2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/parallel-cbthreads-2 into lp:epics-base
To: Ralph Lange <[email protected]>
Date: Tue, 22 Oct 2013 22:03:52 -0000
Michael,
please check if you approve my change to your update-callback stuff. The API suggested one completion callback for all priorities (hence the priority argument in the completion callback function prototype), but the code was only calling it for priority=LOW.
The other option would be registering callbacks separately for each priority. I don't really see a use case for this, so I followed the original idea.
https://code.launchpad.net/~epics-core/epics-base/parallel-cbthreads-2/+merge/192255
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/parallel-cbthreads-2 into lp:epics-base.
[Merge] lp:~epics-core/epics-base/parallel-cbthreads-2 into lp:epics-base Ralph Lange
Prev: [Merge] lp:~epics-core/epics-base/parallel-cbthreads-2 into lp:epics-base Ralph Lange
Next: [Merge] lp:~epics-core/epics-base/parallel-cbthreads into lp:epics-base Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] lp:~epics-core/epics-base/parallel-cbthreads-2 into lp:epics-base mdavidsaver
