2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base
To: Ralph Lange <[email protected]>
Date: Fri, 29 Jun 2012 19:20:23 -0000
Should the AtThreadExits run before the ExitHooks?  You have this in several places:
  + epicsThreadRunExitHooks(pthreadInfo);
    epicsExitCallAtThreadExits ();
My feeling is that task-specific clean-up should happen before the generic task clean-up, so things nest nicely.
I think the Win32 calls to the epicsThreadRun*Hooks() routines belong in the epicsWin32ThreadEntry() routine, and epicsThreadHooksInit() should be called towards the bottom of fetchWin32ThreadGlobal() after the atexit() call but before initCompleted gets set (there doesn't look to be anything in the mutex creation code that would cause problems there).
Then with some tests in libCom/test/epicsThreadTest.cpp and comments in the Release Notes I think this should be good to go.  Eventually I'll want the API documenting in the AppDevGuide too, but not for this release.
- Andrew
https://code.launchpad.net/~ralph-lange/epics-base/thread-hooks/+merge/112806
Your team EPICS Core Developers is requested to review the proposed merge of lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base.
[Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Ralph Lange
Prev: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base mdavidsaver
Next: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <2012>  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Ralph Lange
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
