2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pend_io
To: "Hill, Jeff" <[email protected]>
Date: Tue, 26 Jun 2012 19:21:33 +0200
thanks Jeff,
perhaps the next release could have the caclient makebase app following this advice?
by the way, i dont remember this being necessary in the good old days :)
cheers
Steve
Sent from my iPhone
On 26 Jun 2012, at 19:12, "Hill, Jeff" <[email protected]> wrote:
Hi Steve,
I changed caget to caput :)
The value was not written to my ioc
int main (int argc, char *argv[])
       double  data=86;
       chid        mychid;
       SEVCHK(ca_create_channel(argv[1], NULL, NULL, 10,
                         &mychid),"failure");
       SEVCHK(ca_pend_io(10.0),"failure");
       SEVCHK(ca_array_put(DBR_DOUBLE, 1, mychid, &data),"failure");
It's true that ca_pend_io causes an implicit flush to occur (i.e the
equivalent of a call to ca_flush_io).
A call to ca_flush_io is analogous to placing a letter in the mail box. We know now that the problem of delivery is out of our hands and has been
entrusted to the postal service. So far so good, but the problem in
the above program is that a bomb has been dropped on our local postal
service before the letter can been delivered.
When your program exits from main without calling ca_context_destroy
then the ca client library's send threads are very ungracefully
terminated before they have been given a chance to deliver any
message that they might have in their work queues to TCP. Furthermore,
it is very OS dependent what might happen to any undelivered TCP messages lingering in the local IP kernel if you exit from main without given the
CA client library an opportunity to close its TCP sockets; we end up
with undefined behavior.
In contrast, if the program calls ca_context_destroy before exiting
from main then the CA client library will gracefully shut down its
worker threads delivering all outstanding messages to the IP kernel
before they exit, and also gracefully close all of its sockets;
now we expect defined behavior.
There is a (very brief) discussion of this issue in the troubleshooting
section of the CA reference manual - which perhaps could be expanded.
The bottom line is if you shouldn’t terminate the local postal servi ce
unless you provide also some additional funding for a close out :-)
Jeff
-----Original Message-----
From: [email protected] [mailto:core-talk- [email protected]]
On Behalf Of Steve Hunt
Sent: Tuesday, June 26, 2012 7:49 AM
To: [email protected]
Subject: pend_io
I have a problem running a trivial (too trivial it seems) ca client
program.
I fact I just generated the ca example using makeBaseApp.
I am running 3.14.12.2, on linux_x86_64 but the behavior seems the same
in older versions (at least 3.14.9(
I am sending this to core-talk rather than tech-talk as this seems to be
a real ca problem
#######3
#include <stddef.h>
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <cadef.h>
       double  data=86;
       chid        mychid;
//      SEVCHK(ca_array_get(DBR_DOUBLE, 1, mychid, &data),"failure");
//      SEVCHK(ca_pend_io(10.0),"failure");
//      SEVCHK(ca_flush_io(),"failure");
//      SEVCHK(ca_poll(),"failure");
//      sleep(10);
//      ca_context_destroy();
//      return result;
When I un-comment ca_poll, ca_context_destroy, ca_get (plus its
pend_io), or sleep!!!  it works!!!
so  a ca_poll, a ca_context_destroy, or a ca_pend_io AFTER a ca_get,
seems to flush the send buffer - but just ca_pend_io, nor ca_flush_io
seem not to do so.
At least the client example generated from makebaseApp should have a
ca_put added, and made to work without the ca_get, but perhaps this
could be considered a bug.
Re: pend_io Andrew Johnson
RE: pend_io Hill, Jeff
pend_io Steve Hunt
Prev: Re: pend_io Ernest L. Williams Jr.
Next: Re: pend_io Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: pend_io Hill, Jeff
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
