribution.
-/* dbNotify.c */
-/* base/src/db $Revision-Id$ */
  *      Author: 	Marty Kraimer
- *      Date:           03-30-95
+ *                      Andrew Johnson <[email protected]>
  * Extracted from dbLink.c
 #include <stdlib.h>
 #include <stdarg.h>
@@ -36,7 +36,7 @@
-#include "dbAddr.h"
+#include "dbChannel.h"
 #include "dbScan.h"
 #include "dbLock.h"
@@ -45,7 +45,7 @@
 /*putNotify.state values */
 typedef enum {
     putNotifyNotActive,
@@ -55,44 +55,44 @@
     putNotifyPutInProgress,
     putNotifyUserCallbackRequested,
     putNotifyUserCallbackActive
-}putNotifyState;
+} putNotifyState;
 /*structure attached to ppnr field of each record*/
 typedef struct putNotifyRecord {
-    ellCheckNode  waitNode;
-    ELLLIST  restartList; /*list of putNotifys to restart*/
+    ellCheckNode waitNode;
+    ELLLIST restartList; /*list of putNotifys to restart*/
     dbCommon *precord;
-}putNotifyRecord;
+} putNotifyRecord;
 #define MAGIC 0xfedc0123
 typedef struct putNotifyPvt {
-    ELLNODE      node;   /*For free list*/
-    long         magic;
-    short        state;
-    CALLBACK     callback;
-    ELLLIST      waitList; /*list of records for current putNotify*/
-    short        cancelWait;
-    short        userCallbackWait;
+    ELLNODE node; /*For free list*/
+    long magic;
+    short state;
+    CALLBACK callback;
+    ELLLIST waitList; /*list of records for current putNotify*/
+    short cancelWait;
+    short userCallbackWait;
     epicsEventId cancelEvent;
     epicsEventId userCallbackEvent;
-}putNotifyPvt;
+} putNotifyPvt;
 /* putNotify groups can span locksets if links are dynamically modified*/
 /* Thus a global lock is taken while putNotify fields are accessed     */
 typedef struct notifyGlobal {
     epicsMutexId lock;
     ELLLIST      freeList;
-}notifyGlobal;
+} notifyGlobal;
 static notifyGlobal *pnotifyGlobal = 0;
 /*Local routines*/
 static void putNotifyInit(putNotify *ppn);
 static void putNotifyCleanup(putNotify *ppn);
 static void restartCheck(putNotifyRecord *ppnr);
-static void callUser(dbCommon *precord,putNotify *ppn);
+static void callUser(dbCommon *precord, putNotify *ppn);
 static void notifyCallback(CALLBACK *pcallback);
-static void putNotifyCommon(putNotify *ppn,dbCommon *precord);
+static void putNotifyCommon(putNotify *ppn, dbCommon *precord);
 #define ellSafeAdd(list,listnode) \
@@ -112,9 +112,9 @@
     putNotifyPvt *pputNotifyPvt;
-    pputNotifyPvt = (putNotifyPvt *)ellFirst(&pnotifyGlobal->freeList);
-    if(pputNotifyPvt) {
-        ellDelete(&pnotifyGlobal->freeList,&pputNotifyPvt->node);
+    pputNotifyPvt = (putNotifyPvt *) ellFirst(&pnotifyGlobal->freeList);
+    if (pputNotifyPvt) {
+        ellDelete(&pnotifyGlobal->freeList, &pputNotifyPvt->node);
     } else {
         pputNotifyPvt = dbCalloc(1,sizeof(putNotifyPvt));
         pputNotifyPvt->cancelEvent = epicsEventCreate(epicsEventEmpty);
@@ -135,26 +135,26 @@
-    putNotifyPvt *pputNotifyPvt = (putNotifyPvt *)ppn->pputNotifyPvt;
+    putNotifyPvt *pputNotifyPvt = (putNotifyPvt *) ppn->pputNotifyPvt;
     pputNotifyPvt->state = putNotifyNotActive;
-    ellAdd(&pnotifyGlobal->freeList,&pputNotifyPvt->node);
+    ellAdd(&pnotifyGlobal->freeList, &pputNotifyPvt->node);
     ppn->pputNotifyPvt = 0;
     dbCommon *precord = ppnr->precord;
     putNotify *pfirst;
     assert(precord->ppn);
-    pfirst = (putNotify *)ellFirst(&ppnr->restartList);
-    if(!pfirst) {
+    pfirst = (putNotify *) ellFirst(&ppnr->restartList);
+    if (!pfirst) {
         precord->ppn = 0;
         return;
-    pputNotifyPvt = (putNotifyPvt *)pfirst->pputNotifyPvt;
+    pputNotifyPvt = (putNotifyPvt *) pfirst->pputNotifyPvt;
     assert(pputNotifyPvt->state==putNotifyWaitForRestart);
     /* remove pfirst from restartList */
     ellSafeDelete(&ppnr->restartList,&pfirst->restartNode);
@@ -165,25 +165,25 @@
     callbackRequest(&pputNotifyPvt->callback);
     epicsMutexUnlock(pnotifyGlobal->lock);
     dbScanUnlock(precord);
     (*ppn->userCallback)(ppn);
     epicsMutexMustLock(pnotifyGlobal->lock);
-    if(pputNotifyPvt->cancelWait && pputNotifyPvt->userCallbackWait) {
+    if (pputNotifyPvt->cancelWait && pputNotifyPvt->userCallbackWait) {
         errlogPrintf("%s putNotify: both cancelWait and userCallbackWait true."
-               "This is illegal\n",precord->name);
+            "This is illegal\n", precord->name);
         pputNotifyPvt->cancelWait = pputNotifyPvt->userCallbackWait = 0;
-    if(!pputNotifyPvt->cancelWait && !pputNotifyPvt->userCallbackWait) {
+    if (!pputNotifyPvt->cancelWait && !pputNotifyPvt->userCallbackWait) {
         putNotifyCleanup(ppn);
-        epicsMutexUnlock(pnotifyGlobal->lock);
+        epicsMutexUnlock(pnotifyGlobal->lock);
         return;
-    if(pputNotifyPvt->cancelWait) {
+    if (pputNotifyPvt->cancelWait) {
         pputNotifyPvt->cancelWait = 0;
         epicsEventSignal(pputNotifyPvt->cancelEvent);
@@ -195,38 +195,37 @@
     return;
-    long	status=0;
-    dbFldDes	*pfldDes = ppn->paddr->pfldDes;
+    long status;
-    if(precord->ppn && pputNotifyPvt->state!=putNotifyRestartCallbackRequested)
-    { /*another putNotify owns the record */
-        pputNotifyPvt->state = putNotifyWaitForRestart;
+    if (precord->ppn &&
+        pputNotifyPvt->state != putNotifyRestartCallbackRequested) { /*another putNotify owns the record */
+        pputNotifyPvt->state = putNotifyWaitForRestart;
         ellSafeAdd(&precord->ppnr->restartList,&ppn->restartNode);
         return;
-    } else if(precord->ppn){
-        assert(precord->ppn==ppn);
+    } else if (precord->ppn) {
+        assert(precord->ppn == ppn);
         assert(pputNotifyPvt->state==putNotifyRestartCallbackRequested);
-    if(precord->pact) {
+    if (precord->pact) {
         precord->ppn = ppn;
         ellSafeAdd(&pputNotifyPvt->waitList,&precord->ppnr->waitNode);
-        pputNotifyPvt->state = putNotifyRestartInProgress;
+        pputNotifyPvt->state = putNotifyRestartInProgress;
         return;
-    status=dbPut(ppn->paddr,ppn->dbrType,ppn->pbuffer,ppn->nRequest);
-    ppn->status = (status==0) ? putNotifyOK : putNotifyError;
+    status = dbChannelPut(ppn->chan, ppn->dbrType, ppn->pbuffer, ppn->nRequest);
+    ppn->status = (status == 0) ? putNotifyOK : putNotifyError;
     /* Check to see if dbProcess should not be called */
-    if(!status /*dont process if dbPut returned error */
-    &&((ppn->paddr->pfield==(void *)&precord->proc) /*If PROC call dbProcess*/
-       || (pfldDes->process_passive && precord->scan==0))) {
+    if (!status /*dont process if dbPut returned error */
+    && ((dbChannelField(ppn->chan) == (void *) & precord->proc) /*If PROC call dbProcess*/
+    || (dbChannelFldDes(ppn->chan)->process_passive && precord->scan == 0))) {
         precord->ppn = ppn;
         pputNotifyPvt->state = putNotifyPutInProgress;
@@ -235,31 +234,31 @@
         return;
-    if(pputNotifyPvt->state==putNotifyRestartCallbackRequested) {
+    if (pputNotifyPvt->state == putNotifyRestartCallbackRequested) {
         restartCheck(precord->ppnr);
     pputNotifyPvt->state = putNotifyUserCallbackActive;
     assert(precord->ppn!=ppn);
-    callUser(precord,ppn);
+    callUser(precord, ppn);
-    putNotify	*ppn=NULL;
-    dbCommon	*precord;
+    putNotify *ppn = NULL;
+    dbCommon *precord;
     callbackGetUser(ppn,pcallback);
-    pputNotifyPvt = (putNotifyPvt *)ppn->pputNotifyPvt;
-    precord = ppn->paddr->precord;
+    pputNotifyPvt = (putNotifyPvt *) ppn->pputNotifyPvt;
+    precord = dbChannelRecord(ppn->chan);
     dbScanLock(precord);
     assert(precord->ppnr);
-          || pputNotifyPvt->state==putNotifyUserCallbackRequested);
+            || pputNotifyPvt->state==putNotifyUserCallbackRequested);
     assert(ellCount(&pputNotifyPvt->waitList)==0);
@@ -267,58 +266,61 @@
         return;
-        putNotifyCommon(ppn,precord);
+        putNotifyCommon(ppn, precord);
         return;
     /* All done. Clean up and call userCallback */
 void epicsShareAPI dbPutNotifyInit(void)
-    if(pnotifyGlobal) return;
+    if (pnotifyGlobal)
+        return;
     pnotifyGlobal = dbCalloc(1,sizeof(notifyGlobal));
     pnotifyGlobal->lock = epicsMutexMustCreate();
     ellInit(&pnotifyGlobal->freeList);
 void epicsShareAPI dbPutNotify(putNotify *ppn)
-    dbCommon	*precord = ppn->paddr->precord;
-    short	dbfType = ppn->paddr->field_type;
-    long	status=0;
+    struct dbChannel *chan = ppn->chan;
+    dbCommon *precord = dbChannelRecord(chan);
+    short dbfType = dbChannelFieldType(chan);
+    long status = 0;
     assert(precord);
     /*check for putField disabled*/
-    if(precord->disp) {
-        if((void *)(&precord->disp) != ppn->paddr->pfield) {
-           ppn->status = putNotifyPutDisabled;
-           (*ppn->userCallback)(ppn);
-           return;
+    if (precord->disp) {
+        if (dbChannelField(chan) != (void *) & precord->disp) {
+            ppn->status = putNotifyPutDisabled;
+            (*ppn->userCallback)(ppn);
+            return;
     /* Must handle DBF_XXXLINKs as special case.
-     * Only dbPutField will change link fields.
+     * Only dbPutField will change link fields.
      * Also the record is not processed as a result
-    if(dbfType>=DBF_INLINK && dbfType<=DBF_FWDLINK) {
-	status=dbPutField(ppn->paddr,ppn->dbrType,ppn->pbuffer,ppn->nRequest);
+    if (dbfType >= DBF_INLINK && dbfType <= DBF_FWDLINK) {
+        status = dbChannelPutField(ppn->chan, ppn->dbrType, ppn->pbuffer,
+                ppn->nRequest);
         return;
-    if(pputNotifyPvt && (pputNotifyPvt->magic!=MAGIC)) {
+    if (pputNotifyPvt && (pputNotifyPvt->magic != MAGIC)) {
         printf("dbPutNotify:pputNotifyPvt was not initialized\n");
         pputNotifyPvt = 0;
         assert(pputNotifyPvt->state==putNotifyUserCallbackActive);
         pputNotifyPvt->userCallbackWait = 1;
@@ -328,38 +330,38 @@
     assert(!pputNotifyPvt);
     putNotifyInit(ppn);
-    if(!precord->ppnr) {/* make sure record has a putNotifyRecord*/
+    if (!precord->ppnr) {/* make sure record has a putNotifyRecord*/
         precord->ppnr = dbCalloc(1,sizeof(putNotifyRecord));
         precord->ppnr->precord = precord;
         ellInit(&precord->ppnr->restartList);
 void epicsShareAPI dbNotifyCancel(putNotify *ppn)
+    dbCommon *precord = dbChannelRecord(ppn->chan);
     putNotifyState state;
     assert(precord);
-    if(!pputNotifyPvt || pputNotifyPvt->state==putNotifyNotActive) {
+    if (!pputNotifyPvt || pputNotifyPvt->state == putNotifyNotActive) {
         return;
     state = pputNotifyPvt->state;
     /*If callback is scheduled or active wait for it to complete*/
-    if(state==putNotifyUserCallbackRequested
-    || state==putNotifyRestartCallbackRequested
-    || state==putNotifyUserCallbackActive) {
+    if (state == putNotifyUserCallbackRequested || state
+            == putNotifyRestartCallbackRequested || state
+            == putNotifyUserCallbackActive) {
         pputNotifyPvt->cancelWait = 1;
@@ -369,24 +371,26 @@
         return;
-    switch(state) {
-    case putNotifyNotActive: break;
+    switch (state) {
+    case putNotifyNotActive:
+        break;
     case putNotifyWaitForRestart:
-        ellSafeDelete(&precord->ppnr->restartList,&ppn->restartNode);
+        ellSafeDelete(&precord->ppnr->restartList,&ppn->restartNode)
         break;
     case putNotifyRestartInProgress:
-    case putNotifyPutInProgress:
-        { /*Take all records out of wait list */
-            putNotifyRecord *ppnrWait;
+    case putNotifyPutInProgress: { /*Take all records out of wait list */
+        putNotifyRecord *ppnrWait;
-            while((ppnrWait = (putNotifyRecord *)ellFirst(&pputNotifyPvt->waitList))){
-                ellSafeDelete(&pputNotifyPvt->waitList,&ppnrWait->waitNode);
-                restartCheck(ppnrWait);
+        while ((ppnrWait = (putNotifyRecord *) ellFirst(&pputNotifyPvt->waitList))) {
+            ellSafeDelete(&pputNotifyPvt->waitList,&ppnrWait->waitNode);
+            restartCheck(ppnrWait);
-        if(precord->ppn==ppn) restartCheck(precord->ppnr);
+        if (precord->ppn == ppn)
+            restartCheck(precord->ppnr);
         break;
     default:
         printf("dbNotify: illegal state for notifyCallback\n");
@@ -396,29 +400,29 @@
 void epicsShareAPI dbNotifyCompletion(dbCommon *precord)
-    putNotify	*ppn = precord->ppn;
+    putNotify *ppn = precord->ppn;
     assert(ppn);
-    if(pputNotifyPvt->state!=putNotifyRestartInProgress
-    && pputNotifyPvt->state!=putNotifyPutInProgress) {
+    if (pputNotifyPvt->state != putNotifyRestartInProgress
+            && pputNotifyPvt->state != putNotifyPutInProgress) {
         return;
     ellSafeDelete(&pputNotifyPvt->waitList,&precord->ppnr->waitNode);
-    if((ellCount(&pputNotifyPvt->waitList)!=0)) {
+    if ((ellCount(&pputNotifyPvt->waitList)!=0)) {
-    } else if(pputNotifyPvt->state == putNotifyPutInProgress) {
+    } else if (pputNotifyPvt->state == putNotifyPutInProgress) {
         pputNotifyPvt->state = putNotifyUserCallbackRequested;
-    } else if(pputNotifyPvt->state == putNotifyRestartInProgress) {
+    } else if (pputNotifyPvt->state == putNotifyRestartInProgress) {
         pputNotifyPvt->state = putNotifyRestartCallbackRequested;
     } else {
@@ -432,142 +436,140 @@
     putNotify *ppn = pfrom->ppn;
-    if(pto->pact) return; /*if active it will not be processed*/
+    if (pto->pact)
+        return; /*if active it will not be processed*/
-    if(!pto->ppnr) {/* make sure record has a putNotifyRecord*/
+    if (!pto->ppnr) {/* make sure record has a putNotifyRecord*/
         pto->ppnr = dbCalloc(1,sizeof(putNotifyRecord));
         pto->ppnr->precord = pto;
         ellInit(&pto->ppnr->restartList);
     assert(ppn);
-    if(!(pto->ppn)
-    && (pputNotifyPvt->state==putNotifyPutInProgress)
-    && (pto!=ppn->paddr->precord)) {
+    if (!pto->ppn &&
+        (pputNotifyPvt->state == putNotifyPutInProgress) &&
+        (pto != dbChannelRecord(ppn->chan))) {
         pto->ppn = pfrom->ppn;
-        pputNotifyPvt = (putNotifyPvt *)pfrom->ppn->pputNotifyPvt;
+        pputNotifyPvt = (putNotifyPvt *) pfrom->ppn->pputNotifyPvt;
         ellSafeAdd(&pputNotifyPvt->waitList,&pto->ppnr->waitNode);
 typedef struct tpnInfo {
     epicsEventId callbackDone;
-    putNotify    *ppn;
-}tpnInfo;
+    putNotify *ppn;
+} tpnInfo;
 static void dbtpnCallback(putNotify *ppn)
     putNotifyStatus status = ppn->status;
-    tpnInfo         *ptpnInfo = (tpnInfo *)ppn->usrPvt;
+    tpnInfo *ptpnInfo = (tpnInfo *) ppn->usrPvt;
+    const char *pname = dbChannelRecord(ppn->chan)->name;
-    if(status==0)
-	printf("dbtpnCallback: success record=%s\n",ppn->paddr->precord->name);
+    if (status == 0)
+        printf("dbtpnCallback: success record=%s\n", pname);
     else
-        printf("%s dbtpnCallback putNotify.status %d\n",ppn->paddr->precord->name,(int)status);
+        printf("%s dbtpnCallback putNotify.status %d\n",
+                pname, (int) status);
     epicsEventSignal(ptpnInfo->callbackDone);
 static void tpnThread(void *pvt)
-    tpnInfo   *ptpnInfo = (tpnInfo *)pvt;
-    putNotify *ppn = (putNotify *)ptpnInfo->ppn;
+    tpnInfo *ptpnInfo = (tpnInfo *) pvt;
+    putNotify *ppn = (putNotify *) ptpnInfo->ppn;
     dbPutNotify(ppn);
     epicsEventWait(ptpnInfo->callbackDone);
     dbNotifyCancel(ppn);
     epicsEventDestroy(ptpnInfo->callbackDone);
-    free((void *)ppn->paddr);
+    free(ppn->pbuffer);
+    dbChannelDelete(ppn->chan);
     free(ppn);
     free(ptpnInfo);
-long epicsShareAPI dbtpn(char	*pname,char *pvalue)
+long epicsShareAPI dbtpn(char *pname, char *pvalue)
-    long	status;
-    tpnInfo     *ptpnInfo;
-    DBADDR	*pdbaddr=NULL;
-    char	*psavevalue;
-    int		len;
+    struct dbChannel *chan;
+    tpnInfo *ptpnInfo;
+    putNotify *ppn;
+    char *pbuffer;
-    len = strlen(pvalue);
-    /*allocate space for value immediately following DBADDR*/
-    pdbaddr = dbCalloc(1,sizeof(DBADDR) + len+1);
-    psavevalue = (char *)(pdbaddr + 1);
-    strcpy(psavevalue,pvalue);
-    status = dbNameToAddr(pname,pdbaddr);
-    if(status) {
-	errMessage(status, "dbtpn: dbNameToAddr");
-	free((void *)pdbaddr);
-	return(-1);
+    pbuffer = strdup(pvalue);
+    chan = dbChannelCreate(pname);
+    if (!chan) {
+        printf("dbtpn: No such channel");
+        return -1;
-    ppn = dbCalloc(1,sizeof(putNotify));
-    ppn->paddr = pdbaddr;
-    ppn->pbuffer = psavevalue;
+    ppn = dbCalloc(1, sizeof(putNotify));
+    ppn->chan = chan;
+    ppn->pbuffer = pbuffer;
     ppn->nRequest = 1;
     ppn->dbrType = DBR_STRING;
     ppn->userCallback = dbtpnCallback;
-    ptpnInfo = dbCalloc(1,sizeof(tpnInfo));
+    ptpnInfo = dbCalloc(1, sizeof(tpnInfo));
     ptpnInfo->ppn = ppn;
     ptpnInfo->callbackDone = epicsEventCreate(epicsEventEmpty);
     ppn->usrPvt = ptpnInfo;
-    epicsThreadCreate("dbtpn",epicsThreadPriorityHigh,
-        epicsThreadGetStackSize(epicsThreadStackMedium),
-        tpnThread,ptpnInfo);
-    return(0);
+    epicsThreadCreate("dbtpn", epicsThreadPriorityHigh,
+    epicsThreadGetStackSize(epicsThreadStackMedium), tpnThread, ptpnInfo);
+    return 0;
 int epicsShareAPI dbNotifyDump(void)
     epicsMutexLockStatus lockStatus;
     dbRecordType *pdbRecordType;
     dbRecordNode *pdbRecordNode;
-    putNotify    *ppn;
-    putNotify    *ppnRestart;
+    putNotify *ppn;
+    putNotify *ppnRestart;
     int itry;
-    for(itry=0; itry<100; itry++) {
+    for (itry = 0; itry < 100; itry++) {
         lockStatus = epicsMutexTryLock(pnotifyGlobal->lock);
-        if(lockStatus==epicsMutexLockOK) break;
+        if (lockStatus == epicsMutexLockOK)
+            break;
         epicsThreadSleep(.05);
-    for(pdbRecordType = (dbRecordType *)ellFirst(&pdbbase->recordTypeList);
-    pdbRecordType;
-    pdbRecordType = (dbRecordType *)ellNext(&pdbRecordType->node)) {
-        for (pdbRecordNode=(dbRecordNode *)ellFirst(&pdbRecordType->recList);
-        pdbRecordNode;
-        pdbRecordNode = (dbRecordNode *)ellNext(&pdbRecordNode->node)) {
+    for (pdbRecordType = (dbRecordType *) ellFirst(&pdbbase->recordTypeList); pdbRecordType; pdbRecordType
+            = (dbRecordType *) ellNext(&pdbRecordType->node)) {
+        for (pdbRecordNode = (dbRecordNode *) ellFirst(&pdbRecordType->recList); pdbRecordNode; pdbRecordNode
+                = (dbRecordNode *) ellNext(&pdbRecordNode->node)) {
             precord = pdbRecordNode->precord;
-            if (!precord->name[0] ||
-                pdbRecordNode->flags & DBRN_FLAGS_ISALIAS)
-                continue;
-            if(!precord->ppn) continue;
-            if(!precord->ppnr) continue;
-            if(precord->ppn->paddr->precord != precord) continue;
+            if (!precord->name[0] || pdbRecordNode->flags & DBRN_FLAGS_ISALIAS)
+                continue;
+            if (!precord->ppn)
+                continue;
+                continue;
+            if (dbChannelRecord(precord->ppn->chan) != precord)
+                continue;
             ppn = precord->ppn;
-            printf("%s state %d ppn %p\n  waitList\n",
-                precord->name,pputNotifyPvt->state,(void*)ppn);
-            ppnrWait = (putNotifyRecord *)ellFirst(&pputNotifyPvt->waitList);
-            while(ppnrWait) {
-                printf("    %s pact %d\n",
-                    ppnrWait->precord->name,ppnrWait->precord->pact);
-                ppnrWait = (putNotifyRecord *)ellNext(&ppnrWait->waitNode.node);
+            printf("%s state %d ppn %p\n  waitList\n", precord->name,
+                    pputNotifyPvt->state, (void*) ppn);
+            ppnrWait = (putNotifyRecord *) ellFirst(&pputNotifyPvt->waitList);
+            while (ppnrWait) {
+                printf("    %s pact %d\n", ppnrWait->precord->name,
+                        ppnrWait->precord->pact);
+                ppnrWait = (putNotifyRecord *) ellNext(&ppnrWait->waitNode.node);
             printf("  restartList\n");
-            ppnRestart = (putNotify *)ellFirst(&precord->ppnr->restartList);
-            while(ppnRestart) {
-                printf("    %p\n", (void *)ppnRestart);
-                ppnRestart = (putNotify *)ellNext(&ppnRestart->restartNode.node);
+            ppnRestart = (putNotify *) ellFirst(&precord->ppnr->restartList);
+            while (ppnRestart) {
+                printf("    %p\n", (void *) ppnRestart);
+                ppnRestart = (putNotify *) ellNext(&ppnRestart->restartNode.node);
-    if(lockStatus==epicsMutexLockOK) epicsMutexUnlock(pnotifyGlobal->lock);
-    return(0);
+    return (0);
=== modified file 'src/ioc/db/dbNotify.h'
--- src/ioc/db/dbNotify.h	2006-11-18 00:09:27 +0000
+++ src/ioc/db/dbNotify.h	2012-05-30 18:10:27 +0000
@@ -5,7 +5,7 @@
 * EPICS BASE Versions 3.13.7
 * and higher are distributed subject to a Software License Agreement found
 /* dbNotify.h	*/
@@ -18,12 +18,12 @@
 #ifdef __cplusplus
-	/* for brain dead C++ compilers */
-	struct dbCommon;
-	struct putNotify;
     extern "C" {
 #endif
+struct dbCommon;
+struct putNotify;
 typedef struct ellCheckNode{
     ELLNODE node;
     int     isOnList;
@@ -40,7 +40,7 @@
         ellCheckNode    restartNode;
         /*The following members MUST be set by user*/
         void            (*userCallback)(struct putNotify *);
-        struct dbAddr   *paddr;         /*dbAddr set by dbNameToAddr*/
+        struct dbChannel *chan;         /*dbChannel*/
         void            *pbuffer;       /*address of data*/
         long            nRequest;       /*number of elements to be written*/
         short           dbrType;        /*database request type*/
@@ -55,7 +55,7 @@
 epicsShareFunc void epicsShareAPI dbPutNotify(putNotify *pputNotify);
 epicsShareFunc void epicsShareAPI dbNotifyCancel(putNotify *pputNotify);
-/*dbPutNotifyMapType convience function for old database access*/
+/*dbPutNotifyMapType convenience function for old database access*/
 epicsShareFunc int epicsShareAPI dbPutNotifyMapType (putNotify *ppn, short oldtype);
 /* dbPutNotifyInit called by iocInit */
@@ -70,9 +70,9 @@
 /* dbtpn is test routine for put notify */
 epicsShareFunc long epicsShareAPI dbtpn(char *recordname,char *value);
-/* dbNotifyDump is an INVASIVE debug utility. Dont use this needlessly*/
+/* dbNotifyDump is an INVASIVE debug utility. Don't use this needlessly*/
 epicsShareFunc int epicsShareAPI dbNotifyDump(void);
 /* This module provides code to handle put notify. If a put causes a record to
  * be processed, then a user supplied callback is called when that record
  * and all records processed because of that record complete processing.
@@ -87,8 +87,8 @@
  * After dbPutNotify is called it may not called for the same putNotify
  * until the putCallback is complete. The use can call dbNotifyCancel
- * to cancel the operation.
+ * to cancel the operation.
  * The user callback is called when the operation is completed.
  * The other global routines (dbNotifyAdd and dbNotifyCompletion) are called by:
=== modified file 'src/ioc/db/dbPutNotifyBlocker.cpp'
--- src/ioc/db/dbPutNotifyBlocker.cpp	2011-10-19 18:07:00 +0000
+++ src/ioc/db/dbPutNotifyBlocker.cpp	2012-05-30 18:10:27 +0000
@@ -5,21 +5,21 @@
  *  $Revision-Id$
  *                    L O S  A L A M O S
  *              Los Alamos National Laboratory
  *               Los Alamos, New Mexico 87545
  *  Copyright, 1986, The Regents of the University of California.
- *  Author:
+ *  Author:
  *  Jeffrey O. Hill
  *  [email protected]
  *  505 665 1831
@@ -47,7 +47,7 @@
 #include "dbPutNotifyBlocker.h"
 dbPutNotifyBlocker::dbPutNotifyBlocker ( epicsMutex & mutexIn ) :
-    mutex ( mutexIn ), pNotify ( 0 ),
+    mutex ( mutexIn ), pNotify ( 0 ),
     maxValueSize ( sizeof ( this->dbrScalarValue ) )
     memset ( & this->pn, '\0', sizeof ( this->pn ) );
@@ -55,7 +55,7 @@
     this->pn.pbuffer = & this->dbrScalarValue;
-dbPutNotifyBlocker::~dbPutNotifyBlocker ()
+dbPutNotifyBlocker::~dbPutNotifyBlocker ()
@@ -70,7 +70,7 @@
     this->~dbPutNotifyBlocker ();
-void dbPutNotifyBlocker::cancel (
+void dbPutNotifyBlocker::cancel (
     epicsGuard < epicsMutex > & guard )
     guard.assertIdenticalMutex ( this->mutex );
@@ -82,7 +82,7 @@
     this->block.signal ();
-void dbPutNotifyBlocker::expandValueBuf (
+void dbPutNotifyBlocker::expandValueBuf (
     epicsGuard < epicsMutex > & guard, unsigned long newSize )
@@ -127,9 +127,9 @@
-void dbPutNotifyBlocker::initiatePutNotify (
-    epicsGuard < epicsMutex > & guard, cacWriteNotify & notify,
-    struct dbAddr & addr, unsigned type, unsigned long count,
+void dbPutNotifyBlocker::initiatePutNotify (
+    epicsGuard < epicsMutex > & guard, cacWriteNotify & notify,
+    struct dbChannel * dbch, unsigned type, unsigned long count,
     const void * pValue )
     guard. assertIdenticalMutex ( this->mutex );
@@ -163,7 +163,7 @@
         throw cacChannel::badType();
-    int status = dbPutNotifyMapType (
+    int status = dbPutNotifyMapType (
                 &this->pn, static_cast <short> ( type ) );
     if ( status ) {
         this->pNotify = 0;
@@ -171,7 +171,7 @@
     this->pn.nRequest = static_cast < unsigned > ( count );
-    this->pn.paddr = &addr;
+    this->pn.chan = dbch;
     this->pn.userCallback = putNotifyCompletion;
     this->pn.usrPvt = this;
@@ -191,22 +191,22 @@
     this->show ( guard, level );
-void dbPutNotifyBlocker::show (
+void dbPutNotifyBlocker::show (
     epicsGuard < epicsMutex > &, unsigned level ) const
-    printf ( "put notify blocker at %p\n",
+    printf ( "put notify blocker at %p\n",
         static_cast <const void *> ( this ) );
     if ( level > 0u ) {
         this->block.show ( level - 1u );
-dbSubscriptionIO * dbPutNotifyBlocker::isSubscription ()
+dbSubscriptionIO * dbPutNotifyBlocker::isSubscription ()
     return 0;
-void * dbPutNotifyBlocker::operator new ( size_t size,
+void * dbPutNotifyBlocker::operator new ( size_t size,
     tsFreeList < dbPutNotifyBlocker, 64, epicsMutexNOOP > & freeList )
     return freeList.allocate ( size );
@@ -220,7 +220,7 @@
 #ifdef CXX_PLACEMENT_DELETE
-void dbPutNotifyBlocker::operator delete ( void *pCadaver,
+void dbPutNotifyBlocker::operator delete ( void *pCadaver,
     freeList.release ( pCadaver );
=== modified file 'src/ioc/db/dbPutNotifyBlocker.h'
--- src/ioc/db/dbPutNotifyBlocker.h	2010-10-05 19:27:37 +0000
+++ src/ioc/db/dbPutNotifyBlocker.h	2012-05-30 18:10:27 +0000
@@ -5,20 +5,20 @@
  *  $Revision-Id$
  *                    L O S  A L A M O S
  *	Author Jeffrey O. Hill
  *	[email protected]
  *	505 665 1831
@@ -43,24 +43,24 @@
 public:
     dbPutNotifyBlocker ( epicsMutex & );
     void destructor ( epicsGuard < epicsMutex > & );
-    void initiatePutNotify ( epicsGuard < epicsMutex > &,
-            cacWriteNotify &, struct dbAddr &,
+    void initiatePutNotify ( epicsGuard < epicsMutex > &,
+            cacWriteNotify &, struct dbChannel *,
             unsigned type, unsigned long count, const void * pValue );
     void cancel ( epicsGuard < epicsMutex > & );
     void show ( epicsGuard < epicsMutex > &, unsigned level ) const;
     void show ( unsigned level ) const;
-    void * operator new ( size_t size,
+    void * operator new ( size_t size,
         tsFreeList < dbPutNotifyBlocker, 64, epicsMutexNOOP > & );
-    epicsPlacementDeleteOperator (( void *,
+    epicsPlacementDeleteOperator (( void *,
         tsFreeList < dbPutNotifyBlocker, 64, epicsMutexNOOP > & ))
 private:
     putNotify pn;
-    // Include a union of all scalar types
+    // Include a union of all scalar types
     // including fixed length strings so
-    // that in many cases we can avoid
+    // that in many cases we can avoid
     // allocating another buffer
     union {
         dbr_string_t strval;
         dbr_short_t shrtval;
@@ -76,7 +76,7 @@
     cacWriteNotify * pNotify;
     unsigned long maxValueSize;
     dbSubscriptionIO * isSubscription ();
-    void expandValueBuf (
+    void expandValueBuf (
         epicsGuard < epicsMutex > &, unsigned long newSize );
     friend void putNotifyCompletion ( putNotify * ppn );
 	dbPutNotifyBlocker ( const dbPutNotifyBlocker & );
=== added file 'src/ioc/db/dbState.c'
--- src/ioc/db/dbState.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/dbState.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,107 @@
+#include "iocsh.h"
+#include "epicsMutex.h"
+#include "ellLib.h"
+#include "dbDefs.h"
+static ELLLIST states = ELLLIST_INIT;
+typedef struct dbState {
+    ELLNODE node;
+    int status;
+    char *name;
+    epicsMutexId lock;        /* FIXME: Use atomic operations instead */
+} dbState;
+dbStateId dbStateFind(const char *name)
+    ELLNODE *node;
+    dbStateId id;
+    for (node = ellFirst(&states); node; node = ellNext(node)) {
+        id = CONTAINER(node, dbState, node);
+        if (strcmp(id->name, name) == 0)
+            return id;
+    return NULL;
+dbStateId dbStateCreate(const char *name)
+    dbStateId id;
+    if ((id = dbStateFind(name)))
+        return id;
+    id = callocMustSucceed(1, sizeof(dbState), "createDbState");
+    id->name = strdup(name);
+    id->lock = epicsMutexMustCreate();
+    ellAdd(&states, &id->node);
+    return id;
+void dbStateSet(dbStateId id)
+    if (!id)
+        return;
+    epicsMutexMustLock(id->lock);
+    id->status = 1;
+    epicsMutexUnlock(id->lock);
+void dbStateClear(dbStateId id)
+    if (!id)
+        return;
+    id->status = 0;
+int dbStateGet(dbStateId id)
+    int status;
+    if (!id)
+        return 0;
+    status = id->status;
+    return status;
+void dbStateShow(dbStateId id, unsigned int level)
+    if (level >=1)
+        printf("id %#x '%s' : ", (unsigned int) id, id->name);
+    printf("%s\n", dbStateGet(id) ? "TRUE" : "FALSE");
+void dbStateShowAll(unsigned int level)
+    ELLNODE *node;
+    dbStateId id;
+        dbStateShow(id, level+1);
=== added file 'src/ioc/db/dbState.h'
--- src/ioc/db/dbState.h	1970-01-01 00:00:00 +0000
+++ src/ioc/db/dbState.h	2012-05-30 18:10:27 +0000
@@ -0,0 +1,92 @@
+#ifndef INCdbStateH
+#define INCdbStateH
+/** @file dbState.h
+ * @brief Generic IOC state facility
+ * This library provides a simple global flag facility that can be used to
+ * synchronize e.g. plugins with IOC-wide states, that may be derived from
+ * events (either soft events or hard events coming from specialized timing
+ * and event hardware).
+ * A subset of this API is provided as IOC Shell commands to allow
+ * command line debugging.
+typedef struct dbState *dbStateId;
+/** @brief Create db state.
+ * Creates a new db state with the specified 'name', returning the new id.
+ * If state with that name already exists, the existing state's id is returned.
+ * <em>Also provided as an IOC Shell command.</em>
+ * @param name Db state name.
+ * @return Id of db state, NULL for failure.
+epicsShareFunc dbStateId dbStateCreate(const char *name);
+/** @brief Find db state.
+ * @return Id of db state, NULL if not found.
+epicsShareFunc dbStateId dbStateFind(const char *name);
+/** @brief Set db state to TRUE.
+ * @param id Db state id.
+epicsShareFunc void dbStateSet(dbStateId id);
+/** @brief Set db state to FALSE.
+epicsShareFunc void dbStateClear(dbStateId id);
+/** @brief Get db state.
+ * @return Current db state (0|1).
+epicsShareFunc int dbStateGet(dbStateId id);
+/** @brief Print info about db state.
+ * @param level Interest level.
+epicsShareFunc void dbStateShow(dbStateId id, unsigned int level);
+/** @brief Print info about all db states.
+epicsShareFunc void dbStateShowAll(unsigned int level);
+#endif // INCdbStateH
=== modified file 'src/ioc/db/dbSubscriptionIO.cpp'
--- src/ioc/db/dbSubscriptionIO.cpp	2010-10-05 19:27:37 +0000
+++ src/ioc/db/dbSubscriptionIO.cpp	2012-05-30 18:10:27 +0000
@@ -4,20 +4,20 @@
  *  $Revision-Id$
  *                    L O S  A L A M O S
  *	[email protected]
  *	505 665 1831
@@ -41,18 +41,18 @@
 #include "dbChannelIO.h"
 #include "db_access_routines.h"
-dbSubscriptionIO::dbSubscriptionIO (
+dbSubscriptionIO::dbSubscriptionIO (
     epicsGuard < epicsMutex > & guard, epicsMutex & mutexIn,
-    dbContext &, dbChannelIO & chanIO,
-    dbAddr & addr, cacStateNotify & notifyIn, unsigned typeIn,
+    dbContext &, dbChannelIO & chanIO,
+    dbChannel * dbch, cacStateNotify & notifyIn, unsigned typeIn,
     unsigned long countIn, unsigned maskIn, dbEventCtx ctx ) :
-    mutex ( mutexIn ), count ( countIn ), notify ( notifyIn ),
+    mutex ( mutexIn ), count ( countIn ), notify ( notifyIn ),
     chan ( chanIO ), es ( 0 ), type ( typeIn ), id ( 0u )
         epicsGuardRelease < epicsMutex > unguard ( guard );
-        this->es = db_add_event ( ctx, & addr,
+        this->es = db_add_event ( ctx, dbch,
             dbSubscriptionEventCallback, (void *) this, maskIn );
         if ( this->es == 0 ) {
             throw std::bad_alloc();
@@ -62,7 +62,7 @@
-dbSubscriptionIO::~dbSubscriptionIO ()
+dbSubscriptionIO::~dbSubscriptionIO ()
@@ -72,7 +72,7 @@
     this->~dbSubscriptionIO ();
-void dbSubscriptionIO::unsubscribe (
+void dbSubscriptionIO::unsubscribe (
@@ -86,11 +86,11 @@
-void dbSubscriptionIO::channelDeleteException (
+void dbSubscriptionIO::channelDeleteException (
-    this->notify.exception ( guard, ECA_CHANDESTROY,
+    this->notify.exception ( guard, ECA_CHANDESTROY,
         this->chan.pName(guard), this->type, this->count );
@@ -112,21 +112,21 @@
         __FILE__, __LINE__ );
-void * dbSubscriptionIO::operator new ( size_t size,
+void * dbSubscriptionIO::operator new ( size_t size,
         tsFreeList < dbSubscriptionIO, 256, epicsMutexNOOP > & freeList )
-void dbSubscriptionIO::operator delete ( void * pCadaver,
+void dbSubscriptionIO::operator delete ( void * pCadaver,
 #endif
-extern "C" void dbSubscriptionEventCallback ( void *pPrivate, struct dbAddr * /* paddr */,
+extern "C" void dbSubscriptionEventCallback ( void *pPrivate, struct dbChannel * /* dbch */,
 	int /* eventsRemaining */, struct db_field_log *pfl )
     dbSubscriptionIO * pIO = static_cast < dbSubscriptionIO * > ( pPrivate );
@@ -139,19 +139,19 @@
-void dbSubscriptionIO::show (
+void dbSubscriptionIO::show (
     epicsGuard < epicsMutex > & guard, unsigned level ) const
-    printf ( "Data base subscription IO at %p\n",
+    printf ( "Data base subscription IO at %p\n",
     if ( level > 0u ) {
         short tmpType;
         if ( this->type < SHRT_MAX ) {
             tmpType = static_cast < short > ( this->type );
             printf ( "\ttype %s, count %lu, channel at %p\n",
-                dbf_type_to_text ( tmpType ), this->count,
+                dbf_type_to_text ( tmpType ), this->count,
                 static_cast <void *> ( &this->chan ) );
         else {
@@ -161,7 +161,7 @@
-dbSubscriptionIO * dbSubscriptionIO::isSubscription ()
+dbSubscriptionIO * dbSubscriptionIO::isSubscription ()
     return this;
=== modified file 'src/ioc/db/db_access.c'
--- src/ioc/db/db_access.c	2011-08-30 23:09:11 +0000
+++ src/ioc/db/db_access.c	2012-05-30 18:10:27 +0000
@@ -4,15 +4,13 @@
-/* $Revision-Id$ */
 /* Interface between old database access and new
- *      Date:            6-1-90
 #include <stddef.h>
@@ -24,6 +22,7 @@
 #include "epicsConvert.h"
 #include "dbDefs.h"
 #include "errlog.h"
 #include "ellLib.h"
@@ -42,10 +41,6 @@
-#ifndef NULL
-#define NULL 0
-#endif
 #define oldDBF_STRING      0
 #define oldDBF_INT         1
@@ -108,50 +103,36 @@
 typedef char DBSTRING[MAX_STRING_SIZE];
-#ifndef MAX_STRING_SIZE
-#define MAX_STRING_SIZE	40
-#endif
- * DB_PROCESS
- * process database records
-void db_process(struct dbAddr *paddr)
-    long status = dbProcess(paddr->precord);
-    if (status) errMessage(status, "db_process failed");
- * DB_NAME_TO_ADDR
-int epicsShareAPI db_name_to_addr(const char *pname, struct dbAddr *paddr)
-    long status;
+struct dbChannel * dbChannel_create(const char *pname)
+    dbChannel *chan = dbChannelCreate(pname);
     short ftype;
-    status = dbNameToAddr(pname, paddr);
-    if (!status) {
-        ftype = paddr->dbr_field_type;
-        if (INVALID_DB_REQ(ftype)) {
-            errlogPrintf("%s dbNameToAddr failed\n", pname);
-            return -2;
-        paddr->dbr_field_type = dbDBRnewToDBRold[ftype];
-        return 0;
-    else
-        return -1;
+    if (!chan)
+        return NULL;
+    ftype = chan->addr.dbr_field_type;
+    if (INVALID_DB_REQ(ftype)) {
+        dbChannelDelete(chan);
+        return NULL;
+    chan->addr.dbr_field_type = dbDBRnewToDBRold[ftype];
+    if (dbChannelOpen(chan)) {
+        return NULL;
+    return chan;
-int epicsShareAPI db_get_field(struct dbAddr *paddr,
-    int buffer_type, void *pbuffer, int no_elements, void *pfl)
+int dbChannel_get(struct dbChannel *chan,
+    int buffer_type, void *pbuffer, long no_elements, void *pfl)
     long nRequest = no_elements;
-    int result = db_get_field_and_count(
-        paddr, buffer_type, pbuffer, &nRequest, pfl);
+    int result = dbChannel_get_count(
+        chan, buffer_type, pbuffer, &nRequest, pfl);
     if (nRequest < no_elements) {
         /* The database request returned fewer elements than requested, so
          * fill the remainder of the buffer with zeros.
@@ -168,10 +149,11 @@
 /* Performs the work of the public db_get_field API, but also returns the number
  * of elements actually copied to the buffer.  The caller is responsible for
  * zeroing the remaining part of the buffer. */
-int epicsShareAPI db_get_field_and_count(
-    struct dbAddr *paddr, int buffer_type,
+int epicsShareAPI dbChannel_get_count(
+    struct dbChannel *chan, int buffer_type,
     void *pbuffer, long *nRequest, void *pfl)
+    dbAddr *paddr=&chan->addr;
     long status;
     long options;
     long i;
@@ -184,26 +166,26 @@
     switch(buffer_type) {
     case(oldDBR_STRING):
-        status = dbGetField(paddr, DBR_STRING, pbuffer, &zero, nRequest, pfl);
+        status = dbChannelGetField(chan, DBR_STRING, pbuffer, &zero, nRequest, pfl);
         break;
 /*  case(oldDBR_INT): */
     case(oldDBR_SHORT):
-        status = dbGetField(paddr, DBR_SHORT, pbuffer, &zero, nRequest, pfl);
+        status = dbChannelGetField(chan, DBR_SHORT, pbuffer, &zero, nRequest, pfl);
         break;
     case(oldDBR_FLOAT):
-        status = dbGetField(paddr, DBR_FLOAT, pbuffer, &zero, nRequest, pfl);
+        status = dbChannelGetField(chan, DBR_FLOAT, pbuffer, &zero, nRequest, pfl);
         break;
     case(oldDBR_ENUM):
-        status = dbGetField(paddr, DBR_ENUM, pbuffer, &zero, nRequest, pfl);
+        status = dbChannelGetField(chan, DBR_ENUM, pbuffer, &zero, nRequest, pfl);
         break;
     case(oldDBR_CHAR):
-        status = dbGetField(paddr, DBR_CHAR, pbuffer, &zero, nRequest, pfl);
+        status = dbChannelGetField(chan, DBR_CHAR, pbuffer, &zero, nRequest, pfl);
         break;
     case(oldDBR_LONG):
-        status = dbGetField(paddr, DBR_LONG, pbuffer, &zero, nRequest, pfl);
+        status = dbChannelGetField(chan, DBR_LONG, pbuffer, &zero, nRequest, pfl);
         break;
     case(oldDBR_DOUBLE):
-        status = dbGetField(paddr, DBR_DOUBLE, pbuffer, &zero, nRequest, pfl);
+        status = dbChannelGetField(chan, DBR_DOUBLE, pbuffer, &zero, nRequest, pfl);
         break;
     case(oldDBR_STS_STRING):
@@ -216,10 +198,10 @@
             } newSt;
             options = DBR_STATUS;
-            status = dbGetField(paddr, DBR_STRING, &newSt, &options, &zero, pfl);
+            status = dbChannelGetField(chan, DBR_STRING, &newSt, &options, &zero, pfl);
             pold->status = newSt.status;
             pold->severity = newSt.severity;
-            status = dbGetField(paddr, DBR_STRING, pold->value, &zero,
+            status = dbChannelGetField(chan, DBR_STRING, pold->value, &zero,
                 nRequest, pfl);
         break;
@@ -232,10 +214,10 @@
             } newSt;
-            status = dbGetField(paddr, DBR_SHORT, &newSt, &options, &zero, pfl);
+            status = dbChannelGetField(chan, DBR_SHORT, &newSt, &options, &zero, pfl);
-            status = dbGetField(paddr, DBR_SHORT, &pold->value, &zero,
+            status = dbChannelGetField(chan, DBR_SHORT, &pold->value, &zero,
                 nRequest, pfl);
         break;
@@ -247,10 +229,10 @@
             } newSt;
-            status = dbGetField(paddr, DBR_FLOAT, &newSt, &options, &zero, pfl);
+            status = dbChannelGetField(chan, DBR_FLOAT, &newSt, &options, &zero, pfl);
-            status = dbGetField(paddr, DBR_FLOAT, &pold->value, &zero,
+            status = dbChannelGetField(chan, DBR_FLOAT, &pold->value, &zero,
                 nRequest, pfl);
         break;
@@ -262,10 +244,10 @@
             } newSt;
-            status = dbGetField(paddr, DBR_ENUM, &newSt, &options, &zero, pfl);
+            status = dbChannelGetField(chan, DBR_ENUM, &newSt, &options, &zero, pfl);
-            status = dbGetField(paddr, DBR_ENUM, &pold->value, &zero,
+            status = dbChannelGetField(chan, DBR_ENUM, &pold->value, &zero,
                 nRequest, pfl);
         break;
@@ -277,10 +259,10 @@
             } newSt;
-            status = dbGetField(paddr, DBR_UCHAR, &newSt, &options, &zero, pfl);
+            status = dbChannelGetField(chan, DBR_UCHAR, &newSt, &options, &zero, pfl);
-            status = dbGetField(paddr, DBR_UCHAR, &pold->value, &zero,
+            status = dbChannelGetField(chan, DBR_UCHAR, &pold->value, &zero,
                 nRequest, pfl);
         break;
@@ -292,10 +274,10 @@
             } newSt;
-            status = dbGetField(paddr, DBR_LONG, &newSt, &options, &zero, pfl);
+            status = dbChannelGetField(chan, DBR_LONG, &newSt, &options, &zero, pfl);
-            status = dbGetField(paddr, DBR_LONG, &pold->value, &zero,
+            status = dbChannelGetField(chan, DBR_LONG, &pold->value, &zero,
                 nRequest, pfl);
         break;
@@ -307,11 +289,11 @@
             } newSt;
-            status = dbGetField(paddr, DBR_DOUBLE, &newSt, &options, &zero, pfl);
+            status = dbChannelGetField(chan, DBR_DOUBLE, &newSt, &options, &zero, pfl);
             options = 0;
-            status = dbGetField(paddr, DBR_DOUBLE, &pold->value, &options,
+            status = dbChannelGetField(chan, DBR_DOUBLE, &pold->value, &options,
                 nRequest, pfl);
         break;
@@ -325,12 +307,12 @@
             } newSt;
             options = DBR_STATUS | DBR_TIME;
             pold->stamp = newSt.time;         /* structure copy */
             options = 0;
-            status = dbGetField(paddr, DBR_STRING, pold->value, &options,
+            status = dbChannelGetField(chan, DBR_STRING, pold->value, &options,
                     nRequest, pfl);
         break;
@@ -344,12 +326,12 @@
             } newSt;
             options = 0;
-            status = dbGetField(paddr, DBR_SHORT, &pold->value, &options,
+            status = dbChannelGetField(chan, DBR_SHORT, &pold->value, &options,
                 nRequest, pfl);
         break;
@@ -362,12 +344,12 @@
             } newSt;
             options = 0;
-            status = dbGetField(paddr, DBR_FLOAT, &pold->value, &options,
+            status = dbChannelGetField(chan, DBR_FLOAT, &pold->value, &options,
                 nRequest, pfl);
         break;
@@ -380,12 +362,12 @@
             } newSt;
             options = 0;
-            status = dbGetField(paddr, DBR_ENUM, &pold->value, &options,
+            status = dbChannelGetField(chan, DBR_ENUM, &pold->value, &options,
                 nRequest, pfl);
         break;
@@ -398,12 +380,12 @@
             } newSt;
-            status = dbGetField(paddr, DBR_CHAR, &newSt, &options, &zero, pfl);
+            status = dbChannelGetField(chan, DBR_CHAR, &newSt, &options, &zero, pfl);
             options = 0;
-            status = dbGetField(paddr, DBR_CHAR, &pold->value, &options,
+            status = dbChannelGetField(chan, DBR_CHAR, &pold->value, &options,
                 nRequest, pfl);
         break;
@@ -416,12 +398,12 @@
             } newSt;
             options = 0;
-            status = dbGetField(paddr, DBR_LONG, &pold->value, &options,
+            status = dbChannelGetField(chan, DBR_LONG, &pold->value, &options,
                 nRequest, pfl);
         break;
@@ -434,12 +416,12 @@
             } newSt;
             options = 0;
                 nRequest, pfl);
         break;
@@ -457,7 +439,7 @@
             } newSt;
             options = DBR_STATUS | DBR_UNITS | DBR_GR_LONG | DBR_AL_LONG;
             strncpy(pold->units, newSt.units, MAX_UNITS_SIZE);
@@ -469,7 +451,7 @@
             pold->lower_warning_limit = newSt.lower_warning_limit;
             pold->lower_alarm_limit = newSt.lower_alarm_limit;
             options = 0;
                 nRequest, pfl);
         break;
@@ -486,7 +468,7 @@
             options = DBR_STATUS | DBR_UNITS | DBR_PRECISION | DBR_GR_DOUBLE |
                 DBR_AL_DOUBLE;
             pold->precision = newSt.precision.dp;
@@ -499,7 +481,7 @@
             pold->upper_warning_limit = epicsConvertDoubleToFloat(newSt.upper_warning_limit);
             pold->lower_warning_limit = epicsConvertDoubleToFloat(newSt.lower_warning_limit);
             options = 0;
                 nRequest, pfl);
         break;
@@ -515,7 +497,7 @@
             } newSt;
@@ -527,7 +509,7 @@
             options = 0;
-            status = dbGetField(paddr, DBR_UCHAR, &pold->value, &options,
+            status = dbChannelGetField(chan, DBR_UCHAR, &pold->value, &options,
                 nRequest, pfl);
         break;
@@ -542,7 +524,7 @@
             } newSt;
@@ -554,7 +536,7 @@
             options = 0;
                 nRequest, pfl);
         break;
@@ -571,7 +553,7 @@
                 DBR_AL_DOUBLE;
@@ -584,7 +566,7 @@
             options = 0;
                 nRequest, pfl);
         break;
@@ -603,7 +585,7 @@
             options = DBR_STATUS | DBR_UNITS | DBR_GR_LONG | DBR_CTRL_LONG |
                 DBR_AL_LONG;
@@ -617,7 +599,7 @@
             pold->upper_ctrl_limit = newSt.upper_ctrl_limit;
             pold->lower_ctrl_limit = newSt.lower_ctrl_limit;
             options = 0;
                 nRequest, pfl);
         break;
@@ -635,7 +617,7 @@
                 DBR_CTRL_DOUBLE | DBR_AL_DOUBLE;
@@ -650,7 +632,7 @@
             pold->upper_ctrl_limit = epicsConvertDoubleToFloat(newSt.upper_ctrl_limit);
             pold->lower_ctrl_limit = epicsConvertDoubleToFloat(newSt.lower_ctrl_limit);
             options = 0;
                 nRequest, pfl);
         break;
@@ -667,7 +649,7 @@
             memset(pold, '\0', sizeof(struct dbr_ctrl_enum));
             /* first get status and severity */
             options = DBR_STATUS | DBR_ENUM_STRS;
             no_str = newSt.no_str;
@@ -677,7 +659,7 @@
                 strncpy(pold->strs[i], newSt.strs[i], sizeof(pold->strs[i]));
             /*now get values*/
             options = 0;
                 nRequest, pfl);
         break;
@@ -694,7 +676,7 @@
                 DBR_AL_LONG;
@@ -708,7 +690,7 @@
             options = 0;
                 nRequest, pfl);
         break;
@@ -725,7 +707,7 @@
                 DBR_AL_LONG;
@@ -739,7 +721,7 @@
             options = 0;
                 nRequest, pfl);
         break;
@@ -757,7 +739,7 @@
@@ -772,7 +754,7 @@
             options = 0;
                 nRequest, pfl);
         break;
@@ -785,13 +767,13 @@
             } newSt;
             pold->ackt = newSt.ackt;
             pold->acks = newSt.acks;
             options = 0;
                 &options, nRequest, pfl);
         break;
@@ -807,7 +789,7 @@
                 break;
             dbInitEntry(pdbbase, &dbEntry);
-            status = dbFindRecord(&dbEntry, paddr->precord->name);
+            status = dbFindRecord(&dbEntry, dbChannelRecord(chan)->name);
             if (!status) name = dbGetRecordTypeName(&dbEntry);
             dbFinishEntry(&dbEntry);
             if (status) break;
@@ -825,165 +807,163 @@
     if (status) return -1;
     return 0;
-/* DB_PUT_FIELD put a field and convert it to the desired type */
-int epicsShareAPI db_put_field(struct dbAddr *paddr, int src_type,
-    const void *psrc, int no_elements)
+int dbChannel_put(struct dbChannel *chan, int src_type,
+    const void *psrc, long no_elements)
     long status;
-    switch(src_type) {
+    switch (src_type) {
-        status = dbPutField(paddr, DBR_STRING, psrc, no_elements);
+        status = dbChannelPutField(chan, DBR_STRING, psrc, no_elements);
         break;
     case(oldDBR_SHORT):
-        status = dbPutField(paddr, DBR_SHORT, psrc, no_elements);
+        status = dbChannelPutField(chan, DBR_SHORT, psrc, no_elements);
         break;
     case(oldDBR_FLOAT):
-        status = dbPutField(paddr, DBR_FLOAT, psrc, no_elements);
+        status = dbChannelPutField(chan, DBR_FLOAT, psrc, no_elements);
         break;
     case(oldDBR_ENUM):
-        status = dbPutField(paddr, DBR_ENUM, psrc, no_elements);
+        status = dbChannelPutField(chan, DBR_ENUM, psrc, no_elements);
         break;
     case(oldDBR_CHAR):
-        status = dbPutField(paddr, DBR_UCHAR, psrc, no_elements);
+        status = dbChannelPutField(chan, DBR_UCHAR, psrc, no_elements);
         break;
     case(oldDBR_LONG):
-        status = dbPutField(paddr, DBR_LONG, psrc, no_elements);
+        status = dbChannelPutField(chan, DBR_LONG, psrc, no_elements);
         break;
-        status = dbPutField(paddr, DBR_DOUBLE, psrc, no_elements);
+        status = dbChannelPutField(chan, DBR_DOUBLE, psrc, no_elements);
         break;
             ((const struct dbr_sts_string *)psrc)->value, no_elements);
         break;
 /*  case(oldDBR_STS_INT): */
     case(oldDBR_STS_SHORT):
             &((const struct dbr_sts_short *)psrc)->value, no_elements);
         break;
     case(oldDBR_STS_FLOAT):
             &((const struct dbr_sts_float *)psrc)->value, no_elements);
         break;
     case(oldDBR_STS_ENUM):
             &((const struct dbr_sts_enum *)psrc)->value, no_elements);
         break;
     case(oldDBR_STS_CHAR):
             &((const struct dbr_sts_char *)psrc)->value, no_elements);
         break;
     case(oldDBR_STS_LONG):
             &((const struct dbr_sts_long *)psrc)->value, no_elements);
         break;
     case(oldDBR_STS_DOUBLE):
             &((const struct dbr_sts_double *)psrc)->value, no_elements);
         break;
     case(oldDBR_TIME_STRING):
-        status = dbPutField(paddr, DBR_TIME,
+        status = dbChannelPutField(chan, DBR_TIME,
             ((const struct dbr_time_string *)psrc)->value, no_elements);
         break;
 /*  case(oldDBR_TIME_INT): */
     case(oldDBR_TIME_SHORT):
             &((const struct dbr_time_short *)psrc)->value, no_elements);
         break;
     case(oldDBR_TIME_FLOAT):
             &((const struct dbr_time_float *)psrc)->value, no_elements);
         break;
     case(oldDBR_TIME_ENUM):
             &((const struct dbr_time_enum *)psrc)->value, no_elements);
         break;
     case(oldDBR_TIME_CHAR):
             &((const struct dbr_time_char *)psrc)->value, no_elements);
         break;
     case(oldDBR_TIME_LONG):
             &((const struct dbr_time_long *)psrc)->value, no_elements);
         break;
     case(oldDBR_TIME_DOUBLE):
             &((const struct dbr_time_double *)psrc)->value, no_elements);
         break;
     case(oldDBR_GR_STRING):
         /* no struct dbr_gr_string - use dbr_sts_string instead */
         break;
 /*  case(oldDBR_GR_INT): */
     case(oldDBR_GR_SHORT):
             &((const struct dbr_gr_short *)psrc)->value, no_elements);
         break;
     case(oldDBR_GR_FLOAT):
             &((const struct dbr_gr_float *)psrc)->value, no_elements);
         break;
     case(oldDBR_GR_ENUM):
             &((const struct dbr_gr_enum *)psrc)->value, no_elements);
         break;
     case(oldDBR_GR_CHAR):
             &((const struct dbr_gr_char *)psrc)->value, no_elements);
         break;
     case(oldDBR_GR_LONG):
             &((const struct dbr_gr_long *)psrc)->value, no_elements);
         break;
     case(oldDBR_GR_DOUBLE):
             &((const struct dbr_gr_double *)psrc)->value, no_elements);
         break;
     case(oldDBR_CTRL_STRING):
         /* no struct dbr_ctrl_string - use dbr_sts_string instead */
         break;
 /*  case(oldDBR_CTRL_INT): */
     case(oldDBR_CTRL_SHORT):
             &((const struct dbr_ctrl_short *)psrc)->value, no_elements);
         break;
     case(oldDBR_CTRL_FLOAT):
             &((const struct dbr_ctrl_float *)psrc)->value, no_elements);
         break;
     case(oldDBR_CTRL_ENUM):
             &((const struct dbr_ctrl_enum *)psrc)->value, no_elements);
         break;
     case(oldDBR_CTRL_CHAR):
             &((const struct dbr_ctrl_char *)psrc)->value, no_elements);
         break;
     case(oldDBR_CTRL_LONG):
             &((const struct dbr_ctrl_long *)psrc)->value, no_elements);
         break;
     case(oldDBR_CTRL_DOUBLE):
             &((const struct dbr_ctrl_double *)psrc)->value, no_elements);
         break;
     case(oldDBR_PUT_ACKT):
-        status = dbPutField(paddr, DBR_PUT_ACKT, psrc, no_elements);
+        status = dbChannelPutField(chan, DBR_PUT_ACKT, psrc, no_elements);
         break;
     case(oldDBR_PUT_ACKS):
-        status = dbPutField(paddr, DBR_PUT_ACKS, psrc, no_elements);
+        status = dbChannelPutField(chan, DBR_PUT_ACKS, psrc, no_elements);
         break;
     default:
@@ -993,7 +973,7 @@
     return 0;
     switch(oldtype) {
=== modified file 'src/ioc/db/db_access_routines.h'
--- src/ioc/db/db_access_routines.h	2010-09-27 16:41:53 +0000
+++ src/ioc/db/db_access_routines.h	2012-05-30 18:10:27 +0000
@@ -1,11 +1,10 @@
-* Copyright (c) 2002 The University of Chicago, as Operator of Argonne
+* Copyright (c) 2010 UChicago Argonne LLC, as Operator of Argonne
 *     National Laboratory.
 * Copyright (c) 2002 The Regents of the University of California, as
 *     Operator of Los Alamos National Laboratory.
-* EPICS BASE Versions 3.13.7
-* and higher are distributed subject to a Software License Agreement found
+* EPICS BASE is distributed subject to a Software License Agreement found
+* in file LICENSE that is included with this distribution.
 /* base/include/db_access_routines.h */
@@ -22,26 +21,21 @@
 #endif
 epicsShareExtern struct dbBase *pdbbase;
 epicsShareExtern volatile int interruptAccept;
- * old db access API
- * (included here because these routines use dbAccess.h and their
- * prototypes must also be included in db_access.h)
+ * Adaptors for db_access users
-epicsShareFunc int epicsShareAPI db_name_to_addr(
-    const char *pname, DBADDR *paddr);
-epicsShareFunc int epicsShareAPI db_put_field(
-    DBADDR *paddr, int src_type,const void *psrc, int no_elements);
-epicsShareFunc int epicsShareAPI db_get_field(
-    DBADDR *paddr, int dest_type,void *pdest, int no_elements, void *pfl);
-epicsShareFunc int epicsShareAPI db_get_field_and_count(
-    void *pbuffer, long *nRequest, void *pfl);
+epicsShareFunc struct dbChannel * dbChannel_create(const char *pname);
+epicsShareFunc int dbChannel_get(struct dbChannel *chan,
+    int buffer_type, void *pbuffer, long no_elements, void *pfl);
+epicsShareFunc int dbChannel_put(struct dbChannel *chan, int src_type,
+    const void *psrc, long no_elements);
+epicsShareFunc int epicsShareAPI dbChannel_get_count(struct dbChannel *chan,
+    int buffer_type, void *pbuffer, long *nRequest, void *pfl);
 #ifdef __cplusplus
=== modified file 'src/ioc/db/db_field_log.h'
--- src/ioc/db/db_field_log.h	2010-10-05 19:27:37 +0000
+++ src/ioc/db/db_field_log.h	2012-05-30 18:10:27 +0000
@@ -1,19 +1,26 @@
+* Copyright (c) 2010 Brookhaven National Laboratory.
+* Copyright (c) 2010 Helmholtz-Zentrum Berlin
+*     fuer Materialien und Energie GmbH.
-/* $Revision-Id$
- * 	Author: 	Jeffrey O. Hill
- *      Date:            4-1-89
+ *  Author: Jeffrey O. Hill <[email protected]>
+ *          Ralph Lange <[email protected]>
 #ifndef INCLdb_field_logh
 #define INCLdb_field_logh
+#include "epicsTime.h"
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -27,7 +34,7 @@
  * will most likely change infrequently.
-union native_value{
+union native_value {
       	short		dbf_int;
       	short		dbf_short;
       	float		dbf_float;
@@ -36,7 +43,7 @@
       	long		dbf_long;
       	double		dbf_double;
 #ifdef DB_EVENT_LOG_STRINGS
-      	char		dbf_string[MAXSTRINGSIZE];
+        char		dbf_string[MAX_STRING_SIZE];
 #endif
@@ -44,12 +51,48 @@
  *	structure to log the state of a data base field at the time
  *	an event is triggered.
+struct db_field_log;
+typedef void (dbfl_freeFunc)(struct db_field_log *pfl);
+/* Types of db_field_log: rec = use record, val = val inside, ref = reference inside */
+typedef enum dbfl_type {
+    dbfl_type_rec = 0,
+    dbfl_type_val,
+    dbfl_type_ref
+} dbfl_type;
+/* Context of db_field_log: event = subscription update, read = read reply */
+typedef enum dbfl_context {
+    dbfl_context_read = 0,
+    dbfl_context_event
+} dbfl_context;
+#define dbflTypeStr(t) (t==dbfl_type_val?"val":t==dbfl_type_rec?"rec":"ref")
+struct dbfl_val {
+    union native_value field; /* Field value */
+struct dbfl_ref {
+    dbfl_freeFunc     *dtor;  /* Callback to free filter-allocated resources */
+    void              *pvt;   /* Private pointer */
+    void              *field; /* Field value */
 typedef struct db_field_log {
-        unsigned short		stat;	/* Alarm Status         */
-        unsigned short		sevr;	/* Alarm Severity       */
-	epicsTimeStamp		time;	/* time stamp		*/
-	union native_value	field;	/* field value		*/
-}db_field_log;
+    enum dbfl_type   type:2;  /* type (union) selector */
+    enum dbfl_context ctx:1;  /* context (operation type) */
+    epicsTimeStamp     time;  /* Time stamp */
+    unsigned short     stat;  /* Alarm Status */
+    unsigned short     sevr;  /* Alarm Severity */
+    short        field_type;  /* DBF type of data */
+    short        field_size;  /* Data size */
+    long        no_elements;  /* No of array elements */
+    union {
+        struct dbfl_val v;
+        struct dbfl_ref r;
+    } u;
+} db_field_log;
 #ifdef __cplusplus
=== modified file 'src/ioc/db/db_test.c'
--- src/ioc/db/db_test.c	2012-05-03 17:19:34 +0000
+++ src/ioc/db/db_test.c	2012-05-30 18:10:27 +0000
@@ -5,13 +5,13 @@
-/* share/src/db  @(#)db_test.c	1.10     2/3/94 */
 /*      database access subroutines */
  *      Author: Bob Dalesio
- *      Date:   4/15/88
 #include <stddef.h>
 #include <epicsStdlib.h>
@@ -23,706 +23,230 @@
 #include "cadef.h"
 #include "epicsStdio.h"
 #define epicsExportSharedSymbols
 #include "dbNotify.h"
 #include "db_test.h"
 #include "dbCommon.h"
 #define		MAX_ELEMS	10
-int epicsShareAPI gft(char *pname)
+int gft(char *pname)
-	char		tgf_buffer[MAX_ELEMS*MAX_STRING_SIZE+sizeof(struct dbr_ctrl_double)];
-	struct  dbAddr	addr;
-	struct  dbAddr	*paddr = &addr;
-	short		number_elements;
-	int	i;
-	int status;
-	if (pname==0 || ((*pname < ' ') || (*pname > 'z'))) {
-		printf("\nusage \"pv name\"\n");
-		return(1);
-	/* convert name to database address */
-	status=db_name_to_addr(pname,&addr);
-	if(status) {
-		printf("db_name_to_addr failed\n");
-		return(1);
-	printf("   Record Name: %s\n",pname);
-	printf("Record Address: 0x%p\n",(void *)addr.precord);
-	printf("    Field Type: %d\n",addr.dbr_field_type);
-	printf(" Field Address: 0x%p\n",addr.pfield);
-	printf("    Field Size: %d\n",addr.field_size);
-	printf("   No Elements: %ld\n",addr.no_elements);
-	number_elements =
-		((addr.no_elements > MAX_ELEMS)?MAX_ELEMS:addr.no_elements);
-	for(i=0; i<=LAST_BUFFER_TYPE; i++) {
-		if(addr.dbr_field_type==0) {
-			if( (i!=DBR_STRING)
-			 && (i!=DBR_STS_STRING)
-			 && (i!=DBR_TIME_STRING)
-			 && (i!=DBR_GR_STRING)
-			 && (i!=DBR_CTRL_STRING)) continue;
-		if(db_get_field(paddr,i,tgf_buffer,number_elements,NULL)<0)
-			printf("\t%s Failed\n",dbr_text[i]);
-		else
-			ca_dump_dbr (i,number_elements,tgf_buffer);
-	return(0);
+    char tgf_buffer[MAX_ELEMS*MAX_STRING_SIZE + sizeof(struct dbr_ctrl_double)];
+    struct dbCommon *precord;
+    long elements;
+    short type;
+    int i;
+    chan = dbChannel_create(pname);
+    if (!chan) {
+        printf("Channel couldn't be created\n");
+        return 1;
+    precord = dbChannelRecord(chan);
+    elements = dbChannelElements(chan);
+    type = dbChannelExportType(chan);
+    printf("   Record Name: %s\n", precord->name);
+    printf("Record Address: 0x%p\n", precord);
+    printf("   Export Type: %d\n", type);
+    printf(" Field Address: 0x%p\n", dbChannelField(chan));
+    printf("    Field Size: %d\n", dbChannelFieldSize(chan));
+    printf("   No Elements: %ld\n", elements);
+    if (elements > MAX_ELEMS)
+        elements = MAX_ELEMS;
+    for (i = 0; i <= LAST_BUFFER_TYPE; i++) {
+        if (type == 0) {
+            if ((i != DBR_STRING) && (i != DBR_STS_STRING) &&
+                (i != DBR_TIME_STRING) && (i != DBR_GR_STRING) &&
+                (i != DBR_CTRL_STRING))
+                continue;
+        if (dbChannel_get(chan, i, tgf_buffer, elements, NULL) < 0)
+            printf("\t%s Failed\n", dbr_text[i]);
+        else
+            ca_dump_dbr(i, elements, tgf_buffer);
+    return 0;
  * TPF
  * Test put field
-int epicsShareAPI pft(char *pname,char *pvalue)
-	char			buffer[500];
-	short			shortvalue;
-	long			longvalue;
-	float			floatvalue;
-	unsigned char		charvalue;
-	double			doublevalue;
-	int status;
-	if (pname==0 || pvalue==0
-	  || ((*pname < ' ') || (*pname > 'z'))
-	  || ((*pvalue < ' ') || (*pvalue > 'z'))){
-		printf("\nusage \"pv name\",\"value\"\n");
-		return(1);
-	if(status) {
-		return(1);
-	if (db_put_field(paddr,DBR_STRING,pvalue,1) < 0) printf("\n\t failed ");
-	if (db_get_field(paddr,DBR_STRING,buffer,1,NULL) < 0) printf("\n\tfailed");
-	else ca_dump_dbr(DBR_STRING,1,buffer);
-	if(addr.dbr_field_type<=DBF_STRING || addr.dbr_field_type==DBF_ENUM)
-	  return(0);
-	if(sscanf(pvalue,"%hd",&shortvalue)==1) {
-	  if (db_put_field(paddr,DBR_SHORT,&shortvalue,1) < 0)
-		printf("\n\t SHORT failed ");
-	  if (db_get_field(paddr,DBR_SHORT,buffer,1,NULL) < 0)
-		printf("\n\t SHORT GET failed");
-	  else ca_dump_dbr(DBR_SHORT,1,buffer);
-	if(sscanf(pvalue,"%ld",&longvalue)==1) {
-	  if (db_put_field(paddr,DBR_LONG,&longvalue,1) < 0)
-		printf("\n\t LONG failed ");
-		if (db_get_field(paddr,DBR_LONG,buffer,1,NULL) < 0)
-		  printf("\n\t LONG GET failed");
-		else ca_dump_dbr(DBR_LONG,1,buffer);
-	if(epicsScanFloat(pvalue, &floatvalue)==1) {
-	  if (db_put_field(paddr,DBR_FLOAT,&floatvalue,1) < 0)
-		printf("\n\t FLOAT failed ");
-	  if (db_get_field(paddr,DBR_FLOAT,buffer,1,NULL) < 0)
-		printf("\n\t FLOAT GET failed");
-	  else ca_dump_dbr(DBR_FLOAT,1,buffer);
-	  doublevalue=floatvalue;
-	  if (db_put_field(paddr,DBR_DOUBLE,&doublevalue,1) < 0)
-			printf("\n\t DOUBLE failed ");
-	  if (db_get_field(paddr,DBR_DOUBLE,buffer,1,NULL) < 0)
-		printf("\n\t DOUBLE GET failed");
-	  else ca_dump_dbr(DBR_DOUBLE,1,buffer);
-	  charvalue=(unsigned char)shortvalue;
-	  if (db_put_field(paddr,DBR_CHAR,&charvalue,1) < 0)
-		printf("\n\t CHAR failed ");
-	  if (db_get_field(paddr,DBR_CHAR,buffer,1,NULL) < 0)
-		printf("\n\t CHAR GET failed");
-	  else ca_dump_dbr(DBR_CHAR,1,buffer);
-	  if (db_put_field(paddr,DBR_ENUM,&shortvalue,1) < 0)
-		printf("\n\t ENUM failed ");
-	  if (db_get_field(paddr,DBR_ENUM,buffer,1,NULL) < 0)
-		printf("\n\t ENUM GET failed");
-	  else ca_dump_dbr(DBR_ENUM,1,buffer);
-	printf("\n");
-	return(0);
-#if 0
- * PRINT_RETURNED
- * print out the values in a database access interface structure
-static void print_returned(type,count,pbuffer)
-  short	type;
-  char	*pbuffer;
-  short		count;
-    short i;
-    printf("%s\t",dbr_text[type]);
-    switch(type){
-	case (DBR_STRING):
-		for(i=0; i<count && *pbuffer!=0; i++) {
-			if(count!=1 && (i%5 == 0)) printf("\n");
-			printf("%s ",pbuffer);
-			pbuffer += MAX_STRING_SIZE;
-		break;
-	case (DBR_SHORT):
-	case (DBR_ENUM):
-		short *pvalue = (short *)pbuffer;
-		for (i = 0; i < count; i++,pvalue++){
-			if(count!=1 && (i%10 == 0)) printf("\n");
-			printf("%d ",*(short *)pvalue);
-		break;
-	case (DBR_FLOAT):
-		float *pvalue = (float *)pbuffer;
-			printf("%6.4f ",*(float *)pvalue);
-		break;
-	case (DBR_CHAR):
-		int	value;
-		for (i = 0; i < count; i++,pbuffer++){
-			value = *(unsigned char *)pbuffer;
-			printf("%d ",value);
-		break;
-	case (DBR_LONG):
-		long *pvalue = (long *)pbuffer;
-			printf("%ld ", (unsigned long)*pvalue);
-		break;
-	case (DBR_DOUBLE):
-		double *pvalue = (double *)pbuffer;
-			printf("%6.4f ",(float)(*pvalue));
-		break;
-	case (DBR_STS_STRING):
-	case (DBR_GR_STRING):
-	case (DBR_CTRL_STRING):
-		struct dbr_sts_string *pvalue
-		  = (struct dbr_sts_string *) pbuffer;
-		printf("%2d %2d",pvalue->status,pvalue->severity);
-		printf("\tValue: %s",pvalue->value);
-		break;
-	case (DBR_STS_ENUM):
-	case (DBR_STS_SHORT):
-		struct dbr_sts_short *pvalue
-		  = (struct dbr_sts_short *)pbuffer;
-		short *pshort = &pvalue->value;
-		if(count==1) printf("\tValue: ");
-		for (i = 0; i < count; i++,pshort++){
-			printf("%d ",*pshort);
-		break;
-	case (DBR_STS_FLOAT):
-		struct dbr_sts_float *pvalue
-		  = (struct dbr_sts_float *)pbuffer;
-		float *pfloat = &pvalue->value;
-		for (i = 0; i < count; i++,pfloat++){
-			printf("%6.4f ",*pfloat);
-		break;
-	case (DBR_STS_CHAR):
-		struct dbr_sts_char *pvalue
-		  = (struct dbr_sts_char *)pbuffer;
-		unsigned char *pchar = &pvalue->value;
-		short value;
-		for (i = 0; i < count; i++,pchar++){
-			value=*pchar;
-		break;
-	case (DBR_STS_LONG):
-		struct dbr_sts_long *pvalue
-		  = (struct dbr_sts_long *)pbuffer;
-		dbr_long_t *plong = &pvalue->value;
-		for (i = 0; i < count; i++,plong++){
-			printf("%d ",*plong);
-		break;
-	case (DBR_STS_DOUBLE):
-		struct dbr_sts_double *pvalue
-		  = (struct dbr_sts_double *)pbuffer;
-		double *pdouble = &pvalue->value;
-		for (i = 0; i < count; i++,pdouble++){
-			printf("%6.4f ",(float)(*pdouble));
-		break;
-	case (DBR_TIME_STRING):
-		struct dbr_time_string *pvalue
-		  = (struct dbr_time_string *) pbuffer;
-		printf("\tTimeStamp: %u %u",
-			pvalue->stamp.secPastEpoch, pvalue->stamp.nsec);
-		printf("\tValue: ");
-		printf("%s",pvalue->value);
-		break;
-	case (DBR_TIME_SHORT):
-	case (DBR_TIME_ENUM):
-		struct dbr_time_short *pvalue
-		  = (struct dbr_time_short *)pbuffer;
-		break;
-	case (DBR_TIME_FLOAT):
-		struct dbr_time_float *pvalue
-		  = (struct dbr_time_float *)pbuffer;
-		break;
-	case (DBR_TIME_CHAR):
-		struct dbr_time_char *pvalue
-		  = (struct dbr_time_char *)pbuffer;
-			printf("%d ",(short)(*pchar));
-		break;
-	case (DBR_TIME_LONG):
-		struct dbr_time_long *pvalue
-		  = (struct dbr_time_long *)pbuffer;
-		break;
-	case (DBR_TIME_DOUBLE):
-		struct dbr_time_double *pvalue
-		  = (struct dbr_time_double *)pbuffer;
-		break;
-	case (DBR_GR_SHORT):
-		struct dbr_gr_short *pvalue
-		  = (struct dbr_gr_short *)pbuffer;
-		printf("%2d %2d %.8s",pvalue->status,pvalue->severity,
-			pvalue->units);
-		printf("\n\t%8d %8d %8d %8d %8d %8d",
-		  pvalue->upper_disp_limit,pvalue->lower_disp_limit,
-		  pvalue->upper_alarm_limit,pvalue->upper_warning_limit,
-		  pvalue->lower_warning_limit,pvalue->lower_alarm_limit);
-		break;
-	case (DBR_GR_FLOAT):
-		struct dbr_gr_float *pvalue
-		  = (struct dbr_gr_float *)pbuffer;
-			pvalue->units);
-		printf(" %3d\n\t%8.3f %8.3f %8.3f %8.3f %8.3f %8.3f",
-		  pvalue->precision,
-		break;
-	case (DBR_GR_ENUM):
-	case (DBR_CTRL_ENUM):
-		struct dbr_gr_enum *pvalue
-		  = (struct dbr_gr_enum *)pbuffer;
-			pvalue->severity);
-		printf("\tValue: %d",pvalue->value);
-		if(pvalue->no_str>0) {
-			printf("\n\t%3d",pvalue->no_str);
-			for (i = 0; i < pvalue->no_str; i++)
-				printf("\n\t%.26s",pvalue->strs[i]);
-		break;
-	case (DBR_GR_CHAR):
-		struct dbr_gr_char *pvalue
-		  = (struct dbr_gr_char *)pbuffer;
-			pvalue->units);
-		break;
-	case (DBR_GR_LONG):
-		struct dbr_gr_long *pvalue
-		  = (struct dbr_gr_long *)pbuffer;
-			pvalue->units);
-		break;
-	case (DBR_GR_DOUBLE):
-		struct dbr_gr_double *pvalue
-		  = (struct dbr_gr_double *)pbuffer;
-			pvalue->units);
-		  (float)(pvalue->upper_disp_limit),
-		  (float)(pvalue->lower_disp_limit),
-		  (float)(pvalue->upper_alarm_limit),
-		  (float)(pvalue->upper_warning_limit),
-		  (float)(pvalue->lower_warning_limit),
-		  (float)(pvalue->lower_alarm_limit));
-		break;
-	case (DBR_CTRL_SHORT):
-		struct dbr_ctrl_short *pvalue
-		  = (struct dbr_ctrl_short *)pbuffer;
-			pvalue->units);
-		printf(" %8d %8d",
-		  pvalue->upper_ctrl_limit,pvalue->lower_ctrl_limit);
-		break;
-	case (DBR_CTRL_FLOAT):
-		struct dbr_ctrl_float *pvalue
-		  = (struct dbr_ctrl_float *)pbuffer;
-			pvalue->units);
-		printf(" %8.3f %8.3f",
-		break;
-	case (DBR_CTRL_CHAR):
-		struct dbr_ctrl_char *pvalue
-		  = (struct dbr_ctrl_char *)pbuffer;
-			pvalue->units);
-			printf("%4d ",(short)(*pchar));
-		break;
-	case (DBR_CTRL_LONG):
-		struct dbr_ctrl_long *pvalue
-		  = (struct dbr_ctrl_long *)pbuffer;
-			pvalue->units);
-		break;
-	case (DBR_CTRL_DOUBLE):
-		struct dbr_ctrl_double *pvalue
-		  = (struct dbr_ctrl_double *)pbuffer;
-			pvalue->units);
-		  (float)(pvalue->upper_ctrl_limit),
-		  (float)(pvalue->lower_ctrl_limit));
-			printf("%6.6f ",(float)(*pdouble));
-		break;
-	case (DBR_STSACK_STRING):
-		struct dbr_stsack_string *pvalue
-		  = (struct dbr_stsack_string *)pbuffer;
-		printf(" %2d %2d",pvalue->ackt,pvalue->acks);
-		printf(" %s",pvalue->value);
-		break;
-	case (DBR_CLASS_NAME):
-		printf(" %s",(char *)pbuffer);
-		break;
+int epicsShareAPI pft(char *pname, char *pvalue)
+    long elements;
+    short type;
+    char buffer[500];
+    short shortvalue;
+    long longvalue;
+    float floatvalue;
+    unsigned char charvalue;
+    double doublevalue;
+    if (!chan) {
+        return 1;
+    if (dbChannel_put(chan, DBR_STRING,pvalue, 1) < 0)
+        printf("\n\t failed ");
+    if (dbChannel_get(chan, DBR_STRING,buffer, 1, NULL) < 0)
+        printf("\n\tfailed");
+    else
+        ca_dump_dbr(DBR_STRING,1, buffer);
+    if (type <= DBF_STRING || type == DBF_ENUM)
+        return 0;
+    if (sscanf(pvalue, "%hd", &shortvalue) == 1) {
+        if (dbChannel_put(chan, DBR_SHORT,&shortvalue, 1) < 0)
+            printf("\n\t SHORT failed ");
+        if (dbChannel_get(chan, DBR_SHORT,buffer, 1, NULL) < 0)
+            printf("\n\t SHORT GET failed");
+        else
+            ca_dump_dbr(DBR_SHORT,1, buffer);
+    if (sscanf(pvalue, "%ld", &longvalue) == 1) {
+        if (dbChannel_put(chan, DBR_LONG,&longvalue, 1) < 0)
+            printf("\n\t LONG failed ");
+        if (dbChannel_get(chan, DBR_LONG,buffer, 1, NULL) < 0)
+            printf("\n\t LONG GET failed");
+        else
+            ca_dump_dbr(DBR_LONG,1, buffer);
+    if (epicsScanFloat(pvalue, &floatvalue) == 1) {
+        if (dbChannel_put(chan, DBR_FLOAT,&floatvalue, 1) < 0)
+            printf("\n\t FLOAT failed ");
+        if (dbChannel_get(chan, DBR_FLOAT,buffer, 1, NULL) < 0)
+            printf("\n\t FLOAT GET failed");
+        else
+            ca_dump_dbr(DBR_FLOAT,1, buffer);
+        doublevalue = floatvalue;
+        if (dbChannel_put(chan, DBR_DOUBLE,&doublevalue, 1) < 0)
+            printf("\n\t DOUBLE failed ");
+        if (dbChannel_get(chan, DBR_DOUBLE,buffer, 1, NULL) < 0)
+            printf("\n\t DOUBLE GET failed");
+        else
+            ca_dump_dbr(DBR_DOUBLE,1, buffer);
+        charvalue = (unsigned char) shortvalue;
+        if (dbChannel_put(chan, DBR_CHAR,&charvalue, 1) < 0)
+            printf("\n\t CHAR failed ");
+        if (dbChannel_get(chan, DBR_CHAR,buffer, 1, NULL) < 0)
+            printf("\n\t CHAR GET failed");
+        else
+            ca_dump_dbr(DBR_CHAR,1, buffer);
+        if (dbChannel_put(chan, DBR_ENUM,&shortvalue, 1) < 0)
+            printf("\n\t ENUM failed ");
+        if (dbChannel_get(chan, DBR_ENUM,buffer, 1, NULL) < 0)
+            printf("\n\t ENUM GET failed");
+        else
+            ca_dump_dbr(DBR_ENUM,1, buffer);
     printf("\n");
+    return (0);
-#endif
-    putNotify    *ppn;
-}tpnInfo;
+    putNotify *ppn;
+} tpnInfo;
 static void tpnCallback(putNotify *ppn)
-    struct dbAddr   *pdbaddr = (struct dbAddr *)ppn->paddr;
-    char	    *pname = pdbaddr->precord->name;
-    if(status==0)
-	printf("tpnCallback: success record=%s\n",pname);
+    if (status == 0)
+        printf("tpnCallback: success record=%s\n", pname);
     else
-        printf("%s tpnCallback status = %d\n",pname,status);
+        printf("%s tpnCallback status = %d\n", pname, status);
     dbPutNotify(ppn);
     free(ppn);
     free(ptpnInfo);
-int epicsShareAPI tpn(char	*pname,char *pvalue)
+int epicsShareAPI tpn(char *pname, char *pvalue)
-    long	   status;
-    struct dbAddr *pdbaddr=NULL;
-    char	   *psavevalue;
-    int		   len;
-    	return(1);
-    pdbaddr = calloc(1,sizeof(struct dbAddr) + len+1);
-    if(!pdbaddr) {
-	printf("calloc failed\n");
-	return(-1);
-    status = db_name_to_addr(pname,pdbaddr);
-    if(status) {
-	return(-1);
-    ppn = calloc(1,sizeof(putNotify));
-    if(!pdbaddr) {
-	return(-1);
+    putNotify *ppn;
+    char *pbuffer;
+    if (!chan) {
+        return 1;
+    ppn = calloc(1, sizeof(putNotify));
+    if (!ppn) {
+        printf("calloc failed\n");
+        return -1;
+    ppn->chan = chan;
     ppn->nRequest = 1;
-    if(dbPutNotifyMapType(ppn,DBR_STRING)) {
-	printf("dbPutNotifyMapType failed\n");
-	return(-1);
+    if (dbPutNotifyMapType(ppn, DBR_STRING)) {
+        printf("dbPutNotifyMapType failed\n");
+        return -1;
     ppn->userCallback = tpnCallback;
-    ptpnInfo = calloc(1,sizeof(tpnInfo));
-    if(!ptpnInfo) {
-	return(-1);
+    ptpnInfo = calloc(1, sizeof(tpnInfo));
+    if (!ptpnInfo) {
+        return -1;
-    epicsThreadCreate("tpn",epicsThreadPriorityHigh,
-    return(0);
+    epicsThreadCreate("tpn", epicsThreadPriorityHigh,
+    return 0;
=== added directory 'src/ioc/db/filters'
=== added file 'src/ioc/db/filters/arr.c'
--- src/ioc/db/filters/arr.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/filters/arr.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,205 @@
+ *  Author: Ralph Lange <[email protected]>
+#include <stdio.h>
+#include <epicsExport.h>
+#include <freeList.h>
+#include <dbAccess.h>
+#include <dbExtractArray.h>
+#include <db_field_log.h>
+#include <recSup.h>
+#include <special.h>
+#include <chfPlugin.h>
+typedef struct myStruct {
+    epicsInt32 start;
+    epicsInt32 incr;
+    epicsInt32 end;
+    void *arrayFreeList;
+    long no_elements;
+} myStruct;
+static void *myStructFreeList;
+static const
+chfPluginArgDef opts[] = {
+    chfInt32 (myStruct, start, "s", 0, 1),
+    chfInt32 (myStruct, incr, "i", 0, 1),
+    chfInt32 (myStruct, end, "e", 0, 1),
+    chfPluginArgEnd
+static void * allocPvt(void)
+    myStruct *my = (myStruct*) freeListCalloc(myStructFreeList);
+    my->incr = 1;
+    my->end = -1;
+    return (void *) my;
+static void freePvt(void *pvt)
+    myStruct *my = (myStruct*) pvt;
+    if (my->arrayFreeList) freeListCleanup(my->arrayFreeList);
+    freeListFree(myStructFreeList, pvt);
+static int parse_ok(void *pvt)
+    if (my->incr <= 0) my->incr = 1;
+    return 0;
+static void freeArray(db_field_log *pfl) {
+    if (pfl->type == dbfl_type_ref) {
+        freeListFree(pfl->u.r.pvt, pfl->u.r.field);
+static long wrapArrayIndices(long *start, const long increment, long *end, const long no_elements) {
+    long len = 0;
+    if (*start < 0) *start = no_elements + *start;
+    if (*start < 0) *start = 0;
+    if (*start > no_elements) *start = no_elements;
+    if (*end < 0) *end = no_elements + *end;
+    if (*end < 0) *end = 0;
+    if (*end >= no_elements) *end = no_elements - 1;
+    if (*end - *start >= 0) len = 1 + (*end - *start) / increment;
+    return len;
+static db_field_log* filter(void* pvt, dbChannel *chan, db_field_log *pfl) {
+    struct dbCommon *prec;
+    struct rset *prset;
+    long start = my->start;
+    long end = my->end;
+    long nTarget = 0;
+    long offset = 0;
+    long status;
+    long nSource = chan->addr.no_elements;
+    /* Only array data */
+    if (pfl->type == dbfl_type_val) {
+        return pfl;
+    /* Extract from record */
+    } else if (pfl->type == dbfl_type_rec) {
+        if (chan->addr.special == SPC_DBADDR &&
+            nSource > 1 &&
+            (prset = dbGetRset(&chan->addr)) &&
+            prset->get_array_info) {
+            status = prset->get_array_info(&chan->addr, &nSource, &offset);
+            nTarget = wrapArrayIndices(&start, my->incr, &end, nSource);
+            prec = dbChannelRecord(chan);
+            pfl->type = dbfl_type_ref;
+            pfl->stat = prec->stat;
+            pfl->sevr = prec->sevr;
+            pfl->time = prec->time;
+            pfl->field_type = chan->addr.field_type;
+            pfl->field_size = chan->addr.field_size;
+            pfl->no_elements = nTarget;
+            if (nTarget) {
+                pfl->u.r.dtor = freeArray;
+                pfl->u.r.pvt = my->arrayFreeList;
+                void *pdst = freeListCalloc(my->arrayFreeList);
+                offset = (offset + start) % chan->addr.no_elements;
+                dbExtractArrayFromRec(&chan->addr, pdst, nTarget, nSource, offset, my->incr);
+                pfl->u.r.field = pdst;
+    /* Extract from buffer */
+    } else if (pfl->type == dbfl_type_ref) {
+        nSource = pfl->no_elements;
+        void *psrc = pfl->u.r.field;
+        void *pdst = NULL;
+        if (nTarget) {                                        /* Copy the data out */
+            pdst = freeListCalloc(my->arrayFreeList);
+            offset = start;
+            dbExtractArrayFromBuf(psrc, pdst, pfl->field_size, pfl->field_type, nTarget, nSource, offset, my->incr);
+        if (pfl->u.r.dtor) pfl->u.r.dtor(pfl);
+        if (nTarget) {
+    return pfl;
+static void channelRegisterPost(dbChannel *chan, void *pvt,
+                                chPostEventFunc **cb_out, void **arg_out, db_field_log *probe)
+    long max = 0;
+    if (probe->no_elements <= 1) return;                                    /* array data only */
+    max = wrapArrayIndices(&start, my->incr, &end, probe->no_elements);     /* wrap indices into array */
+    if (max) {
+        if (!my->arrayFreeList)
+            freeListInitPvt(&my->arrayFreeList, max * probe->field_size, 2);
+        if (!my->arrayFreeList) return;
+    probe->no_elements = my->no_elements = max;
+    *cb_out = filter;
+    *arg_out = pvt;
+static void channel_report(dbChannel *chan, void *pvt, int level, const unsigned short indent)
+    printf("%*s  plugin arr, start=%d, incr=%d, end=%d\n", indent, "",
+           my->start, my->incr, my->end);
+static chfPluginIf pif = {
+    allocPvt,
+    freePvt,
+    NULL, /* parse_error, */
+    parse_ok,
+    NULL, /* channel_open, */
+    NULL, /* channelRegisterPre, */
+    channelRegisterPost,
+    channel_report,
+    NULL /* channel_close */
+static void arrInitialize(void)
+    static int firstTime = 1;
+    if (!firstTime) return;
+    firstTime = 0;
+    if (!myStructFreeList)
+        freeListInitPvt(&myStructFreeList, sizeof(myStruct), 64);
+    chfPluginRegister("arr", &pif, opts);
+epicsExportRegistrar(arrInitialize);
=== added file 'src/ioc/db/filters/dbnd.c'
--- src/ioc/db/filters/dbnd.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/filters/dbnd.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,142 @@
+#include <stdio.h>
+#include <epicsMath.h>
+#include <dbConvertFast.h>
+    int    mode;
+    double cval;
+    double hyst;
+    double last;
+} myStruct;
+static const
+chfPluginEnumType modeEnum[] = { {"abs", 0}, {"rel", 1}, {NULL,0} };
+static const
+    chfDouble (myStruct, cval, "d", 0, 1),
+    chfEnum   (myStruct, mode, "m", 0, 1, modeEnum),
+    chfPluginArgEnd
+    return freeListCalloc(myStructFreeList);
+    my->hyst = my->cval;
+    my->last = epicsNAN;
+    return 0;
+static void shiftval (myStruct *my, double val) {
+    my->last = val;
+    if (my->mode == 1)
+        my->hyst = val * my->cval/100.;
+    long status;
+    double val, delta;
+    short drop = 0;
+     * Only scalar values supported - strings, arrays, and conversion errors
+     * are just passed on
+        DBADDR localAddr = chan->addr; /* Structure copy */
+        localAddr.field_type = pfl->field_type;
+        localAddr.field_size = pfl->field_size;
+        localAddr.no_elements = pfl->no_elements;
+        localAddr.pfield = (char *) &pfl->u.v.field;
+        status = dbFastGetConvertRoutine[pfl->field_type][DBR_DOUBLE]
+                 (localAddr.pfield, (void*) &val, &localAddr);
+        if (!status) {
+            if (isnan(my->last)) {
+                shiftval(my, val);
+            } else {
+                delta = fabs(my->last - val);
+                if (delta <= my->hyst) {
+                    drop = 1;
+                } else {
+    if (drop) return NULL;
+    else return pfl;
+static void channelRegisterPre(dbChannel *chan, void *pvt,
+    *cb_out = filter;
+    *arg_out = pvt;
+    printf("%*s  plugin dbnd, mode=%s, delta=%g%s\n", indent, "",
+           chfPluginEnumString(modeEnum, my->mode, "n/a"), my->cval,
+           my->mode == 1 ? "%" : "");
+    allocPvt,
+    freePvt,
+    parse_ok,
+    channelRegisterPre,
+    NULL, /* channelRegisterPost, */
+    channel_report,
+static void dbndInitialize(void)
+    firstTime = 0;
+    chfPluginRegister("dbnd", &pif, opts);
+epicsExportRegistrar(dbndInitialize);
=== added file 'src/ioc/db/filters/filters.dbd'
--- src/ioc/db/filters/filters.dbd	1970-01-01 00:00:00 +0000
+++ src/ioc/db/filters/filters.dbd	2012-05-30 18:10:27 +0000
@@ -0,0 +1,4 @@
+registrar(tsInitialize)
+registrar(dbndInitialize)
+registrar(arrInitialize)
+registrar(syncInitialize)
=== added file 'src/ioc/db/filters/sync.c'
--- src/ioc/db/filters/sync.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/filters/sync.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,170 @@
+#include <stdio.h>
+#include "epicsExport.h"
+#include "freeList.h"
+#include "db_field_log.h"
+#include "chfPlugin.h"
+#include "dbState.h"
+#define STATE_NAME_LENGTH 20
+static const
+chfPluginEnumType modeEnum[] = { {"before", 0}, {"first", 1},
+                                 {"last", 2}, {"after", 3},
+                                 {"while", 4}, {"unless", 5},
+                                 {NULL,0} };
+typedef enum syncMode {
+    syncModeBefore=0,
+    syncModeFirst=1,
+    syncModeLast=2,
+    syncModeAfter=3,
+    syncModeWhile=4,
+    syncModeUnless=5
+} syncMode;
+    syncMode mode;
+    char state[STATE_NAME_LENGTH];
+    dbStateId id;
+    db_field_log *lastfl;
+    int laststate:1;
+} myStruct;
+static const
+    chfEnum   (myStruct, mode,  "m", 1, 1, modeEnum),
+    chfString (myStruct, state, "s", 1, 0),
+    chfPluginArgEnd
+    if (!(my->id = dbStateFind(my->state)))
+        return -1;
+    return 0;
+    if (pfl->ctx == dbfl_context_read)
+        return pfl;
+    db_field_log *passfl = NULL;
+    int actstate = dbStateGet(my->id);
+    switch (my->mode) {
+    case syncModeBefore:
+        if (actstate && !my->laststate) {
+            passfl = my->lastfl;
+            my->lastfl = NULL;
+        break;
+    case syncModeFirst:
+            passfl = pfl;
+            pfl = NULL;
+        break;
+    case syncModeLast:
+        if (!actstate && my->laststate) {
+        break;
+    case syncModeAfter:
+            passfl = pfl;
+            pfl = NULL;
+        break;
+    case syncModeWhile:
+        if (actstate) {
+            passfl = pfl;
+        goto no_shift;
+    case syncModeUnless:
+        if (!actstate) {
+            passfl = pfl;
+        goto no_shift;
+    if (my->lastfl)
+        db_delete_field_log(my->lastfl);
+    my->lastfl = pfl;
+    my->laststate = actstate;
+    no_shift:
+    return passfl;
+    *cb_out = filter;
+    *arg_out = pvt;
+    printf("%*s  plugin sync, mode=%s, state=%s\n", indent, "",
+           chfPluginEnumString(modeEnum, my->mode, "n/a"), my->state);
+    allocPvt,
+    freePvt,
+    parse_ok,
+    channel_report,
+static void syncInitialize(void)
+    firstTime = 0;
+    chfPluginRegister("sync", &pif, opts);
+epicsExportRegistrar(syncInitialize);
=== added directory 'src/ioc/db/filters/test'
=== added file 'src/ioc/db/filters/test/Makefile'
--- src/ioc/db/filters/test/Makefile	1970-01-01 00:00:00 +0000
+++ src/ioc/db/filters/test/Makefile	2012-05-30 18:10:27 +0000
@@ -0,0 +1,47 @@
+# Copyright (c) 2006 UChicago Argonne LLC, as Operator of Argonne
+#     National Laboratory.
+# Copyright (c) 2002 The Regents of the University of California, as
+#     Operator of Los Alamos National Laboratory.
+# EPICS BASE is distributed subject to a Software License Agreement found
+# in the file LICENSE that is included with this distribution.
+TOP=../../../../..
+include $(TOP)/configure/CONFIG
+PROD_LIBS += dbCore ca Com
+TESTPROD_HOST += tsTest
+tsTest_SRCS += tsTest.c xRecord_registerRecordDeviceDriver.cpp
+OBJS_IOC_vxWorks += tsTest
+TESTS += tsTest
+TESTPROD_HOST += dbndTest
+dbndTest_SRCS += dbndTest.c xRecord_registerRecordDeviceDriver.cpp
+OBJS_IOC_vxWorks += dbndTest
+TESTS += dbndTest
+TARGETS += $(COMMON_DIR)/arrTest.dbd
+arrTest_DBD += arrRecord.dbd
+TESTPROD_HOST += arrTest
+arrTest_SRCS += arrTest.cpp arrRecord.c arrRecord_registerRecordDeviceDriver.cpp
+OBJS_IOC_vxWorks += arrTest
+TESTS += arrTest
+TESTPROD_HOST += syncTest
+syncTest_SRCS += syncTest.c xRecord_registerRecordDeviceDriver.cpp
+OBJS_IOC_vxWorks += syncTest
+TESTS += syncTest
+TESTSCRIPTS_HOST += $(TESTS:%=%.t)
+include $(TOP)/configure/RULES
+$(COMMON_DIR)/xRecord.dbd: ../../../test/xRecord.dbd
+	$(INSTALL) -d $< $(@D)
+tsTest$(OBJ): $(COMMON_DIR)/xRecord.h
+dbndTest$(OBJ): $(COMMON_DIR)/xRecord.h
+syncTest$(OBJ): $(COMMON_DIR)/xRecord.h
+arrTest$(OBJ): $(COMMON_DIR)/arrRecord.h
=== added file 'src/ioc/db/filters/test/arrRecord.c'
--- src/ioc/db/filters/test/arrRecord.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/filters/test/arrRecord.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,135 @@
+* Copyright (c) 2008 UChicago Argonne LLC, as Operator of Argonne
+*     National Laboratory.
+* Copyright (c) 2002 The Regents of the University of California, as
+*     Operator of Los Alamos National Laboratory.
+/* arrRecord.c - minimal array record for test purposes: no processing */
+ * vaguely implemented like parts of recWaveform.c by Bob Dalesio
+#include <stdio.h>
+#include "epicsPrint.h"
+#include "dbAccess.h"
+#include "dbEvent.h"
+#include "dbFldTypes.h"
+#include "recSup.h"
+#include "recGbl.h"
+#include "cantProceed.h"
+#define GEN_SIZE_OFFSET
+#include "arrRecord.h"
+#undef  GEN_SIZE_OFFSET
+/* Create RSET - Record Support Entry Table*/
+#define report NULL
+#define initialize NULL
+static long init_record(arrRecord *, int);
+static long process(arrRecord *);
+#define special NULL
+#define get_value NULL
+static long cvt_dbaddr(DBADDR *);
+static long get_array_info(DBADDR *, long *, long *);
+static long put_array_info(DBADDR *, long);
+#define get_units NULL
+#define get_precision NULL
+#define get_enum_str NULL
+#define get_enum_strs NULL
+#define put_enum_str NULL
+#define get_graphic_double NULL
+#define get_control_double NULL
+#define get_alarm_double NULL
+rset arrRSET = {
+        RSETNUMBER,
+        report,
+        initialize,
+        init_record,
+        process,
+        special,
+        get_value,
+        cvt_dbaddr,
+        get_array_info,
+        put_array_info,
+        get_units,
+        get_precision,
+        get_enum_str,
+        get_enum_strs,
+        put_enum_str,
+        get_graphic_double,
+        get_control_double,
+        get_alarm_double
+epicsExportAddress(rset, arrRSET);
+static long init_record(arrRecord *prec, int pass)
+    if (pass == 0) {
+        if (prec->nelm <= 0)
+            prec->nelm = 1;
+        if (prec->ftvl > DBF_ENUM)
+            prec->ftvl = DBF_UCHAR;
+        prec->bptr = callocMustSucceed(prec->nelm, dbValueSize(prec->ftvl),
+            "arr calloc failed");
+        if (prec->nelm == 1) {
+            prec->nord = 1;
+        } else {
+            prec->nord = 0;
+        return 0;
+    return 0;
+static long process(arrRecord *prec)
+    return 0;
+static long cvt_dbaddr(DBADDR *paddr)
+    arrRecord *prec = (arrRecord *) paddr->precord;
+    paddr->pfield = prec->bptr;
+    paddr->no_elements = prec->nelm;
+    paddr->field_type = prec->ftvl;
+    paddr->field_size = dbValueSize(prec->ftvl);
+    paddr->dbr_field_type = prec->ftvl;
+    return 0;
+static long get_array_info(DBADDR *paddr, long *no_elements, long *offset)
+    *no_elements = prec->nord;
+    *offset = prec->off;
+    return 0;
+static long put_array_info(DBADDR *paddr, long nNew)
+    prec->nord = nNew;
+    if (prec->nord > prec->nelm)
+        prec->nord = prec->nelm;
+    return 0;
=== added file 'src/ioc/db/filters/test/arrRecord.dbd'
--- src/ioc/db/filters/test/arrRecord.dbd	1970-01-01 00:00:00 +0000
+++ src/ioc/db/filters/test/arrRecord.dbd	2012-05-30 18:10:27 +0000
@@ -0,0 +1,33 @@
+include "menuGlobal.dbd"
+include "menuConvert.dbd"
+recordtype(arr) {
+  include "dbCommon.dbd"
+  field(VAL, DBF_NOACCESS) {
+    prompt("Value")
+    special(SPC_DBADDR)
+    pp(TRUE)
+    extra("void *val")
+  field(NELM, DBF_ULONG) {
+    prompt("Number of Elements")
+    special(SPC_NOMOD)
+    initial("1")
+  field(FTVL, DBF_MENU) {
+    prompt("Field Type of Value")
+    menu(menuFtype)
+  field(NORD, DBF_ULONG) {
+    prompt("Number elements read")
+  field(OFF, DBF_ULONG) {
+    prompt("Offset into array")
+  field(BPTR, DBF_NOACCESS) {
+    prompt("Buffer Pointer")
+    extra("void *bptr")
=== added file 'src/ioc/db/filters/test/arrTest.cpp'
--- src/ioc/db/filters/test/arrTest.cpp	1970-01-01 00:00:00 +0000
+++ src/ioc/db/filters/test/arrTest.cpp	2012-05-30 18:10:27 +0000
@@ -0,0 +1,337 @@
+* Copyright (c) 2003 The Regents of the University of California, as
+* EPICS BASE is distributed subject to the Software License Agreement
+* found in the file LICENSE that is included with this distribution.
+/* using stuff from softIoc.cpp by Andrew Johnson */
+#include <stddef.h>
+#include <stdlib.h>
+#include <string.h>
+#include <stdio.h>
+#include "registryFunction.h"
+#include "epicsThread.h"
+#include "epicsExit.h"
+#include "epicsStdio.h"
+#include "envDefs.h"
+#include "dbStaticLib.h"
+#include "subRecord.h"
+#include "dbAddr.h"
+#include "asDbLib.h"
+#include "iocInit.h"
+#include "iocsh.h"
+#include "dbChannel.h"
+#include "epicsUnitTest.h"
+#include "testMain.h"
+extern "C" int arrRecord_registerRecordDeviceDriver(struct dbBase *pdbbase);
+extern "C" void (*pvar_func_arrInitialize)(void);
+#define CA_SERVER_PORT "65535"
+#define PATTERN 0x55
+const char *server_port = CA_SERVER_PORT;
+static void exitSubroutine(subRecord *precord) {
+    epicsExit((precord->a == 0.0) ? EXIT_SUCCESS : EXIT_FAILURE);
+static int fl_equals_array(short type, const db_field_log *pfl1, void *p2) {
+    for (int i = 0; i < pfl1->no_elements; i++) {
+        switch (type) {
+        case DBR_DOUBLE:
+            if (((epicsFloat64*)pfl1->u.r.field)[i] != ((epicsInt32*)p2)[i]) {
+                testDiag("at index=%d: field log has %g, should be %d",
+                         i, ((epicsFloat64*)pfl1->u.r.field)[i], ((epicsInt32*)p2)[i]);
+                return 0;
+            break;
+        case DBR_LONG:
+            if (((epicsInt32*)pfl1->u.r.field)[i] != ((epicsInt32*)p2)[i]) {
+                testDiag("at index=%d: field log has %d, should be %d",
+                         i, ((epicsInt32*)pfl1->u.r.field)[i], ((epicsInt32*)p2)[i]);
+                return 0;
+            break;
+        case DBR_STRING:
+            if (strtol(&((const char*)pfl1->u.r.field)[i*MAX_STRING_SIZE], NULL, 0) != ((epicsInt32*)p2)[i]) {
+                testDiag("at index=%d: field log has '%s', should be '%d'",
+                         i, &((const char*)pfl1->u.r.field)[i*MAX_STRING_SIZE], ((epicsInt32*)p2)[i]);
+                return 0;
+            break;
+        default:
+            return 0;
+    return 1;
+static void createAndOpen(const char *chan, const char *json, const char *type, dbChannel**pch, short no) {
+    ELLNODE *node;
+    chFilter *filter;
+    char name[80];
+    strncpy(name, chan, sizeof(name)-1);
+    strncat(name, json, sizeof(name)-strlen(name)-1);
+    testOk(!!(*pch = dbChannelCreate(name)), "dbChannel with plugin arr %s created", type);
+    testOk((ellCount(&(*pch)->filters) == no), "channel has %d filter(s) in filter list", no);
+    testOk(!(dbChannelOpen(*pch)), "dbChannel with plugin arr opened");
+    node = ellFirst(&(*pch)->pre_chain);
+    filter = CONTAINER(node, chFilter, pre_node);
+    testOk((ellCount(&(*pch)->pre_chain) == 0), "arr has no filter in pre chain");
+    node = ellFirst(&(*pch)->post_chain);
+    filter = CONTAINER(node, chFilter, post_node);
+    testOk((ellCount(&(*pch)->post_chain) == no),
+           "arr has %d filter(s) in post chain", no);
+static void testHead (const char *title, const char *typ = "") {
+    const char *line = "------------------------------------------------------------------------------";
+    testDiag(line);
+    testDiag(title, typ);
+    testDiag(line);
+#define TEST1(Size, Offset, Incr, Text) \
+    testDiag("Offset: %d (%s)", Offset, Text); \
+    off = Offset; \
+    status = dbPutField(&offaddr, DBR_LONG, &off, 1); \
+    pfl = db_create_read_log(pch); \
+    testOk(pfl->type == dbfl_type_rec, "original field log has type rec"); \
+    pfl2 = dbChannelRunPostChain(pch, pfl); \
+    testOk(pfl2 == pfl, "call does not drop or replace field_log"); \
+    testOk(pfl->type == dbfl_type_ref, "filtered field log has type ref"); \
+    testOk(fl_equals_array(dbr_type, pfl2, ar##Size##_##Offset##_##Incr), "array data correct"); \
+    db_delete_field_log(pfl);
+static void check(short dbr_type) {
+    dbChannel *pch;
+    db_field_log *pfl, *pfl2;
+    int status;
+    dbAddr valaddr;
+    dbAddr offaddr;
+    const char *offname = NULL, *valname = NULL, *typname = NULL;
+    long ar[10] = {10,11,12,13,14,15,16,17,18,19};
+    long *ar10_0_1 = ar;
+    long ar10_4_1[10] = {14,15,16,17,18,19,10,11,12,13};
+    long ar5_0_1[10] = {12,13,14,15,16};
+    long ar5_3_1[10] = {15,16,17,18,19};
+    long ar5_5_1[10] = {17,18,19,10,11};
+    long ar5_9_1[10] = {11,12,13,14,15};
+    long ar5_0_2[10] = {12,14,16};
+    long ar5_3_2[10] = {15,17,19};
+    long ar5_5_2[10] = {17,19,11};
+    long ar5_9_2[10] = {11,13,15};
+    long ar5_0_3[10] = {12,15};
+    long ar5_3_3[10] = {15,18};
+    long ar5_5_3[10] = {17,10};
+    long ar5_9_3[10] = {11,14};
+    long off = 0;
+    switch (dbr_type) {
+    case DBR_LONG:
+        offname = "x.OFF";
+        valname = "x.VAL";
+        typname = "long";
+        break;
+    case DBR_DOUBLE:
+        offname = "y.OFF";
+        valname = "y.VAL";
+        typname = "double";
+        break;
+    case DBR_STRING:
+        offname = "z.OFF";
+        valname = "z.VAL";
+        typname = "string";
+        break;
+    default:
+        testDiag("Invalid data type %d", dbr_type);
+    status = dbNameToAddr(offname, &offaddr);
+    status = dbNameToAddr(valname, &valaddr);
+    status = dbPutField(&valaddr, DBR_LONG, ar, 10);
+    /* Default: should not change anything */
+    testHead("Ten %s elements from rec, increment 1, full size (default)", typname);
+    createAndOpen(valname, "{\"arr\":{}}", "(default)", &pch, 1);
+    testOk(pch->final_type == valaddr.field_type,
+           "final type unchanged (%d->%d)", valaddr.field_type, pch->final_type);
+    testOk(pch->final_no_elements == valaddr.no_elements,
+           "final no_elements unchanged (%ld->%ld)", valaddr.no_elements, pch->final_no_elements);
+    TEST1(10, 0, 1, "no offset");
+    TEST1(10, 4, 1, "wrapped");
+    dbChannelDelete(pch);
+    testHead("Ten %s elements from rec, increment 1, out-of-bound start parameter", typname);
+    createAndOpen(valname, "{\"arr\":{\"s\":-500}}", "out-of-bound start", &pch, 1);
+    testHead("Ten %s elements from rec, increment 1, out-of-bound end parameter", typname);
+    createAndOpen(valname, "{\"arr\":{\"e\":500}}", "out-of-bound end", &pch, 1);
+    testHead("Ten %s elements from rec, increment 1, zero increment parameter", typname);
+    createAndOpen(valname, "{\"arr\":{\"i\":0}}", "zero increment", &pch, 1);
+    testHead("Ten %s elements from rec, increment 1, invalid increment parameter", typname);
+    createAndOpen(valname, "{\"arr\":{\"i\":-30}}", "invalid increment", &pch, 1);
+#define TEST5(Incr, Left, Right, Type) \
+    testHead("Five %s elements from rec, increment " #Incr ", " Type " addressing", typname); \
+    createAndOpen(valname, "{\"arr\":{\"s\":" #Left ",\"e\":" #Right ",\"i\":" #Incr "}}", \
+                  "(" #Left ":" #Incr ":" #Right ")", &pch, 1); \
+    testOk(pch->final_type == valaddr.field_type, \
+           "final type unchanged (%d->%d)", valaddr.field_type, pch->final_type); \
+    testOk(pch->final_no_elements == 4 / Incr + 1, \
+           "final no_elements correct (%ld->%ld)", valaddr.no_elements, pch->final_no_elements); \
+    TEST1(5, 0, Incr, "no offset"); \
+    TEST1(5, 3, Incr, "from upper block"); \
+    TEST1(5, 5, Incr, "wrapped"); \
+    TEST1(5, 9, Incr, "from lower block"); \
+    /* Contiguous block of 5 */
+    TEST5(1,  2,  6, "regular");
+    TEST5(1, -8,  6, "left side from-end");
+    TEST5(1,  2, -4, "right side from-end");
+    TEST5(1, -8, -4, "both sides from-end");
+    /* 5 elements with increment 2 */
+    TEST5(2,  2,  6, "regular");
+    TEST5(2, -8,  6, "left side from-end");
+    TEST5(2,  2, -4, "right side from-end");
+    TEST5(2, -8, -4, "both sides from-end");
+    /* 5 elements with increment 3 */
+    TEST5(3,  2,  6, "regular");
+    TEST5(3, -8,  6, "left side from-end");
+    TEST5(3,  2, -4, "right side from-end");
+    TEST5(3, -8, -4, "both sides from-end");
+    /* From buffer (plugin chain) */
+#define TEST5B(Incr, Left, Right, Type) \
+    testHead("Five %s elements from buffer, increment " #Incr ", " Type " addressing", typname); \
+    createAndOpen(valname, "{\"arr\":{},\"arr\":{\"s\":" #Left ",\"e\":" #Right ",\"i\":" #Incr "}}", \
+                  "(" #Left ":" #Incr ":" #Right ")", &pch, 2); \
+    TEST5B(1,  2,  6, "regular");
+    TEST5B(1, -8,  6, "left side from-end");
+    TEST5B(1,  2, -4, "right side from-end");
+    TEST5B(1, -8, -4, "both sides from-end");
+    TEST5B(2,  2,  6, "regular");
+    TEST5B(2, -8,  6, "left side from-end");
+    TEST5B(2,  2, -4, "right side from-end");
+    TEST5B(2, -8, -4, "both sides from-end");
+    TEST5B(3,  2,  6, "regular");
+    TEST5B(3, -8,  6, "left side from-end");
+    TEST5B(3,  2, -4, "right side from-end");
+    TEST5B(3, -8, -4, "both sides from-end");
+MAIN(arrTest)
+    const chFilterPlugin *plug;
+    char arr[] = "arr";
+    int status;
+    testPlan(1404);
+    /* Prepare the IOC */
+    epicsEnvSet("EPICS_CA_SERVER_PORT", server_port);
+    testOk1(!(status=dbReadDatabase(&pdbbase, "arrRecord.dbd", ".:..:../../../../../../dbd", NULL)));
+    if (status) epicsExit(EXIT_FAILURE);
+    (*pvar_func_arrInitialize)();
+    arrRecord_registerRecordDeviceDriver(pdbbase);
+    registryFunctionAdd("exit", (REGISTRYFUNCTION) exitSubroutine);
+    testOk1(!(status=dbReadDatabase(&pdbbase, "arrTest.db", ".:..", NULL)));
+    /* Start the IOC */
+    iocInit();
+    db_init_events();
+    epicsThreadSleep(0.2);
+    testOk(!!(plug = dbFindFilter(arr, strlen(arr))), "plugin arr registered correctly");
+    check(DBR_LONG);
+    check(DBR_DOUBLE);
+    check(DBR_STRING);
+    dbFreeBase(pdbbase);
+    return testDone();
+    epicsExit(EXIT_SUCCESS);
+    /*Note that the following statement will never be executed*/
+    return 0;
=== added file 'src/ioc/db/filters/test/arrTest.db'
--- src/ioc/db/filters/test/arrTest.db	1970-01-01 00:00:00 +0000
+++ src/ioc/db/filters/test/arrTest.db	2012-05-30 18:10:27 +0000
@@ -0,0 +1,15 @@
+record(arr, "x") {
+    field(DESC, "test array record")
+    field(NELM, "10")
+    field(FTVL, "LONG")
+record(arr, "y") {
+    field(NELM, "10")
+    field(FTVL, "DOUBLE")
+record(arr, "z") {
+    field(NELM, "10")
+    field(FTVL, "STRING")
=== added file 'src/ioc/db/filters/test/dbndTest.c'
--- src/ioc/db/filters/test/dbndTest.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/filters/test/dbndTest.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,228 @@
+#include "dbAccessDefs.h"
+#include "dbCommon.h"
+epicsShareExtern void (*pvar_func_dbndInitialize)(void);
+static db_field_log fl;
+static int fl_equal(const db_field_log *pfl1, const db_field_log *pfl2) {
+    return !(memcmp(pfl1, pfl2, sizeof(db_field_log)));
+static void fl_setup(dbChannel *chan, db_field_log *pfl) {
+    struct dbCommon  *prec = dbChannelRecord(chan);
+    pfl->ctx  = dbfl_context_read;
+    pfl->type = dbfl_type_val;
+    pfl->field_type  = dbChannelFieldType(chan);
+    pfl->no_elements = dbChannelElements(chan);
+     * use memcpy to avoid a bus error on
+     * union copy of char in the db at an odd
+     * address
+    memcpy(&pfl->u.v.field,
+           dbChannelField(chan),
+           dbChannelFieldSize(chan));
+static void changeValue(db_field_log *pfl2, long val) {
+    pfl2->u.v.field.dbf_long = val;
+    testDiag("new value: %ld", val);
+static void mustPassOnce(dbChannel *pch, db_field_log *pfl2, char* m, double d, long val) {
+    changeValue(pfl2, val);
+    testDiag("mode=%s delta=%g filter must pass once", m, d);
+    db_field_log *pfl = dbChannelRunPreChain(pch, pfl2);
+    testOk(pfl2 == pfl, "call 1 does not drop or replace field_log");
+    testOk(fl_equal(pfl, pfl2), "call 1 does not change field_log data");
+    pfl = dbChannelRunPreChain(pch, pfl2);
+    testOk(NULL == pfl, "call 2 drops field_log");
+static void mustDrop(dbChannel *pch, db_field_log *pfl2, char* m, double d, long val) {
+    testDiag("mode=%s delta=%g filter must drop", m, d);
+    testOk(NULL == pfl, "call 1 drops field_log");
+static void mustPassTwice(dbChannel *pch, db_field_log *pfl2, char* m, double d, long val) {
+    testDiag("mode=%s delta=%g filter must pass twice", m, d);
+    testOk(pfl2 == pfl, "call 2 does not drop or replace field_log");
+    testOk(fl_equal(pfl, pfl2), "call 2 does not change field_log data");
+static void testHead (char* title) {
+    testDiag("--------------------------------------------------------");
+    testDiag(title);
+void xRecord_registerRecordDeviceDriver(struct dbBase *);
+MAIN(dbndTest)
+    dbChannel *pch;
+    chFilter *filter;
+    char dbnd[] = "dbnd";
+    ELLNODE *node;
+    chPostEventFunc *cb_out = NULL;
+    void *arg_out = NULL;
+    db_field_log *pfl2;
+    db_field_log fl1;
+    testPlan(62);
+    db_init_events();
+    testOk1(!dbReadDatabase(&pdbbase, "xRecord.dbd", ".:../../../test", NULL));
+    testOk(!!pdbbase, "pdbbase was set");
+    (*pvar_func_dbndInitialize)();       /* manually initialize plugin */
+    xRecord_registerRecordDeviceDriver(pdbbase);
+    testOk1(!dbReadDatabase(&pdbbase, "dbChannelTest.db", ".:../../../test", NULL));
+    testOk(!!(plug = dbFindFilter(dbnd, strlen(dbnd))), "plugin dbnd registered correctly");
+    testOk(!!(pch = dbChannelCreate("x.VAL{\"dbnd\":{}}")), "dbChannel with plugin dbnd (delta=0) created");
+    testOk((ellCount(&pch->filters) == 1), "channel has one plugin");
+    memset(&fl, PATTERN, sizeof(fl));
+    fl1 = fl;
+    node = ellFirst(&pch->filters);
+    filter = CONTAINER(node, chFilter, list_node);
+    plug->fif->channel_register_pre(filter, &cb_out, &arg_out, &fl1);
+    testOk(!!(cb_out) && !!(arg_out), "register_pre registers one filter with argument");
+    testOk(fl_equal(&fl1, &fl), "register_pre does not change field_log data type");
+    testOk(!(dbChannelOpen(pch)), "dbChannel with plugin dbnd opened");
+    node = ellFirst(&pch->pre_chain);
+    testOk((ellCount(&pch->pre_chain) == 1 && filter->pre_arg != NULL),
+           "dbnd has one filter with argument in pre chain");
+    testOk((ellCount(&pch->post_chain) == 0), "dbnd has no filter in post chain");
+    /* Field logs of type ref and rec: pass any update */
+    testHead("Field logs of type ref and rec");
+    fl1.type = dbfl_type_rec;
+    mustPassTwice(pch, &fl1, "abs field_log=rec", 0., 0);
+    fl1.type = dbfl_type_ref;
+    mustPassTwice(pch, &fl1, "abs field_log=ref", 0., 0);
+    /* Delta = 0: pass any change */
+    testHead("Delta = 0: pass any change");
+    pfl2 = db_create_read_log(pch);
+    testDiag("new field_log from record");
+    fl_setup(pch, pfl2);
+    mustPassOnce(pch, pfl2, "abs", 0., 0);
+    mustPassOnce(pch, pfl2, "abs", 0., 1);
+    db_delete_field_log(pfl2);
+    /* Delta = -1: pass any update */
+    testHead("Delta = -1: pass any update");
+    testOk(!!(pch = dbChannelCreate("x.VAL{\"dbnd\":{\"d\":-1.0}}")), "dbChannel with plugin dbnd (delta=-1) created");
+    mustPassTwice(pch, pfl2, "abs", -1., 0);
+    mustPassTwice(pch, pfl2, "abs", -1., 1);
+    /* Delta = absolute */
+    testHead("Delta = absolute");
+    testOk(!!(pch = dbChannelCreate("x.VAL{\"dbnd\":{\"d\":3}}")), "dbChannel with plugin dbnd (delta=3) created");
+    mustPassOnce(pch, pfl2, "abs", 3., 1);
+    mustDrop(pch, pfl2, "abs", 3., 3);
+    mustDrop(pch, pfl2, "abs", 3., 4);
+    mustPassOnce(pch, pfl2, "abs", 3., 5);
+    /* Delta = relative */
+    testHead("Delta = relative");
+    testOk(!!(pch = dbChannelCreate("x.VAL{\"dbnd\":{\"m\":\"rel\",\"d\":50}}")),
+           "dbChannel with plugin dbnd (mode=rel, delta=50) created");
+    mustPassOnce(pch, pfl2, "rel", 50., 1);
+    mustPassOnce(pch, pfl2, "rel", 50., 2);
+    mustDrop(pch, pfl2, "rel", 50., 3);
+    mustPassOnce(pch, pfl2, "rel", 50., 4);
+    mustDrop(pch, pfl2, "rel", 50., 5);
+    mustDrop(pch, pfl2, "rel", 50., 6);
+    mustPassOnce(pch, pfl2, "rel", 50., 7);
+#include "xRecord.h"
+static rset xRSET;
+epicsExportAddress(rset,xRSET);
=== added file 'src/ioc/db/filters/test/syncTest.c'
--- src/ioc/db/filters/test/syncTest.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/filters/test/syncTest.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,371 @@
+epicsShareExtern void (*pvar_func_syncInitialize)(void);
+static dbStateId red;
+static void fl_setup(dbChannel *chan, db_field_log *pfl, long val) {
+    pfl->ctx  = dbfl_context_event;
+    pfl->field_type  = DBF_LONG;
+    pfl->no_elements = 1;
+     * address
+    pfl->u.v.field.dbf_long = val;
+    testDiag(title);
+static void mustDrop(dbChannel *pch, db_field_log *pfl2, char* m) {
+    testOk(NULL == pfl, "filter drops field_log (%s)", m);
+static void mustPassTwice(dbChannel *pch, db_field_log *pfl2, char* m) {
+    testDiag("%s: filter must pass twice", m);
+static void mustPassOld(dbChannel *pch, db_field_log *old, db_field_log *cur, char* m) {
+    db_field_log *pfl = dbChannelRunPreChain(pch, cur);
+    testOk(old == pfl, "filter passes previous field log (%s)", m);
+static void mustPass(dbChannel *pch, db_field_log *cur, char* m) {
+    testOk(cur == pfl, "filter passes field_log (%s)", m);
+static void checkCtxRead(dbChannel *pch, dbStateId id) {
+    fl.ctx = dbfl_context_read;
+    dbStateClear(id);
+    mustPassTwice(pch, &fl, "ctx='read', state=FALSE");
+    dbStateSet(id);
+    mustPassTwice(pch, &fl, "ctx='read', state=TRUE");
+    dbStateClear(id);
+    fl.ctx = dbfl_context_event;
+static void checkAndOpenChannel(dbChannel *pch, const chFilterPlugin *plug) {
+    ELLNODE *node;
+    chFilter *filter;
+    testDiag("Test filter structure and open channel");
+    db_field_log fl1 = fl;
+    testOk(!(dbChannelOpen(pch)), "dbChannel with plugin sync opened");
+           "sync has one filter with argument in pre chain");
+    testOk((ellCount(&pch->post_chain) == 0), "sync has no filter in post chain");
+    checkCtxRead(pch, red);
+//MAIN(syncTest)
+int main()
+    dbChannel *pch;
+    chFilter *filter;
+    char myname[] = "sync";
+    ELLNODE *node;
+    db_field_log *pfl[10];
+    db_field_log fl1;
+    int i;
+    testPlan(0);
+    db_init_events();
+    (*pvar_func_syncInitialize)();       /* manually initialize plugin */
+    testOk(!!(plug = dbFindFilter(myname, strlen(myname))), "plugin %s registered correctly", myname);
+    testOk(!!(red = dbStateCreate("red")), "state 'red' created successfully");
+    /* nonexisting state */
+    testOk(!(pch = dbChannelCreate("x.VAL{\"sync\":{\"m\":\"while\",\"s\":\"blue\"}}")),
+           "dbChannel with sync (m='while' s='blue') (nonex state) failed");
+    /* missing state */
+    testOk(!(pch = dbChannelCreate("x.VAL{\"sync\":{\"m\":\"while\"}}")),
+           "dbChannel with sync (m='while') (no state) failed");
+    /* missing mode */
+    testOk(!(pch = dbChannelCreate("x.VAL{\"sync\":{\"s\":\"red\"}}")),
+           "dbChannel with sync (s='red') (no mode) failed");
+    /* mode WHILE */
+    testHead("Mode WHILE  (m='while', s='red')");
+    testOk(!!(pch = dbChannelCreate("x.VAL{\"sync\":{\"m\":\"while\",\"s\":\"red\"}}")),
+           "dbChannel with plugin sync (m='while' s='red') created");
+    checkAndOpenChannel(pch, plug);
+    for (i = 0; i < 10; i++) {
+        pfl[i] = db_create_read_log(pch);
+        fl_setup(pch, pfl[i], 120 + i);
+    testDiag("Test event stream");
+    dbStateClear(red);
+    mustDrop(pch, pfl[0], "state=FALSE, log0");
+    mustDrop(pch, pfl[1], "state=FALSE, log1");
+    mustDrop(pch, pfl[2], "state=FALSE, log2");
+    dbStateSet(red);
+    mustPass(pch, pfl[3], "state=TRUE, log3");
+    mustPass(pch, pfl[4], "state=TRUE, log4");
+    mustPass(pch, pfl[5], "state=TRUE, log5");
+    mustDrop(pch, pfl[6], "state=FALSE, log6");
+    mustDrop(pch, pfl[7], "state=FALSE, log7");
+    mustDrop(pch, pfl[8], "state=FALSE, log8");
+        db_delete_field_log(pfl[i]);
+    /* mode UNLESS */
+    testHead("Mode UNLESS  (m='unless', s='red')");
+    testOk(!!(pch = dbChannelCreate("x.VAL{\"sync\":{\"m\":\"unless\",\"s\":\"red\"}}")),
+           "dbChannel with plugin sync (m='unless' s='red') created");
+    mustPass(pch, pfl[0], "state=FALSE, log0");
+    mustPass(pch, pfl[1], "state=FALSE, log1");
+    mustPass(pch, pfl[2], "state=FALSE, log2");
+    dbStateSet(red);
+    mustDrop(pch, pfl[3], "state=TRUE, log3");
+    mustDrop(pch, pfl[4], "state=TRUE, log4");
+    mustDrop(pch, pfl[5], "state=TRUE, log5");
+    mustPass(pch, pfl[6], "state=FALSE, log6");
+    mustPass(pch, pfl[7], "state=FALSE, log7");
+    mustPass(pch, pfl[8], "state=FALSE, log8");
+    /* mode BEFORE */
+    testHead("Mode BEFORE  (m='before', s='red')");
+    testOk(!!(pch = dbChannelCreate("x.VAL{\"sync\":{\"m\":\"before\",\"s\":\"red\"}}")),
+           "dbChannel with plugin sync (m='before' s='red') created");
+    dbStateSet(red);
+    mustPassOld(pch, pfl[2], pfl[3], "state=TRUE, log3, pass=log2");
+    mustDrop(pch, pfl[6], "state=TRUE, log6");
+    mustDrop(pch, pfl[9], "state=FALSE, log9");
+    /* mode FIRST */
+    testHead("Mode FIRST  (m='first', s='red')");
+    testOk(!!(pch = dbChannelCreate("x.VAL{\"sync\":{\"m\":\"first\",\"s\":\"red\"}}")),
+           "dbChannel with plugin sync (m='first' s='red') created");
+    dbStateSet(red);
+    /* mode LAST */
+    testHead("Mode LAST  (m='last', s='red')");
+    testOk(!!(pch = dbChannelCreate("x.VAL{\"sync\":{\"m\":\"last\",\"s\":\"red\"}}")),
+           "dbChannel with plugin sync (m='last' s='red') created");
+    dbStateSet(red);
+    mustPassOld(pch, pfl[5], pfl[6], "state=TRUE, log6, pass=log5");
+    /* mode AFTER */
+    testHead("Mode AFTER  (m='after', s='red')");
+    testOk(!!(pch = dbChannelCreate("x.VAL{\"sync\":{\"m\":\"after\",\"s\":\"red\"}}")),
+           "dbChannel with plugin sync (m='after' s='red') created");
+    dbStateSet(red);
+static rset xRSET;
=== added file 'src/ioc/db/filters/test/tsTest.c'
--- src/ioc/db/filters/test/tsTest.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/filters/test/tsTest.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,111 @@
+epicsShareExtern void (*pvar_func_tsInitialize)(void);
+static int fl_equal_ex_ts(const db_field_log *pfl1, const db_field_log *pfl2) {
+    db_field_log fl1 = *pfl1;
+    fl1.time = pfl2->time;
+    return fl_equal(&fl1, pfl2);
+MAIN(tsTest)
+    dbChannel *pch;
+    chFilter *filter;
+    char ts[] = "ts";
+    ELLNODE *node;
+    db_field_log fl1;
+    testPlan(15);
+    db_init_events();
+    (*pvar_func_tsInitialize)();       /* manually initialize plugin */
+    testOk(!!(plug = dbFindFilter(ts, strlen(ts))), "plugin ts registered correctly");
+    testOk(!!(pch = dbChannelCreate("x.VAL{\"ts\":{}}")), "dbChannel with plugin ts created");
+    fl1 = fl;
+    testOk(!!(cb_out) && !(arg_out), "register_pre registers one filter w/o argument");
+    testOk(!(dbChannelOpen(pch)), "dbChannel with plugin ts opened");
+    testOk((ellCount(&pch->pre_chain) == 1 && filter->pre_arg == NULL),
+           "ts has one filter w/o argument in pre chain");
+    testOk((ellCount(&pch->post_chain) == 0), "ts has no filter in post chain");
+    fl1 = fl;
+    pfl2 = dbChannelRunPreChain(pch, &fl1);
+    testOk(pfl2 == &fl1, "ts filter does not drop or replace field_log");
+    testOk(fl_equal_ex_ts(&fl1, pfl2), "ts filter does not change field_log data");
+    testOk(!!(pfl2 = db_create_read_log(pch)), "create field log from channel");
+    epicsTimeStamp stamp = pfl2->time;
+    epicsTimeStamp now; epicsTimeGetCurrent(&now);
+    testOk(epicsTimeDiffInSeconds(&pfl2->time, &stamp) > 0. &&
+           epicsTimeDiffInSeconds(&now, &pfl2->time) > 0., "ts filter sets time stamp to \"now\"");
+static rset xRSET;
=== added file 'src/ioc/db/filters/ts.c'
--- src/ioc/db/filters/ts.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/filters/ts.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,67 @@
+#include <stdio.h>
+    epicsTimeGetCurrent(&now);
+    /* If string or array, must make a copy (to ensure coherence between time and data) */
+    if (pfl->type == dbfl_type_rec) {
+        dbChannelMakeArrayCopy(pvt, pfl, chan);
+    pfl->time = now;
+    return pfl;
+    *cb_out = filter;
+    printf("%*s  plugin ts\n", indent, "");
+    NULL, /* allocPvt, */
+    NULL, /* freePvt, */
+    NULL, /* parse_ok, */
+    channel_report,
+static void tsInitialize(void)
+    if(!firstTime) return;
+    firstTime = 0;
+    chfPluginRegister("ts", &pif, NULL);
+epicsExportRegistrar(tsInitialize);
=== modified file 'src/ioc/db/recGbl.c'
--- src/ioc/db/recGbl.c	2010-10-05 19:27:37 +0000
+++ src/ioc/db/recGbl.c	2012-05-30 18:10:27 +0000
@@ -6,12 +6,10 @@
-/* recGbl.c */
-/* $Revision-Id$ */
  *      Author:          Marty Kraimer
- *      Date:            11-7-90
+ *                       Andrew Johnson <[email protected]>
 #include <stddef.h>
@@ -34,6 +32,7 @@
 #include "caeventmask.h"
+#include "dbLink.h"
 #include "dbCa.h"
@@ -166,60 +165,17 @@
     return;
 int  epicsShareAPI recGblInitConstantLink(
     struct link *plink,short dbftype,void *pdest)
-    if(plink->type != CONSTANT) return(FALSE);
-    if(!plink->value.constantStr) return(FALSE);
-    switch(dbftype) {
-    case DBF_STRING:
-	strcpy((char *)pdest,plink->value.constantStr);
-	break;
-    case DBF_CHAR : {
-	epicsInt16 value;
-	epicsInt8 *pvalue = (epicsInt8 *)pdest;
-	sscanf(plink->value.constantStr,"%hi",&value);
-	*pvalue = value;
-	break;
-    case DBF_UCHAR : {
-	epicsUInt16 value;
-	epicsUInt8 *pvalue = (epicsUInt8 *)pdest;
-	sscanf(plink->value.constantStr,"%hu",&value);
-	*pvalue = value;
-	break;
-    case DBF_SHORT :
-	sscanf(plink->value.constantStr,"%hi",(epicsInt16 *)pdest);
-	break;
-    case DBF_USHORT :
-    case DBF_ENUM :
-    case DBF_MENU :
-    case DBF_DEVICE :
-	sscanf(plink->value.constantStr,"%hu",(epicsUInt16 *)pdest);
-	break;
-    case DBF_LONG :
-	*(epicsInt32 *)pdest = strtol(plink->value.constantStr, NULL, 0);
-	break;
-    case DBF_ULONG :
-	*(epicsUInt32 *)pdest = strtoul(plink->value.constantStr, NULL, 10);
-	break;
-    case DBF_FLOAT :
-	epicsScanFloat(plink->value.constantStr, (epicsFloat32 *)pdest);
-	break;
-    case DBF_DOUBLE :
-	epicsScanDouble(plink->value.constantStr, (epicsFloat64 *)pdest);
-	break;
-    default:
-	epicsPrintf("Error in recGblInitConstantLink: Illegal DBF type\n");
-	return(FALSE);
-    return(TRUE);
+    long status = dbLoadLink(plink, dbftype, pdest);
+    if (status)
+        return FALSE;
+    return TRUE;
 unsigned short epicsShareAPI recGblResetAlarms(void *precord)
     dbCommon *pdbc = precord;
=== modified file 'src/ioc/db/test/Makefile'
--- src/ioc/db/test/Makefile	2012-05-29 21:20:17 +0000
+++ src/ioc/db/test/Makefile	2012-05-30 18:10:27 +0000
@@ -27,7 +27,31 @@
 TESTSPEC_vxWorks = dbTestHarness.munch; epicsRunDbTests
 TESTSPEC_RTEMS = dbTestHarness.boot; epicsRunDbTests
+TESTPROD_HOST += dbChannelTest
+dbChannelTest_SRCS += dbChannelTest.c xRecord_registerRecordDeviceDriver.cpp
+OBJS_IOC_vxWorks += dbChannelTest
+TESTS += dbChannelTest
+TESTPROD_HOST += chfPluginTest
+chfPluginTest_SRCS += chfPluginTest.c xRecord_registerRecordDeviceDriver.cpp
+OBJS_IOC_vxWorks += chfPluginTest
+TESTS += chfPluginTest
+TESTPROD_HOST += arrShorthandTest
+arrShorthandTest_SRCS += arrShorthandTest.c xRecord_registerRecordDeviceDriver.cpp
+OBJS_IOC_vxWorks += arrShorthandTest
+TESTS += arrShorthandTest
+TESTPROD_HOST += dbStateTest
+dbStateTest_SRCS += dbStateTest.c
+OBJS_IOC_vxWorks += dbStateTest
+TESTS += dbStateTest
+dbChannelTest$(OBJ): $(COMMON_DIR)/xRecord.h
+chfPluginTest$(OBJ): $(COMMON_DIR)/xRecord.h
+arrShorthandTest$(OBJ): $(COMMON_DIR)/xRecord.h
+dbStateTest$(OBJ): $(COMMON_DIR)/xRecord.h
=== added file 'src/ioc/db/test/arrShorthandTest.c'
--- src/ioc/db/test/arrShorthandTest.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/test/arrShorthandTest.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,139 @@
+  * Test the shorthand array notation  [ start : incr : end ]
+  * by registering a thin fake arr plugin
+  * and checking if values are forwarded correctly
+    epicsInt32 start;
+    epicsInt32 incr;
+    epicsInt32 end;
+} myStruct;
+static const
+    chfPluginArgEnd
+static myStruct my;
+    my.start = 0;
+    my.incr = 1;
+    my.end = -1;
+    return &my;
+static chfPluginIf myPif = {
+    allocPvt,
+    NULL, /* channel_report, */
+static int checkValues(epicsUInt32 s, epicsUInt32 i, epicsUInt32 e) {
+    if (s == my.start && i == my.incr && e == my.end)
+        return 1;
+    else
+        return 0;
+    testDiag(title);
+MAIN(chfPluginTest)
+    dbChannel *pch;
+    testPlan(29);
+    db_init_events();
+    testHead("Set up database");
+    testOk1(!dbReadDatabase(&pdbbase, "xRecord.dbd", ".:..", NULL));
+    testOk1(!dbReadDatabase(&pdbbase, "dbChannelTest.db", ".:..", NULL));
+    testHead("Register plugin");
+    testOk(!chfPluginRegister("arr", &myPif, opts), "register fake arr plugin");
+#define TESTBAD(Title, Expr) \
+    testDiag(Title); \
+    testOk(!(pch = dbChannelCreate("x." Expr)), "dbChannelCreate (" Expr ") fails"); \
+    if (pch) dbChannelDelete(pch);
+#define TESTGOOD(Title, Expr, Start, Incr, End) \
+    testOk(!!(pch = dbChannelCreate("x." Expr)), "dbChannelCreate (" Expr ")"); \
+    testOk(checkValues(Start, Incr, End), "parameters set correctly: s=%d i=%d e=%d", Start, Incr, End); \
+    TESTBAD("no parameters []", "[]");
+    TESTBAD("invalid char at beginning [x", "[x");
+    TESTBAD("invalid char after 1st arg [2x", "[2x");
+    TESTBAD("invalid char after 2nd arg [2:3x", "[2:3x");
+    TESTBAD("invalid char after 3rd arg [2:3:4x", "[2:3:4x");
+    TESTGOOD("one element [index]",         "[2]",     2, 1, 2);
+    TESTGOOD("to end [s:]",                 "[2:]",    2, 1, -1);
+    TESTGOOD("to end [s::]",                "[2::]",   2, 1, -1);
+    TESTGOOD("to end with incr [s:i:]",     "[2:3:]",  2, 3, -1);
+    TESTGOOD("from beginning [:e]",         "[:2]",    0, 1, 2);
+    TESTGOOD("from beginning [::e]",        "[::2]",   0, 1, 2);
+    TESTGOOD("from begin with incr [:i:e]", "[:3:2]",  0, 3, 2);
+    TESTGOOD("range [s:e]",                 "[2:4]",   2, 1, 4);
+    TESTGOOD("range [s::e]",                "[2::4]",  2, 1, 4);
+    TESTGOOD("range with incr [s:i:e]",     "[2:3:4]", 2, 3, 4);
+static rset xRSET;
=== added file 'src/ioc/db/test/chfPluginTest.c'
--- src/ioc/db/test/chfPluginTest.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/test/chfPluginTest.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,746 @@
+* EPICS BASE is distributed subject to a Software License Agreement found
+* in file LICENSE that is included with this distribution.
+#define PATTERN 0x55555555
+#define TYPE_START 0xAAA
+#define R_LEVEL 42
+/* Expected / actually run callback bit definitions */
+#define e_alloc         0x00000001
+#define e_free          0x00000002
+#define e_error         0x00000004
+#define e_ok            0x00000008
+#define e_open          0x00000010
+#define e_reg_pre       0x00000020
+#define e_reg_post      0x00000040
+#define e_report        0x00000080
+#define e_close         0x00000100
+#define e_pre           0x00000200
+#define e_post          0x00000400
+#define e_dtor          0x00000800
+unsigned int e1, e2, c1, c2;
+unsigned int offset;
+int drop = -1;
+db_field_log *dtorpfl;
+#define e_any (e_alloc | e_free | e_error | e_ok | e_open \
+| e_reg_pre | e_reg_post | e_pre | e_post | e_dtor | e_report | e_close)
+    int sent1;
+    char        flag;
+    int sent2;
+    epicsUInt32 ival;
+    int sent3;
+    double      dval;
+    int sent4;
+    int         enumval;
+    int sent5;
+    char        str[20];
+    int sent6;
+    char        c;
+    char        c1[2];
+    int         offpre;
+    int         offpost;
+} myStruct;
+static const
+chfPluginEnumType colorEnum[] = { {"R", 1}, {"G", 2}, {"B", 4}, {NULL,0} };
+static const
+chfPluginArgDef strictOpts[] = {
+    chfInt32  (myStruct, ival,    "i" , 1, 0),
+    chfBoolean(myStruct, flag,    "f" , 1, 0),
+    chfDouble (myStruct, dval,    "d" , 1, 0),
+    chfString (myStruct, str,     "s" , 1, 0),
+    chfEnum   (myStruct, enumval, "c" , 1, 0, colorEnum),
+    chfPluginArgEnd
+static const
+chfPluginArgDef noconvOpts[] = {
+    chfInt32  (myStruct, ival,    "i" , 0, 0),
+    chfBoolean(myStruct, flag,    "f" , 0, 0),
+    chfDouble (myStruct, dval,    "d" , 0, 0),
+    chfString (myStruct, str,     "s" , 0, 0),
+    chfEnum   (myStruct, enumval, "c" , 0, 0, colorEnum),
+    chfPluginArgEnd
+static const
+chfPluginArgDef sloppyOpts[] = {
+    chfInt32  (myStruct, ival,    "i" , 0, 1),
+    chfBoolean(myStruct, flag,    "f" , 0, 1),
+    chfDouble (myStruct, dval,    "d" , 0, 1),
+    chfString (myStruct, str,     "s" , 0, 1),
+    chfEnum   (myStruct, enumval, "c" , 0, 1, colorEnum),
+    chfPluginArgEnd
+/* Options defs with not enough room provided */
+static const
+chfPluginArgDef brokenOpts1[] = {
+    chfInt32 (myStruct,  c1, "i" , 0, 1),
+    chfPluginArgEnd
+static const
+chfPluginArgDef brokenOpts2[] = {
+    chfDouble(myStruct,  c1, "d" , 0, 1),
+    chfPluginArgEnd
+static const
+chfPluginArgDef brokenOpts3[] = {
+    chfString(myStruct, c1, "s" , 0, 1),
+    chfPluginArgEnd
+static const
+chfPluginArgDef brokenOpts4[] = {
+    chfEnum  (myStruct,  c1, "c" , 0, 1, colorEnum),
+    chfPluginArgEnd
+int p_ok_return = 0;
+int c_open_return = 0;
+void *puser1, *puser2;
+static void clearStruct(void *p) {
+    myStruct *my = (myStruct*) p;
+    if (!my) return;
+    memset(my, 0, sizeof(myStruct));
+    my->sent1 = my->sent2 = my->sent3 = my->sent4 = my->sent5 = my->sent6 = PATTERN;
+    my->ival = 12;
+    my->flag = 1;
+    my->dval = 1.234e5;
+    strcpy(my->str, "hello");
+    my->enumval = 4;
+static char inst(void* user) {
+    return user == puser1 ? '1' : user == puser2 ? '2' : 'x';
+    myStruct *my = (myStruct*) calloc(1, sizeof(myStruct));
+    if (!puser1) {
+        puser1 = my;
+        testOk(e1 & e_alloc, "allocPvt (1) called");
+        c1 |= e_alloc;
+    } else if (!puser2) {
+        puser2 = my;
+        testOk(e2 & e_alloc, "allocPvt (2) called");
+        c2 |= e_alloc;
+    clearStruct (my);
+    return my;
+static void freePvt(void *user)
+    testOk(user == puser1 || user == puser2, "freePvt: user pointer valid");
+    if (user == puser1) {
+        testOk(e1 & e_free, "freePvt (1) called");
+        c1 |= e_free;
+        free(user);
+        puser1 = NULL;
+    } else if (user == puser2) {
+        testOk(e2 & e_free, "freePvt (2) called");
+        c2 |= e_free;
+        free(user);
+        puser2 = NULL;
+static void parse_error(void *user)
+    testOk(user == puser1 || user == puser2, "parse_error: user pointer valid");
+        testOk(e1 & e_error, "parse_error (1) called");
+        c1 |= e_error;
+        testOk(e2 & e_error, "parse_error (2) called");
+        c2 |= e_error;
+static int parse_ok(void *user)
+    testOk(user == puser1 || user == puser2, "parse_ok: user pointer valid");
+        testOk(e1 & e_ok, "parse_ok (1) called");
+        c1 |= e_ok;
+        testOk(e2 & e_ok, "parse_ok (2) called");
+        c2 |= e_ok;
+    return p_ok_return;
+static long channel_open(dbChannel *chan, void *user)
+    testOk(user == puser1 || user == puser2, "channel_open: user pointer valid");
+        testOk(e1 & e_open, "channel_open (1) called");
+        c1 |= e_open;
+        testOk(e2 & e_open, "channel_open (2) called");
+        c2 |= e_open;
+    return c_open_return;
+static void dbfl_free1(db_field_log *pfl) {
+    testOk(e1 & e_dtor, "dbfl_free (1) called");
+    testOk(dtorpfl == pfl, "dbfl_free (1): db_field_log pointer correct");
+    dtorpfl = NULL;
+    c1 |= e_dtor;
+static void dbfl_free2(db_field_log *pfl) {
+    testOk(e2 & e_dtor, "dbfl_free (2) called");
+    testOk(dtorpfl == pfl, "dbfl_free (2): db_field_log pointer correct");
+    dtorpfl = NULL;
+    c2 |= e_dtor;
+static db_field_log * pre(void *user, dbChannel *chan, db_field_log *pLog) {
+    myStruct *my = (myStruct*)user;
+    dbfl_freeFunc *dtor = NULL;
+    testOk(user == puser1 || user == puser2, "pre: user pointer valid");
+    if (my == puser1) {
+        testOk(e1 & e_pre, "pre (1) called");
+        testOk(!(c2 & e_pre), "pre (2) has not been called before pre (1)");
+        c1 |= e_pre;
+        dtor = dbfl_free1;
+    } else if (my == puser2) {
+        testOk(e2 & e_pre, "pre (2) called");
+        testOk(!(e1 & e_pre) || c1 & e_pre, "pre (1) has been called before pre (2)");
+        c2 |= e_pre;
+        dtor = dbfl_free2;
+    testOk(!(c1 & e_post), "post (1) has not been called before pre (%c)", inst(user));
+    testOk(!(c2 & e_post), "post (2) has not been called before pre (%c)", inst(user));
+    if (!testOk(pLog->field_type == TYPE_START + my->offpre, "pre (%c) got field log of expected type", inst(user)))
+        testDiag("expected: %d, got %d", TYPE_START + my->offpre, pLog->field_type);
+    pLog->field_type++;
+    if (my->offpre == 0) {                 /* The first one registers a dtor and saves pfl */
+        pLog->u.r.dtor = dtor;
+        dtorpfl = pLog;
+    if (my->offpre == drop) {
+        testDiag("pre (%c) is dropping the field log", inst(user));
+        return NULL;
+    return pLog;
+static db_field_log * post(void *user, dbChannel *chan, db_field_log *pLog) {
+    testOk(user == puser1 || user == puser2, "post: user pointer valid");
+        testOk(e1 & e_post, "post (1) called");
+        testOk(!(c2 & e_post), "post (2) has not been called before post (1)");
+        c1 |= e_post;
+        testOk(e2 & e_post, "post (2) called");
+        testOk(!(e1 & e_post) || c1 & e_post, "post (1) has been called before post (2)");
+        c2 |= e_post;
+    testOk(!(e1 & e_pre) || c1 & e_pre, "pre (1) has been called before post (%c)", inst(user));
+    testOk(!(e2 & e_pre) || c2 & e_pre, "pre (2) has been called before post (%c)", inst(user));
+    if (!testOk(pLog->field_type == TYPE_START + my->offpost, "post (%c) got field log of expected type", inst(user)))
+        testDiag("expected: %d, got %d", TYPE_START + my->offpost, pLog->field_type);
+    if (my->offpost == 0) {                 /* The first one registers a dtor and remembers pfl */
+        dtorpfl = pLog;
+    if (my->offpost == drop) {
+        testDiag("post (%c) is dropping the field log", inst(user));
+        return NULL;
+    return pLog;
+static void channelRegisterPre(dbChannel *chan, void *user,
+    testOk(user == puser1 || user == puser2, "register_pre: user pointer valid");
+        testOk(e1 & e_reg_pre, "register_pre (1) called");
+        testOk(!(c2 & e_reg_pre), "register_pre (2) has not been called before register_pre (1)");
+        c1 |= e_reg_pre;
+        testOk(e2 & e_reg_pre, "register_pre (2) called");
+        testOk(!(e1 & e_reg_pre) || c1 & e_reg_pre, "register_pre (1) has been called before register_pre (2)");
+        c2 |= e_reg_pre;
+    testOk(!(c1 & e_reg_post), "register_post (1) has not been called before register_pre (%c)", inst(user));
+    testOk(!(c2 & e_reg_post), "register_post (2) has not been called before register_pre (%c)", inst(user));
+    my->offpre = offset++;
+    probe->field_type++;
+    *cb_out  = pre;
+    *arg_out = user;
+static void channelRegisterPost(dbChannel *chan, void *user,
+    testOk(user == puser1 || user == puser2, "register_post: user pointer valid");
+        testOk(e1 & e_reg_post, "register_post (1) called");
+        testOk(!(c2 & e_reg_post), "register_post (2) has not been called before register_post (1)");
+        c1 |= e_reg_post;
+        testOk(e2 & e_reg_post, "register_post (2) called");
+        testOk(!(e1 & e_reg_post) || c1 & e_reg_post, "register_post (1) has been called before register_post (2)");
+        c2 |= e_reg_post;
+    testOk(!(e1 & e_reg_pre) || c1 & e_reg_pre, "register_pre (1) has been called before register_post (%c)", inst(user));
+    testOk(!(e2 & e_reg_pre) || c2 & e_reg_pre, "register_pre (2) has been called before register_post (%c)", inst(user));
+    my->offpost = offset++;
+    *cb_out  = post;
+    *arg_out = user;
+static void channel_report(dbChannel *chan, void *user, int level, const unsigned short indent)
+    testOk(user == puser1 || user == puser2, "channel_report: user pointer valid");
+    testOk(level == R_LEVEL - 1, "channel_report: level correct");
+        testOk(e1 & e_report, "channel_report (1) called");
+        c1 |= e_report;
+        testOk(e2 & e_report, "channel_report (2) called");
+        c2 |= e_report;
+static void channel_close(dbChannel *chan, void *user)
+    testOk(user == puser1 || user == puser2, "channel_close: user pointer valid");
+        testOk(e1 & e_close, "channel_close (1) called");
+        c1 |= e_close;
+        testOk(e2 & e_close, "channel_close (2) called");
+        c2 |= e_close;
+    allocPvt,
+    freePvt,
+    parse_error,
+    parse_ok,
+    channel_open,
+    channel_report,
+    channel_close
+static chfPluginIf prePif = {
+    allocPvt,
+    freePvt,
+    parse_error,
+    parse_ok,
+    channel_open,
+    NULL,
+    channel_report,
+    channel_close
+static chfPluginIf postPif = {
+    allocPvt,
+    freePvt,
+    parse_error,
+    parse_ok,
+    channel_open,
+    NULL,
+    channel_report,
+    channel_close
+static int checkValues(myStruct *my, epicsUInt32 i, int f, double d, char *s, int c) {
+    if (!my) return 0;
+    if (my->sent1 == PATTERN && my->sent2 == PATTERN && my->sent3 == PATTERN
+        && my->sent4 == PATTERN && my->sent5 == PATTERN && my->sent6 == PATTERN
+        && my->ival == i && my->flag == f && my->dval == d && my->enumval == c
+        && (strcmp(s, my->str) == 0)) {
+        return 1;
+    } else {
+        return 0;
+    testDiag(title);
+    dbChannel *pch;
+    db_field_log *pfl;
+    testPlan(1755);
+    db_init_events();
+    /* Enum to string conversion */
+    testHead("Enum to string conversion");
+    testOk(strcmp(chfPluginEnumString(colorEnum, 1, "-"), "R") == 0, "Enum to string: R");
+    testOk(strcmp(chfPluginEnumString(colorEnum, 2, "-"), "G") == 0, "Enum to string: G");
+    testOk(strcmp(chfPluginEnumString(colorEnum, 4, "-"), "B") == 0, "Enum to string: B");
+    testOk(strcmp(chfPluginEnumString(colorEnum, 3, "-"), "-") == 0, "Enum to string: invalid index");
+    testHead("Try to register buggy plugins");
+    testOk(!!chfPluginRegister("buggy", &myPif, brokenOpts1), "not enough storage for integer");
+    testOk(!!chfPluginRegister("buggy", &myPif, brokenOpts2), "not enough storage for double");
+    testOk(!!chfPluginRegister("buggy", &myPif, brokenOpts3), "not enough storage for string");
+    testOk(!!chfPluginRegister("buggy", &myPif, brokenOpts4), "not enough storage for enum");
+    testHead("Register plugins");
+    testOk(!chfPluginRegister("strict", &myPif, strictOpts), "register plugin strict");
+    testOk(!chfPluginRegister("noconv", &myPif, noconvOpts), "register plugin noconv");
+    testOk(!chfPluginRegister("sloppy", &myPif, sloppyOpts), "register plugin sloppy");
+    testOk(!chfPluginRegister("pre",   &prePif, sloppyOpts), "register plugin pre");
+    testOk(!chfPluginRegister("post", &postPif, sloppyOpts), "register plugin post");
+    /* STRICT parsing: mandatory, no conversion */
+    /* All perfect */
+    testHead("STRICT parsing: all ok");
+    e1 = e_alloc | e_ok; c1 = 0;
+    testOk(!!(pch = dbChannelCreate("x.{\"strict\":{\"i\":1,\"f\":false,\"d\":1.2e15,\"s\":\"bar\",\"c\":\"R\"}}")), "strict parsing: JSON correct");
+    testOk(checkValues(puser1, 1, 0, 1.2e15, "bar", 1), "guards intact, values correct");
+    if (!testOk(c1 == e1, "all expected calls happened")) testDiag("expected %#x - called %#x", e1, c1);
+    e1 = e_close | e_free; c1 = 0;
+    testOk(!puser1, "user part cleaned up");
+    /* Any one missing must fail */
+    testHead("STRICT parsing: any missing parameter must fail");
+    e1 = e_alloc | e_error | e_free; c1 = 0;
+    testOk(!(pch = dbChannelCreate("x.{\"strict\":{\"i\":1,\"f\":false,\"d\":1.2e15,\"s\":\"bar\"}}")), "strict parsing: c missing");
+    testOk(!(pch = dbChannelCreate("x.{\"strict\":{\"f\":false,\"i\":1,\"d\":1.2e15,\"c\":\"R\"}}")), "strict parsing: s missing");
+    testOk(!(pch = dbChannelCreate("x.{\"strict\":{\"i\":1,\"c\":\"R\",\"f\":false,\"s\":\"bar\"}}")), "strict parsing: d missing");
+    testOk(!(pch = dbChannelCreate("x.{\"strict\":{\"d\":1.2e15,\"c\":\"R\",\"i\":1,\"s\":\"bar\"}}")), "strict parsing: f missing");
+    testOk(!(pch = dbChannelCreate("x.{\"strict\":{\"c\":\"R\",\"s\":\"bar\",\"f\":false,\"d\":1.2e15}}")), "strict parsing: i missing");
+    /* NOCONV parsing: optional, no conversion */
+    /* Any one missing must leave the default intact */
+    testHead("NOCONV parsing: any missing parameter must fall back to default value");
+    testOk(!!(pch = dbChannelCreate("x.{\"noconv\":{\"i\":1,\"f\":false,\"d\":1.2e15,\"s\":\"bar\"}}")), "noconv parsing: c missing");
+    testOk(checkValues(puser1, 1, 0, 1.2e15, "bar", 4), "guards intact, values correct");
+    e1 = e_any;
+    testOk(!!(pch = dbChannelCreate("x.{\"noconv\":{\"i\":1,\"f\":false,\"d\":1.2e15,\"c\":\"R\"}}")), "noconv parsing: s missing");
+    testOk(checkValues(puser1, 1, 0, 1.2e15, "hello", 1), "guards intact, values correct");
+    testOk(!!(pch = dbChannelCreate("x.{\"noconv\":{\"i\":1,\"f\":false,\"s\":\"bar\",\"c\":\"R\"}}")), "noconv parsing: d missing");
+    testOk(checkValues(puser1, 1, 0, 1.234e5, "bar", 1), "guards intact, values correct");
+    testOk(!!(pch = dbChannelCreate("x.{\"noconv\":{\"i\":1,\"d\":1.2e15,\"s\":\"bar\",\"c\":\"R\"}}")), "noconv parsing: f missing");
+    testOk(checkValues(puser1, 1, 1, 1.2e15, "bar", 1), "guards intact, values correct");
+    testOk(!!(pch = dbChannelCreate("x.{\"noconv\":{\"f\":false,\"d\":1.2e15,\"s\":\"bar\",\"c\":\"R\"}}")), "noconv parsing: i missing");
+    testOk(checkValues(puser1, 12, 0, 1.2e15, "bar", 1), "guards intact, values correct");
+    /* Reject wrong types */
+#define WRONGTYPETEST(Var, Val, Typ) \
+    e1 = e_alloc | e_error | e_free; c1 = 0; \
+    testOk(!(pch = dbChannelCreate("x.{\"noconv\":{\""#Var"\":"#Val"}}")), "noconv parsing: wrong type "#Typ" for "#Var); \
+    testOk(!puser1, "user part cleaned up"); \
+    testHead("NOCONV parsing: rejection of wrong parameter types");
+    WRONGTYPETEST(i, 123.0, double);
+    WRONGTYPETEST(i, true, boolean);
+    WRONGTYPETEST(i, "1", string);
+    WRONGTYPETEST(f, "false", string);
+    WRONGTYPETEST(f, 0.0, double);
+    WRONGTYPETEST(f, 1, integer);
+    WRONGTYPETEST(d, "1.2", string);
+    WRONGTYPETEST(d, true, boolean);
+    WRONGTYPETEST(d, 123, integer);
+    WRONGTYPETEST(s, 1.23, double);
+    WRONGTYPETEST(s, true, boolean);
+    WRONGTYPETEST(s, 123, integer);
+    WRONGTYPETEST(c, 1.23, double);
+    WRONGTYPETEST(c, true, boolean);
+    WRONGTYPETEST(c, 2, integer);
+    /* SLOPPY parsing: optional, with conversion */
+#define CONVTESTGOOD(Var, Val, Typ, Ival, Fval, Dval, Sval, Cval) \
+    e1 = e_alloc | e_ok; c1 = 0; \
+    testOk(!!(pch = dbChannelCreate("x.{\"sloppy\":{\""#Var"\":"#Val"}}")), "sloppy parsing: "#Typ" (good) for "#Var); \
+    testOk(checkValues(puser1, Ival, Fval, Dval, Sval, Cval), "guards intact, values correct"); \
+    if (!testOk(c1 == e1, "create channel: all expected calls happened")) testDiag("expected %#x - called %#x", e1, c1); \
+    e1 = e_close | e_free; c1 = 0; \
+    if (pch) dbChannelDelete(pch); \
+    if (!testOk(c1 == e1, "delete channel: all expected calls happened")) testDiag("expected %#x - called %#x", e1, c1);
+#define CONVTESTBAD(Var, Val, Typ) \
+    testOk(!(pch = dbChannelCreate("x.{\"sloppy\":{\""#Var"\":"#Val"}}")), "sloppy parsing: "#Typ" (bad) for "#Var); \
+    /* To integer */
+    testHead("SLOPPY parsing: conversion to integer");
+    CONVTESTGOOD(i, "123e4", positive string, 123, 1, 1.234e5, "hello", 4);
+    CONVTESTGOOD(i, "-12345", negative string, -12345, 1, 1.234e5, "hello", 4);
+    CONVTESTBAD(i, "9234567890", out-of-range string);
+    CONVTESTBAD(i, ".4", invalid string);
+    CONVTESTGOOD(i, false, valid boolean, 0, 1, 1.234e5, "hello", 4);
+    CONVTESTGOOD(i, 3456.789, valid double, 3456, 1, 1.234e5, "hello", 4);
+    CONVTESTBAD(i, 34.7e14, out-of-range double);
+    /* To boolean */
+    testHead("SLOPPY parsing: conversion to boolean");
+    CONVTESTGOOD(f, "false", valid string, 12, 0, 1.234e5, "hello", 4);
+    CONVTESTGOOD(f, "False", capital valid string, 12, 0, 1.234e5, "hello", 4);
+    CONVTESTGOOD(f, "0", 0 string, 12, 0, 1.234e5, "hello", 4);
+    CONVTESTGOOD(f, "15", 15 string, 12, 1, 1.234e5, "hello", 4);    /* Any one missing must leave the default intact */
+    CONVTESTBAD(f, ".4", invalid .4 string);
+    CONVTESTBAD(f, "Flase", misspelled invalid string);
+    CONVTESTGOOD(f, 0, zero integer, 12, 0, 1.234e5, "hello", 4);
+    CONVTESTGOOD(f, 12, positive integer, 12, 1, 1.234e5, "hello", 4);
+    CONVTESTGOOD(f, -1234, negative integer, 12, 1, 1.234e5, "hello", 4);
+    CONVTESTGOOD(f, 0.4, positive non-zero double, 12, 1, 1.234e5, "hello", 4);
+    CONVTESTGOOD(f, 0.0, zero double, 12, 0, 1.234e5, "hello", 4);
+    CONVTESTGOOD(f, -0.0, minus-zero double, 12, 0, 1.234e5, "hello", 4);
+    CONVTESTGOOD(f, -1.24e14, negative double, 12, 1, 1.234e5, "hello", 4);
+    /* To double */
+    testHead("SLOPPY parsing: conversion to double");
+    CONVTESTGOOD(d, "123e4", positive double string, 12, 1, 1.23e6, "hello", 4);
+    CONVTESTGOOD(d, "-7.89e-14", negative double string, 12, 1, -7.89e-14, "hello", 4);
+    CONVTESTGOOD(d, "123", positive integer string, 12, 1, 123.0, "hello", 4);
+    CONVTESTGOOD(d, "-1234567", negative integer string, 12, 1, -1.234567e6, "hello", 4);
+    CONVTESTBAD(d, "1.67e407", out-of-range double string);
+    CONVTESTBAD(d, "blubb", invalid blubb string);
+    CONVTESTGOOD(d, 123, positive integer, 12, 1, 123.0, "hello", 4);
+    CONVTESTGOOD(d, -12345, negative integer, 12, 1, -1.2345e4, "hello", 4);
+    CONVTESTGOOD(d, true, true boolean, 12, 1, 1.0, "hello", 4);
+    CONVTESTGOOD(d, false, false boolean, 12, 1, 0.0, "hello", 4);
+    /* To string */
+    testHead("SLOPPY parsing: conversion to string");
+    CONVTESTGOOD(s, 12345, positive integer, 12, 1, 1.234e5, "12345", 4);
+    CONVTESTGOOD(s, -1234567891, negative integer, 12, 1, 1.234e5, "-1234567891", 4);
+    CONVTESTGOOD(s, true, true boolean, 12, 1, 1.234e5, "true", 4);
+    CONVTESTGOOD(s, false, false boolean, 12, 1, 1.234e5, "false", 4);
+    CONVTESTGOOD(s, 123e4, small positive double, 12, 1, 1.234e5, "1230000", 4);
+    CONVTESTGOOD(s, -123e24, negative double, 12, 1, 1.234e5, "-1.23e+26", 4);
+    CONVTESTGOOD(s, -1.23456789123456789e26, large rounded negative double, 12, 1, 1.234e5, "-1.234567891235e+26", 4);
+    /* To Enum */
+    testHead("SLOPPY parsing: conversion to enum");
+    CONVTESTGOOD(c, 2, valid integer choice, 12, 1, 1.234e5, "hello", 2);
+    CONVTESTBAD(c, 3, invalid integer choice);
+    CONVTESTBAD(c, 3.2, double);
+    CONVTESTGOOD(c, "R", valid string choice, 12, 1, 1.234e5, "hello", 1);
+    CONVTESTBAD(c, "blubb", invalid string choice);
+    /* Registering and running filter callbacks */
+#define CHAINTEST1(Type, Json, ExpReg, ExpRun, DType) \
+    testHead("Filter chain test, "Type" filter"); \
+    offset = 0; \
+    testOk(!!(pch = dbChannelCreate("x."Json)), "filter chains: create channel with "Type" filter"); \
+    e1 = e_open | ExpReg; c1 = 0; \
+    testOk(!dbChannelOpen(pch), "dbChannelOpen returned channel"); \
+    if (!testOk(c1 == e1, "open channel: all expected calls happened")) testDiag("expected %#x - called %#x", e1, c1); \
+    e1 = ExpRun; c1 = 0; \
+    testOk(!!(pfl = db_create_read_log(pch)), "create db_field_log"); \
+    pfl->type = dbfl_type_ref; \
+    pfl->field_type = TYPE_START; \
+    testOk(!!(pfl = dbChannelRunPreChain(pch, pfl)), "run pre eventq chain"); \
+    testOk(!!(pfl = dbChannelRunPostChain(pch, pfl)), "run post eventq chain"); \
+    testOk(pfl->field_type == TYPE_START + DType, "final data type is correct"); \
+    db_delete_field_log(pfl); \
+    if (!testOk(c1 == e1, "run filter chains: all expected calls happened")) testDiag("expected %#x - called %#x", e1, c1); \
+    e1 = e_report; c1 = 0; \
+    dbChannelShow(pch, R_LEVEL, 0); \
+    if (!testOk(c1 == e1, "report: all expected calls happened")) testDiag("expected %#x - called %#x", e1, c1); \
+#define CHAINTEST2(Type, Json, ExpReg1, ExpRun1, ExpReg2, ExpRun2, DType) \
+    testHead("Filter chain test, "Type" filters"); \
+    offset = 0; \
+    e2 = e_alloc | e_ok; c2 = 0; \
+    testOk(!!(pch = dbChannelCreate("x."Json)), "filter chains: create channel with "Type" filters"); \
+    if (!testOk(c1 == e1, "create channel (1): all expected calls happened")) testDiag("expected %#x - called %#x", e1, c1); \
+    if (!testOk(c2 == e2, "create channel (2): all expected calls happened")) testDiag("expected %#x - called %#x", e2, c2); \
+    e1 = e_open | ExpReg1; c1 = 0; \
+    e2 = e_open | ExpReg2; c2 = 0; \
+    if (pch) testOk(!dbChannelOpen(pch), "dbChannelOpen returned channel"); \
+    if (!testOk(c1 == e1, "open channel (1): all expected calls happened")) testDiag("expected %#x - called %#x", e1, c1); \
+    if (!testOk(c2 == e2, "open channel (2): all expected calls happened")) testDiag("expected %#x - called %#x", e2, c2); \
+    e1 = ExpRun1; c1 = 0; \
+    e2 = ExpRun2; c2 = 0; \
+    if (pch) testOk(!!(pfl = db_create_read_log(pch)), "create db_field_log"); \
+    if (pch) testOk(!!(pfl = dbChannelRunPreChain(pch, pfl)) || (drop >=0 && drop <= 1), "run pre eventq chain"); \
+    if (pch && (drop < 0 || drop >= 2)) testOk(!!(pfl = dbChannelRunPostChain(pch, pfl)) || drop >=2, "run post eventq chain"); \
+    if (pfl) testOk(pfl->field_type == TYPE_START + DType, "final data type is correct"); \
+    if (pfl) db_delete_field_log(pfl); \
+    if (!testOk(c1 == e1, "run filter chains (1): all expected calls happened")) testDiag("expected %#x - called %#x", e1, c1); \
+    if (!testOk(c2 == e2, "run filter chains (2): all expected calls happened")) testDiag("expected %#x - called %#x", e2, c2); \
+    e2 = e_report; c2 = 0; \
+    if (!testOk(c1 == e1, "report (1): all expected calls happened")) testDiag("expected %#x - called %#x", e1, c1); \
+    if (!testOk(c2 == e2, "report (2): all expected calls happened")) testDiag("expected %#x - called %#x", e2, c2); \
+    e2 = e_close | e_free; c2 = 0; \
+    if (!testOk(c1 == e1, "delete channel (1): all expected calls happened")) testDiag("expected %#x - called %#x", e1, c1); \
+    if (!testOk(c2 == e2, "delete channel (2): all expected calls happened")) testDiag("expected %#x - called %#x", e2, c2);
+    CHAINTEST1("1 pre", "{\"pre\":{}}", e_reg_pre, e_pre | e_dtor, 1);                                        /* One filter, pre chain */
+    CHAINTEST1("1 post", "{\"post\":{}}", e_reg_post, e_post | e_dtor, 1);                                   /* One filter, post chain */
+    CHAINTEST1("1 both", "{\"sloppy\":{}}", e_reg_pre | e_reg_post, e_pre | e_post | e_dtor, 2);                   /* One, both chains */
+    CHAINTEST2("2 pre", "{\"pre\":{},\"pre\":{}}", e_reg_pre, e_pre | e_dtor, e_reg_pre, e_pre, 2);          /* Two filters, pre chain */
+    CHAINTEST2("2 post", "{\"post\":{},\"post\":{}}", e_reg_post, e_post | e_dtor, e_reg_post, e_post, 2);  /* Two filters, post chain */
+    CHAINTEST2("2 both", "{\"sloppy\":{},\"sloppy\":{}}",                                                          /* Two, both chains */
+               e_reg_pre | e_reg_post, e_pre | e_post | e_dtor, e_reg_pre | e_reg_post, e_pre | e_post, 4);
+    CHAINTEST2("1 pre, 1 post", "{\"pre\":{},\"post\":{}}", e_reg_pre, e_pre | e_dtor, e_reg_post, e_post, 2);   /* Two, pre then post */
+    CHAINTEST2("1 post, 1 pre", "{\"post\":{},\"pre\":{}}", e_reg_post, e_post, e_reg_pre, e_pre | e_dtor, 2);   /* Two, post then pre */
+    CHAINTEST2("1 pre, 1 both", "{\"pre\":{},\"sloppy\":{}}",                                                    /* Two, pre then both */
+               e_reg_pre, e_pre | e_dtor, e_reg_pre | e_reg_post, e_pre | e_post, 3);
+    CHAINTEST2("1 both, 1 pre", "{\"sloppy\":{},\"pre\":{}}",                                                    /* Two, both then pre */
+               e_reg_pre | e_reg_post, e_pre | e_post | e_dtor, e_reg_pre, e_pre, 3);
+    CHAINTEST2("1 post, 1 both", "{\"post\":{},\"sloppy\":{}}",                                                 /* Two, post then both */
+               e_reg_post, e_post, e_reg_pre | e_reg_post, e_pre | e_post | e_dtor, 3);
+    CHAINTEST2("1 both, 1 post", "{\"sloppy\":{},\"post\":{}}",                                                 /* Two, both then post */
+               e_reg_pre | e_reg_post, e_pre | e_post | e_dtor, e_reg_post, e_post, 3);
+    /* Plugins dropping updates */
+    drop = 0;
+    CHAINTEST2("2 both (drop at 0)", "{\"sloppy\":{},\"sloppy\":{}}",                            /* Two, both chains, drop at filter 0 */
+               e_reg_pre | e_reg_post, e_pre, e_reg_pre | e_reg_post, 0, -1);
+    drop = 1;
+    CHAINTEST2("2 both (drop at 1)", "{\"sloppy\":{},\"sloppy\":{}}",                            /* Two, both chains, drop at filter 1 */
+               e_reg_pre | e_reg_post, e_pre, e_reg_pre | e_reg_post, e_pre, -1);
+    drop = 2;
+    CHAINTEST2("2 both (drop at 2)", "{\"sloppy\":{},\"sloppy\":{}}",                            /* Two, both chains, drop at filter 2 */
+               e_reg_pre | e_reg_post, e_pre | e_post, e_reg_pre | e_reg_post, e_pre, -1);
+    drop = 3;
+    CHAINTEST2("2 both (drop at 3)", "{\"sloppy\":{},\"sloppy\":{}}",                            /* Two, both chains, drop at filter 3 */
+               e_reg_pre | e_reg_post, e_pre | e_post, e_reg_pre | e_reg_post, e_pre | e_post, -1);
+    drop = -1;
+#include <recSup.h>
+#include <epicsExport.h>
+static rset xRSET;
=== added file 'src/ioc/db/test/dbChannelTest.c'
--- src/ioc/db/test/dbChannelTest.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/test/dbChannelTest.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,260 @@
+* Copyright (c) 2010 UChicago Argonne LLC, as Operator of Argonne
+* Copyright (c) 2010 Brookhaven National Laboratory.
+* Copyright (c) 2010 Helmholtz-Zentrum Berlin
+*     fuer Materialien und Energie GmbH.
+ *  Author: Andrew Johnson <[email protected]>
+ *          Ralph Lange <[email protected]>
+/* Expected call bit definitions */
+#define e_start         0x00000001
+#define e_abort         0x00000002
+#define e_end           0x00000004
+#define e_null          0x00000008
+#define e_boolean       0x00000010
+#define e_integer       0x00000020
+#define e_double        0x00000040
+#define e_string        0x00000080
+#define e_start_map     0x00000100
+#define e_map_key       0x00000200
+#define e_end_map       0x00000400
+#define e_start_array   0x00000800
+#define e_end_array     0x00001000
+#define e_open          0x00002000
+#define e_reg_pre       0x00004000
+#define e_reg_post      0x00008000
+#define e_report        0x00010000
+#define e_close         0x00020000
+#define r_any (e_start | e_abort | e_end | \
+        e_null | e_boolean | e_integer | e_double | e_string | \
+        e_start_map | e_map_key | e_end_map | e_start_array | e_end_array)
+#define r_scalar (e_start | e_abort | e_end | \
+        e_null | e_boolean | e_integer | e_double | e_string)
+unsigned int e, r;
+#define p_ret(x) return r & x ? parse_continue : parse_stop
+parse_result p_start(chFilter *filter)
+    testOk(e & e_start, "parse_start called");
+    p_ret(e_start);
+void p_abort(chFilter *filter)
+    testOk(e & e_abort, "parse_abort called");
+parse_result p_end(chFilter *filter)
+    testOk(e & e_end, "parse_end called");
+    p_ret(e_end);
+parse_result p_null(chFilter *filter)
+    testOk(e & e_null, "parse_null called");
+    p_ret(e_null);
+parse_result p_boolean(chFilter *filter, int boolVal)
+    testOk(e & e_boolean, "parse_boolean called, val = %d", boolVal);
+    p_ret(e_boolean);
+parse_result p_integer(chFilter *filter, long integerVal)
+    testOk(e & e_integer, "parse_integer called, val = %ld", integerVal);
+    p_ret(e_integer);
+parse_result p_double(chFilter *filter, double doubleVal)
+    testOk(e & e_double, "parse_double called, val = %g", doubleVal);
+    p_ret(e_double);
+parse_result p_string(chFilter *filter, const char *stringVal, size_t stringLen)
+    testOk(e & e_string, "parse_string called, val = '%.*s'", (int) stringLen,
+            stringVal);
+    p_ret(e_string);
+parse_result p_start_map(chFilter *filter)
+    testOk(e & e_start_map, "parse_start_map called");
+    p_ret(e_start_map);
+parse_result p_map_key(chFilter *filter, const char *key, size_t stringLen)
+    testOk(e & e_map_key, "parse_map_key called, key = '%.*s'", (int) stringLen, key);
+    p_ret(e_map_key);
+parse_result p_end_map(chFilter *filter)
+    testOk(e & e_end_map, "parse_end_map called");
+    p_ret(e_end_map);
+parse_result p_start_array(chFilter *filter)
+    testOk(e & e_start_array, "parse_start_array called");
+    p_ret(e_start_array);
+parse_result p_end_array(chFilter *filter)
+    testOk(e & e_end_array, "parse_end_array called");
+    p_ret(e_end_array);
+long c_open(chFilter *filter)
+    testOk(e & e_open, "channel_open called");
+    return 0;
+void c_reg_pre(chFilter *filter, chPostEventFunc **cb_out, void **arg_out, db_field_log *probe)
+    testOk(e & e_reg_pre, "channel_register_pre called");
+void c_reg_post(chFilter *filter, chPostEventFunc **cb_out, void **arg_out, db_field_log *probe)
+    testOk(e & e_reg_post, "channel_register_post called");
+void c_report(chFilter *filter, int level, const unsigned short indent)
+    testOk(e & e_report, "channel_report called, level = %d", level);
+void c_close(chFilter *filter)
+    testOk(e & e_close, "channel_close called");
+chFilterIf testIf =
+    { p_start, p_abort, p_end, p_null, p_boolean, p_integer, p_double,
+      p_string, p_start_map, p_map_key, p_end_map, p_start_array, p_end_array,
+      c_open, c_reg_pre, c_reg_post, c_report, c_close };
+MAIN(dbChannelTest)
+    dbChannel *pch;
+    testPlan(69);
+    r = e = 0;
+    /* dbChannelTest() checks record and field names */
+    testOk1(!dbChannelTest("x.NAME"));
+    testOk1(!dbChannelTest("x.VAL"));
+    testOk1(!dbChannelTest("x."));
+    testOk1(!dbChannelTest("x"));
+    testOk(dbChannelTest("y"), "Test, nonexistent record");
+    testOk(dbChannelTest("x.NOFIELD"), "Test, nonexistent field");
+    /* dbChannelTest() allows but ignores field modifiers */
+    testOk1(!dbChannelTest("x.NAME$"));
+    testOk1(!dbChannelTest("x.{}"));
+    testOk1(!dbChannelTest("x.VAL{\"json\":true}"));
+    /* dbChannelCreate() accepts field modifiers */
+    testOk1(!!(pch = dbChannelCreate("x.{}")));
+    testOk1(!!(pch = dbChannelCreate("x.VAL{}")));
+    testOk1(!!(pch = dbChannelCreate("x.NAME$")));
+    testOk1(pch && pch->addr.no_elements > 1);
+    testOk1(!!(pch = dbChannelCreate("x.NAME${}")));
+    /* dbChannelCreate() rejects bad PVs */
+    testOk(!dbChannelCreate("y"), "Create, bad record");
+    testOk(!dbChannelCreate("x.NOFIELD"), "Create, bad field");
+    testOk(!dbChannelCreate("x.{not-json}"), "Create, bad JSON");
+    testOk(!dbChannelCreate("x.{\"none\":null}"), "Create, bad filter");
+    dbRegisterFilter("any", &testIf, NULL);
+    /* Parser event rejection by filter */
+    e = e_start;
+    testOk1(!dbChannelCreate("x.{\"any\":null}"));
+    r = e_start;
+    e = e_start | e_null | e_abort;
+    r = e_start | e_null;
+    e = e_start | e_null | e_end;
+    /* Successful parsing... */
+    r = r_any;
+    testOk1(!!(pch = dbChannelCreate("x.{\"any\":null}")));
+    e = e_close;
+    dbRegisterFilter("scalar", &testIf, NULL);
+    testOk1(!!(pch = dbChannelCreate("x.{\"scalar\":null}")));
+    e = e_report;
+    dbChannelShow(pch, 1, 2);
+    e = e_close;
+    e = e_start | e_start_array | e_boolean | e_integer | e_end_array
+            | e_end;
+    testOk1(!!(pch = dbChannelCreate("x.{\"any\":[true,1]}")));
+    e = e_close;
+    e = e_start | e_start_map | e_map_key | e_double | e_string | e_end_map
+            | e_end;
+    testOk1(!!(pch = dbChannelCreate("x.{\"any\":{\"a\":2.7183,\"b\":\"c\"}}")));
+    e = e_close;
+    /* More event rejection */
+    r = r_scalar;
+    e = e_start | e_start_array | e_abort;
+    testOk1(!dbChannelCreate("x.{\"scalar\":[null]}"));
+    e = e_start | e_start_map | e_abort;
+    testOk1(!dbChannelCreate("x.{\"scalar\":{}}"));
+#define GEN_SIZE_OFFSET
+static rset xRSET;
=== added file 'src/ioc/db/test/dbChannelTest.db'
--- src/ioc/db/test/dbChannelTest.db	1970-01-01 00:00:00 +0000
+++ src/ioc/db/test/dbChannelTest.db	2012-05-30 18:10:27 +0000
@@ -0,0 +1,2 @@
+record(x, x) {}
=== added file 'src/ioc/db/test/dbStateTest.c'
--- src/ioc/db/test/dbStateTest.c	1970-01-01 00:00:00 +0000
+++ src/ioc/db/test/dbStateTest.c	2012-05-30 18:10:27 +0000
@@ -0,0 +1,56 @@
+ *  Author: Ralph Lange <[email protected]>
+#include "dbState.h"
+MAIN(dbStateTest)
+    dbStateId red, red2, blue, blue2;
+    int i;
+    testPlan(20);
+    testOk(!dbStateFind("y"), "Finding nonexisting state fails");
+    testOk(!!(red = dbStateCreate("red")), "Create state 'red'");
+    testOk((red2 = dbStateFind("red")) == red, "Find 'red' returns correct id");
+    testOk((red2 = dbStateCreate("red")) == red, "Create existing 'red' returns correct id");
+    testOk(!dbStateFind("y"), "Finding nonexisting state still fails");
+    testOk(!!(blue = dbStateCreate("blue")), "Create state 'blue'");
+    testOk((blue2 = dbStateFind("blue")) == blue, "Find 'blue' returns correct id");
+    testOk((blue2 = dbStateCreate("blue")) == blue, "Create existing 'blue' returns correct id");
+    testOk((i = dbStateGet(red)) == 0, "Default 'red' state is 0");
+    testOk((i = dbStateGet(blue)) == 0, "Default 'blue' state is 0");
+    dbStateSet(red);
+    testOk((i = dbStateGet(red)) == 1, "After setting, 'red' state is 1");
+    testOk((i = dbStateGet(blue)) == 0, "'blue' state is 0");
+    dbStateSet(blue);
+    testOk((i = dbStateGet(blue)) == 1, "After setting, 'blue' state is 1");
+    testOk((i = dbStateGet(red)) == 1, "'red' state is 1");
+    dbStateClear(blue);
+    testOk((i = dbStateGet(blue)) == 0, "After clearing, 'blue' state is 0");
+    testOk((i = dbStateGet(red)) == 0, "After clearing, 'red' state is 0");
+    testOk((i = dbStateGet(blue)) == 0, "'red' state is 0");
=== added file 'src/ioc/db/test/xRecord.dbd'
--- src/ioc/db/test/xRecord.dbd	1970-01-01 00:00:00 +0000
+++ src/ioc/db/test/xRecord.dbd	2012-05-30 18:10:27 +0000
@@ -0,0 +1,12 @@
+# This is a combined minimal DBD and DB file
+recordtype(x) {
+  field(NAME, DBF_STRING) {
+    prompt("Record Name")
+    special(SPC_NOMOD)
+    size(61)
+  field(VAL, DBF_LONG) {
+    prompt("Value")
=== modified file 'src/ioc/dbStatic/dbBase.h'
--- src/ioc/dbStatic/dbBase.h	2010-10-05 19:27:37 +0000
+++ src/ioc/dbStatic/dbBase.h	2012-05-30 18:10:27 +0000
@@ -4,7 +4,7 @@
 * Copyright (c) 2002 The Regents of the University of California, as
 *     Operator of Los Alamos National Laboratory.
-* in file LICENSE that is included with this distribution.
 /* $Revision-Id$
@@ -19,7 +19,7 @@
 #include "dbFldTypes.h"
 #include "ellLib.h"
 #include "dbDefs.h"
 typedef struct dbMenu {
 	ELLNODE		node;
 	char		*name;
@@ -67,7 +67,7 @@
 	long		number;		/*number of brkInt in this table*/
 	struct brkInt	*paBrkInt;	/* ptr to array of brkInts */
 }brkTable;
 typedef struct dbFldDes{  /* field description */
 	char	*prompt; 	/*Prompt string for DCT*/
 	char	*name;		/*Field name*/
@@ -128,7 +128,7 @@
 	ELLNODE		node;
 	char		*name;
         char            *type;
 }dbVariableDef;
 typedef struct dbRecordType {
@@ -164,6 +164,7 @@
 	ELLLIST		functionList;
 	ELLLIST		variableList;
 	ELLLIST		bptList;
+	ELLLIST         filterList;
 	void		*pathPvt;
 	struct dbPvd	*ppvd;
 	struct gphPvt	*pgpHash;
=== modified file 'src/ioc/dbStatic/dbPvdLib.c'
--- src/ioc/dbStatic/dbPvdLib.c	2009-04-09 17:28:59 +0000
+++ src/ioc/dbStatic/dbPvdLib.c	2012-05-30 18:10:27 +0000
@@ -181,6 +181,7 @@
             ellDelete(&pbucket->list, (ELLNODE *)ppvdNode);
             free(ppvdNode);
+        epicsMutexUnlock(pbucket->lock);
         epicsMutexDestroy(pbucket->lock);
         free(pbucket);
=== modified file 'src/ioc/dbStatic/dbStaticLib.c'
--- src/ioc/dbStatic/dbStaticLib.c	2012-05-29 21:44:49 +0000
+++ src/ioc/dbStatic/dbStaticLib.c	2012-05-30 18:10:27 +0000
@@ -4,7 +4,7 @@
 /* $Revision-Id$ */
@@ -41,7 +41,7 @@
 #include "guigroup.h"
 #include "dbStaticLib.h"
 #include "dbStaticPvt.h"
 int dbStaticDebug = 0;
 static char *pNullString = "";
 #define messagesize	100
@@ -191,7 +191,7 @@
 sizeof(promptBBGPIB_IO)/sizeof(char *),
 sizeof(promptRF_IO)/sizeof(char *),
 sizeof(promptVXI_IO)/sizeof(char *)};
 /*forward references for private routines*/
 static FILE *openOutstream(const char *filename);
 static void finishOutstream(FILE *stream);
@@ -203,7 +203,7 @@
 static char *getpMessage(DBENTRY *pdbentry);
 static long putPvLink(DBENTRY *pdbentry,short pvlMask,const char *pvname);
 static long epicsShareAPI dbAddOnePath (DBBASE *pdbbase, const char *path, unsigned length);
 /* internal routines*/
@@ -347,7 +347,7 @@
     if(plink->text) free(plink->text);
     memset((char *)plink,0,sizeof(struct link));
 void dbFreePath(DBBASE *pdbbase)
     ELLLIST	*ppathList;
@@ -366,7 +366,7 @@
     return;
 static long mapLINKTtoFORMT(DBLINK *plink,dbFldDes *pflddes,int *ind)
     switch(plink->type) {
@@ -407,7 +407,7 @@
     return(S_dbLib_badLink);
 static void entryErrMessage(DBENTRY *pdbentry,long status,char *mess)
     char		message[200];
@@ -439,7 +439,7 @@
     strcat(pmessage,mess);
     errMessage(status,pmessage);
 static void zeroDbentry(DBENTRY *pdbentry)
     /*NOTE that pdbbase, message, and formpvt MUST NOT be set to NULL*/
@@ -466,7 +466,7 @@
     dbFldDes	*pflddes;
     DBLINK	*plink;
     char	*pname;
     dbGetFieldAddress(pdbentry);
     pflddes = pdbentry->pflddes;
     if(!pflddes) return(-1);
@@ -489,7 +489,7 @@
 /*Public only for dbStaticNoRun*/
 dbDeviceMenu *dbGetDeviceMenu(DBENTRY *pdbentry)
@@ -526,7 +526,7 @@
     pflddes->ftPvt = pdbDeviceMenu;
     return(pdbDeviceMenu);
 /* Beginning of Public Routines */
 #define INC_SIZE	256
@@ -555,7 +555,7 @@
     strcat(*string,src);
     *stringLength += strlen(src);
 dbBase * epicsShareAPI dbAllocBase(void)
     dbBase	*pdbbase;
@@ -568,6 +568,7 @@
     ellInit(&pdbbase->functionList);
     ellInit(&pdbbase->variableList);
     ellInit(&pdbbase->bptList);
+    ellInit(&pdbbase->filterList);
     gphInitPvt(&pdbbase->pgpHash,256);
     dbPvdInitPvt(pdbbase);
     return (pdbbase);
@@ -595,7 +596,7 @@
     brkTable		*pbrkTableNext;
     int			i;
     DBENTRY		dbentry;
     dbInitEntry(pdbbase,&dbentry);
     pdbRecordType = (dbRecordType *)ellFirst(&pdbbase->recordTypeList);
@@ -620,7 +621,7 @@
 	    free((void *)pdbFldDes->initial);
 	    if(pdbFldDes->field_type==DBF_DEVICE && pdbFldDes->ftPvt) {
 		dbDeviceMenu *pdbDeviceMenu;
 		pdbDeviceMenu = (dbDeviceMenu *)pdbFldDes->ftPvt;
 		free((void *)pdbDeviceMenu->papChoice);
 		free((void *)pdbDeviceMenu);
@@ -729,12 +730,12 @@
     free((void *)pdbbase);
     return;
 DBENTRY * epicsShareAPI dbAllocEntry(dbBase *pdbbase)
     DBENTRY *pdbentry;
-    pdbentry = dbmfMalloc(sizeof(DBENTRY));
+    pdbentry = dbmfMalloc(sizeof(DBENTRY));
     memset(pdbentry,'\0',sizeof(DBENTRY));
     pdbentry->pdbbase = pdbbase;
     return(pdbentry);
@@ -780,7 +781,7 @@
     pto->formpvt = NULL;
 long epicsShareAPI dbPath(DBBASE *pdbbase,const char *path)
     if(!pdbbase) return(-1);
@@ -796,7 +797,7 @@
     const char	*plast;
     unsigned	expectingPath;
     unsigned	sawMissingPath;
     ppathList = (ELLLIST *)pdbbase->pathPvt;
     if(!ppathList) {
@@ -865,7 +866,7 @@
     ELLLIST	*ppathList;
     dbPathNode *pdbPathNode;
@@ -877,7 +878,7 @@
     return 0;
 long epicsShareAPI dbWriteRecord(DBBASE *ppdbbase,const char *filename,
 	const char *precordTypename,int level)
@@ -974,7 +975,7 @@
     dbFinishEntry(pdbentry);
     return(0);
 long epicsShareAPI dbWriteMenu(
     DBBASE *ppdbbase,const char *filename,const char *menuName)
@@ -1017,7 +1018,7 @@
     return(0);
 long epicsShareAPI dbWriteRecordType(
     DBBASE *pdbbase,const char *filename,const char *recordTypeName)
@@ -1114,7 +1115,7 @@
     return(0);
 long epicsShareAPI dbWriteDevice(DBBASE *pdbbase,const char *filename)
     FILE *stream;
@@ -1156,7 +1157,7 @@
     return(0);
 long epicsShareAPI dbWriteDriver(DBBASE *pdbbase,const char *filename)
     FILE *stream;
@@ -1227,7 +1228,7 @@
     return(0);
 long epicsShareAPI dbWriteBreaktable(DBBASE *pdbbase,const char *filename)
     FILE *stream;
@@ -1262,7 +1263,7 @@
     return(0);
 long epicsShareAPI dbFindRecordType(DBENTRY *pdbentry,const char *recordType)
     dbBase	*pdbbase = pdbentry->pdbbase;
@@ -1306,7 +1307,7 @@
     return(ellCount(&pdbentry->pdbbase->recordTypeList));
 long epicsShareAPI dbPutRecordAttribute(
     DBENTRY *pdbentry, const char *name, const char*value)
@@ -1382,7 +1383,7 @@
     return dbGetAttributePart(pdbentry, &pname);
 long epicsShareAPI dbFirstField(DBENTRY *pdbentry,int dctonly)
@@ -1426,7 +1427,7 @@
 	indfield++;
 int epicsShareAPI dbGetFieldType(DBENTRY *pdbentry)
     dbFldDes  	*pflddes = pdbentry->pflddes;
@@ -1450,7 +1451,7 @@
     n = 0;
     for(indfield=0; indfield<precordType->no_fields; indfield++) {
 	pflddes = precordType->papFldDes[indfield];
-	if(dctonly && (pflddes->field_type==DBF_DEVICE)
+	if(dctonly && (pflddes->field_type==DBF_DEVICE)
 	&& (ellCount(&precordType->devList)==0) ) continue;
 	if(!dctonly || pflddes->promptgroup) n++;
@@ -1488,7 +1489,7 @@
     if(!pflddes) return(0);
     return(pflddes->promptgroup);
 long epicsShareAPI dbCreateRecord(DBENTRY *pdbentry,const char *precordName)
     dbRecordType	*precordType = pdbentry->precordType;
@@ -1535,7 +1536,7 @@
     if(!ppvd) {errMessage(-1,"Logic Err: Could not add to PVD");return(-1);}
     return(0);
 long epicsShareAPI dbDeleteAliases(DBENTRY *pdbentry)
@@ -1653,7 +1654,7 @@
         return dbFindField(pdbentry, ++pname);
     return 0;
 long epicsShareAPI dbFirstRecord(DBENTRY *pdbentry)
@@ -1706,7 +1707,7 @@
     if(!precnode) return NULL;
     return precnode->recordname;
 long epicsShareAPI dbRenameRecord(DBENTRY *pdbentry,const char *newName)
@@ -1752,7 +1753,7 @@
     /*Leave pdbentry pointing to newly renamed record*/
     return(dbFindRecord(pdbentry,newName));
 long epicsShareAPI dbVisibleRecord(DBENTRY *pdbentry)
     dbRecordNode	*precnode = pdbentry->precnode;
@@ -1778,7 +1779,7 @@
     if(!precnode) return 0;
     return precnode->flags & DBRN_FLAGS_VISIBLE ? 1 : 0;
 long epicsShareAPI dbCreateAlias(DBENTRY *pdbentry, const char *alias)
@@ -1828,7 +1829,7 @@
     return precnode->flags & DBRN_FLAGS_ISALIAS ? 1 : 0;
 long epicsShareAPI dbCopyRecord(DBENTRY *pdbentry,const char *newRecordName,int overWriteOK)
@@ -1882,7 +1883,7 @@
     /*Leave pdbentry pointing to newRecordName*/
     return(dbFindRecord(pdbentry,newRecordName));
 long epicsShareAPI dbFindFieldPart(DBENTRY *pdbentry,const char **ppname)
@@ -1967,7 +1968,7 @@
 int epicsShareAPI dbFoundField(DBENTRY *pdbentry)
 { return((pdbentry->pfield) ? TRUE : FALSE); }
 char * epicsShareAPI dbGetString(DBENTRY *pdbentry)
@@ -1997,7 +1998,7 @@
     case DBF_DEVICE:
 	return(dbGetStringNum(pdbentry));
     case DBF_INLINK:
-    case DBF_OUTLINK:
+    case DBF_OUTLINK:
 	if(!pfield) {strcpy(message,"Field not found"); return(message);}
 	plink = (DBLINK *)pfield;
@@ -2138,7 +2139,7 @@
     return (message);
 static void cvtDecimalOrHexToShort(char *from,short *value)
     if(strspn(from,"0x")==2 || strspn(from,"0X")==2) {
@@ -2264,7 +2265,7 @@
 		goto done;
 	    switch (plink->type) {
-	    case CONSTANT:
+	    case CONSTANT:
 	    case PV_LINK: {
 	    	    short	ppOpt = 0;
 		    short	msOpt = 0;
@@ -2428,7 +2429,7 @@
                 break;
             case GPIB_IO: {
-                    char *end;
+                    char *end;
 		    if(!(end = strchr(pstr,'#'))) return (S_dbLib_badField);
 		    pstr = end + 1;
@@ -2545,7 +2546,7 @@
     return(status);
 char * epicsShareAPI dbVerify(DBENTRY *pdbentry,const char *pstring)
@@ -2591,13 +2592,13 @@
 		return(message);
 	    switch (pflddes->field_type) {
-	    case DBF_CHAR :
+	    case DBF_CHAR :
 		if(value<-128 || value>127) {
 		    strcpy(message,"must have -128<=value<=127");
 		    return(message);
 		return(NULL);
-	    case DBF_SHORT :
+	    case DBF_SHORT :
 		if(value<-32768 || value>32767) {
 		    strcpy(message,"must have -32768<=value<=32767");
 		    return(message);
@@ -2626,14 +2627,14 @@
 		return(message);
-	    case DBF_UCHAR :
+	    case DBF_UCHAR :
 		if(value>255) {
 		    strcpy(message,"must have 0<=value<=255");
 		    return(message);
 		return(NULL);
 	    case DBF_ENUM:
-	    case DBF_USHORT :
+	    case DBF_USHORT :
 		if(value>65535) {
 		    strcpy(message,"must have 0<=value<=65535");
 		    return(message);
@@ -2646,7 +2647,7 @@
     case DBF_FLOAT:
-    case DBF_DOUBLE: {
+    case DBF_DOUBLE: {
 	    double value;
 	    char  *endp;
@@ -2661,7 +2662,7 @@
 	    dbMenu	*pdbMenu = (dbMenu *)pflddes->ftPvt;
 	    char	*pchoice;
 	    int		i;
 	    if(!pdbMenu) return(NULL);
 	    for (i = 0; i < pdbMenu->nChoice; i++) {
 		if(!(pchoice = pdbMenu->papChoiceValue[i])) continue;
@@ -2699,7 +2700,7 @@
     strcpy(message,"Not a valid field type");
     return (message);
 char *epicsShareAPI dbGetRange(DBENTRY *pdbentry)
@@ -2729,14 +2730,14 @@
     return (message);
 long epicsShareAPI dbFirstInfo(DBENTRY *pdbentry)
     pdbentry->pinfonode = NULL;
     if (!precnode) return (S_dbLib_recNotFound);
     pdbentry->pinfonode = (dbInfoNode *)ellFirst(&precnode->infoList);
     return (pdbentry->pinfonode ? 0 : S_dbLib_infoNotFound);
@@ -2745,11 +2746,11 @@
     dbInfoNode *pinfo;
     pinfo = pdbentry->pinfonode;
     if (!pinfo) return (S_dbLib_infoNotFound);
     pinfo = (dbInfoNode *)ellNext(&pinfo->node);
     pdbentry->pinfonode = pinfo;
     return (pinfo ? 0 : S_dbLib_infoNotFound);
@@ -2759,10 +2760,10 @@
     dbInfoNode *pinfo;
     if (!precnode) return(S_dbLib_recNotFound);
     pinfo = (dbInfoNode *)ellFirst(&precnode->infoList);
     while (pinfo) {
 	if (!strcmp(pinfo->name, name)) {
@@ -2778,7 +2779,7 @@
     dbInfoNode		*pinfo = pdbentry->pinfonode;
     ellDelete(&precnode->infoList,&pinfo->node);
@@ -2841,11 +2842,11 @@
     dbInfoNode *pinfo;
     dbFindInfo(pdbentry, name);
     if (pinfo) return (dbPutInfoString(pdbentry, string));
     /*Create new info node*/
     pinfo = calloc(1,sizeof(dbInfoNode));
     if (!pinfo) return (S_dbLib_outMem);
@@ -2875,7 +2876,7 @@
     if(!pgph) return(NULL);
     return((brkTable *)pgph->userPvt);
 dbMenu * epicsShareAPI dbFindMenu(dbBase *pdbbase,const char *name)
     GPHENTRY *pgph;
@@ -2933,7 +2934,7 @@
     return (-1);
 char * epicsShareAPI dbGetMenuStringFromIndex(DBENTRY *pdbentry, int index)
@@ -2996,13 +2997,13 @@
     return (-1);
 drvSup * epicsShareAPI dbFindDriver(dbBase *pdbbase, const char *name) {
     GPHENTRY *pgph = gphFind(pdbbase->pgpHash,name,&pdbbase->drvList);
     if (!pgph) return NULL;
     return (drvSup *) pgph->userPvt;
 int epicsShareAPI dbAllocForm(DBENTRY *psave)
     DBENTRY	dbEntry;
@@ -3076,7 +3077,7 @@
     return(nlines);
 long epicsShareAPI dbFreeForm(DBENTRY *pdbentry)
     if(pdbentry->formpvt) {
@@ -3093,7 +3094,7 @@
     if(!pform) return(NULL);
     return(pform->prompt);
 char  ** epicsShareAPI dbGetFormValue(DBENTRY *pdbentry)
     struct form *pform = pdbentry->formpvt;
@@ -3105,7 +3106,7 @@
     if(!plink) return(NULL);
     value = pform->value;
     switch(pform->linkType) {
-    case FORM_CONSTANT:
+    case FORM_CONSTANT:
 	if(plink->value.constantStr) {
 	    strcpy(*value,plink->value.constantStr);
 	} else {
@@ -3263,7 +3264,7 @@
     return(pform->value);
 long epicsShareAPI dbPutForm(DBENTRY *pdbentry,char **value)
@@ -3279,7 +3280,7 @@
     if(!plink) return(S_dbLib_badLink);
     verify = pform->verify;
 	**verify = 0; /*Initialize to no error*/
 	if(**value == '\0') break;
 	dvalue = epicsStrtod(*value,&endp);
@@ -3580,7 +3581,7 @@
 	**verify = 0;
 	break;
     case FORM_VXI_IO:
-	plink->value.vxiio.flag =
+	plink->value.vxiio.flag =
 	    ((strchr(*value,'Y')||strchr(*value,'y') ? VXIDYNAMIC : VXISTATIC));
 	value++; verify++;
 	lvalue = strtol(*value,&endp,0);
@@ -3619,7 +3620,7 @@
     return(status);
 char  ** epicsShareAPI dbVerifyForm(DBENTRY *pdbentry,char **value)
@@ -3664,7 +3665,7 @@
     return(rtnval);
 int  epicsShareAPI dbGetNLinks(DBENTRY *pdbentry)
@@ -3715,7 +3716,7 @@
     return(-1);
 long  epicsShareAPI dbCvtLinkToConstant(DBENTRY *pdbentry)
     dbFldDes	*pflddes;
@@ -3779,7 +3780,7 @@
 void  epicsShareAPI dbDumpPath(DBBASE *pdbbase)
     ELLLIST	*ppathList;
@@ -3821,7 +3822,7 @@
     dbWriteMenuFP(pdbbase,stdout,menuName);
 void epicsShareAPI dbDumpRecordType(DBBASE *pdbbase,const char *recordTypeName)
     dbRecordType *pdbRecordType;
@@ -3863,7 +3864,7 @@
 	if(recordTypeName) break;
 void  epicsShareAPI dbDumpField(
     DBBASE *pdbbase,const char *recordTypeName,const char *fname)
@@ -3955,7 +3956,7 @@
 void  epicsShareAPI dbDumpDevice(DBBASE *pdbbase,const char *recordTypeName)
@@ -4051,7 +4052,7 @@
     return;
 static char *bus[VXI_IO+1] = {"","","VME","CAMAC","AB",
 	"GPIB","BITBUS","","","","","","INST","BBGPIB","VXI"};
 void  epicsShareAPI dbReportDeviceConfig(dbBase *pdbbase,FILE *report)
=== modified file 'src/ioc/dbStatic/link.h'
--- src/ioc/dbStatic/link.h	2010-10-05 19:27:37 +0000
+++ src/ioc/dbStatic/link.h	2012-05-30 18:10:27 +0000
@@ -1,27 +1,24 @@
-* Copyright (c) 2002 The University of Chicago, as Operator of Argonne
 *     National Laboratory.
-* EPICS BASE Versions 3.13.7
-* and higher are distributed subject to a Software License Agreement found
 /* link.h */
-/* base/include $Revision-Id$ */
+/* $Id$ */
- *      Original Author: Bob Dalesio
- *      Current Author:  Marty Kraimer
- *      Date:            6-1-90
+ * Original Authors: Bob Dalesio, Marty Kraimer
+#ifndef INC_link_H
+#define INC_link_H
 #include "dbDefs.h"
 #include "shareLib.h"
-#ifndef INClinkh
-#define INClinkh 1
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -55,8 +52,8 @@
 /* structure of a PV_LINK DB_LINK and a CA_LINK	*/
 /*Options defined by pvlMask			*/
 #define pvlOptMsMode       0x3	/*Maximize Severity mode selection*/
-#define pvlOptNMS            0	/*Dont Maximize Severity*/
-#define pvlOptMS             1	/*Maximize Severity allways*/
+#define pvlOptNMS            0	/*Don't Maximize Severity*/
+#define pvlOptMS             1	/*Maximize Severity always*/
 #define pvlOptMSI            2	/*Maximize Severity if INVALID*/
 #define pvlOptMSS            3	/*Maximize Severity and copy Status*/
 #define pvlOptPP           0x4	/*Process Passive*/
@@ -77,14 +74,15 @@
 struct dbCommon;
+struct pvlet;
 struct pv_link {
-	char	*pvname;	/*pvname to link to*/
-	struct dbCommon *precord;	/*Address of record containing link*/
-	void	*pvt;		/*CA or DB private*/
-	LINKCVT	getCvt;		/*input conversion function*/
-	short	pvlMask;	/*Options mask*/
-	short	lastGetdbrType;	/*last dbrType for DB or CA get*/
+	char	*pvname;		/* pvname link points to */
+	struct dbCommon *precord;	/* Address of record owning link */
+	void	*pvt;			/* CA or DB private */
+	LINKCVT	getCvt;			/* input conversion function */
+	short	pvlMask;		/* Options mask */
+	short	lastGetdbrType;		/* last dbrType for DB or CA get */
 /* structure of a VME io channel */
@@ -150,13 +148,12 @@
 /* structure of an instrument io link */
 struct	instio {
-	char	*string;		/* the cat of location.
-							signal.parameter  */
+	char	*string;
 /* structure of a vxi link */
 struct	vxiio{
-	short	flag;				/* 0 = frame/slot, 1 = SA */
+	short	flag;			/* 0 = frame/slot, 1 = SA */
 	short	frame;
 	short	slot;
 	short	la;				/* logical address if flag =1 */
@@ -165,7 +162,7 @@
 /* union of possible address structures */
-union value{
+union value {
 	char		*constantStr;	/*constant string*/
 	struct macro_link macro_link;	/* link containing macro substitution*/
 	struct pv_link	pv_link;	/* link to process variable*/
@@ -180,9 +177,9 @@
 	struct	vxiio	vxiio;		/* vxi io */
-struct link{
-	union value	value;
-	short		type;
+struct link {
+	union value value;
+	short type;
         char		*text;		/* original INP/OUT link text */
@@ -191,4 +188,4 @@
 #ifdef __cplusplus
 #endif
-#endif /*INClinkh*/
+#endif /* INC_link_H */
=== modified file 'src/ioc/misc/iocInit.c'
--- src/ioc/misc/iocInit.c	2011-09-26 21:42:15 +0000
+++ src/ioc/misc/iocInit.c	2012-05-30 18:10:27 +0000
@@ -41,7 +41,6 @@
 #include "taskwd.h"
 #include "callback.h"
 #include "dbCommon.h"
-#include "dbLock.h"
 #include "devSup.h"
 #include "drvSup.h"
 #include "menuConvert.h"
@@ -59,6 +58,7 @@
 #include "initHooks.h"
 #include "epicsExit.h"
 #include "epicsSignal.h"
+#include "dbChannel.h"
 #define epicsExportSharedSymbols
 #include "epicsRelease.h"
@@ -426,48 +426,18 @@
 static void doResolveLinks(dbRecordType *pdbRecordType, dbCommon *precord,
     void *user)
+    dbFldDes **papFldDes = pdbRecordType->papFldDes;
+    short *link_ind = pdbRecordType->link_ind;
     devSup *pdevSup;
     int j;
-    /* Convert all PV_LINKs to DB_LINKs or CA_LINKs */
     /* For all the links in the record type... */
     for (j = 0; j < pdbRecordType->no_links; j++) {
-        dbFldDes *pdbFldDes =
-            pdbRecordType->papFldDes[pdbRecordType->link_ind[j]];
+        dbFldDes *pdbFldDes = papFldDes[link_ind[j]];
         DBLINK *plink = (DBLINK *)((char *)precord + pdbFldDes->offset);
-        if (plink->type == PV_LINK) {
-            DBADDR dbaddr;
-            if (plink == &precord->tsel) recGblTSELwasModified(plink);
-            if (!(plink->value.pv_link.pvlMask&(pvlOptCA|pvlOptCP|pvlOptCPP))
-                && (dbNameToAddr(plink->value.pv_link.pvname,&dbaddr)==0)) {
-                DBADDR  *pdbAddr;
-                plink->type = DB_LINK;
-                pdbAddr = dbCalloc(1,sizeof(struct dbAddr));
-                *pdbAddr = dbaddr; /*structure copy*/;
-                plink->value.pv_link.pvt = pdbAddr;
-            } else {/*It is a CA link*/
-                if (pdbFldDes->field_type == DBF_INLINK) {
-                    plink->value.pv_link.pvlMask |= pvlOptInpNative;
-                dbCaAddLink(plink);
-                if (pdbFldDes->field_type == DBF_FWDLINK) {
-                    char *pperiod =
-                        strrchr(plink->value.pv_link.pvname,'.');
-                    if (pperiod && strstr(pperiod,"PROC")) {
-                        plink->value.pv_link.pvlMask |= pvlOptFWD;
-                    } else {
-                        errlogPrintf("%s.FLNK is a Channel Access Link "
-                            " but does not link to a PROC field\n",
-                                precord->name);
+        if (plink->type == PV_LINK)
+            dbInitLink(precord, plink, pdbFldDes->field_type);
     pdevSup = dbDTYPtoDevSup(pdbRecordType, precord->dtyp);
     if (pdevSup) {
@@ -491,6 +461,7 @@
 static void initDatabase(void)
+    dbChannelInit();
     iterateRecords(doInitRecord0, NULL);
     iterateRecords(doResolveLinks, NULL);
     iterateRecords(doInitRecord1, NULL);
=== modified file 'src/ioc/registry/registerRecordDeviceDriver.pl'
--- src/ioc/registry/registerRecordDeviceDriver.pl	2012-03-27 15:47:59 +0000
+++ src/ioc/registry/registerRecordDeviceDriver.pl	2012-05-30 18:10:27 +0000
@@ -18,12 +18,18 @@
 use DBD::Parser;
 use EPICS::Readfile;
 use EPICS::Path;
+use EPICS::Getopts;
 use Text::Wrap;
+getopts('I@') or
+    die "Usage: registerRecordDeviceDriver [-I dir] in.dbd subroutinename [TOP]";
+my @path = map { split /[:;]/ } @EPICS::Getopts::opt_I; # FIXME: Broken on Win32?
 my ($file, $subname, $bldTop) = @ARGV;
 my $dbd = DBD->new();
-&ParseDBD($dbd, &Readfile($file));
+&ParseDBD($dbd, &Readfile($file, "", \@path));
 $Text::Wrap::columns = 75;
=== modified file 'src/ioc/rsrv/camessage.c'
--- src/ioc/rsrv/camessage.c	2010-11-01 21:01:04 +0000
+++ src/ioc/rsrv/camessage.c	2012-05-30 18:10:27 +0000
@@ -1,15 +1,19 @@
- *  Author: Jeffrey O. Hill
+ *  Author: Jeffrey O. Hill <[email protected]>
 #include <stddef.h>
@@ -45,7 +49,7 @@
 #include "rsrv.h"
 #include "server.h"
-#define RECORD_NAME(PADDR) ((PADDR)->precord->name)
+#define RECORD_NAME(CHAN) (dbChannelRecord(CHAN)->name)
 static EVENTFUNC read_reply;
@@ -60,9 +64,9 @@
     putNotify       dbPutNotify;
     caHdrLargeArray msg;
-     * Include a union of all scalar types
+     * Include a union of all scalar types
      * including fixed length strings so
-     * that in many cases we can avoid
+     * that in many cases we can avoid
      * allocating another buffer and only
      * use an rsrv_put_notify from its
      * free list.
@@ -173,8 +177,8 @@
      * allocate plenty of space for a sprintf() buffer
-    localStatus = cas_copy_in_header ( client,
-        CA_PROTO_ERROR, maxDiagLen, 0, 0, cid, status,
+    localStatus = cas_copy_in_header ( client,
+        CA_PROTO_ERROR, maxDiagLen, 0, 0, cid, status,
         ( void * ) &pReqOut );
     if ( localStatus != ECA_NORMAL ) {
         errlogPrintf ( "caserver: Unable to deliver err msg \"%s\" to client because \"%s\"\n",
@@ -187,7 +191,7 @@
      * copy back the request protocol
      * (in network byte order)
-    if ( ( curp->m_postsize >= 0xffff || curp->m_count >= 0xffff ) &&
+    if ( ( curp->m_postsize >= 0xffff || curp->m_count >= 0xffff ) &&
             CA_V49( client->minor_version_number ) ) {
         ca_uint32_t *pLW = ( ca_uint32_t * ) ( pReqOut + 1 );
         pReqOut->m_cmmd = htons ( curp->m_cmmd );
@@ -222,7 +226,7 @@
             size += (ca_uint32_t) (diagLen + 1u);
         else {
-            errlogPrintf (
+            errlogPrintf (
                 "caserver: vsend_err: epicsVsnprintf detected "
                 "error message truncation, pFormat = \"%s\"\n",
                 pformat );
@@ -282,9 +286,9 @@
 "CAS: Request from %s => cmmd=%d cid=0x%x type=%d count=%d postsize=%u\n",
         hostName, mp->m_cmmd, mp->m_cid, mp->m_dataType, mp->m_count, mp->m_postsize);
-    epicsPrintf (
-"CAS: Request from %s =>  available=0x%x \tN=%u paddr=%p\n",
-        hostName, mp->m_available, mnum, (pciu?(void *)&pciu->addr:NULL));
+    epicsPrintf (
+"CAS: Request from %s =>  available=0x%x \tN=%u dbch=%p\n",
+        hostName, mp->m_available, mnum, (pciu?(void *)&pciu->dbch:NULL));
     if (mp->m_cmmd==CA_PROTO_WRITE && mp->m_dataType==DBF_STRING && pPayLoad ) {
         epicsPrintf (
@@ -297,7 +301,7 @@
  * logBadIdWithFileAndLineno()
 static void logBadIdWithFileAndLineno(
-struct client       *client,
+struct client       *client,
 caHdrLargeArray     *mp,
 const void          *pPayload,
 char                *pFileName,
@@ -314,10 +318,10 @@
  * bad_udp_cmd_action()
-static int bad_udp_cmd_action ( caHdrLargeArray *mp,
+static int bad_udp_cmd_action ( caHdrLargeArray *mp,
                        void *pPayload, struct client *pClient )
-    log_header ("invalid (damaged?) request code from UDP",
+    log_header ("invalid (damaged?) request code from UDP",
         pClient, mp, pPayload, 0);
     return RSRV_ERROR;
@@ -325,13 +329,13 @@
  * udp_echo_action()
-static int udp_echo_action ( caHdrLargeArray *mp,
+static int udp_echo_action ( caHdrLargeArray *mp,
     char *pPayloadOut;
     int status;
     SEND_LOCK ( pClient );
-    status = cas_copy_in_header ( pClient, mp->m_cmmd, mp->m_postsize,
+    status = cas_copy_in_header ( pClient, mp->m_cmmd, mp->m_postsize,
         mp->m_dataType, mp->m_count, mp->m_cid, mp->m_available,
         ( void * ) &pPayloadOut );
     if ( status == ECA_NORMAL ) {
@@ -345,13 +349,13 @@
  * bad_tcp_cmd_action()
-static int bad_tcp_cmd_action ( caHdrLargeArray *mp, void *pPayload,
+static int bad_tcp_cmd_action ( caHdrLargeArray *mp, void *pPayload,
                            struct client *client )
     const char *pCtx = "invalid (damaged?) request code from TCP";
     log_header ( pCtx, client, mp, pPayload, 0 );
      *  by default, clients dont recover
      *  from this
@@ -365,7 +369,7 @@
  * tcp_version_action()
-static int tcp_version_action ( caHdrLargeArray *mp, void *pPayload,
+static int tcp_version_action ( caHdrLargeArray *mp, void *pPayload,
     double tmp;
@@ -406,13 +410,13 @@
  * tcp_echo_action()
-static int tcp_echo_action ( caHdrLargeArray *mp,
+static int tcp_echo_action ( caHdrLargeArray *mp,
     char *pPayloadOut;
     int status;
@@ -426,7 +430,7 @@
  * events_on_action ()
-static int events_on_action ( caHdrLargeArray *mp,
+static int events_on_action ( caHdrLargeArray *mp,
     db_event_flow_ctrl_mode_off ( pClient->evuser );
@@ -436,7 +440,7 @@
  * events_off_action ()
-static int events_off_action ( caHdrLargeArray *mp,
+static int events_off_action ( caHdrLargeArray *mp,
     db_event_flow_ctrl_mode_on ( pClient->evuser );
@@ -462,8 +466,8 @@
      * on failure to pre v41 clients
     if ( ! CA_V41 ( pClient->minor_version_number ) ) {
-        send_err ( &pevext->msg, ECA_GETFAIL, pClient,
-            RECORD_NAME ( &pevext->pciu->addr ) );
+        send_err ( &pevext->msg, ECA_GETFAIL, pClient,
+            RECORD_NAME ( pevext->pciu->dbch ) );
         return;
@@ -473,30 +477,30 @@
      * event/put/get callback.
      * Fetched value is zerod in case they
-     * use it even when the status indicates
+     * use it even when the status indicates
      * failure.
      * The m_cid field in the protocol
      * header is abused to carry the status
-    status = cas_copy_in_header ( pClient, pevext->msg.m_cmmd, pevext->size,
-        pevext->msg.m_dataType, pevext->msg.m_count, ECA_NORDACCESS,
+    status = cas_copy_in_header ( pClient, pevext->msg.m_cmmd, pevext->size,
+        pevext->msg.m_dataType, pevext->msg.m_count, ECA_NORDACCESS,
         pevext->msg.m_available, ( void * ) &pPayloadOut );
         memset ( pPayloadOut, 0, pevext->size );
         cas_commit_msg ( pClient, pevext->size );
     else {
-        send_err ( &pevext->msg, status, pClient,
+        send_err ( &pevext->msg, status, pClient,
             "server unable to load read access denied response into protocol buffer PV=\"%s max bytes=%u\"",
-            RECORD_NAME ( &pevext->pciu->addr ), rsrvSizeofLargeBufTCP );
+            RECORD_NAME ( pevext->pciu->dbch ), rsrvSizeofLargeBufTCP );
  *  read_reply()
-static void read_reply ( void *pArg, struct dbAddr *paddr,
+static void read_reply ( void *pArg, struct dbChannel *dbch,
                        int eventsRemaining, db_field_log *pfl )
     ca_uint32_t cid;
@@ -508,12 +512,14 @@
     int status;
     int v41;
     int autosize;
+    int local_fl = 0;
     long item_count;
     ca_uint32_t payload_size;
+    dbAddr *paddr=&dbch->addr;
      * New clients recv the status of the
      * operation directly to the
@@ -543,10 +549,10 @@
         pevext->msg.m_dataType, item_count, cid, pevext->msg.m_available,
         &pPayload );
     if ( status != ECA_NORMAL ) {
             "server unable to load read (or subscription update) response "
             "into protocol buffer PV=\"%s\" max bytes=%u",
-            RECORD_NAME ( paddr ), rsrvSizeofLargeBufTCP );
+            RECORD_NAME ( dbch ), rsrvSizeofLargeBufTCP );
         if ( ! eventsRemaining )
             cas_send_bs_msg ( pClient, FALSE );
         SEND_UNLOCK ( pClient );
@@ -564,19 +570,32 @@
         return;
-    status = db_get_field_and_count(
-        paddr, pevext->msg.m_dataType, pPayload, &item_count, pfl);
+    /* If filters are involved in a read, create field log and run filters */
+    if (!pfl && (ellCount(&dbch->pre_chain) || ellCount(&dbch->post_chain))) {
+        pfl = db_create_read_log(dbch);
+        if (pfl) {
+            local_fl = 1;
+            pfl = dbChannelRunPreChain(dbch, pfl);
+            pfl = dbChannelRunPostChain(dbch, pfl);
+    status = dbChannel_get_count ( dbch, pevext->msg.m_dataType,
+                  pPayload, &item_count, pfl);
+    if (local_fl) db_delete_field_log(pfl);
     if ( status < 0 ) {
          * I cant wait to redesign this protocol from scratch!
         if ( ! v41 ) {
-             * old client & plain get
+             * old client & plain get
              * continue to return an exception
              * on failure
-            send_err ( &pevext->msg, ECA_GETFAIL, pClient, RECORD_NAME ( paddr ) );
+            send_err ( &pevext->msg, ECA_GETFAIL, pClient, RECORD_NAME ( dbch ) );
         else {
             /* New clients recv the status of the operation directly to the
@@ -598,8 +617,8 @@
     else {
-        int cacStatus = caNetConvert (
-            pevext->msg.m_dataType, pPayload, pPayload,
+        int cacStatus = caNetConvert (
+            pevext->msg.m_dataType, pPayload, pPayload,
             TRUE /* host -> net format */, item_count );
         if ( cacStatus == ECA_NORMAL ) {
             ca_uint32_t data_size =
@@ -646,6 +665,8 @@
     void *pPayload;
     int status;
     int v41;
+    int local_fl = 0;
+    db_field_log *pfl = NULL;
     if ( ! pciu ) {
         logBadId ( pClient, mp, 0 );
@@ -655,18 +676,18 @@
     if ( INVALID_DB_REQ ( mp->m_dataType ) ) {
-        send_err ( mp, ECA_BADTYPE, pClient, RECORD_NAME ( &pciu->addr ) );
+        send_err ( mp, ECA_BADTYPE, pClient, RECORD_NAME ( pciu->dbch ) );
         return RSRV_ERROR;
     payloadSize = dbr_size_n ( mp->m_dataType, mp->m_count );
-    status = cas_copy_in_header ( pClient, mp->m_cmmd, payloadSize,
+    status = cas_copy_in_header ( pClient, mp->m_cmmd, payloadSize,
         mp->m_dataType, mp->m_count, pciu->cid, mp->m_available, &pPayload );
-        send_err ( mp, status, pClient,
+        send_err ( mp, status, pClient,
             "server unable to load read response into protocol buffer PV=\"%s\" max bytes=%u",
-            RECORD_NAME ( &pciu->addr ), rsrvSizeofLargeBufTCP );
+            RECORD_NAME ( pciu->dbch ), rsrvSizeofLargeBufTCP );
         return RSRV_OK;
@@ -682,25 +703,38 @@
         else{
             status = ECA_GETFAIL;
-            pClient, RECORD_NAME ( &pciu->addr ) );
+            pClient, RECORD_NAME ( pciu->dbch ) );
         return RSRV_OK;
-    status = db_get_field ( &pciu->addr, mp->m_dataType,
-                  pPayload, mp->m_count, 0 );
+    if (ellCount(&pciu->dbch->pre_chain) || ellCount(&pciu->dbch->post_chain)) {
+        pfl = db_create_read_log(pciu->dbch);
+        if (pfl) {
+            local_fl = 1;
+            pfl = dbChannelRunPreChain(pciu->dbch, pfl);
+            pfl = dbChannelRunPostChain(pciu->dbch, pfl);
+    status = dbChannel_get ( pciu->dbch, mp->m_dataType,
+                  pPayload, mp->m_count, pfl );
     if ( status < 0 ) {
-        send_err ( mp, ECA_GETFAIL, pClient, RECORD_NAME ( &pciu->addr ) );
+        send_err ( mp, ECA_GETFAIL, pClient, RECORD_NAME ( pciu->dbch ) );
         return RSRV_OK;
-    status = caNetConvert (
-        mp->m_dataType, pPayload, pPayload,
+    status = caNetConvert (
+        mp->m_dataType, pPayload, pPayload,
         TRUE /* host -> net format */, mp->m_count );
-        send_err ( mp, status, pClient, RECORD_NAME ( &pciu->addr ) );
+        send_err ( mp, status, pClient, RECORD_NAME ( pciu->dbch ) );
         return RSRV_OK;
@@ -717,7 +751,7 @@
         else {
             pStr[payloadSize-1] = '\0';
-            errlogPrintf (
+            errlogPrintf (
                 "caserver: read_action: detected DBR_STRING w/o nill termination "
                 "in response from db_get_field, pPayload = \"%s\"\n",
                 pStr );
@@ -754,11 +788,11 @@
      * favor of the standard db event calling
      * mechanism-  routine(userarg, paddr). See
      * events added above.
      * Hold argument set true so the send message
      * buffer is not flushed once each call.
-    read_reply ( &evext, &pciu->addr, TRUE, NULL );
+    read_reply ( &evext, pciu->dbch, TRUE, NULL );
     return RSRV_OK;
@@ -766,7 +800,7 @@
  * write_action()
-static int write_action ( caHdrLargeArray *mp,
+static int write_action ( caHdrLargeArray *mp,
                         void *pPayload, struct client *client )
     struct channel_in_use   *pciu;
@@ -791,25 +825,25 @@
         SEND_LOCK(client);
         send_err(
-            mp,
-            status,
-            client,
-            RECORD_NAME(&pciu->addr));
+            mp,
+            status,
+            client,
+            RECORD_NAME ( pciu->dbch ));
         SEND_UNLOCK(client);
         return RSRV_OK;
         FALSE /* net -> host format */, mp->m_count );
         log_header ("invalid data type", client, mp, pPayload, 0);
         SEND_LOCK(client);
         send_err(
-            mp,
-            status,
-            client,
+            mp,
+            status,
+            client,
         return RSRV_ERROR;
@@ -817,10 +851,10 @@
     asWritePvt = asTrapWriteBefore ( pciu->asClientPVT,
         pciu->client->pUserName ? pciu->client->pUserName : "",
         pciu->client->pHostName ? pciu->client->pHostName : "",
-        (void *) &pciu->addr );
+        pciu->dbch );
-    dbStatus = db_put_field(
-                  &pciu->addr,
+    dbStatus = dbChannel_put(
+                  pciu->dbch,
                   mp->m_dataType,
                   pPayload,
                   mp->m_count);
@@ -830,10 +864,10 @@
     if (dbStatus < 0) {
         SEND_LOCK(client);
         send_err(
-            mp,
-            ECA_PUTFAIL,
-            client,
+            mp,
+            ECA_PUTFAIL,
+            client,
@@ -852,8 +886,8 @@
     int                     chanCount;
     epicsMutexMustLock ( client->chanListLock );
-    chanCount =
-        ellCount ( &client->chanList ) +
+    chanCount =
+        ellCount ( &client->chanList ) +
         ellCount ( &client->chanPendingUpdateARList );
     epicsMutexUnlock( client->chanListLock );
@@ -872,13 +906,13 @@
     pName = (char *) pPayload;
     size = strlen(pName)+1;
     if (size > 512) {
-        log_header ( "bad (very long) host name",
+        log_header ( "bad (very long) host name",
         SEND_LOCK(client);
         send_err(
-            mp,
-            ECA_INTERNAL,
-            client,
+            mp,
+            ECA_INTERNAL,
+            client,
             "bad (very long) host name");
         return RSRV_ERROR;
@@ -889,7 +923,7 @@
     pMalloc = malloc(size);
     if(!pMalloc){
-        log_header ( "no space in pool for new host name",
+        log_header ( "no space in pool for new host name",
         SEND_LOCK(client);
         send_err(
@@ -901,8 +935,8 @@
         return RSRV_ERROR;
     strncpy(
-        pMalloc,
-        pName,
+        pMalloc,
+        pName,
         size-1);
     pMalloc[size-1]='\0';
@@ -912,13 +946,13 @@
         free ( pName );
-    DLOG (2, ( "CAS: host_name_action for \"%s\"\n",
+    DLOG (2, ( "CAS: host_name_action for \"%s\"\n",
         client->pHostName ? client->pHostName : "" ) );
     return RSRV_OK;
  * client_name_action()
@@ -931,8 +965,8 @@
     int                     chanCount;
-    chanCount =
+    chanCount =
@@ -951,13 +985,13 @@
     if (size > 512) {
-        log_header ("a very long user name was specified",
+        log_header ("a very long user name was specified",
         SEND_LOCK(client);
         send_err(
-            mp,
-            ECA_INTERNAL,
-            client,
+            mp,
+            ECA_INTERNAL,
+            client,
             "a very long user name was specified");
         return RSRV_ERROR;
@@ -968,7 +1002,7 @@
     if(!pMalloc){
-        log_header ("no memory for new user name",
+        log_header ("no memory for new user name",
         SEND_LOCK(client);
         send_err(
@@ -980,8 +1014,8 @@
         return RSRV_ERROR;
     strncpy(
-        pMalloc,
-        pName,
+        pMalloc,
+        pName,
         size-1);
@@ -999,7 +1033,7 @@
 static struct channel_in_use *casCreateChannel (
-struct dbAddr   *pAddr,
+struct dbChannel *dbch,
 unsigned    cid
@@ -1009,14 +1043,14 @@
     int         status;
     /* get block off free list if possible */
-    pchannel = (struct channel_in_use *)
+    pchannel = (struct channel_in_use *)
         freeListCalloc(rsrvChanFreeList);
     if (!pchannel) {
         return NULL;
     ellInit(&pchannel->eventq);
     epicsTimeGetCurrent(&pchannel->time_at_creation);
-    pchannel->addr = *pAddr;
+    pchannel->dbch = dbch;
     pchannel->client = client;
      * bypass read only warning
@@ -1046,8 +1080,8 @@
          * Verify that this id is not in use
         status = bucketAddItemUnsignedId (
-                pCaBucket,
-                &pchannel->sid,
+                pCaBucket,
+                &pchannel->sid,
                 pchannel);
     } while (status == S_bucket_idInUse);
@@ -1116,7 +1150,7 @@
             epicsMutexUnlock ( pclient->chanListLock );
-             * Update all event call backs
+             * Update all event call backs
             epicsMutexMustLock(pclient->eventqLock);
             for (pevext = (struct event_ext *) ellFirst(&pciu->eventq);
@@ -1175,8 +1209,8 @@
     SEND_LOCK ( pciu->client );
-        pciu->client, CA_PROTO_ACCESS_RIGHTS, 0,
+        pciu->client, CA_PROTO_ACCESS_RIGHTS, 0,
         0, 0, pciu->cid, ar, 0 );
      * OK to just ignore the request if the connection drops
@@ -1197,26 +1231,28 @@
     if ( v42 ) {
         int status;
         ca_uint32_t nElem;
+        long dbElem;
-        if ( pciu->addr.no_elements < 0 ) {
+        dbElem = dbChannelFinalElements(pciu->dbch);
+        if ( dbElem < 0 ) {
             nElem = 0;
         else {
             if ( ! CA_V49 ( pciu->client->minor_version_number ) ) {
-                if ( pciu->addr.no_elements >= 0xffff ) {
+                if ( dbElem >= 0xffff ) {
                     nElem = 0xfffe;
                 else {
-                    nElem = (ca_uint32_t) pciu->addr.no_elements;
+                    nElem = (ca_uint32_t) dbElem;
             else {
             pciu->client, CA_PROTO_CREATE_CHAN, 0u,
-            pciu->addr.dbr_field_type, nElem, pciu->cid,
+            dbChannelFinalExportType(pciu->dbch), nElem, pciu->cid,
             pciu->sid, NULL );
             cas_commit_msg ( pciu->client, 0u );
@@ -1228,7 +1264,7 @@
  * claim_ciu_action()
-static int claim_ciu_action ( caHdrLargeArray *mp,
+static int claim_ciu_action ( caHdrLargeArray *mp,
                             void *pPayload, client *client )
     int status;
@@ -1243,47 +1279,48 @@
     client->minor_version_number = mp->m_available;
     if (CA_V44(client->minor_version_number)) {
-        struct dbAddr  tmp_addr;
+        struct dbChannel *dbch;
         char *pName = (char *) pPayload;
          * check the sanity of the message
         if (mp->m_postsize<=1) {
-            log_header ( "empty PV name in UDP search request?",
+            log_header ( "empty PV name in UDP search request?",
             return RSRV_OK;
         pName[mp->m_postsize-1] = '\0';
-        status = db_name_to_addr (pName, &tmp_addr);
-        if (status) {
+        dbch = dbChannel_create (pName);
+        if (!dbch) {
             return RSRV_OK;
-        DLOG ( 2, ("CAS: claim_ciu_action found '%s', type %d, count %d\n",
-            pName, tmp_addr.dbr_field_type, tmp_addr.no_elements) );
+        DLOG ( 2, ("CAS: claim_ciu_action found '%s', type %d, count %d\n",
+            pName, dbChannelExportType(dbch), dbChannelElements(dbch)) );
         pciu = casCreateChannel (
-                client,
-                &tmp_addr,
+                client,
+                dbch,
                 mp->m_cid);
         if (!pciu) {
-            log_header ("no memory to create new channel",
+            log_header ("no memory to create new channel",
             SEND_LOCK(client);
-            send_err(mp,
-                ECA_ALLOCMEM,
-                client,
-                RECORD_NAME(&tmp_addr));
+            send_err(mp,
+                ECA_ALLOCMEM,
+                client,
+                RECORD_NAME(dbch));
+            dbChannelDelete(dbch);
             return RSRV_ERROR;
     else {
         epicsMutexMustLock(prsrv_cast_client->chanListLock);
-         * clients which dont claim their
+         * clients which dont claim their
          * channel in use block prior to
          * timeout must reconnect
@@ -1302,8 +1339,8 @@
             return RSRV_ERROR;
-         * duplicate claim message are unacceptable
+         * duplicate claim message are unacceptable
          * (so we disconnect the client)
         if (pciu->client!=prsrv_cast_client) {
@@ -1327,7 +1364,7 @@
          * who is claiming it
         ellDelete(
-            &prsrv_cast_client->chanList,
+            &prsrv_cast_client->chanList,
             &pciu->node);
         epicsMutexUnlock(prsrv_cast_client->chanListLock);
@@ -1343,12 +1380,12 @@
     status = asAddClient(
             &pciu->asClientPVT,
-            asDbGetMemberPvt(&pciu->addr),
-            asDbGetAsl(&pciu->addr),
+            asDbGetMemberPvt(pciu->dbch),
+            asDbGetAsl(pciu->dbch),
             client->pUserName ? client->pUserName : "",
-            client->pHostName ? client->pHostName : "");
+            client->pHostName ? client->pHostName : "");
     if(status != 0 && status != S_asLib_asNotActive){
-        log_header ("No room for security table",
+        log_header ("No room for security table",
         SEND_LOCK(client);
         send_err(mp, ECA_ALLOCMEM, client, "No room for security table");
@@ -1357,7 +1394,7 @@
-     * store ptr to channel in use block
+     * store ptr to channel in use block
      * in access security private
     asPutClientPvt(pciu->asClientPVT, pciu);
@@ -1366,7 +1403,7 @@
      * register for asynch updates of access rights changes
     status = asRegisterClientCallback(
-            pciu->asClientPVT,
+            pciu->asClientPVT,
             casAccessRightsCB);
     if ( status == S_asLib_asNotActive ) {
@@ -1378,10 +1415,10 @@
         claim_ciu_reply ( pciu );
     else if (status!=0) {
-        log_header ("No room for access security state change subscription",
+        log_header ("No room for access security state change subscription",
         SEND_LOCK(client);
-        send_err(mp, ECA_ALLOCMEM, client,
+        send_err(mp, ECA_ALLOCMEM, client,
             "No room for access security state change subscription");
         return RSRV_ERROR;
@@ -1429,7 +1466,7 @@
     db_post_extra_labor(pClient->evuser);
  * write_notify_reply()
  * (called by the CA server event task via the extra labor interface)
@@ -1477,18 +1514,18 @@
         asTrapWriteAfter ( asWritePvtTmp );
-         * the channel id field is being abused to carry
+         * the channel id field is being abused to carry
          * status here
         SEND_LOCK(pClient);
-            pClient, CA_PROTO_WRITE_NOTIFY,
-            0u, msgtmp.m_dataType, msgtmp.m_count, status,
+            pClient, CA_PROTO_WRITE_NOTIFY,
+            0u, msgtmp.m_dataType, msgtmp.m_count, status,
             msgtmp.m_available, 0 );
              * inability to aquire buffer space
-             * Indicates corruption
+             * Indicates corruption
             errlogPrintf("CA server corrupted - put call back(s) discarded\n");
@@ -1511,11 +1548,11 @@
 static void sendAllUpdateAS ( struct client *client )
-    struct channel_in_use *pciu;
+    struct channel_in_use *pciu;
-    pciu = ( struct channel_in_use * )
+    pciu = ( struct channel_in_use * )
         ellGet ( & client->chanPendingUpdateARList );
     while ( pciu ) {
         if ( pciu->state == rsrvCS_pendConnectRespUpdatePendAR ) {
@@ -1531,14 +1568,14 @@
         pciu->state = rsrvCS_inService;
         ellAdd ( & client->chanList, & pciu->node );
  * rsrv_extra_labor()
@@ -1562,8 +1599,8 @@
      * the cid field abused to contain status
      * during put cb replies
-    status = cas_copy_in_header ( client, CA_PROTO_WRITE_NOTIFY,
-        0u, mp->m_dataType, mp->m_count, statusCA,
+    status = cas_copy_in_header ( client, CA_PROTO_WRITE_NOTIFY,
+        0u, mp->m_dataType, mp->m_count, statusCA,
         mp->m_available, 0 );
         SEND_UNLOCK ( client );
@@ -1578,28 +1615,28 @@
 void initializePutNotifyFreeList (void)
     if ( ! rsrvPutNotifyFreeList ) {
-        freeListInitPvt ( &rsrvPutNotifyFreeList,
+        freeListInitPvt ( &rsrvPutNotifyFreeList,
             sizeof(struct rsrv_put_notify), 512 );
         assert ( rsrvPutNotifyFreeList );
-static struct rsrv_put_notify *
+static struct rsrv_put_notify *
     rsrvAllocPutNotify ( struct channel_in_use * pciu )
     struct rsrv_put_notify *pNotify;
     if ( rsrvPutNotifyFreeList ) {
         pNotify = (RSRVPUTNOTIFY *)
             freeListCalloc ( rsrvPutNotifyFreeList );
         if ( pNotify ) {
-            pNotify->dbPutNotify.pbuffer =
+            pNotify->dbPutNotify.pbuffer =
                     &pNotify->dbrScalarValue;
-            pNotify->valueSize =
+            pNotify->valueSize =
                     sizeof (pNotify->dbrScalarValue);
             pNotify->dbPutNotify.usrPvt = pciu;
-            pNotify->dbPutNotify.paddr = &pciu->addr;
-            pNotify->dbPutNotify.userCallback =
+            pNotify->dbPutNotify.chan = pciu->dbch;
+            pNotify->dbPutNotify.userCallback =
                     write_notify_call_back;
@@ -1609,18 +1646,18 @@
     return pNotify;
-static int rsrvExpandPutNotify (
+static int rsrvExpandPutNotify (
     struct rsrv_put_notify * pNotify, unsigned sizeNeeded )
     int booleanStatus;
     if ( sizeNeeded > pNotify->valueSize ) {
-         * try to use the union embeded in the free list
-         * item, but allocate a random sized block if they
+         * try to use the union embeded in the free list
+         * item, but allocate a random sized block if they
          * writing a vector.
-        if ( pNotify->valueSize >
+        if ( pNotify->valueSize >
             sizeof (pNotify->dbrScalarValue) ) {
             free ( pNotify->dbPutNotify.pbuffer );
@@ -1633,9 +1670,9 @@
              * revert back to the embedded union
             booleanStatus = FALSE;
@@ -1643,7 +1680,7 @@
     else {
         booleanStatus = TRUE;
     return booleanStatus;
@@ -1651,7 +1688,7 @@
     unsigned size = sizeof ( *pNotify );
     if ( pNotify ) {
                 sizeof ( pNotify->dbrScalarValue ) ) {
             size += pNotify->valueSize;
@@ -1659,7 +1696,7 @@
     return size;
-void rsrvFreePutNotify ( client *pClient,
+void rsrvFreePutNotify ( client *pClient,
         struct rsrv_put_notify *pNotify )
      if ( pNotify ) {
@@ -1671,16 +1708,16 @@
         epicsMutexUnlock ( pClient->putNotifyLock );
-         * if any possiblity that the put notify is
+         * if any possiblity that the put notify is
          * outstanding then cancel it
         if ( busyTmp ) {
             dbNotifyCancel ( &pNotify->dbPutNotify );
         epicsMutexMustLock ( pClient->putNotifyLock );
         if ( pNotify->onExtraLaborQueue ) {
-            ellDelete ( &pClient->putNotifyQue,
+            ellDelete ( &pClient->putNotifyQue,
                         &pNotify->node );
         busyTmp = pNotify->busy;
@@ -1692,7 +1729,7 @@
                 sizeof(pNotify->dbrScalarValue) ) {
@@ -1703,7 +1740,7 @@
  * write_notify_action()
-static int write_notify_action ( caHdrLargeArray *mp, void *pPayload,
+static int write_notify_action ( caHdrLargeArray *mp, void *pPayload,
     unsigned size;
@@ -1732,7 +1769,7 @@
     if ( pciu->pPutNotify ) {
-         * serialize concurrent put notifies
+         * serialize concurrent put notifies
         epicsMutexMustLock(client->putNotifyLock);
         while(pciu->pPutNotify->busy){
@@ -1757,7 +1794,7 @@
                 busyTmp = pciu->pPutNotify->busy;
                 if ( busyTmp ) {
                     if ( pciu->pPutNotify->onExtraLaborQueue ) {
-                        ellDelete ( &client->putNotifyQue,
+                        ellDelete ( &client->putNotifyQue,
                                     &pciu->pPutNotify->node );
                     pciu->pPutNotify->busy = FALSE;
@@ -1765,9 +1802,9 @@
                     pciu->pPutNotify->asWritePvt = 0;
                 epicsMutexUnlock(client->putNotifyLock);
                 if ( busyTmp ) {
-                    log_header("put call back time out", client,
+                    log_header("put call back time out", client,
                         &pciu->pPutNotify->msg, pciu->pPutNotify->dbPutNotify.pbuffer, 0);
                     putNotifyErrorReply (client, &pciu->pPutNotify->msg, ECA_PUTCBINPROG);
@@ -1784,15 +1821,15 @@
              * send error and go to next request
              * if there isnt enough memory left
-            log_header ( "no memory to initiate put notify",
+            log_header ( "no memory to initiate put notify",
             putNotifyErrorReply (client, mp, ECA_ALLOCMEM);
             return RSRV_ERROR;
     if ( ! rsrvExpandPutNotify ( pciu->pPutNotify, size ) ) {
-        log_header ( "no memory to initiate vector put notify",
+        log_header ( "no memory to initiate vector put notify",
         putNotifyErrorReply ( client, mp, ECA_ALLOCMEM );
         return RSRV_ERROR;
@@ -1803,8 +1840,8 @@
     pciu->pPutNotify->msg = *mp;
     pciu->pPutNotify->dbPutNotify.nRequest = mp->m_count;
-        mp->m_dataType, pPayload, pciu->pPutNotify->dbPutNotify.pbuffer,
+        mp->m_dataType, pPayload, pciu->pPutNotify->dbPutNotify.pbuffer,
@@ -1819,11 +1856,11 @@
         return RSRV_OK;
-    pciu->pPutNotify->asWritePvt = asTrapWriteBefore (
+    pciu->pPutNotify->asWritePvt = asTrapWriteBefore (
         pciu->asClientPVT,
+        pciu->dbch );
     dbPutNotify(&pciu->pPutNotify->dbPutNotify);
@@ -1849,10 +1886,10 @@
-     * stop further use of server if memory becomes scarse
+     * stop further use of server if memory becomes scarce
     spaceAvailOnFreeList = freeListItemsAvail ( rsrvEventFreeList ) > 0;
-    if ( osiSufficentSpaceInPool(sizeof(*pevext)) || spaceAvailOnFreeList ) {
+    if ( osiSufficentSpaceInPool(sizeof(*pevext)) || spaceAvailOnFreeList ) {
         pevext = (struct event_ext *) freeListCalloc (rsrvEventFreeList);
     else {
@@ -1860,14 +1897,14 @@
     if (!pevext) {
-        log_header ("no memory to add subscription",
+        log_header ("no memory to add subscription",
         SEND_LOCK(client);
         send_err(
             mp,
-            ECA_ALLOCMEM,
-            client,
+            ECA_ALLOCMEM,
+            client,
+            RECORD_NAME(pciu->dbch));
         return RSRV_ERROR;
@@ -1881,15 +1918,15 @@
     ellAdd( &pciu->eventq, &pevext->node);
     epicsMutexUnlock(client->eventqLock);
-    pevext->pdbev = db_add_event (client->evuser, &pciu->addr,
+    pevext->pdbev = db_add_event (client->evuser, pciu->dbch,
                 read_reply, pevext, pevext->mask);
     if (pevext->pdbev == NULL) {
-        log_header ("no memory to add subscription to db",
+        log_header ("no memory to add subscription to db",
         SEND_LOCK(client);
-        send_err (mp, ECA_ALLOCMEM, client,
-            "subscription install into record %s failed",
+        send_err (mp, ECA_ALLOCMEM, client,
+            "subscription install into record %s failed",
         return RSRV_ERROR;
@@ -1903,7 +1940,7 @@
      * of the socket would block. This prevents
      * a application program initiated deadlock.
-     * However when I am reconnecting I reissue
+     * However when I am reconnecting I reissue
      * the monitors and I could get deadlocked.
      * The client is blocked sending and the server
      * task for the client is blocked sending in
@@ -1914,7 +1951,7 @@
      * post_single_event() below instead of calling
      * read_reply() in this module. This is a complete
      * fix since a monitor setup is the only request
-     * soliciting a reply in the client which is
+     * soliciting a reply in the client which is
      * issued from inside of service.c (from inside
      * of the part of the ca client which services
      * messages sent by the server).
@@ -1940,13 +1977,13 @@
  *  clear_channel_reply()
-static int clear_channel_reply ( caHdrLargeArray *mp,
+static int clear_channel_reply ( caHdrLargeArray *mp,
      struct event_ext *pevext;
      int status;
       * Verify the channel
@@ -1957,43 +1994,43 @@
          logBadId ( client, mp, pPayload );
          return RSRV_ERROR;
      rsrvFreePutNotify ( client, pciu->pPutNotify );
      while (TRUE){
          epicsMutexMustLock(client->eventqLock);
          pevext = (struct event_ext *) ellGet(&pciu->eventq);
          if(!pevext){
              break;
          if (pevext->pdbev) {
              db_cancel_event (pevext->pdbev);
          freeListFree(rsrvEventFreeList, pevext);
      db_flush_extra_labor_event ( client->evuser );
       * send delete confirmed message
      SEND_LOCK(client);
-     status = cas_copy_in_header ( client, CA_PROTO_CLEAR_CHANNEL,
-        0u, mp->m_dataType, mp->m_count, mp->m_cid,
+     status = cas_copy_in_header ( client, CA_PROTO_CLEAR_CHANNEL,
+        0u, mp->m_dataType, mp->m_count, mp->m_cid,
         mp->m_available, NULL );
         return RSRV_ERROR;
      cas_commit_msg ( client, 0u );
-     if ( pciu->state == rsrvCS_inService ||
+     if ( pciu->state == rsrvCS_inService ||
             pciu->state == rsrvCS_pendConnectResp  ) {
         ellDelete ( &client->chanList, &pciu->node );
@@ -2004,22 +2041,22 @@
      else {
         SEND_LOCK(client);
-        send_err(mp, ECA_INTERNAL, client,
+        send_err(mp, ECA_INTERNAL, client,
             "channel was in strange state or corrupted during cleanup");
         return RSRV_ERROR;
       * remove from access control list
      status = asRemoveClient(&pciu->asClientPVT);
-         errMessage(status, RECORD_NAME(&pciu->addr));
+         errMessage(status, RECORD_NAME(pciu->dbch));
          return RSRV_ERROR;
      LOCK_CLIENTQ;
      status = bucketRemoveItemUnsignedId (pCaBucket, &pciu->sid);
      if(status != S_bucket_success){
@@ -2031,11 +2068,12 @@
      rsrvChannelCount--;
      UNLOCK_CLIENTQ;
+     dbChannelDelete(pciu->dbch);
      freeListFree(rsrvChanFreeList, pciu);
      return RSRV_OK;
  *  event_cancel_reply()
@@ -2049,7 +2087,7 @@
      int                    status;
@@ -2060,7 +2098,7 @@
          return RSRV_ERROR;
       * search events on this channel for a match
       * (there are usually very few monitors per channel)
@@ -2068,38 +2106,38 @@
             pevext; pevext = (struct event_ext *) ellNext(&pevext->node)){
          if (pevext->msg.m_available == mp->m_available) {
              ellDelete(&pciu->eventq, &pevext->node);
              break;
-      * Not Found- return an exception event
+      * Not Found- return an exception event
      if(!pevext){
          SEND_LOCK(client);
-         send_err(mp, ECA_BADMONID, client, RECORD_NAME(&pciu->addr));
+         send_err(mp, ECA_BADMONID, client, RECORD_NAME(pciu->dbch));
          return RSRV_ERROR;
       * cancel monitor activity in progress
      SEND_LOCK(client);
-     status = cas_copy_in_header ( client, pevext->msg.m_cmmd,
-        0u, pevext->msg.m_dataType, pevext->msg.m_count, pevext->msg.m_cid,
+     status = cas_copy_in_header ( client, pevext->msg.m_cmmd,
+        0u, pevext->msg.m_dataType, pevext->msg.m_count, pevext->msg.m_cid,
         pevext->msg.m_available, NULL );
@@ -2107,7 +2145,7 @@
      cas_commit_msg ( client, 0 );
      freeListFree (rsrvEventFreeList, pevext);
      return RSRV_OK;
@@ -2120,8 +2158,8 @@
     int status;
     SEND_LOCK(client);
-    status = cas_copy_in_header ( client, mp->m_cmmd,
+    status = cas_copy_in_header ( client, mp->m_cmmd,
@@ -2132,17 +2170,17 @@
     return RSRV_OK;
  *  search_fail_reply()
- *  Only when requested by the client
+ *  Only when requested by the client
  *  send search failed reply
 static void search_fail_reply ( caHdrLargeArray *mp, void *pPayload, struct client *client)
     int status;
     SEND_LOCK ( client );
-    status = cas_copy_in_header ( client, CA_PROTO_NOT_FOUND,
+    status = cas_copy_in_header ( client, CA_PROTO_NOT_FOUND,
         0u, mp->m_dataType, mp->m_count, mp->m_cid, mp->m_available, NULL );
@@ -2180,16 +2218,16 @@
      * sequence number is specified zero when we copy in the
-     * header because we dont know it until we receive a datagram
+     * header because we dont know it until we receive a datagram
      * from the client
-    status = cas_copy_in_header ( client, CA_PROTO_VERSION,
-        0, 0, CA_MINOR_PROTOCOL_REVISION,
+    status = cas_copy_in_header ( client, CA_PROTO_VERSION,
+        0, 0, CA_MINOR_PROTOCOL_REVISION,
         0, 0, 0 );
         return RSRV_ERROR;
     return RSRV_OK;
@@ -2200,7 +2238,6 @@
 static int search_reply_udp ( caHdrLargeArray *mp, void *pPayload, struct client *client )
     ca_uint16_t     *pMinorVersion;
     int             status;
@@ -2215,41 +2252,41 @@
-        log_header ("empty PV name in UDP search request?",
+        log_header ("empty PV name in UDP search request?",
         return RSRV_OK;
     /* Exit quickly if channel not on this node */
-    if (status) {
+    if (dbChannelTest(pName)) {
         DLOG ( 2, ( "CAS: Lookup for channel \"%s\" failed\n", pPayLoad ) );
         if (mp->m_dataType == DOREPLY)
             search_fail_reply ( mp, pPayload, client );
         return RSRV_OK;
     spaceAvailOnFreeList =     freeListItemsAvail ( rsrvChanFreeList ) > 0
                             && freeListItemsAvail ( rsrvEventFreeList ) > reasonableMonitorSpace;
-    spaceNeeded = sizeof (struct channel_in_use) +
+    spaceNeeded = sizeof (struct channel_in_use) +
         reasonableMonitorSpace * sizeof (struct event_ext);
-    if ( ! ( osiSufficentSpaceInPool(spaceNeeded) || spaceAvailOnFreeList ) ) {
+    if ( ! ( osiSufficentSpaceInPool(spaceNeeded) || spaceAvailOnFreeList ) ) {
         SEND_LOCK(client);
         send_err ( mp, ECA_ALLOCMEM, client, "Server memory exhausted" );
         return RSRV_OK;
      * starting with V4.4 the count field is used (abused)
      * to store the minor version number of the client.
      * New versions dont alloc the channel in response
      * to a search request.
+     * For these, allocation has been moved to claim_ciu_action().
      * m_count, m_cid are already in host format...
@@ -2259,49 +2296,58 @@
         type = ca_server_port;
     else {
         struct channel_in_use   *pchannel;
-        pchannel = casCreateChannel ( client, &tmp_addr, mp->m_cid );
+        dbch = dbChannel_create(pName);
+        if (!dbch) {
+            DLOG ( 2, ( "CAS: dbChannel Test of \"%s\" OK but Create failed\n", pName ) );
+            if (mp->m_dataType == DOREPLY)
+                search_fail_reply ( mp, pPayload, client );
+            return RSRV_OK;
+        pchannel = casCreateChannel ( client, dbch, mp->m_cid );
         if (!pchannel) {
             SEND_LOCK(client);
-            send_err ( mp, ECA_ALLOCMEM, client,
-                RECORD_NAME ( &tmp_addr ) );
+            send_err ( mp, ECA_ALLOCMEM, client,
+                RECORD_NAME ( dbch ) );
             return RSRV_OK;
         sid = pchannel->sid;
-        if ( tmp_addr.no_elements < 0 ) {
+        if ( dbChannelFinalElements(dbch) < 0 ) {
             count = 0;
-        else if ( tmp_addr.no_elements > 0xffff ) {
+        else if ( dbChannelFinalElements(dbch) > 0xffff ) {
             count = 0xfffe;
         else {
-            count = (ca_uint16_t) tmp_addr.no_elements;
+            count = (ca_uint16_t) dbChannelFinalElements(dbch);
-        type = (ca_uint16_t) tmp_addr.dbr_field_type;
+        type = (ca_uint16_t) dbChannelFinalExportType(dbch);
-    status = cas_copy_in_header ( client, CA_PROTO_SEARCH,
-        sizeof(*pMinorVersion), type, count,
-        sid, mp->m_available,
+    status = cas_copy_in_header ( client, CA_PROTO_SEARCH,
+        sizeof(*pMinorVersion), type, count,
+        sid, mp->m_available,
         ( void * ) &pMinorVersion );
         return RSRV_ERROR;
      * Starting with CA V4.1 the minor version number
      * is appended to the end of each search reply.
-     * This value is ignored by earlier clients.
+     * This value is ignored by earlier clients.
     *pMinorVersion = htons ( CA_MINOR_PROTOCOL_REVISION );
     cas_commit_msg ( client, sizeof ( *pMinorVersion ) );
     return RSRV_OK;
@@ -2311,7 +2357,6 @@
 static int search_reply_tcp (
     int             status;
     int             spaceAvailOnFreeList;
@@ -2329,8 +2374,7 @@
-    if (status) {
Re: [Merge] lp:~epics-core/epics-base/server-side-plugins into lp:epics-base Andrew Johnson
[Merge] lp:~epics-core/epics-base/server-side-plugins into lp:epics-base noreply
Prev: Re: R3.15.0 deadline approaching Michael Davidsaver
Next: [Merge] lp:~epics-core/epics-base/thread-pool into lp:epics-base mdavidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] lp:~epics-core/epics-base/server-side-plugins into lp:epics-base Andrew Johnson
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
