2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: alarm lag
To: "Pearson, Matthew R." <[email protected]>
Cc: EPICS core-talk <[email protected]>, "Chen, Xihui" <[email protected]>
Date: Thu, 30 May 2013 14:41:15 -0500
Hi Matt,
On 2013-05-30 Pearson, Matthew R. wrote:
> Should it be up to the record to decide which fields to update alarm status
> for? For example, ai has VAL and RVAL. The RVAL field has the same issue.
> But having a monitor on RVAL, and wanting alarm updates on it, is probably
> something people want to do.
It is already, in that any fixes have to be made in the Record.c file anyway
so different record types could come up with different semantics for monitor
updates.  However the record has no control over what alarm info gets returned
when you do a caget of one of the DBR-types that includes it, or for the first
monitor update after subscribing to a channel; the server code automatically
fills in the alarm data from the record's STAT and SEVR fields, and that can't
be overridden by the record.
The solution I want to adopt for monitors should make updates more unified,
but it does increase the network bandwidth used because we'll be sending out
more monitor events.  This is the output I'd like to see from the example
template:
tux2% camonitor anjHost:aiExample anjHost:aiExample.HIGH
anjHost:aiExample              2013-05-30 12:53:29.932526 4 LOW MINOR
anjHost:aiExample.HIGH         2013-05-30 12:53:29.932526 6 LOW MINOR
anjHost:aiExample              2013-05-30 12:53:30.932580 5
anjHost:aiExample.HIGH         2013-05-30 12:53:30.932580 6
anjHost:aiExample              2013-05-30 12:53:31.932526 6 HIGH MINOR
anjHost:aiExample.HIGH         2013-05-30 12:53:31.932526 6 HIGH MINOR
anjHost:aiExample              2013-05-30 12:53:32.932592 7 HIGH MINOR
anjHost:aiExample              2013-05-30 12:53:33.932526 8 HIHI MAJOR
anjHost:aiExample.HIGH         2013-05-30 12:53:33.932526 6 HIHI MAJOR
anjHost:aiExample              2013-05-30 12:53:34.932607 9 HIHI MAJOR
anjHost:aiExample              2013-05-30 12:53:35.932525 0 LOLO MAJOR
anjHost:aiExample.HIGH         2013-05-30 12:53:35.932525 6 LOLO MAJOR
anjHost:aiExample              2013-05-30 12:53:36.932587 1 LOLO MAJOR
anjHost:aiExample              2013-05-30 12:53:37.932526 2 LOLO MAJOR
anjHost:aiExample              2013-05-30 12:53:38.932585 3 LOW MINOR
anjHost:aiExample.HIGH         2013-05-30 12:53:38.932585 6 LOW MINOR
anjHost:aiExample              2013-05-30 12:53:39.932526 4 LOW MINOR
> Whereas having alarm updates for other fields might not mean much. However,
> one problem I see is with other records that might take these other fields
> as inputs. Would there be a problem with alarm propagation if, say, a calc
> record monitored a LOW or HIGH field in a ai record?
If you're using a link (DB or CA) with the alarm flags MS/MSS/MSI the alarm
data are fetched properly from the data source using a DBR_STS_xxx type or its
equivalent.  If we did develop the ability to provide per-field alarm data,
the only problem would be where a database explicitly asks for the .STAT or
.SEVR fields.  However I don't think it's particularly likely that we'd work
on this ability, there are many more pressing features that need working on
first IMHO.
- Andrew
It is difficult to get a man to understand something, when his salary
depends upon his not understanding it. -- Upton Sinclair
Re: alarm lag Kasemir, Kay
Re: alarm lag Pearson, Matthew R.
Prev: Re: alarm lag Andrew Johnson
Next: [Merge] lp:~anj/epics-base/udf-severity into lp:epics-base noreply
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: alarm lag Pearson, Matthew R.
Next: Re: alarm lag Andrew Johnson
