2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: epicsTimer and rounding
To: EPICS Core Talk <[email protected]>
Cc: Dirk Zimoch <[email protected]>
Date: Wed, 06 Jun 2012 12:31:29 +0200
While helping us with finding a weird behavior in a StreamDevice based
interface, Dirk Zimoch found the following:
When adapting the expire period (requested as a double value in seconds)
to the matching amount of sleep quantums, the current implementation of
epicsTimer rounds mathematically (line 71 of timer.cpp subtracts half a
quantum from the expire time). So, for requested expire periods in the
same order as the quantum, the actual expire period used by the timer is
up to 100% shorter than the requested period.
In the section about epicsTimer, the App Developers' does not make a
statement about the relation between requested and actual period.
IMHO, the actual expire period should always be equal or larger than the
requested value, i.e. the implementation should always round up when
converting to quantums. (And the doc should mention this behavior.)
What do you think?
Cheers,
~Ralph
RE: epicsTimer and rounding Hill, Jeff
Prev: [Merge] lp:~mdavidsaver/epics-base/epicsconf into lp:epics-base/3.14 Andrew Johnson
Next: RE: epicsTimer and rounding Hill, Jeff
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
